  4. Hue wird nicht erkannt.
hue connection verbindung nichnicht erkannthue
79 Beiträge 5 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • R relaxz
    Guten Morgen!
    Es geht immer noch nicht... Dachte wenn man einmal drüber schläft gehts vlt. 😊
    Noch ne Info oder Indiz... wie man es auch nennen möchte...
    Wenn ich App auf dem iPhone öffne kommt immer die Meldung Index.html nicht gefunden... Scheinbar fehlen da die Webdateien, bzw. sind vlt. auch irgendwo falsch abgelegt?!
    @relaxz
    iobroker del discovery
    cd /opt/iobroker
    npm cache clean
    iobroker add discovery
    • R Offline
      relaxz
      #66
      pi@ioBroker-RasPi4:~ $ iobroker del discovery
      Delete adapter "discovery"
      host.ioBroker-RasPi4 Counted 1 instances of discovery
      host.ioBroker-RasPi4 Counted 1 adapter for discovery
      host.ioBroker-RasPi4 Counted 5 states of discovery
      host.ioBroker-RasPi4 Counted 11 states of system.adapter.discovery
      host.ioBroker-RasPi4 object discovery deleted
      host.ioBroker-RasPi4 object discovery.admin deleted
      host.ioBroker-RasPi4 Deleting 18 object(s).
      Error deleting adapter discovery from disk: SyntaxError: /opt/iobroker/node_modules/iobroker.discovery/io-package.json: Unexpected end of JSON input
      You might have to delete it yourself!
      pi@ioBroker-RasPi4:~ $ cd /opt/iobroker
      pi@ioBroker-RasPi4:/opt/iobroker $ npm cache clean
      npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
      npm ERR!
      npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
      npm ERR!     /home/iobroker/.npm/_logs/2020-05-29T09_50_33_408Z-debug.log
      pi@ioBroker-RasPi4:/opt/iobroker $ iobroker add discovery
      host.ioBroker-RasPi4 install adapter discovery
      host.ioBroker-RasPi4 error: reading io-package.json SyntaxError: Unexpected end of JSON input
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      TypeError: Cannot read property 'common' of undefined
          at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:693:25)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:799:29
          at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:83755
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
      • R relaxz
        npm ERR!
                throw e;
        #67
        @relaxz
        sudo rm /opt/iobroker/node_modules/iobroker.discovery/io-package.json
        npm cache clean --force
        • R Offline
          relaxz
          #68
          @Thomas-Braun said in Hue wird nicht erkannt.:
          iobroker del discovery sudo rm /opt/iobroker/node_modules/iobroker.discovery/io-package.json npm cache clean --force iobroker add discovery
          Hey, hatte heut nen harten Tag und komme erst eben wieder online. Die letzte Befehlskette hat dazu geführt das das Webinteface endlich wieder geht. Vielen Dank!!!!!
          Soll ich die letzten Befehle dann doch durchführen oder lassen wir das?
          • R relaxz
            #69
            @relaxz Ich weiß zwar nicht, was genau du meinst, aber wenn es läuft...
            • R Offline
              relaxz
              #70
              Das Webinterface läuft Gottseidank wieder, aber ich bekomm den HomematicIP Adapter nicht mehr zum laufen... Die Token Erstellung ist ausgegraut. Auch ne Neuinstallation hat nichts gebracht. Gibts dafür auch ne Lösung?
              Mein Hauptziel war eigentlich Hue, Homematic und Alexa zusammenzuführen.
              • R Offline
                relaxz
                #71
                Ahja und der Harmony Hub lässt sich auch nicht mehr starten... Gibts da auch einen Zauber? :)
                • R Offline
                  relaxz
                  #72
                  Last but not least. Gibts einen Dreambox, respektive Newigma Adapter? Konnte keinen finden.
                  • R Offline
                    relaxz
                    #73
                    Fehler Homematic
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.520	info	Do not restart adapter system.adapter.hmip.0 because disabled or deleted
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.519	error	instance system.adapter.hmip.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.518	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.518	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.517	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.516	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.515	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.511	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.510	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hmip/main.js:11:49)
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.510	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.509	error	Caught by controller[0]: ^
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.508	error	Caught by controller[0]: class HmIpCloudAccesspointAdapter extends utils.Adapter {
                    host.ioBroker-RasPi4	2020-05-31 14:18:25.500	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hmip/main.js:11
                    Fehler Harmony
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.600	info	Do not restart adapter system.adapter.harmony.0 because disabled or deleted
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.600	error	instance system.adapter.harmony.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.599	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.599	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.599	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.598	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.598	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.597	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:598:5)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.597	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:30:15)
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.596	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.596	error	Caught by controller[0]: ^
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.595	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                    host.ioBroker-RasPi4	2020-05-31 14:17:55.594	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.harmony/harmony.js:30
                    Fehler Shutter:
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.889	info	Do not restart adapter system.adapter.shuttercontrol.0 because disabled or deleted
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.888	error	instance system.adapter.shuttercontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.888	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.887	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.887	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.887	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.886	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.886	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.885	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.shuttercontrol/main.js:2302:5)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.885	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.shuttercontrol/main.js:82:15)
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.884	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.884	error	Caught by controller[0]: ^
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.883	error	Caught by controller[0]: adapter = new utils.Adapter(options);
                    host.ioBroker-RasPi4	2020-05-31 14:17:42.882	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.shuttercontrol/main.js:82
                    • R Offline
                      relaxz
                      #74
                      Hab wohl zuviele Fragen gestellt... Dachte aber Aufgrund der Logs das die vlt. zusammenhängen könnten?!
                      Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                      • R relaxz
                        #75
                        @relaxz
                        Am besten pro Thema einen Thread starten.
                        • R relaxz
                          Meister MopperM Online
                          Meister Mopper
                          #76
                          @relaxz guck mal hier
                          Proxmox und HA ...
                          • R Offline
                            relaxz
                            #77
                            Hier muss ich nochmal nachfragen. HUE wird einfach nicht erkannt.
                            Einen User hab ich mit der folgenden Anleitung erstellt. Aber der Adapter wird einfach nicht grün (IP stimmt)
                            HUE Nutzer (https://www.tutonaut.de/anleitung-hue-api-ansprechen-aka-nutzer-anlegen/)
                            host.ioBroker-RasPi4	2020-06-07 00:28:41.679	info	Restart adapter system.adapter.hue.0 because enabled
                            host.ioBroker-RasPi4	2020-06-07 00:28:41.679	error	instance system.adapter.hue.0 terminated with code 1 ()
                            Caught	2020-06-07 00:28:41.678	error	by controller[0]: }
                            Caught	2020-06-07 00:28:41.678	error	by controller[0]: ]
                            Caught	2020-06-07 00:28:41.678	error	by controller[0]: '/opt/iobroker/node_modules/iobroker.hue/main.js'
                            Caught	2020-06-07 00:28:41.678	error	by controller[0]: '/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/index.js',
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: requireStack: [
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: code: 'MODULE_NOT_FOUND',
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                            Caught	2020-06-07 00:28:41.677	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                            Caught	2020-06-07 00:28:41.676	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                            Caught	2020-06-07 00:28:41.676	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/index.js:29:54)
                            Caught	2020-06-07 00:28:41.676	error	by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                            Caught	2020-06-07 00:28:41.676	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
                            Caught	2020-06-07 00:28:41.676	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                            Caught	2020-06-07 00:28:41.675	error	by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                            Caught	2020-06-07 00:28:41.675	error	by controller[0]: - /opt/iobroker/node_modules/iobroker.hue/main.js
                            Caught	2020-06-07 00:28:41.675	error	by controller[0]: - /opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/index.js
                            Caught	2020-06-07 00:28:41.675	error	by controller[0]: Require stack:
                            Caught	2020-06-07 00:28:41.675	error	by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
                            Caught	2020-06-07 00:28:41.674	error	by controller[0]: ^
                            Caught	2020-06-07 00:28:41.674	error	by controller[0]: throw err;
                            Caught	2020-06-07 00:28:41.673	error	by controller[0]: internal/modules/cjs/loader.js:969
                            host.ioBroker-RasPi4	2020-06-07 00:28:39.688	info	instance system.adapter.hue.0 started with pid 6280
                            • R Offline
                              relaxz
                              #78
                              Will ja nicht nochmal rumpfuschen... 😊
                              • R Offline
                                relaxz
                                #79
                                Läuft jetzt. Ein Update des jscontroller hat geholfen
