  4. Gelöst: Probleme beim Javascript-Update auf 4.5.1 auf 4.6.17
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
admin adapterjavascript adaptermaster slave
48 Beiträge 6 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • crepp1967C Offline
    crepp1967C Offline
    crepp1967
    pi@raspisuper:~ $ iobroker list instances
      system.adapter.admin.0.0               : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.0.1               : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                 : admin                 - disabled, port: 8081, bind: 192.168.1.154, run as: admin
    Mist !
    • crepp1967C crepp1967
      Mist !
      @crepp1967
      iobroker del admin.0.0
      iobroker del admin.0.1
      iobroker del admin.1
      ioboroker list instances
      Wenn dann kein admin mehr auftaucht
      iobroker add admin
      crepp1967C 1 Antwort Letzte Antwort
        @crepp1967
        iobroker add admin
        crepp1967C Offline
        crepp1967C Offline
        crepp1967
        @Thomas-Braun sagte in Probleme beim Javascript-Update auf 4.5.1 auf 4.6.17:
        ohne sudo kommt das: (die Hilfe ?)
        pi@raspisuper:~ $ iobroker del admin.0.0
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start - starts the js-controller
        iobroker stop - stops the js-controller
        iobroker start <adapter>[.instance] - starts a specified adapter instance
        iobroker stop <adapter>.[instance] - stops a specified adapter instance
        iobroker start all - starts js-controller and all adapters
        iobroker restart - restarts the js-controller
        iobroker restart <adapter>[.instance] - restarts a specified adapter
        iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
            --wait stops the execution until the debugger is attached.
            --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
        iobroker info - shows the host info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter> - installs a specified adapter
        iobroker rebuild <adapter>|self [--install]
        iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
        iobroker del <adapter> - remove adapter from system
        iobroker del <adapter>.<instance> - remove adapter instance
        iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
        iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all - upload all adapter files to make them available for instances
        iobroker upload <adapter> - upload specified adapter files to make them available for instan
          crepp1967C Offline
          crepp1967
          soll ich es mal mit sudo probieren ?
            @crepp1967
            sudo sollte eigentlich nicht erforderlich sein.
            Probier mal ein
            iobroker stop
            iobroker fix
              crepp1967C Offline
              crepp1967
              trotz stop und fix kommt die gleiche Ausgabe beim Befehl:
                @crepp1967
                Dann weiß ich auch nicht weiter.
                @haselchen hat's kaputt gemacht!1!11 ;-)
                  @crepp1967
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @Thomas-Braun
                  Ruhig Brauner
                  Verantwortlich ist immer noch jeder für sich selber.
                  Ich habe zu nichts geraten ,sondern ein Link gepostet und auch zu Bedenken gegeben ob das überhaupt auf das Problem vom TE aufwendbar ist.
                  Ich wäre dir zu Dank verpflichtet ,wenn Du diese unsinnige Aussage löschen würdest.
                  -1
                  • haselchenH haselchen
                    @Thomas-Braun
                    Ruhig Brauner
                    @haselchen War nicht ernst gemeint. Sollte man an dem !111!!1 erkennen.
                      crepp1967C Offline
                      crepp1967
                      nein ist schon klar das jeder für sich selbst verantwortlich ist. Ein Backup ist selbstverständlich vorhanden - es nützt hier bloß nicht viel weil der verdammte admin1 dann immer noch da ist...
                        crepp1967C Offline
                        crepp1967
                        Habe mittlerweile ein Backup vom 4.6. wiederhergestellt und natürlich den Ausgangszustand u. natürlich auch den Ausgangsfehler.
                        Iregndjemand eine Idee wie ich meinen Javascript Adapter updaten kann und vor allen Dingen wie ich die widerspenstige admin.1 Instanz loswerde ?
                        Torsten
                          crepp1967C Offline
                          crepp1967
                          Zusätzlich zum Javascript Adapter steht auch noch ein Update des JS Controllers an:
                            was wäre denn mit iobroker del admin
                            das müsste dochh eigentlich alle Instanzen mit löschen
                            • BluefoxB Offline
                              BluefoxB Offline
                              Man kann auch Objekt löschen:
                              iobroker state del system.adapter.admin.0.0
                              Usw
                              • BluefoxB Bluefox
                                Usw
                                @Bluefox aber dann eher "object del" oder?
                                • apollon77A apollon77
                                  crepp1967C Offline
                                  crepp1967C Offline
                                  crepp1967
                                  @apollon77
                                  Aktuell habe ich ein Backup zurückgespielt und wieder den Ausgangszustand vom Start des Threads:
                                    @apollon77
                                    @crepp1967
                                    iobroker object del system.adapter.admin.1
                                      crepp1967C Offline
                                      crepp1967
                                      Das war der notwendige Befehl, alles OK !
                                      Vielen Dank für Eure Hilfe.
                                      Auch das Javascript Update lief durch.
                                      Bin happy...
                                      Torsten
