  4. Kein Update von Adapter möglich
    6.7k
adapterupdate
18 Beiträge 4 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • I igloh
    Erst mal nur das Protokoll vom Docker und das sieht auf den ersten Bick fehlerfrei aus.
    Die Webseiten vom Admin oder Vis lassen sich halt nicht öffnet.
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.systeminfo.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.synology.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.fritzdect.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.vis-justgage.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.firetv.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.javascript.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.alexa2.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.tr-064.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.hm-rpc.2" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.ical.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.fritzbox.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.daswetter.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.terminal.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.vis-timeandweather.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.vis.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.web.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.hm-rpc.1" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.hm-rega.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.hm-rpc.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.hue.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.info.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
    2020-05-27 18:49:50
    stdout
    host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
    2020-05-27 18:49:49
    stdout
    2020-05-27 18:49:49
    stdout
    Starting ioBroker...
    2020-05-27 18:49:49
    stdout
    2020-05-27 18:49:49
    stdout
    2020-05-27 18:49:49
    stdout
    -----          Step 5 of 5: ioBroker startup           -----
    2020-05-27 18:49:49
    stdout
    2020-05-27 18:49:44
    stdout
    2020-05-27 18:49:44
    stdout
    For more information take a look at readme.md on Github!
    2020-05-27 18:49:44
    stdout
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    2020-05-27 18:49:44
    stdout
    2020-05-27 18:49:44
    stdout
    2020-05-27 18:49:44
    stdout
    -----      Step 4 of 5: Applying special settings      -----
    2020-05-27 18:49:44
    stdout
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    Done.
    2020-05-27 18:49:40
    stdout
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    Done.
    2020-05-27 18:49:40
    stdout
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    -----   Step 3 of 5: Checking ioBroker installation    -----
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    2020-05-27 18:49:40
    stdout
    Existing installation of ioBroker detected in /opt/iobroker.
    2020-05-27 18:49:39
    stdout
    2020-05-27 18:49:39
    stdout
    2020-05-27 18:49:39
    stdout
    -----   Step 2 of 5: Detecting ioBroker installation   -----
    2020-05-27 18:49:39
    stdout
    2020-05-27 18:49:39
    stdout
    2020-05-27 18:49:39
    stdout
    Done.
    2020-05-27 18:49:39
    stdout
    E: Paket vi kann nicht gefunden werden.
    2020-05-27 18:49:34
    stdout
    The following packages will be installed: vi...
    2020-05-27 18:49:34
    stdout
    Installing additional packages is set by ENV.
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    -----         Step 1 of 5: Preparing container         -----
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    -----               SETUID:    1000                    -----
    2020-05-27 18:49:34
    stdout
    -----               SETGID:    1000                    -----
    2020-05-27 18:49:34
    stdout
    -----               PACKAGES:  vi                      -----
    2020-05-27 18:49:34
    stdout
    -----                       ENV                        -----
    2020-05-27 18:49:34
    stdout
    2020-05-27 18:49:34
    stdout
    -----               npm:       6.14.4                  -----
    2020-05-27 18:49:33
    stdout
    -----               node:      v12.16.3                -----
    2020-05-27 18:49:33
    stdout
    -----               image:     v4.2.0                  -----
    2020-05-27 18:49:33
    stdout
    -----                     Versions                     -----
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    -----               arch:      x86_64                  -----
    2020-05-27 18:49:33
    stdout
    -----                      System                      -----
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    -----              Debugging information               -----
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    -----                Please be patient!                -----
    2020-05-27 18:49:33
    stdout
    -----          Startupscript is now running.           -----
    2020-05-27 18:49:33
    stdout
    -----       Welcome to your ioBroker-container!        -----
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    ---------------     2020-05-27 20:49:33      ---------------
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:49:33
    stdout
    2020-05-27 18:43:03
    stdout
    2020-05-27 18:38:26
    stdout
    GlasfaserG Offline
    GlasfaserG Offline
    @igloh
    Zeige mal
    iobroker status
    iobroker list instances
    • I igloh
      OK, das mit der falschen Node.js Version habe ich grade gefunden und gelöst.
      Das Verzeichnis von v12 ist ein anderes:
      root@buanet-iobroker1:/opt/iobroker# rm /usr/bin/node
      root@buanet-iobroker1:/opt/iobroker# ln -s /usr/local/bin/node /usr/bin/node
      root@buanet-iobroker1:/opt/iobroker# node -v
      v12.16.3
      root@buanet-iobroker1:/opt/iobroker# nodejs -v
      v12.16.3
      Das eigentliche Problem besteht aber weiterhin.
      @igloh Da ist node aber nicht sauber installiert, wenn du da mit symlinks arbeiten musst.
      apt policy nodejs
      which nodejs && which node && which npm
      • I Offline
        I Offline
        igloh
        Danke das hat geholfen!
        Genau die Module die ich vorhin von Hand gestoppt habe, waren immer noch gestoppt.
        Auch Admin und Web.
        Dachte sie kommen zumindest bei einen Neustart wieder mit hoch, das ist aber anscheinend nicht so.
        OK.
        Nun läuft wieder alles, die Node Version stimmt, das ursprüngliche Problem besteht aber leider immer noch.
        Beim Versuch des Updates kommt wieder der genannte Fehler.
        Für heute ist aber erst mal Schluss, schon mal vielen Dank für die lehrreichen Tipps!
        • I igloh
          Auch Admin und Web.
          OK.
          GlasfaserG Offline
          GlasfaserG Offline
          @igloh
          siehe oben von @Thomas-Braun
          • I Offline
            I Offline
            igloh
            Könnte gut sein, da steht wieder die 10er Version...
            root@buanet-iobroker1:/opt/iobroker# apt policy nodejs
            nodejs:
              Installiert:           10.20.1-1nodesource1
              Installationskandidat: 10.20.1-1nodesource1
              Versionstabelle:
             *** 10.20.1-1nodesource1 100
            root@buanet-iobroker1:/opt/iobroker# which nodejs && which node && which npm
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            • I igloh
              nodejs:
                Versionstabelle:
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/local/bin/npm
              @igloh Siehste...
              • I igloh
                nodejs:
                  Versionstabelle:
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                @igloh
                rm /usr/local/bin/node
                rm /usr/local/bin/npm
                curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                apt update
                apt dist-upgrade
                apt install nodejs --reinstall
                Das sollte ein node 12 richtig auf das System spülen.
                • G Offline
                  gifftstaub
                  ich würde es erstmal so machen wie Thomas Braun schon geschrieben hat die node sauber neu zu Installieren.
                  dann nochmals prüfen.
                  node -v
                  nodejs -v
                  und die pfade
                  which node
                  /usr/bin/node
                  which nodejs
                  /usr/bin/nodejs
                  lg
                  • I Offline
                    I Offline
                    igloh
                    Danke, habe node nun richtig installiert:
                    v12.17.0
                    v12.17.0
                    nodejs:
                      Installiert:           12.17.0-1nodesource1
                      Installationskandidat: 12.17.0-1nodesource1
                      Versionstabelle:
                     *** 12.17.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                         10.19.0~dfsg1-1 500
                            500 http://deb.debian.org/debian buster/main amd64 Packages
                            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                    Aber dem eigentlichen Problem hat das leider nicht geholfen.
                    Ich kann weder die 4 Adatper noch den Controller (update self) upgraden.
                    Es kommt weiterhin die Fehlermeldung mit dem "3.12.1","istanbu"
                    code_text$ ./iobroker upgrade socketio
                    Update socketio from @3.0.6 to @3.0.7
                    NPM version: 6.14.4
                    npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                    npm ERR! Unexpected end of JSON input while parsing near '..."^3.12.1","istanbul":'
                    npm ERR! A complete log of this run can be found in:npm ERR!     /opt/iobroker/.npm/_logs/2020-05-28T06_11_16_609Z-debug.log
                    upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                    upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                    upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                    upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                    Adapter "socketio" updated
                    process exited with code 0
                    • I Offline
                      I Offline
                      igloh
                      Problem gelöst!
                      Ein "npm cache clean --force" hat geholfen, danach konnte ich alle Adapter problemlos updaten.
                      Das war ja einfach..... ;-)
                      Was ist noch gemerkt habe ist das zusätzlich zum "iobroker stop" das "pkill io" nicht reicht, die Module laufen trotzdem weiter. Ich habe dann letztendlich rausgefunden das man mit einen "iobroker stop all" wirklich alles stoppen kann. Man muss sie am Ende aber trotzdem wieder mit "iobroker start all" manuell starten, sonst kann man lange warten.
                      Ich kam da noch drauf weil ich den Adapter auf V3 hochziehen wollte.
                      Aber egal wo ist gucke oder was ich mache (z.B. iobroker upgrade self), er sagt das der aktuelle installiert ist.
                      Auch nach der manuellen Installation im o.g. Link wird noch mal die 2.9.9 installiert.
                      Falls mir noch einer sagen kann wie ich den V3 installieren kann wäre ich dankbar.
                      Ansonsten läuft jetzt alles bei mir.
                      Vielen Dank für die tolle Hilfe, ich habe zumindest auch viel dabei gelernt.
