  4. Update js-controller und node.js
    6.8k
update js-controller node.js
93 Beiträge 10 Kommentatoren 71.2k Aufrufe 10 Beobachtet
    @Smartuser Wooo... Da zieht libvips aber einiges mit...
    cd /opt/iobroker
    npm i libvips
    Smartuser
    @Thomas-Braun sagte in Update js-controller und node.js:
    npm i libvips
    Hmmm ....
    rock64@rock64:/opt/iobroker$ npm i libvips
    > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
      AR(target) Release/obj.target/../node-addon-api/src/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    In file included from ../src/common.cc:23:
    /usr/include/vips/vips8:35:10: fatal error: glib-object.h: No such file or directory
     #include <glib-object.h>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + libvips@0.0.2
    added 1 package in 101.931s
    22 packages are looking for funding
      run `npm fund` for details
    • S Smartuser
      npm i libvips
      Hmmm ....
      gyp ERR! not ok
      + libvips@0.0.2
      @Smartuser
      sudo apt install libglib2.0-dev
      Dann nochmal bauen:
      npm i libvips
        @Smartuser
        Dann nochmal bauen:
        npm i libvips
        Smartuser
        @Smartuser
        Dann nochmal bauen:
        npm i libvips
        Ist schon aktuell :(
        rock64@rock64:/opt/iobroker$ sudo apt install libglib2.0-dev
        Reading package lists... Done
        Building dependency tree
        libglib2.0-dev is already the newest version (2.58.3-2+deb10u2).
        libglib2.0-dev set to manually installed.
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          @Smartuser
          sudo apt install libvips-dev
          [Edit:] Ich sehe gerade, die dürfte zu alt sein.
          apt policy libvips-dev
          Smartuser
          Ich seh grad, dass ich deinen editierten post nicht gesehen habe!
          Soll ich das nochmal ausführen?
          • S Smartuser
            @Smartuser
            Ja, lass mal sehen.
              @Smartuser
              Ja, lass mal sehen.
              Smartuser
              schrieb am zuletzt editiert von Smartuser
              @Smartuser
              Ja, lass mal sehen.
              rock64@rock64:/opt/iobroker$ apt policy libvips-dev
              libvips-dev:
                Installed: 8.7.4-1
                Candidate: 8.7.4-1
                Version table:
               *** 8.7.4-1 500
                      500 http://httpredir.debian.org/debian buster/main arm64 Packages
              • S Smartuser
                @Smartuser
                Ja, lass mal sehen.
                libvips-dev:
                  Installed: 8.7.4-1
                  Candidate: 8.7.4-1
                  Version table:
                 *** 8.7.4-1 500
                @Smartuser
                npm rebuild libvips --build-from-source
                  @Smartuser
                  Smartuser
                  rock64@rock64:/opt/iobroker$ npm rebuild libvips --build-from-source
                  libvips@0.0.2 /opt/iobroker/node_modules/libvips
                  • S Smartuser
                    @Smartuser Ich glaube die Syntax ist falsch.
                    npm rebuild --build-from-source libvips
                      Smartuser
                      Gleiches Ergebnis:
                      rock64@rock64:/opt/iobroker$ npm rebuild --build-from-source libvips
                      • S Smartuser
                        Gleiches Ergebnis:
                        @Smartuser
                        npm i libvips@8.9.1
                          @Smartuser
                          npm i libvips@8.9.1
                          Smartuser
                          @Smartuser
                          npm i libvips@8.9.1
                          rock64@rock64:/opt/iobroker$ npm i libvips@8.9.1
                          npm ERR! code ETARGET
                          npm ERR! notarget No matching version found for libvips@8.9.1.
                          npm ERR! notarget In most cases you or one of your dependencies are requesting
                          npm ERR! notarget a package version that doesn't exist.
                          npm ERR!     /home/iobroker/.npm/_logs/2020-05-09T20_47_31_974Z-debug.log
                          • S Smartuser
                            @Smartuser
                            npm i libvips@8.9.1
                            @Smartuser Komisch. Die Kiste baut oben, aber mit den falschen sourcen. Keine Ahnung wie man den auf latest oder eine Version >= 8.9.1 bringen kann.
                            npm i libvips@latest
                            :-D
                            • Thomas BraunT Online
                              Seltsamerweise baut das bei mir, denn da liegen auch die richtigen Quelltexte.
                              /home/iobroker/.npm/_libvips
                              /home/iobroker/.npm/_libvips/libvips-8.9.0-linux-armv7.tar.gz
                              /home/iobroker/.npm/_libvips/libvips-8.9.1-linux-armv7.tar.gz
                                :-D
                                Smartuser
                                :-D
                                Ich versteh es gleich gar nicht ;) :D
                                rock64@rock64:/opt/iobroker$ npm i libvips@latest
                                gyp ERR! not ok
                                + libvips@0.0.2
                                updated 1 package in 49.631s
                                • S Smartuser
                                  :-D
                                  gyp ERR! not ok
                                  + libvips@0.0.2
                                  @Smartuser
                                  npm i vips
                                    @Smartuser
                                    npm i vips
                                    Smartuser
                                    #66
                                    npm i vips
                                    rock64@rock64:/opt/iobroker$ npm i vips
                                    gyp ERR! not ok
                                    + vips@1.0.0
                                    added 1 package from 1 contributor in 44.674s
                                    • S Smartuser
                                      npm i vips
                                      gyp ERR! not ok
                                      + vips@1.0.0
                                      #67
                                      @Smartuser
                                      npm i canvas
                                        @Smartuser
                                        npm i canvas
                                        Smartuser
                                        #68
                                        npm i canvas
                                        Es lief eine Weile, am Ende dieses Ergebnis:
                                        make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
                                        gyp ERR! not ok
                                        + canvas@2.6.1
                                        updated 1 package in 158.31s
                                        • S Smartuser
                                          npm i canvas
                                          gyp ERR! not ok
                                          + canvas@2.6.1
                                          #69
                                          @Smartuser
                                          Sorry, irgendwas übersehe ich. Ich hab nur keinen Schimmer was.
                                          Muss sich einer anschauen, der in node tiefer drin ist.
                                          Auf meinem Raspberry mit ARMV7l Architektur baut der Kram.
                                          Keine Ahnung, ob das mit deiner AARCH64 zusammenhängt.
