  4. Backitup löscht keine alten Sicherungen
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
backitup
45 Beiträge 4 Kommentatoren 4.7k Aufrufe 4 Beobachtet
    @simatec sagte in Backitup löscht keine alten Sicherungen:
    Hmm eas sagt der Log beim Start von Backitup?
    2020-06-06 11:39:48.706 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2020-06-06 11:39:48.707 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2020-06-06 11:39:48.710 - info: backitup.0 (29386) Got terminate signal TERMINATE_YOURSELF
    2020-06-06 11:39:48.712 - info: backitup.0 (29386) cleaned everything up...
    2020-06-06 11:39:48.713 - info: backitup.0 (29386) terminating
    2020-06-06 11:39:48.715 - info: backitup.0 (29386) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-06-06 11:39:49.245 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156)
    2020-06-06 11:39:51.255 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 27917
    2020-06-06 11:39:58.999 - debug: backitup.0 (27917) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-06-06 11:40:02.999 - warn: backitup.0 (27917) no connection to objects DB
    2020-06-06 11:40:03.919 - debug: backitup.0 (27917) Objects client ready ... initialize now
    2020-06-06 11:40:04.286 - debug: backitup.0 (27917) Objects create System PubSub Client
    2020-06-06 11:40:04.287 - debug: backitup.0 (27917) Objects create User PubSub Client
    2020-06-06 11:40:04.288 - debug: backitup.0 (27917) Objects client initialize lua scripts
    2020-06-06 11:40:09.759 - debug: backitup.0 (27917) Objects connected to redis: 127.0.0.1:9001
    2020-06-06 11:40:09.766 - debug: backitup.0 (27917) objectDB connected
    2020-06-06 11:40:09.769 - debug: backitup.0 (27917) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-06-06 11:40:09.899 - debug: backitup.0 (27917) States create User PubSub Client
    2020-06-06 11:40:09.901 - debug: backitup.0 (27917) States create System PubSub Client
    2020-06-06 11:40:09.920 - debug: backitup.0 (27917) States connected to redis: 127.0.0.1:9000
    2020-06-06 11:40:09.921 - debug: backitup.0 (27917) statesDB connected
    2020-06-06 11:40:12.521 - info: backitup.0 (27917) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
    2020-06-06 11:40:12.628 - info: backitup.0 (27917) [iobroker] backup was activated at 02:00 every 1 day(s)
    Findet Backitup die vorhandenen Backups beim Start?
    Bin auf wiederherstellen - Lokal - Backups suchen gegangen.
    Meckert es erstmal wieder dass ich erst sichern solle.
    Danach geht brav der Button auf grau, aber passiert erst mal nichts.
    Inzwischen ist der Button immer noch grau
    simatecS Offline
    simatecS Offline
    simatec
    @Homoran
    Starte den Adapter einfach mal mit debuglog neu.
    Da sollten alle Backups im Log erscheinen
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      @Homoran
      Habe ich jetzt bereits zigmal gemacht (Instanz neu gestartet)
        simatecS Offline
        simatecS Offline
        simatec
        @Homoran
        Welche Version ist installiert? 1.5.8?
        • simatecS simatec
          @Homoran
          @Homoran
          1.4.5 (actual stable!)
            @Homoran
            simatecS Offline
            simatecS Offline
            simatec
            @Homoran
            OK ... da gab es die Logausgaben noch nicht.
            Ich denke da ist irgendwas schief und ich würde sagen Instanz und Adapter löschen, neustarten und nochmal neu installieren.
            Eventuell direkt die aktuelle Version aus der latest
            • simatecS simatec
              @Homoran
              @simatec
              Gut - ich wollte nur warten ob du noch weitere Infos brauchst, die dir vielleicht helfen würden.
                @simatec
                simatecS Offline
                simatecS Offline
                simatec
                @Homoran
                Nein brauch ich nicht ... glaube das eher Systembedingt, wo eventuell bei der Installation was schief gelaufen ist
                • simatecS simatec
                  @Homoran
                  @simatec
                  irgendwas ist oberfaul.
                  habe den Adapter gelöscht , auf latest gestellt und neu installiert - immer noch 1.4.5
                  refresh bringt weiterhin nur die 1.4.5, egal welchen Pfad zum repo
                  host.raspberrypi	2020-06-06 12:47:30.262	info	Update repository "das_allerletzte" under "http://iobroker.live/repo/sources-dist-latest.json"
                  host.raspberrypi	2020-06-06 12:46:51.061	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                  host.raspberrypi	2020-06-06 12:46:28.313	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                  Ich denke ich mach mal heute abend ne neue Installation
                  Bevor du fragst: reboot des Raspi und neustart von ioB habe ich auch schon mehrfach, genau wie upload
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @Homoran sagte in Backitup löscht keine alten Sicherungen:
                    Ja das scheint es wirklich. Wie ist es bei anderen installierten Adaptern? Will er da auch bei jedem Aufruf der Config, dass du diese speichern sollst?
                    • simatecS simatec
                      nein
                      • simatecS simatec
                        @simatec
                        Habe noch ein wenig rumgespielt:
                        erst über github installiert - 1.5.8 passt
                        Fand aber immer noch keine Backups.
                        backitup.0	2020-06-06 13:22:47.628	debug	(1715) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                        backitup.0	2020-06-06 13:22:45.623	debug	(1715) Backup list be read ...
                        backitup.0	2020-06-06 13:22:31.895	debug	(1715) [iobroker] exec: done
                        backitup.0	2020-06-06 13:22:31.893	debug	(1715) [iobroker] exec: done
                        backitup.0	2020-06-06 13:22:31.891	debug	(1715) [iobroker/history] backitup.0.history.json
                        backitup.0	2020-06-06 13:22:31.887	debug	(1715) [iobroker/history] backitup.0.history.html
                        backitup.0	2020-06-06 13:22:31.865	debug	(1715) [iobroker/clean] done
                        backitup.0	2020-06-06 13:22:31.863	debug	(1715) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                        backitup.0	2020-06-06 13:22:31.858	debug	(1715) [iobroker/historyDB] [IGNORED] No source for compress!
                        backitup.0	2020-06-06 13:22:31.850	debug	(1715) [iobroker/iobroker] done
                        backitup.0	2020-06-06 13:22:30.783	debug	(1715) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_06_06-13_22_09_backupiobroker.tar.gz
                        backitup.0	2020-06-06 13:22:19.799	debug	(1715) [iobroker/iobroker] host.raspberrypi 12915 objects saved
                        backitup.0	2020-06-06 13:22:19.739	debug	(1715) [iobroker/iobroker] host.raspberrypi 14516 states saved
                        backitup.0	2020-06-06 13:22:09.732	debug	(1715) Backup has started ...
                        backitup.0	2020-06-06 13:22:07.709	debug	(1715) No backup file was found
                        backitup.0	2020-06-06 13:22:07.702	debug	(1715) [iobroker] 10 00 02 */1 * *
                        backitup.0	2020-06-06 13:22:07.678	info	(1715) [iobroker] backup was activated at 02:00 every 1 day(s)
                        backitup.0	2020-06-06 13:22:07.610	info	(1715) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                        backitup.0	2020-06-06 13:22:04.887	debug	(1715) statesDB connected
                        backitup.0	2020-06-06 13:22:04.886	debug	(1715) States connected to redis: 127.0.0.1:9000
                        backitup.0	2020-06-06 13:22:04.867	debug	(1715) States create System PubSub Client
                        backitup.0	2020-06-06 13:22:04.865	debug	(1715) States create User PubSub Client
                        backitup.0	2020-06-06 13:22:04.824	debug	(1715) Redis States: Use Redis connection: 127.0.0.1:9000
                        backitup.0	2020-06-06 13:22:04.819	debug	(1715) objectDB connected
                        backitup.0	2020-06-06 13:22:04.808	debug	(1715) Objects connected to redis: 127.0.0.1:9001
                        backitup.0	2020-06-06 13:22:04.730	debug	(1715) Objects client initialize lua scripts
                        backitup.0	2020-06-06 13:22:04.729	debug	(1715) Objects create User PubSub Client
                        backitup.0	2020-06-06 13:22:04.727	debug	(1715) Objects create System PubSub Client
                        backitup.0	2020-06-06 13:22:04.715	debug	(1715) Objects client ready ... initialize now
                        backitup.0	2020-06-06 13:22:04.148	debug	(1715) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        backitup.0	2020-06-06 13:21:58.866	info	(1627) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        backitup.0	2020-06-06 13:21:58.865	info	(1627) terminating
                        backitup.0	2020-06-06 13:21:58.864	info	(1627) cleaned everything up...
                        backitup.0	2020-06-06 13:21:58.863	info	(1627) Got terminate signal TERMINATE_YOURSELF
                        backitup.0	2020-06-06 13:21:55.978	debug	(1627) system.adapter.admin.0: logging false
                        backitup.0	2020-06-06 13:21:13.272	debug	(1627) No backup file was found
                        backitup.0	2020-06-06 13:21:13.255	info	(1627) [iobroker] backup was activated at 02:00 every 1 day(s)
                        backitup.0	2020-06-06 13:21:13.143	info	(1627) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                        backitup.0	2020-06-06 13:21:10.635	debug	(1627) statesDB connected
                        backitup.0	2020-06-06 13:21:10.635	debug	(1627) States connected to redis: 127.0.0.1:9000
                        backitup.0	2020-06-06 13:21:10.616	debug	(1627) States create System PubSub Client
                        backitup.0	2020-06-06 13:21:10.613	debug	(1627) States create User PubSub Client
                        backitup.0	2020-06-06 13:21:10.598	debug	(1627) Redis States: Use Redis connection: 127.0.0.1:9000
                        backitup.0	2020-06-06 13:21:10.595	debug	(1627) objectDB connected
                        backitup.0	2020-06-06 13:21:10.588	debug	(1627) Objects connected to redis: 127.0.0.1:9001
                        backitup.0	2020-06-06 13:21:10.567	debug	(1627) Objects client initialize lua scripts
                        backitup.0	2020-06-06 13:21:10.566	debug	(1627) Objects create User PubSub Client
                        backitup.0	2020-06-06 13:21:10.565	debug	(1627) Objects create System PubSub Client
                        backitup.0	2020-06-06 13:21:10.560	debug	(1627) Objects client ready ... initialize now
                        backitup.0	2020-06-06 13:21:10.518	debug	(1627) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        backitup.0	2020-06-06 13:21:04.784	info	(1359) Got terminate signal TERMINATE_YOURSELF
                        backitup.0	2020-06-06 13:21:04.545	info	(1359) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        backitup.0	2020-06-06 13:21:04.541	info	(1359) terminating
                        backitup.0	2020-06-06 13:21:04.540	info	(1359) cleaned everything up...
                        backitup.0	2020-06-06 13:21:04.539	info	(1359) Got terminate signal TERMINATE_YOURSELF
                        backitup.0	2020-06-06 13:20:44.018	info	(1359) [iobroker] backup was activated at 02:00 every 1 day(s)
                        backitup.0	2020-06-06 13:20:41.604	info	(1359) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                        backitup.0	2020-06-06 13:19:28.242	warn	(1359) no connection to objects DB
                        backitup.0	2020-06-06 13:23:06.017	debug	(1715) system.adapter.admin.0: logging true
                        Dann habe ich mich erst einmal um die Repos gekümmert.
                        Das bekannte Bild: Pfad über Browser ok, im admin kein oder leeres Repo gefunden.
                        Umbennen des Pfads - abspeichern - neu benennen!
                        Voila, zumindest der Pfad nach iobroker.live klappte wieder
                        Dann wieder um die Backups.
                        Habe dann ein Backup manuell erzeugt.
                        Jetzt findet er auch die alten - ist auch oben im log drin
                          @simatec
                          Habe jetzt eine komplett neue Installation aufgesetzt nachdem backitup immer noch weiter gesponnen hatte
                          In allen Backups war kein history drin, obwohl angehakt.
                          Gottseidank hatte ich aus alter Gewohnheit eine neue Karte genommen und konnte die alte nochmal reinstecken un das history-Verzeichnis zu ziehen.
                          Im Moment läuft alles
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            Schaue mal bitte, ob auch der richtige Pfad eingetragen war.
                            Wenn ja, wäre mal interessant, ob es irgendwelche Rechteprobleme für den User iobroker gab und er dadurch die History Daten nicht lesen konnte
                            • simatecS simatec
                              Genau, da lag das Problem.
                              Es lief doch nicht alles :-(
                              hatte auch vorher immer nur auf "Konfiguration ermitteln" geklickt. Dann kam die Meldung ...wurde übernommen.
                              Damit war für mich die Konfiguration durch. Aber es wurde nichts eingetragen
                              Habe jetzt manuell /opt/iobroker/iobroker-data/history eingetragen, jetzt läuft es und die Meldung "bitte erst Konfig sichern" kommt nciht mehr
                              • simatecS simatec
                                wenn ich beim mitlesen der posts von thomas braun alles verstanden haben sollte, wäre das korrekt?
                                pi@raspberrypi:~ $ sudo -u iobroker groups
                                iobroker tty dialout audio video bluetooth gpio i2c
                                müsste da nicht auch sudo bei sein?
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  sieht bei mir auch so aus ...
                                  iobroker tty dialout audio video bluetooth redis gpio i2c
                                  • simatecS simatec
                                    heißt ja gar nichts :duckundwech:
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
