Adapter: Geofency
Beim Hinzufügen eines zweiten Gerätes:
raspberrypi 2016-03-07 00:43:19 error instance system.adapter.geofency.0 terminated with code 6 (uncaught exception) geofency-0 2016-03-07 00:43:19 info terminating http server on port 8000 TypeError: 2016-03-07 00:43:19 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) TypeError: 2016-03-07 00:43:19 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) TypeError: 2016-03-07 00:43:19 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-03-07 00:43:19 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8) TypeError: 2016-03-07 00:43:19 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 2016-03-07 00:43:19 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-03-07 00:43:19 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12) TypeError: 2016-03-07 00:43:19 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9) TypeError: 2016-03-07 00:43:19 error at Socket. (/opt/iobroker/node_modules/iobroker.geofency/geofency.js:186:26) TypeError: 2016-03-07 00:43:19 error at setStates (/opt/iobroker/node_modules/iobroker.geofency/geofency.js:140:12) TypeError: 2016-03-07 00:43:19 error Cannot read property 'entry' of undefined uncaught 2016-03-07 00:43:18 error exception: Cannot read property 'entry' of undefined geofency-0 2016-03-07 00:43:18 info adapter geofency received webhook from device ipadwh with values: name: Home, entry: 0 -
Umgehungslösung:
atHomeCount mit "0"
und
atHome mit "[]"
befüllen. Danach läuft es. `
Super analyse! Danke!
Kannst Du ein Pull-Request (heisst das so?) auf Github machen?
Was wäre der beste Weg?in der io-package.json bei beiden Datenpunkten "def": anpassen?
Hallo zusammen!
Ich oute mich mal als ioBroker Anfänger.
Aktuell habe ich 2 Fragen zu dem Geofency Adapter:
- Was muss ich einstellen, damit https funktioniert?
Nach dem einfachen aktivieren erhalte ich nur diese Meldung im Log:
Error Cannot enable secure web server, because no certificates found: undefined, undefined
- Und ich verstehe nicht, warum es empfohlen ist, einen Reverse-Proxy vor den Dienst zu setzen?
Ob nun die FritzBox weiterleitet oder noch Proxy dazwischen ist, kommt doch auf´s selbe raus, oder?
Kennwort kann doch auch im Adapter aktiviert werden.
Ich danke euch im Voraus!
Rene
Danke für deine Antwort.
Ich habe jetzt mal Zertifikate hinzugefügt (zusätzlich zu den Standard-Zertifikaten).
Der Fehler tritt weiterhin auf.
Ich vermute, ich kenne die Stelle nicht, an der man die zu verwendenden Zertifikate definiert.
Die Fehlermeldung sagt ja undefined. Aber in den Parametern und in der Doku finde ich nix.
Beste Grüße
René
irgendwie ist das nicht vollständig implementiert. Wahrscheinlich fehlen in deiner Adapter.Config die Namen der zu verwendenden Zertifikate.
Öffne einmal im ioBroker-Admin den "Objecte" Tap, aktiviere oben in der Toolbar "Zeige Systemobjecte" und suche den Eintrag "system.adapter.geofency".
In der gefundenen Zeile dann ganz rechts auf das Zahnrad klicken. Unter dem Tap "Raw" das "native" Object betrachten.
Für die Zertifikate sind die beiden Einträge "certPrivate" und "certPublic" wie hier unten notwendig. Die Konfiguration dieser Werte wurde wahrscheinlich vergessen.
... "native": { "port": 7999, "ssl": false, "user": "user", "pass": "password", "atHome": "Home", "certPrivate": "defaultPrivate", "certPublic": "defaultPublic", "usessl": false, "devices": "iPhone-xy" }, ...Vor Anpassung dieses Objects den Geofency Adapter einmal beenden und nach erfolgter Änderung wieder starten.
Viele Grüße.
ich habe mal eine Frage zu diesem Adapter. Ich bin noch relativ neu im HM-Bereich und es kann sein das ich hier voll auf dem Holzweg bin. :?
Ich habe eine CCU2, ein dutzend Aktoren, einen Raspberry 2 mit ioBroker und dem Geofency Adapter sowie den hm-rega und hm-rcp Adaptern.
Das Ändern der Geofency Status für unsere beiden iPhones funktioniert in ioBroker auch wunderbar. Jetzt kommt aber mein Knackpunkt:
Wie bekomme ich diese beiden States in die CCU oder wie kann ich da mit den States als Variable arbeiten?
Grüße Markus
willkommen hier im Forum.
Du kannst den HM-REGA Adapter nutzen, um die States aus dem Geofency Adapter in eine Homematic Variable zu schreiben.
Variable in Homematic anlegen
rega-Adapter neu synchronisieren bzw neu starten
mini javascript anlegen:````
on("geofency.0.NAME.Zu_Hause.entry"/entry/, hm-rega.0.NUMMERDERCCUVARIABLE); // für jede Variable diese zeile kopieren und anpassen -
fertig; bei Änderung des Geofency Status, wird der gleiche Wert in die CCU Variable geschrieben.
Pix
PS: Bitt in Zukunft für eine neue Frage einfach einen neuen Thread mit passendem Titel (zB "Frage: geofency Status in CCU übertragen") aufmachen, danke.
ich wollte mich hier nochmal melden, da die Variablen entry und leave leider bisher noch gleichzeitig geändert werden. Dazu gibt es auch schon einen Eintrag im GIT. Da ich die Funktion bisher eigentlich immer genutzt habe, würde ich gerne wissen ob ich die Möglichkeit habe wieder zu einer "älteren" Version des Adapters zurück zu kehren, in dem es noch funktioniert hat.
Wenn ja wie?
Oder ist da schon jemand dran das Problem zu lösen? Oder kann ich bei der Lösung in Form von Tests behilflich sein?
Adapter programmieren kann ich leider nicht.
Danke Gruß Sven
wollte da mal gerade reinschauen.
Also der "entry"-Datenpunkt wird immer bei einer Änderung aktualisiert und hat den Wert 0 oder 1 je nachdem ob Anwesend oder nicht.
Zusätzlich wird lastEntry und lastLeave gesetzt je nachdem wie sich entry ändert (entry auf 0, dann "lastLeave" und entry auf 1 dann "lastEnter").
Was ist daran falsch bzw. soll anders sein?
Er meint das hier
Ich bin gerade nicht daheim und das Objekt LastLeave ist nicht gefüllt
filename="Bildschirmfoto%202016-12-02%20um%2010.24.52.png" index="0">~~
Das hat bis 1.Oktober funktioniert, aber das habe ich auch schon auf Github erwähnt Denn das Objekt wurde da auf meinen anderen Raps zum letzten Mal gefüllt
Und was mir jetzt aufgefallen ist, ist das das LastEnter die Zeit hat wo ich zuhause weggefahren bin :)
Hallo Apollon,
Ich sitze grade nicht davor, aber ich schaue nachher gerne nochmal nach.
Aus dem Kopf meine ich ist so, das sich der Punkt lastLeave nicht mehr ändert. Dafür aber der Punkt lastEnter sowohl bei an als auch bei Abwesenheit ändert. (Oder genau umgekehrt)
Gebe nachher nochmal genau Bescheid.
Gruß Sven
v0.1.6 steht auf Github zur Verfügung. Bitte testen ob es das Problem behebt `
Also habe den Adapter installiert und was soll ich sagen….. ES FUNKTIONIERT WIEDER!!!! Toll :D
Adrian
