  4. [gelöst] HomeMatic ReGaHSS Update von ver. 0.3.7 auf 1.1.0 funktioniert nicht
    2.5k
    4.4k
6 Beiträge 5 Kommentatoren 1.2k Aufrufe
    Schnutexxl
    Hallo Zusammen,
    wollte heute Morgen ein Update des HM ReGaHSS Adaper von er. 0.3.7 auf 1.1.0 durchführen, leider ohne Erfolg. Bei folgender Meldung bleibt das Update stehen:
    ` > http 200 https://registry.npmjs.org/hoek
    npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
    npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
    npm http GET https://registry.npmjs.org/is-property
    npm http 304 https://registry.npmjs.org/is-property `
    Und folgende LOG Errors erscheinen:
    ` > iobroker 2016-05-14 05:57:56 info exit 25
    iobroker 2016-05-14 05:57:56 error host.ioBroker Cannot install iobroker.hm-rega: 137
    iobroker 2016-05-14 05:57:56 info Killed
    Error: 2016-05-14 05:57:56 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
    Error: 2016-05-14 05:57:56 error at [object Object]._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:243:18)
    Error: 2016-05-14 05:57:56 error at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:296:8)
    Error: 2016-05-14 05:57:56 error at Request.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
    Error: 2016-05-14 05:57:56 error at Request. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:108:10)
    Error: 2016-05-14 05:57:56 error at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:62:13)
    Error: 2016-05-14 05:57:56 error xhr post error
    xhr 2016-05-14 05:57:56 error post error
    Error: 2016-05-14 05:57:56 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:243:18)
    xhr 2016-05-14 05:57:56 error post error `
    Wo liegt hier das Problem? Ist der nodejs auf der falschen Version, wenn ja wie update ich den, oder liegt es an was anderem?
    Danke schonmal.
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      Ja es liegt an deiner nodejs version. Du solltest auf 4.x.x updaten.
      Update: Alte nodejs version deinstallieren und dann die neue Version installieren.
      Einzelne schritte kann ich dir keine nennen, da es davon abhängt worauf ioBroker bei dir läuft.
      Ein Blick in die Installationsanleitung von iobroker auf der iobroker.de hilft sicher da ist die Installation für verschiedene Systeme beschrieben.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • L Offline
        looxer01
        ich habe auch noch 0.10.22, weil es einfach stabil läuft.
        Die Warnungen konnten bisher ignoriert werden. Es gab nie Probleme.
        Kann jemand bestätigen, dass ab jetzt Node 0.10.22 nicht mehr läuft ?
        vG Looxer
        • paul53P Offline
          @looxer01:
          Kann jemand bestätigen, dass ab jetzt Node 0.10.22 nicht mehr läuft ? `
          Auf https://docs.npmjs.com/getting-started/installing-node wird Version > 0.10.32 gefordert.
          • BluefoxB Offline
            BluefoxB Offline
            @looxer01:
            vG Looxer `
            Nein. 0.10.22 sollte gehen.
            Da war ein temporären Fehler. Man sollte mit
            cd /opt/iobroker
            npm install iobroker.hm-rega
            probieren.
              Schnutexxl
              Trotz der Fehlermeldungen wird mir nun der Adapter mit der Version 1.1.0 in iobroker angezeigt. Scheint zu funktionieren. Habe aber keinen neuen Installationsversuch gemacht.
