  4. IOBroker - Radar2
    5.9k
IOBroker - Radar2
radar2 adapterraspberry
153 Beiträge 23 Kommentatoren 29.8k Aufrufe 26 Beobachtet
  • G Offline
    gammler2003
    bei mir will der Adapter einfach nicht starten. Sämtliche Befehle aus der Readme habe ich ausgeführt und liefen auf meinem RPI auch sauber durch. Der Log (Debug Modus) sagt folgendes:
    radar2.0	2020-06-01 23:55:54.538	info	(17798) debug: Adapter will exit now with code true and method adapter.terminate!
    radar2.0	2020-06-01 23:55:54.159	info	(17798) Terminated (NO_ERROR): Without reason
    radar2.0	2020-06-01 23:55:54.155	info	(17798) terminating
    radar2.0	2020-06-01 23:55:53.670	info	(17798) Will try to scan BT devices: true
    radar2.0	2020-06-01 23:55:53.645	error	(17798) Error: bind EADDRINUSE 0.0.0.0:67 at dgram.js:321:20 at processTicksAndRejections (internal/process/task_queues.js:81:21)
    radar2.0	2020-06-01 23:55:53.644	error	(17798) uncaught exception: bind EADDRINUSE 0.0.0.0:67
    radar2.0	2020-06-01 23:55:53.637	warn	(17798) Adapter will exit in latest 1 sec with code true!
    radar2.0	2020-06-01 23:55:53.628	info	(17798) radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0	2020-06-01 23:55:53.627	info	(17798) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
    radar2.0	2020-06-01 23:55:53.626	info	(17798) use known IP list: [ '1.1.1.1' ]
    radar2.0	2020-06-01 23:55:53.625	info	(17798) use known BT list: [ '01:12:23:34:45:56' ]
    radar2.0	2020-06-01 23:55:53.623	info	(17798) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0	2020-06-01 23:55:53.610	info	(17798) Adapter disconnected and stopped with dostop(true) and callback(false)
    radar2.0	2020-06-01 23:55:53.609	warn	(17798) No to be scanned devices are configured for host phoscon! Will stop Adapter
    radar2.0	2020-06-01 23:55:53.563	info	(17798) radar2 initialization started...
    radar2.0	2020-06-01 23:55:53.456	info	(17798) starting. Version 1.2.5 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.14.0, js-controller: 3.1.4
    Hat jemand eine Idee, was ich falsch mache?
    Vielen Dank an euch!
    frankjokeF 1 Antwort Letzte Antwort
    • frankjokeF frankjoke
      @stefande
      Ok, habe die Zahl auf den State ._nHere gesetzt und ._here gibt wieder das boolean.
      stefande
      @frankjoke
      • G gammler2003
        frankjokeF Offline
        frankjokeF Offline
        frankjoke
        @gammler2003
        Da sind zwei Probleme die ich sehe:
        1. 2020-06-01 23:55:53.609 warn (17798) No to be scanned devices are configured for host phoscon! Will stop Adapter zeigt dass kein Eintrag in der Konfig aktiv ist und nichts gesucht wird! Vielleicht hast alles mit - am Ende?
        2. Error: bind EADDRINUSE 0.0.0.0:67 at dgram.js:321:20 at processTicksAndRejections (internal/process/task_queues.js:81:21) zeigt dass node keine Erlaubnis hat die DHCP-Scan durchzuführen, also der Befehl sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f ``which node``) nicht erfolgreich durchgeführt wurde (bevor der Adapter startet).
        Jedenfalls schau mal wie du die 2 Dinge beheben kannst und kade dir auch Version 1.9.9 von Git!
        Frank,
        NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
        Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
        • G Offline
          gammler2003
          Guten Morgen zusammen,
          nach dem Update auf die 1.9.9 sieht der Log leicht anders aus. Der Adapter springt für eine Sekunde auf grün und dann wieder zurück auf Status rot:
          radar2.0	2020-06-02 07:52:16.148	info	(6254) Terminated (ADAPTER_REQUESTED_TERMINATION): true
          radar2.0	2020-06-02 07:52:16.147	info	(6254) debug: Adapter will exit now with code true and method adapter.terminate!
          radar2.0	2020-06-02 07:52:16.145	info	(6254) Adapter disconnected and stopped with dostop(true) and callback(false)
          radar2.0	2020-06-02 07:52:16.144	warn	(6254) No to be scanned devices are configured for host phoscon! Will stop Adapter
          radar2.0	2020-06-02 07:52:16.141	info	(6254) radar2 initialization started...
          radar2.0	2020-06-02 07:52:15.985	info	(6254) starting. Version 1.9.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.14.0, js-controller: 3.1.4
          Die folgenden Befehle habe ich vor dem Adapterstart ausgeführt (ohne Fehlermeldungen):
          apt-get install -y coreutils libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
          Irgendetwas vergessen oder übersehen? Sind noch weitere Befehle vorab nötig?
            @stefande
            @frankjoke Danke, musste auch Skripte deswegen umbauen :-)
            Übrigens generell trick um einen Wert in einen Boolean schnell umzuwandeln: "wert = !!wert;" ... quasi eine doppelte negation ... das erste ! macht einen Boolean draus je nachdme ob "falsy" oder nicht. Das zweite negiert das wieder.
            @frankjoke könntest DU das ganze "debug log als info" noch bitte als echtes debug machen und das als info lassen was info ist? Musste jetzt Loglevel auf "warn" setzen das das log nicht zugemüllt ist
            • G gammler2003
              SBorgS Offline
              SBorgS Offline
              SBorg
              @gammler2003 sagte in IOBroker - Radar2:
              No to be scanned devices are configured...
              Hast du denn wenigstens ein Device konfiguriert? radar2 hat einfach nichts zu tun und beendet sich... ;)
              LG SBorg ( SBorg auf GitHub)
              G 1 Antwort Letzte Antwort
              • frankjokeF Offline
                frankjokeF Offline
                frankjoke
                Hallo @alle !
                Ok, hab mir den Adapter nochmal vorgenommen und einen bug gefunden und eine Änderung vorgenommen:
                1. Wenn ihr debuglevel auf info habt und das debugflag in der Konfig nicht gesetzt ist schreibt der Adapter nach dem Start und 1. scan nur noch Warmeldungen, Die Info beschreibt den Adapterstart, was er finded und wie die Geräte konfiguriert siund u.s.w... Das werde ich definitiv lassen! Wenn euer Adapter nach der Adapter initialization finished! message noch was schreibt dann habt ihr in der Konfig wahrscheinlich das debug-flag gesetzt... Das ist eigentlich drinnen um auch beim Testen debug ein/auszuschalten ohne den Adapter neu starten zu müssen...
                2. Es hat we angemerkt dass keine unknown BT gelistet werden wenn keine eingetragen sind, das stimmt nicht, es werden nur unknown von noble oder lescan gefunden (also LE Geräte die sich auf den scan melden) und normale BT-Geräte können nicht gefunden werden da die meisten Geräte bei hcitool scan sich nur dann melden wenn sie sichtbar (scannen auf meinem Handy) oder gepairt sind! Deshalb kann ich das nicht brauchen. Du musst es selbst verwenden um natürlich die mac herauszufinden und dann in den Adapter zu schreiben!
                3. Ich habe einen Fehler entdeck dass unter bestimmten Umständen Geräte die nur eine IP mac-Adresse in der konfig hatten (keine IP oder BT-Mac dazu) als invalid gekennzeichnet wurden. Der bug ist jetzt behoben.
                4. Was manche vielleicht freuen wird ist dass ich das neue 'enabled' geändert habe auf Abwesenheitszeit geändert habe die jetzt -1 für den default wert, 0 für disabled item oder 1-30 für Abwesenheit nach so vielen Minuen gestzt werden kann. Damit sind unterschiedliche Away-Zeiten in einer adapter-Instanz machbar!
                Danke für feedback und Test!
                Frank,
                • SBorgS SBorg
                  gammler2003
                  @SBorg in der Tat hatte ich keine Geräte drin. Jetzt habe ich die Instanz nochmal gelöscht und eine neue erzeugt, sodass die Beispiele wieder drin sind.
                  Ergebnis ist der nachfolgende Log bei weiterhin rotem Adapter:
                  radar2.0	2020-06-02 22:51:03.620	info	(25721) debug: ChangeState ack:false of radar2.0.info.connection = false
                  radar2.0	2020-06-02 22:51:03.562	info	(25721) debug: created State radar2.0.info.connection
                  radar2.0	2020-06-02 22:51:03.561	info	(25721) terminating
                  radar2.0	2020-06-02 22:51:03.560	info	(25721) terminating
                  radar2.0	2020-06-02 22:51:03.559	info	(25721) Terminated (NO_ERROR): Without reason
                  radar2.0	2020-06-02 22:51:03.557	info	(25721) terminating
                  radar2.0	2020-06-02 22:51:03.531	info	(25721) Adapter disconnected and stopped with dostop(null) and callback(true)
                  radar2.0	2020-06-02 22:51:03.530	info	(25721) Unload adapter now with null
                  radar2.0	2020-06-02 22:51:03.528	warn	(25721) Uncaught Exception: bind EADDRINUSE 0.0.0.0:67
                  radar2.0	2020-06-02 22:51:03.522	error	at processTicksAndRejections (internal/process/task_queues.js:81:21)
                  radar2.0	2020-06-02 22:51:03.522	error	at dgram.js:321:20
                  radar2.0	2020-06-02 22:51:03.522	error	(25721) Error: bind EADDRINUSE 0.0.0.0:67
                  radar2.0	2020-06-02 22:51:03.521	error	(25721) uncaught exception: bind EADDRINUSE 0.0.0.0:67
                  • G gammler2003
                    @gammler2003 und jetzt scrollst Du hier nach oben und liesst ditte in dem noch so langen Thread :-)
                    Stichwort "setcap"
                    • apollon77A apollon77
                      Stichwort "setcap"
                      gammler2003
                      @apollon77 Hi & danke dir für den Hinweis.
                      Das Ausführen des Befehls
                      führt bei mir zu folgender Meldung:
                      ~ $ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f ``which node``)
                      Failed to set capabilities on file `/home/pi/which' (No such file or directory)
                      The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
                      Ich bin hier leider mit meinem Latein am Ende und lerne gerne von den Profis hier im Forum...
                      • G gammler2003
                        muss das heißen.
                        • G Offline
                          gammler2003
                          #66
                          wird angenommen ohne Fehlermeldung oder weiteren Output - Adapter bleibt rot und der Log identisch.... :(
                          radar2.0	2020-06-02 23:23:42.371	info	(25491) debug: ChangeState ack:false of radar2.0.info.connection = false
                          radar2.0	2020-06-02 23:23:42.313	info	(25491) debug: created State radar2.0.info.connection
                          radar2.0	2020-06-02 23:23:42.312	info	(25491) terminating
                          radar2.0	2020-06-02 23:23:42.311	info	(25491) terminating
                          radar2.0	2020-06-02 23:23:42.308	info	(25491) Terminated (NO_ERROR): Without reason
                          radar2.0	2020-06-02 23:23:42.307	info	(25491) terminating
                          radar2.0	2020-06-02 23:23:42.279	info	(25491) Adapter disconnected and stopped with dostop(null) and callback(true)
                          radar2.0	2020-06-02 23:23:42.278	info	(25491) Unload adapter now with null
                          radar2.0	2020-06-02 23:23:42.276	warn	(25491) Uncaught Exception: bind EADDRINUSE 0.0.0.0:67
                          radar2.0	2020-06-02 23:23:42.271	error	(25491) Error: bind EADDRINUSE 0.0.0.0:67 at dgram.js:321:20 at processTicksAndRejections (internal/process/task_queues.js:81:21)
                          radar2.0	2020-06-02 23:23:42.270	error	(25491) uncaught exception: bind EADDRINUSE 0.0.0.0:67
                          radar2.0	2020-06-02 23:23:42.254	info	(25491) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
                          radar2.0	2020-06-02 23:23:42.253	info	(25491) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
                          radar2.0	2020-06-02 23:23:42.253	info	(25491) debug: use known BT list: [ '01:12:23:34:45:56' ]
                          radar2.0	2020-06-02 23:23:42.251	info	(25491) debug: radar2 set to flag items away if they are not seen for 3 minutes
                          radar2.0	2020-06-02 23:23:41.995	info	(25491) debug: started #3 hciconfig hci0 up
                          radar2.0	2020-06-02 23:23:41.875	info	(25491) debug: started #2 hciconfig hci0 down
                          radar2.0	2020-06-02 23:23:41.865	info	(25491) Will run hcitool-mode and not noble on device [ [Object] ]!
                          radar2.0	2020-06-02 23:23:41.838	info	(25491) debug: started #1 hcitool dev
                          radar2.0	2020-06-02 23:23:41.811	info	(25491) Will use l2Ping for BT scans.
                          radar2.0	2020-06-02 23:23:41.797	info	(25491) radar2 initialization started...
                          radar2.0	2020-06-02 23:23:41.666	info	(25491) starting. Version 1.9.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.14.0, js-controller: 3.1.4
                          • G gammler2003
                            #67
                            @gammler2003
                            Bei diesem Adapter müssen mehrere caps gesetzt werden, wenn ich mich richtig erinnere. Musste du mal nach suchen. Davon abgesehen ist der log nicht identisch.
                              @gammler2003
                              #68
                              @Thomas-Braun wie ich sagte ... steht alles weiter oben in diesem Thread ... oder auf der GitHub Readme des Adapters
                              Thomas BraunT G 2 Antworten Letzte Antwort
                                #69
                                @apollon77 ICH weiß wo das steht...
                                • S stefande
                                  @frankjoke
                                  Zunächst mal Danke für die Entwicklung des Adapters.
                                  @frankjoke sagte in IOBroker - Radar2:
                                  Habe in der letzten Beta das _here durch eine Zahl ersetzt, damit kann man jetzt nur dann auf here schalten wenn z.B _here >1 scans da war!
                                  Wäre es nicht sinnvoller einen zusätzlichen neuen Datenpunkt anzulegen als den _here zu ändern?
                                  Ich hab bisher meine Auswertung über _here gemacht und muss jetzt alles umstellen.
                                  frankjokeF Offline
                                  frankjokeF Offline
                                  frankjoke
                                  #70
                                  @stefande Übrigens, habe gerade beta 1.9.9 durch release 2.0.0 auf git und npm gesetzt. Sollte damit bals im latest auftauchen.
                                  Frank,
                                  S lobomauL 2 Antworten Letzte Antwort
                                    stefande
                                    #71
                                    Ich hab die 2.0.0 jetzt ohne Probleme installieren können, und werde mal im Auge behalten wie sie sich so schlägt.
                                    Danke erstmal.
                                      gammler2003
                                      #72
                                      @apollon77 Hi, ich frage ja nicht nach, um irgendwem auf den Keks zu gehen. Ich würde einfach gerne den Adapter nutzen, packe es aber alleine offensichtlich nicht.
                                      Wie oben beschrieben habe ich die in der Readme beschriebenen Befehle sowie den oben im Thread beschriebenen Zusatz ausgeführt. Lief alles ohne Fehler durch, brachte aber bislang nicht den gewünschten Erfolg.
                                      Wenn du dich auf diesen Abschnitt beziehst...ja, den verstehe ich schlichtweg nicht. Die Datei bekomme ich noch in den edit-modus, aber dann hört es leider bei mir auf.
                                      If first line installs everything but readlink or hcitools cannot be found a path is missing most probably, try to search for the path with sudo find / -name readlink (in my case it was /usr/bin) which was not included in $PATH! Edit then .bashrc and add a line with export PATH=$PATH:/usr/bin!
                                      Vielen Dank für eure Hilfe & Geduld.
                                      Thomas BraunT frankjokeF 2 Antworten Letzte Antwort
                                      • G gammler2003
                                        #73
                                        @gammler2003
                                        Ich denke zwar nicht, dass es am fehlenden PATH liegt, aber schau dir das mal an:
                                        which hcitool readlink && echo $PATH
                                        Sollte ungefähr das bei herauskommen:
                                        /usr/bin/hcitool
                                        /bin/readlink
                                        /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                        Du musst jede dieser 7 Zeilen in dein Terminal kopieren:
                                        sudo apt-get install -y coreutils libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                                          @gammler2003
                                          /usr/bin/hcitool
                                          /bin/readlink
                                          lobomauL Offline
                                          lobomauL Offline
                                          lobomau
                                          #74
                                          @Thomas-Braun sagte in IOBroker - Radar2:
                                          @gammler2003
                                          Und du kannst sie alle auf einmal einfügen. Jedenfalls hat es bei mir immer so funktioniert. Copy & paste geht ratzfatz.
                                          Host: NUC8i3 mit Proxmox:
                                          • Slave: Pi4
