  4. [gelöst] Zigbee: uncaught exception: Timeout
cc2538 + cc2592errorsbl-toolzigbeezigbee adapter
25 Beiträge 4 Kommentatoren 4.3k Aufrufe 6 Beobachtet
    Kueppert
    weiteres Testing: Adapter deinstalliert und neu installiert im Admin. Mal schauen...
    • K Kueppert
      Kueppert
      Schade,
      leider kein Erfolg :(
      @dimaiv @arteck @Asgothian ggf. eine Idee, was ich unternehmen/ausprobieren sollte? Danke euch.
      VG Thorsten
      nut.0	2020-05-04 12:06:37.549	info	(580) All Nut values set
      nut.0	2020-05-04 12:06:37.512	info	(580) Start NUT update
      zigbee.0	2020-05-04 12:06:10.139	info	(20768) Zigbee started
      zigbee.0	2020-05-04 12:06:10.139	info	(20768) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
      zigbee.0	2020-05-04 12:06:10.138	info	(20768) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2020-05-04 12:06:10.137	info	(20768) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
      zigbee.0	2020-05-04 12:06:10.136	info	(20768) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
      zigbee.0	2020-05-04 12:06:10.136	info	(20768) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2020-05-04 12:06:10.135	info	(20768) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.134	info	(20768) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.133	info	(20768) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2020-05-04 12:06:10.124	info	(20768) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
      zigbee.0	2020-05-04 12:06:10.123	info	(20768) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.122	info	(20768) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2020-05-04 12:06:10.122	info	(20768) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.121	info	(20768) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.120	info	(20768) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.119	info	(20768) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.118	info	(20768) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.117	info	(20768) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.116	info	(20768) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.115	info	(20768) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.114	info	(20768) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2020-05-04 12:06:10.113	info	(20768) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2020-05-04 12:06:10.112	info	(20768) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.110	info	(20768) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.109	info	(20768) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      zigbee.0	2020-05-04 12:06:10.097	info	(20768) Currently 24 devices are joined:
      zigbee.0	2020-05-04 12:06:10.074	info	(20768) --> transmitPower : normal
      zigbee.0	2020-05-04 12:06:10.073	info	(20768) Unable to disable LED, unsupported function.
      zigbee.0	2020-05-04 12:06:04.065	info	(20768) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
      zigbee.0	2020-05-04 12:06:02.724	info	(20768) Starting Zigbee...
      zigbee.0	2020-05-04 12:06:02.701	info	(20768) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
      host.ioBroker2	2020-05-04 12:06:00.710	info	instance system.adapter.zigbee.0 started with pid 20768
      host.ioBroker2	2020-05-04 12:05:30.680	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.ioBroker2	2020-05-04 12:05:30.676	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      zigbee.0	2020-05-04 12:05:30.151	info	(13898) Terminated (NO_ERROR): Without reason
      zigbee.0	2020-05-04 12:05:30.150	info	(13898) terminating
      zigbee.0	2020-05-04 12:05:29.648	info	(13898) Zigbee: disabling joining new devices.
      zigbee.0	2020-05-04 12:05:29.647	info	(13898) cleaned everything up...
      zigbee.0	2020-05-04 12:05:29.646	error	(13898) Error: Timeout - 1681 - 3 - 3 - 0 - 1 after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at list
      zigbee.0	2020-05-04 12:05:29.645	error	(13898) uncaught exception: Timeout - 1681 - 3 - 3 - 0 - 1 after 10000ms
      nut.0	2020-05-04 12:01:37.561	info	(580) All Nut values set
      nut.0	2020-05-04 12:01:37.510	info	(580) Start NUT update
      sql.0	2020-05-04 12:00:20.293	info	(746) disabled logging of zigbee.0.00158d000273d4a7.humidity
      sql.0	2020-05-04 12:00:20.291	info	(746) disabled logging of zigbee.0.00158d000273d4a7.temperature
      sql.0	2020-05-04 12:00:20.173	info	(746) disabled logging of zigbee.0.00158d0002720c7a.humidity
      sql.0	2020-05-04 12:00:20.170	info	(746) disabled logging of zigbee.0.00158d0002720c7a.temperature
      zigbee.0	2020-05-04 12:00:19.694	info	(13898) Zigbee started
      zigbee.0	2020-05-04 12:00:19.694	info	(13898) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
      zigbee.0	2020-05-04 12:00:19.693	info	(13898) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2020-05-04 12:00:19.692	info	(13898) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
      zigbee.0	2020-05-04 12:00:19.691	info	(13898) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
      zigbee.0	2020-05-04 12:00:19.690	info	(13898) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2020-05-04 12:00:19.689	info	(13898) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.688	info	(13898) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.687	info	(13898) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2020-05-04 12:00:19.677	info	(13898) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
      zigbee.0	2020-05-04 12:00:19.675	info	(13898) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.675	info	(13898) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2020-05-04 12:00:19.674	info	(13898) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.673	info	(13898) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.672	info	(13898) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.671	info	(13898) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.670	info	(13898) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.669	info	(13898) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.668	info	(13898) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.668	info	(13898) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.667	info	(13898) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2020-05-04 12:00:19.666	info	(13898) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
      zigbee.0	2020-05-04 12:00:19.665	info	(13898) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.663	info	(13898) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.662	info	(13898) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      zigbee.0	2020-05-04 12:00:19.653	info	(13898) Currently 24 devices are joined:
      zigbee.0	2020-05-04 12:00:19.628	info	(13898) --> transmitPower : normal
      zigbee.0	2020-05-04 12:00:19.627	info	(13898) Unable to disable LED, unsupported function.
      host.ioBroker2	2020-05-04 12:00:14.309	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      ical.0	2020-05-04 12:00:13.793	info	(13734) Terminated (NO_ERROR): Without reason
      zigbee.0	2020-05-04 12:00:13.623	info	(13898) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
      zigbee.0	2020-05-04 12:00:12.271	info	(13898) Starting Zigbee...
      zigbee.0	2020-05-04 12:00:12.233	info	(13898) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
      host.ioBroker2	2020-05-04 12:00:09.712	info	instance system.adapter.zigbee.0 started with pid 13898
      • MichMeinM Offline
        MichMeinM Offline
        MichMein
        schrieb am zuletzt editiert von MichMein
        ich hänge mich mal hier mit ran. Ich habe die Tage in meinem Log ebenfalls gesehen das sich der Zigbee Adapter neugestartet hatte, das ganze habe ich jetzt zwei oder drei mal gehabt.
        Hier die Zeilen aus den "Log-Tab":
        zigbee.0 	2020-05-03 14:28:39.489 	error 	at processTimers (internal/timers.js:492:7)
        zigbee.0 	2020-05-03 14:28:39.489 	error 	at listOnTimeout (internal/timers.js:549:17)
        zigbee.0 	2020-05-03 14:28:39.489 	error 	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
        zigbee.0 	2020-05-03 14:28:39.489 	error 	(12788) Error: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
        zigbee.0 	2020-05-03 14:28:39.469 	error 	(12788) uncaught exception: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
        Und hier die Zeilen aus der Log-Datei:
        2020-05-03 14:28:39.469 - error: zigbee.0 (12788) uncaught exception: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
        2020-05-03 14:28:39.489 - error: zigbee.0 (12788) Error: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
        Installierte Adapter-Version: 1.1.1
        Node.js: 12.16.3
        Vielen Dank
        Michael
        EDIT: Grundsätzlich funktioniert alles so wie es soll (das glaube ich zumindestens), bis auf das selbstständige neustarten.
        Gruß Michael
        Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
        • MichMeinM MichMein
          Node.js: 12.16.3
          Vielen Dank
          Michael
          Kueppert
          @MichMein 3mal in 2-3 Tagen geht ja, aber ich hab das alle 5-15 Minuten ^^
          MichMeinM D 2 Antworten Letzte Antwort
          • K Kueppert
            MichMeinM Offline
            MichMeinM Offline
            MichMein
            @Kueppert Das glaube ich wohl 😞 Allerdings habe ich auch zur Zeit nur 5 Geräte angelernt, vielleicht hängt es auch damit zusammen 🙄
            Gruß Michael
            • K Kueppert
              dimaiv
              @Kueppert
              Laut log, startet dein Zigbee Stick sauber, und wird richtig erkannt.
              ! Der Stick funktioniert!
              Dein IoBroker spielt verrückt. Wo der Fehler genau liegt kann ich dir noch nicht sagen.
              ioBroker- NUC8i3 / Proxmox / VM
              Node.js v22.21.0
              NPM v10.9.4
              JS controller 7.1.0
              Admin 7.7.20
              ZigBee Adapter 3.3.1alpha.0
              Zigbee LAN Gateway CC2652P
              Zigbee Firmware 20250321
              • GarfonsoG Offline
                GarfonsoG Offline
                Garfonso
                Da wird irgendeine Timeout exception tief in Herdsman nicht abgefangen (bzw. die Promise-Rejection nicht behandelt). js-controller 3.0 macht das zu fatalen Fehlern und killt damit den Adapter. Könnte auch ein Problem in Herdsman sein.
                Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                MichMeinM 1 Antwort Letzte Antwort
                • GarfonsoG Garfonso
                  MichMeinM Offline
                  MichMeinM Offline
                  MichMein
                  @Garfonso das klingt gut, hilft mir aber leider nicht 😢 Gibt es seitens der Entwickler da ne Chance auf Fehlerbehebung?
                  Ich habe gerade mal geschaut, heute wurde der Adapter drei mal neu gestartet.
                  Gruß Michael
                  GarfonsoG K 2 Antworten Letzte Antwort
                    GarfonsoG Offline
                    GarfonsoG Offline
                    Garfonso
                    @MichMein
                    Das müssen die Entwickler beheben, ja... vielleicht machst du mit dem Log, falls noch nicht geschehen, beim github des zigbee adapters mal ein Issue auf -> dann haben die Entwickler das an zentraler Stelle und werden da auch dran erinnert. :-)
                    Ggf. ist es aber etwas komplexer, weil das Problem sich nicht im zigbee Adapter lösen lässt, sondern nur im Herdsmann, da müsste man dann dort den Fehler beheben, das könnte es etwas verzögern.
                      Kueppert
                      @MichMein ist in GitHub schon adressiert
                        Kueppert
                        Ich habe vom Entwickler die Info, dass im Herdsman das Provblem behoben wurde. Ich habe den Zigbee-Adapter via Git drüber installiert (Version bleibt 1.1.1) und dies hat bei mir den Fehler behoben.
                        Git-Installation für alle betroffenen auf eigene Gefahr. BACKUP vorher nicht vergessen ;)
                        • K Kueppert
                          MichMeinM Offline
                          MichMeinM Offline
                          MichMein
                          @Kueppert oh das klingt gut, werde ich direkt mal probieren und anschliessend berichten.
                          Gruß Michael
                          • MichMeinM Offline
                            MichMeinM Offline
                            MichMein
                            Ich habe den Adapter über Git neuinstalliert und habe folgende Meldungen im Log gefunden, vielleicht kann mir jemand etwas genaueres dazu sagen
                            2020-05-05 13:57:10.695 - info: host.raspberrypi iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
                            2020-05-05 13:57:12.292 - info: host.raspberrypi iobroker install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                            2020-05-05 13:57:12.911 - info: host.raspberrypi iobroker NPM version: 6.14.4
                            2020-05-05 13:57:12.913 - info: host.raspberrypi iobroker npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                            2020-05-05 13:58:07.692 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_TS0201.png img/tuya_TS0201.png image/png
                            2020-05-05 13:58:10.779 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_surface_light_tw.png img/osram_surface_light_tw.png image/png
                            2020-05-05 13:58:13.858 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr_color_gu10.png img/innr_color_gu10.png image/png
                            2020-05-05 13:58:14.493 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_transformer.png img/ikea_transformer.png image/png
                            2020-05-05 13:58:15.627 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_e14_bulb.png img/ikea_e14_bulb.png image/png
                            2020-05-05 13:58:16.232 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1sa.png img/hs1sa.png image/png
                            2020-05-05 13:58:16.850 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gld003z.png img/gld003z.png image/png
                            2020-05-05 13:58:17.441 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
                            2020-05-05 13:58:18.054 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                            2020-05-05 13:58:18.668 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                            2020-05-05 13:58:19.265 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
                            2020-05-05 13:58:19.324 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                            2020-05-05 13:58:19.381 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                            2020-05-05 13:58:19.443 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                            2020-05-05 13:58:19.505 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                            2020-05-05 13:58:19.567 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                            2020-05-05 13:58:19.629 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                            2020-05-05 13:58:19.690 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                            2020-05-05 13:58:19.752 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                            2020-05-05 13:58:19.813 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                            2020-05-05 13:58:19.875 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            2020-05-05 13:58:19.939 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            2020-05-05 13:58:20.000 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            2020-05-05 13:58:20.064 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            2020-05-05 13:58:20.150 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            2020-05-05 13:58:20.259 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            2020-05-05 13:58:20.322 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            2020-05-05 13:58:20.404 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            2020-05-05 13:58:20.466 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            2020-05-05 13:58:20.533 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            2020-05-05 13:58:20.597 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                            2020-05-05 13:58:20.685 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
                            2020-05-05 13:58:20.704 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2020-05-05 13:58:20.706 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2020-05-05 13:58:20.712 - info: zigbee.0 (32715) Got terminate signal TERMINATE_YOURSELF
                            2020-05-05 13:58:20.715 - info: zigbee.0 (32715) cleaned everything up...
                            2020-05-05 13:58:20.718 - info: zigbee.0 (32715) Zigbee: disabling joining new devices.
                            2020-05-05 13:58:20.976 - info: zigbee.0 (32715) terminating
                            2020-05-05 13:58:20.977 - info: zigbee.0 (32715) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2020-05-05 13:58:21.528 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2020-05-05 13:58:21.715 - info: host.raspberrypi iobroker exit 0
                            2020-05-05 13:58:22.082 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                            2020-05-05 13:58:23.870 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15253
                            2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                            2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: throw e;
                            2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: ^
                            2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                            2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                            2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                            2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                            2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                            2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                            2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                            2020-05-05 13:58:24.371 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2020-05-05 13:58:24.372 - info: host.raspberrypi Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                            2020-05-05 13:58:24.372 - info: host.raspberrypi system.adapter.zigbee.0 will be rebuilt
                            2020-05-05 13:58:24.373 - warn: host.raspberrypi adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                            2020-05-05 13:58:24.373 - info: host.raspberrypi iobroker rebuild zigbee
                            2020-05-05 13:58:24.906 - info: host.raspberrypi iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
                            2020-05-05 13:58:25.959 - info: host.raspberrypi iobroker npm-rebuild: Rebuild zigbee done
                            2020-05-05 13:58:26.908 - info: host.raspberrypi iobroker npm-rebuild: exit 0
                            2020-05-05 13:58:26.978 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15445
                            2020-05-05 13:58:27.442 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                            2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: throw e;
                            2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: ^
                            2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                            2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                            2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                            2020-05-05 13:58:27.446 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                            2020-05-05 13:58:27.446 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                            2020-05-05 13:58:27.446 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2020-05-05 13:58:27.446 - info: host.raspberrypi Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                            2020-05-05 13:58:27.447 - info: host.raspberrypi system.adapter.zigbee.0 will be rebuilt
                            2020-05-05 13:58:27.447 - warn: host.raspberrypi adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                            2020-05-05 13:58:27.447 - info: host.raspberrypi iobroker rebuild zigbee --install
                            2020-05-05 13:58:27.604 - warn: readFile will not read this file (simple-api.png) in future versions: simple-api.admin is not an object of type "meta"
                            2020-05-05 13:58:27.625 - warn: readFile will not read this file (socketio.png) in future versions: socketio.admin is not an object of type "meta"
                            2020-05-05 13:58:27.972 - info: host.raspberrypi iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
                            2020-05-05 13:58:58.428 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                            2020-05-05 13:58:58.488 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                            2020-05-05 13:58:58.494 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                            2020-05-05 13:58:58.498 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                            2020-05-05 13:58:58.501 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                            2020-05-05 13:58:58.505 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                            2020-05-05 13:58:58.509 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                            2020-05-05 13:58:58.515 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                            2020-05-05 13:58:58.521 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                            2020-05-05 13:58:58.523 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { ^
                            2020-05-05 13:58:58.525 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                            2020-05-05 13:58:58.528 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../../../nan/nan.h:56, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                            2020-05-05 13:59:01.879 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/serialport.h:6, from ../src/serialport_unix.cpp:2:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                            2020-05-05 13:59:02.221 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2020-05-05 13:59:02.261 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2020-05-05 13:59:03.778 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/poller.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                            2020-05-05 13:59:07.320 - info: host.raspberrypi iobroker npm-rebuild:
                            2020-05-05 13:59:07.321 - info: host.raspberrypi iobroker npm-rebuild: Rebuild zigbee done
                            2020-05-05 13:59:08.339 - info: host.raspberrypi iobroker npm-rebuild: exit 0
                            2020-05-05 13:59:08.426 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 16543
                            2020-05-05 13:59:09.957 - info: zigbee.0 (16543) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
                            2020-05-05 13:59:09.992 - info: zigbee.0 (16543) Starting Zigbee...
                            2020-05-05 13:59:11.410 - info: zigbee.0 (16543) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                            2020-05-05 13:59:11.419 - info: zigbee.0 (16543) --> transmitPower : high
                            2020-05-05 13:59:11.431 - info: zigbee.0 (16543) Currently 5 devices are joined:
                            2020-05-05 13:59:11.440 - info: zigbee.0 (16543) 0x00158d0004659dbd (addr 454): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-05-05 13:59:11.442 - info: zigbee.0 (16543) 0x00158d0004208499 (addr 35479): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                            2020-05-05 13:59:11.445 - info: zigbee.0 (16543) 0x84182600000f0c04 (addr 62092): AB3257001NJ - OSRAM Smart+ plug (Router)
                            2020-05-05 13:59:11.446 - info: zigbee.0 (16543) 0x00158d00042d1b54 (addr 2753): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            2020-05-05 13:59:11.447 - info: zigbee.0 (16543) 0x00158d0004658581 (addr 12099): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            2020-05-05 13:59:11.448 - info: zigbee.0 (16543) Zigbee started
                            Gruß Michael
                              Kueppert
                              @MichMein sagte in [gelöst] CC2538 + CC2592: Error & SBL-Tool:
                              kommt mir bekannt vor ;) Welche JS-Controller-Version hast du drauf?
                              • K Kueppert
                                MichMeinM Offline
                                MichMeinM Offline
                                MichMein
                                @Kueppert
                                Node.js: 12.16.3
                                Gruß Michael
                                  dimaiv
                                  Hi, wollt ihr nicht überlegen das Thema umzubenennen?
                                  Das was ihr hier diskutiert hat nix mit CC2538 und SBL-Tool zu tun.
                                  Danke für das Verständnis.
                                  Node.js v22.21.0
                                  NPM v10.9.4
                                  JS controller 7.1.0
                                  Admin 7.7.20
                                    @Kueppert
                                    Node.js: 12.16.3
                                    Kueppert
                                    @MichMein eigentlich hätte mit JS-Controller 3.0.20 ein automatisches rebuild stattfinden müssen. Wenn kein "rebuild" im Log stand, kannst das einfach selbst manuell machen. WO drauf läuft dein ioBroker? Ich hoffe, Linux ^^
                                    • GarfonsoG Offline
                                      GarfonsoG Offline
                                      Garfonso
                                      Rebuild ist doch im log passiert. Ich sehe da keinen Fehler. Tut denn irgendwas nicht?
                                        Kueppert
                                        schrieb am zuletzt editiert von Kueppert
                                        hier stand quatsch
                                        • K Kueppert
                                          MichMeinM Offline
                                          MichMeinM Offline
                                          MichMein
                                          @Kueppert ja, mein ioBroker läuft auf nem Raspberrypi4 mit 4GB.
                                          @Garfonso das mit dem rebuild hatte ich gesehen, wusste aber nicht genau ob das alles korrekt war.
                                          Ein Problem gab es, einer meiner Xiaomi Multisensoren hat seit gestern Abend nichts mehr gemeldet gehabt. Ich konnte ihn auch nicht mehr zum senden „animieren“ und habe ihn vorhin gelöscht und neu angelernt, mal schauen wie es jetzt so läuft.
                                          Gruß Michael
