Test Adapter vw-connect für VW, ID, Audi, Seat, Skoda
Hier leider auch (Skoda), Auszug aus dem Log:
vw-connect.0 2020-04-30 17:31:00.777 error (1538) 400 vw-connect.0 2020-04-30 17:31:00.776 error (1538) Failing to refresh token. vw-connect.0 2020-04-30 17:31:00.353 debug (1538) refreshToken vw-connect.0 2020-04-30 17:07:25.361 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/dwap/v1/$type/$country/vehicles/$vin/history vw-connect.0 2020-04-30 17:07:25.360 debug (1538) 403 vw-connect.0 2020-04-30 17:07:25.353 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/rs/v1/$type/$country/vehicles/$vin/status vw-connect.0 2020-04-30 17:07:25.352 debug (1538) 502 vw-connect.0 2020-04-30 17:07:25.322 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/cf/v1/$type/$country/vehicles/$vin/position vw-connect.0 2020-04-30 17:07:25.321 debug (1538) 403 vw-connect.0 2020-04-30 17:07:25.287 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/batterycharge/v1/$type/$country/vehicles/$vin/charger vw-connect.0 2020-04-30 17:07:25.287 debug (1538) 403 vw-connect.0 2020-04-30 17:07:25.185 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/departuretimer/v1/$type/$country/vehicles/$vin/timer vw-connect.0 2020-04-30 17:07:25.184 debug (1538) 403 vw-connect.0 2020-04-30 17:07:24.808 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/vsr/v1/$type/$country/vehicles/$vin/status vw-connect.0 2020-04-30 17:07:24.807 debug (1538) 403 vw-connect.0 2020-04-30 17:07:24.796 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/climatisation/v1/$type/$country/vehicles/$vin/climater vw-connect.0 2020-04-30 17:07:24.795 debug (1538) 403 vw-connect.0 2020-04-30 17:07:23.662 debug (1538) {"destinations":[]} vw-connect.0 2020-04-30 17:07:23.416 debug (1538) error while getting https://msg.volkswagen.de/fs-car/bs/tripstatistics/v1/$type/$country/vehicles/$vin/tripdata/$tripType?type=list vw-connect.0 2020-04-30 17:07:23.415 debug (1538) 400 vw-connect.0 2020-04-30 16:43:13.279 debug (1538) {"access_token":"xxxx vw-connect.0 2020-04-30 16:43:13.108 debug (1538) refreshToken vw-connect.0 2020-04-30 16:37:00.846 error (1538) 400 vw-connect.0 2020-04-30 16:37:00.845 error (1538) Failing to refresh token. vw-connect.0 2020-04-30 16:37:00.352 debug (1538) refreshTokenAccess Token habe ich unkenntlich gemacht.
Fehler mit "Failing to refresh token" war weiter oben schon ´mal erwähnt, leider ohne Lösung, die ich nachvollziehen könnte.Viele Grüße,
Andreas -
Hallo
bei mir (node js 12, js-controller@3.0.20) kommt folgende Fehler.
Ich habe bereits das Objekt vw-connect.0 gelöscht - danach werden die Unterobjekte: Fahrzg-Id, info und personal angelegt und personal korrekt gefüllt
Viele Grüße
Markus2020-05-01 16:24:35.200 - info: vw-connect.0 (30760) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20 2020-05-01 16:24:38.884 - error: vw-connect.0 (30760) 406 2020-05-01 16:24:38.887 - error: vw-connect.0 (30760) uncaught exception: undefined 2020-05-01 16:24:38.889 - error: vw-connect.0 (30760) uncaught exception: Cannot read property 'stack' of undefined 2020-05-01 16:24:38.895 - error: vw-connect.0 (30760) TypeError: Cannot read property 'stack' of undefined at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17) at process.emit (events.js:310:20) at processPromiseRejections (internal/process/promises.js:209:33) at processTicksAndRejections (internal/process/task_queues.js:98:32) 2020-05-01 16:24:38.897 - info: vw-connect.0 (30760) cleaned everything up... 2020-05-01 16:24:38.963 - info: vw-connect.0 (30760) terminating 2020-05-01 16:24:38.965 - info: vw-connect.0 (30760) Terminated (NO_ERROR): Without reason -
Hallo
Viele Grüße
Markus2020-05-01 16:24:35.200 - info: vw-connect.0 (30760) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20 2020-05-01 16:24:38.884 - error: vw-connect.0 (30760) 406 2020-05-01 16:24:38.887 - error: vw-connect.0 (30760) uncaught exception: undefined 2020-05-01 16:24:38.889 - error: vw-connect.0 (30760) uncaught exception: Cannot read property 'stack' of undefined 2020-05-01 16:24:38.895 - error: vw-connect.0 (30760) TypeError: Cannot read property 'stack' of undefined at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17) at process.emit (events.js:310:20) at processPromiseRejections (internal/process/promises.js:209:33) at processTicksAndRejections (internal/process/task_queues.js:98:32) 2020-05-01 16:24:38.897 - info: vw-connect.0 (30760) cleaned everything up... 2020-05-01 16:24:38.963 - info: vw-connect.0 (30760) terminating 2020-05-01 16:24:38.965 - info: vw-connect.0 (30760) Terminated (NO_ERROR): Without reason@fritz0815 du kannst versuchen die js controller rversion 3.0.21 via github zu installieren
Andreas -
@tombox :
Ja, es kam dauerhaft. Zwischenzeitlich habe ich aber den Adapter ca. 12h gestoppt.
Gerade nochmals gestartet, Token-Fehler tritt nicht auf (vielleicht hatte VW mich temporär wegen der Anfragen ausgesperrt?).
Wie bei @fritz0815 werden die persönliche Daten und die FIN geladen, aber danach nun folgender Fehler:vw-connect.0 2020-05-02 12:29:32.389 error (1912) 406 vw-connect.0 2020-05-02 12:29:32.320 error (1912) 403 vw-connect.0 2020-05-02 12:29:30.814 debug (1912) {"userVehicles":{"vehicle":["xxxx"]}} vw-connect.0 2020-05-02 12:29:29.910 debug (1912) {"firstName":"Andreas","lastName":"Kxxxx","salutation":"SALUTATION:MR","dateOfBirth":"19xx-xx-xx","nickname":"Andreas","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdent vw-connect.0 2020-05-02 12:29:29.686 debug (1912) getData vw-connect.0 2020-05-02 12:29:29.682 debug (1912) Login successful vw-connect.0 2020-05-02 12:29:29.146 debug (1912) Error: Invalid protocol: skodaconnect: vw-connect.0 2020-05-02 12:29:28.259 debug (1912) {"date":"Sat, 02 May 2020 10:29:28 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locatio vw-connect.0 2020-05-02 12:29:28.259 debug (1912) "" vw-connect.0 2020-05-02 12:29:27.782 debug (1912) parsePasswordForm vw-connect.0 2020-05-02 12:29:26.789 debug (1912) parseEmailForm vw-connect.0 2020-05-02 12:29:24.524 info (1912) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.19.0JS controller: 2.2.9
Viele Grüße,
Andreas -
@tombox :
Viele Grüße,
Andreas -
@tombox
Alles klar.
Ja, es wurden keine weiteren Daten geladen (nur die VIN und persönlichen).
Inzwischen kommen allerdings wieder nur die Meldungenvw-connect.0 2020-05-02 14:39:07.018 error (1941) 400 vw-connect.0 2020-05-02 14:39:07.017 error (1941) Failing to refresh token.und es findet keinerlei Aktualisierung statt.
Viele Grüße,
Andreas -
@tombox
Alles klar.
Viele Grüße,
Andreas -
@tombox sagte in Test Adapter VW Connect v0.0.x:
ich werde berichten
bei mir geht der Adapter nach dem Update auf die JS-Controller Version 3.0.21 (installiert via Github) nach Wechsel auf Grün direkt wieder auf Rot. Die Skoda-App funktioniert.
Ich habe das Objekt vw-connect.0 gelöscht sowie die Instanz des Adapters neu angelegt, das hat leider nichts gebracht.
Wäre für Tipps dankbar.
Gruß,
Danielhost.ioBroker-RasPi4 2020-05-05 19:41:07.842 info instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR) vw-connect.0 2020-05-05 19:41:06.415 error (2195) unhandled promise rejection: undefined vw-connect.0 2020-05-05 19:41:06.414 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). vw-connect.0 2020-05-05 19:41:06.413 error (2195) 429 vw-connect.0 2020-05-05 19:41:06.359 info (2195) Terminated (NO_ERROR): Without reason vw-connect.0 2020-05-05 19:41:06.358 info (2195) terminating vw-connect.0 2020-05-05 19:41:05.962 info (2195) cleaned everything up... vw-connect.0 2020-05-05 19:41:05.961 error (2195) unhandled promise rejection: undefined vw-connect.0 2020-05-05 19:41:05.961 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). vw-connect.0 2020-05-05 19:41:05.959 error (2195) 406 vw-connect.0 2020-05-05 19:41:05.703 debug (2195) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXX"]}} vw-connect.0 2020-05-05 19:41:05.444 debug (2195) {"firstName":"XXXXX","lastName":"XXXXX","salutation":"SALUTATION:MR","dateOfBirth":"XXXX-XX-XX","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"XXXXX","businessIdentifierTyp vw-connect.0 2020-05-05 19:41:05.201 debug (2195) getData vw-connect.0 2020-05-05 19:41:05.200 debug (2195) Login successful vw-connect.0 2020-05-05 19:41:04.687 debug (2195) Error: Invalid protocol: skodaconnect: vw-connect.0 2020-05-05 19:41:03.896 debug (2195) {"date":"Tue, 05 May 2020 17:41:03 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locatio vw-connect.0 2020-05-05 19:41:03.894 debug (2195) "" vw-connect.0 2020-05-05 19:41:03.490 debug (2195) parsePasswordForm vw-connect.0 2020-05-05 19:41:02.961 debug (2195) parseEmailForm vw-connect.0 2020-05-05 19:41:01.925 info (2195) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.21 -
habe das Problem auch. Habe den Adapter extra deinstalliert. dann neu installiert. Daten eingetragen (vorher im Web kontrolliert, ob ich mich verbinden kann). Adapter aktiviert, kurz gelb, dann grün und sofort wieder auf rot. Hatte dazu ein Issue erstellt. Heute die Nachricht bekommen, ich soll Adapter von Github installieren oder den js-conroller 3.0.21. Habe bisher nur den 3.0.20 installiert. Aber laut @Ultor bringt das ja auch keine Punkte. Naja, teste ich dann von zeit zu zeit wieder. -
immer noch das gleiche Verhalten. Hier mal das Log:host.iobrokerprod 2020-05-09 18:15:24.221 info "system.adapter.vw-connect.0" disabled host.iobrokerprod 2020-05-09 18:15:23.574 info Restart adapter system.adapter.vw-connect.0 because enabled host.iobrokerprod 2020-05-09 18:15:23.574 info instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR) vw-connect.0 2020-05-09 18:15:23.548 error (22894) [object Object] vw-connect.0 2020-05-09 18:15:23.548 error (22894) 400 vw-connect.0 2020-05-09 18:15:23.055 info (22894) Terminated (NO_ERROR): Without reason vw-connect.0 2020-05-09 18:15:23.055 info (22894) terminating vw-connect.0 2020-05-09 18:15:23.052 info (22894) cleaned everything up... vw-connect.0 2020-05-09 18:15:23.051 error at processTicksAndRejections (internal/process/task_queues.js:98:32) vw-connect.0 2020-05-09 18:15:23.051 error at processPromiseRejections (internal/process/promises.js:209:33) vw-connect.0 2020-05-09 18:15:23.051 error at process.emit (events.js:310:20) vw-connect.0 2020-05-09 18:15:23.051 error at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17) vw-connect.0 2020-05-09 18:15:23.051 error (22894) TypeError: Cannot read property 'stack' of undefined vw-connect.0 2020-05-09 18:15:23.050 error (22894) uncaught exception: Cannot read property 'stack' of undefined vw-connect.0 2020-05-09 18:15:23.050 error (22894) uncaught exception: undefined vw-connect.0 2020-05-09 18:15:23.049 error (22894) 406 vw-connect.0 2020-05-09 18:15:20.054 info (22894) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20 host.iobrokerprod 2020-05-09 18:15:18.958 info instance system.adapter.vw-connect.0 started with pid 22894 host.iobrokerprod 2020-05-09 18:15:18.933 info "system.adapter.vw-connect.0" enabledSchicke Dir mal die Zugangsdaten per Chat.
Hallo, @tombox,
bei mir bleibt der Adapter in der neuen Version (js-controller 3.1.2) ebenfalls grün. Leider bekomme ich jetzt eine neue Fehlermeldung (Invalid Trip Type). Das Loggen der Fahrdaten habe ich im Adapter ausgeschaltet.
Außerdem scheint die Funktion "Position in Adresse umwandeln" nicht mehr zu funktionieren, die entsprechenden Datenpunkte werden hier nicht mehr eingerichtet.
EDIT: Adress-Daten werden doch noch aufgebaut und alle anderen Daten aktualisiert, daher wohl kein großes Problem.
Gruß, Daniel
vw-connect.0 2020-05-10 16:20:02.276 error (21405) {"error":{"errorCode":"gw.error.parameter","description":"Invalid Trip Type"}} -
Hallo, @tombox,
Gruß, Daniel
