  4. [gelöst] Ping-Adapter pingt nicht mehr
    6.3k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
ping-adapter
27 Beiträge 4 Kommentatoren 4.9k Aufrufe 3 Beobachtet
    @Meister-Mopper Sorry, mein Fehler
    root@iobroker:~# adduser thomas sudo
    Adding user `thomas' to group `sudo' ...
    Adding user thomas to group sudo
    Done.
    @Meister-Mopper
    Ich bin nicht ganz sicher ob das funktioniert, aber versuch mal dem User die default Gruppen noch mitzugeben:
    sudo useradd -D thomas
      @Meister-Mopper
      Meister MopperM Online
      Meister Mopper
      @Thomas-Braun Da kommen nur die ganzen Schaltererläuterungen:
      $ sudo useradd -D thomas
      Usage: useradd [options] LOGIN
            useradd -D
            useradd -D [options]
      Options:
       -b, --base-dir BASE_DIR       base directory for the home directory of the
                                     new account
       -c, --comment COMMENT         GECOS field of the new account
       -d, --home-dir HOME_DIR       home directory of the new account
       -D, --defaults                print or change default useradd configuration
       -e, --expiredate EXPIRE_DATE  expiration date of the new account
       -f, --inactive INACTIVE       password inactivity period of the new account
       -g, --gid GROUP               name or ID of the primary group of the new
                                     account
       -G, --groups GROUPS           list of supplementary groups of the new
                                     account
       -h, --help                    display this help message and exit
       -k, --skel SKEL_DIR           use this alternative skeleton directory
       -K, --key KEY=VALUE           override /etc/login.defs defaults
       -l, --no-log-init             do not add the user to the lastlog and
                                     faillog databases
       -m, --create-home             create the user's home directory
       -M, --no-create-home          do not create the user's home directory
       -N, --no-user-group           do not create a group with the same name as
                                     the user
       -o, --non-unique              allow to create users with duplicate
                                     (non-unique) UID
       -p, --password PASSWORD       encrypted password of the new account
       -r, --system                  create a system account
       -R, --root CHROOT_DIR         directory to chroot into
       -s, --shell SHELL             login shell of the new account
       -u, --uid UID                 user ID of the new account
       -U, --user-group              create a group with the same name as the user
       -Z, --selinux-user SEUSER     use a specific SEUSER for the SELinux user mapping
      Proxmox und HA ...
              useradd -D
        Options:
                                       new account
                                       account
                                       account
                                       faillog databases
                                       the user
                                       (non-unique) UID
        @Meister-Mopper
        sudo adduser thomas
          @Meister-Mopper
          sudo adduser thomas
          Meister Mopper
          @Thomas-Braun sagte in Ping-Adapter pingt nicht mehr:
          sudo adduser thomas
          $ sudo adduser thomas
          adduser: The user `thomas' already exists.
          Das hat er aber weiter oben schon ausgeworfen. Mit sudo kann ich jetzt pingen, aber offenbar der iobroker nicht.
          Proxmox und HA ...
            sudo adduser thomas
            @Meister-Mopper
            Die 'iobroker' ist vermutlich genauso gruppenlos wie 'thomas'.
            sudo -u iobroker groups
              @Meister-Mopper
              Meister Mopper
              $ sudo -u iobroker groups
              iobroker tty dialout audio video
              Proxmox und HA ...
                @Meister-Mopper
                Hmmm. Eigentlich sollte 'dialout' richtig sein.
                Keine Ahnung dann...
                  @Meister-Mopper
                  Meister Mopper
                  @Thomas-Braun habe das bei vmware gefunden und es hat funktioniert:
                  Als root ausführen:
                  chmod 4755 /bin/ping
                  [gpadmin@hdm4] ping -c 1 admin.pivotal.com
                  ping: icmp open socket: Operation not permitted
                  You may see such an error if setuid bit (s) is not set on /bin/ping command.
                  Verify using:
                  [INCORRECT]
                  ls -al /bin/ping
                  -rwxr-xr-x 1 root root 40760 May 20 2011 /bin/ping
                  [CORRECT]
                  [root@pccadmin ~]# chmod 4755 /bin/ping
                  [root@pccadmin ~]# ls -tlr /bin/ping
                  -rwsr-xr-x. 1 root root 40760 Jul 18 2011 /bin/ping
                  where: s instead of x in the owner permissions means that the setuid is enabled, so this file will be executed with root permissions by all users.
                  Proxmox und HA ...
                  Thomas BraunT Axel KoenekeA Rainer.KR 3 Antworten Letzte Antwort
                    Als root ausführen:
                    Verify using:
                    [INCORRECT]
                    ls -al /bin/ping
                    [CORRECT]
                    @Meister-Mopper
                    Jetzt hat ping das setuid bit. Da hatte ich eben auch mal dran gedacht, das zu setzen. Nagut, wenn es nun geht...
                    Aber auch das sollst du nicht als root setzen, sondern mit
                    sudo
                    vor dem Befehl...
                      @Meister-Mopper
                      sudo
                      vor dem Befehl...
                      Meister Mopper
                      @Thomas-Braun Alles klar, ich danke Dir für den guten Rat.
                      Proxmox und HA ...
                        @Meister-Mopper
                        root login ist Tabu!
                        • Meister MopperM Online
                          Meister Mopper
                          schrieb am zuletzt editiert von Meister Mopper
                          Sollte man denn root generell löschen, und wie kommt man dann an die root-Rechte, wenn sie mal nötig sind? Sorry, ich blicke da noch nicht durch.
                          Proxmox und HA ...
                            @Meister-Mopper
                            Es gibt Distributionen, die haben keinen (aktiven) root. Man kann den unter debian auch ausknipsen. Würde ich aber nicht machen.
                            Entsprechende Rechte bekommst du, wenn halt 'sudo' vor den Befehl gesetzt wird. In ganz außergewöhnlichen Fällen kann man auch per
                            sudo su
                            wieder 'root' werden. Aber das darf nur an besonders hohen Feiertagen der Fall sein.
                              @Meister-Mopper
                              sudo su
                              Meister Mopper
                              @Thomas-Braun @Meister-Mopper Wahrscheinlich - nach all den Informationen - sollte man nach der abschließenden Konfiguration "sudo su" den root-user löschen, oder?
                              Proxmox und HA ...
                                @Meister-Mopper
                                Ich würde es nicht machen. Entfernt dein System nur weiter vom 'Standard' und macht ggf. das Helfen bei Problemen schwieriger.
                                Hab oben auch einen Fehler im Befehl. Richtig muss es
                                sudo su -
                                heißen. Das - ist wichtig! Setzt die Rechte bzw. das Environment in der shell. Aber da du ja eh nicht mehr root werden musst kannste das auch wieder vergessen.
                                  Als root ausführen:
                                  Verify using:
                                  [INCORRECT]
                                  ls -al /bin/ping
                                  [CORRECT]
                                  Axel KoenekeA Offline
                                  Axel Koeneke
                                  @meister-mopper sagte in [gelöst] Ping-Adapter pingt nicht mehr:
                                  Danke für den Tip!
                                  Ich hatte genau das gleiche Problem nach einer neuen, sauberen LCX Installation.
                                  Axel
                                    Als root ausführen:
                                    Verify using:
                                    [INCORRECT]
                                    ls -al /bin/ping
                                    [CORRECT]
                                    Rainer.KR Offline
                                    Rainer.KR Offline
                                    Rainer.K
                                    schrieb am zuletzt editiert von Rainer.K
                                    @meister-mopper Auch von mir vielen Dank! Ich bin schon verzweifelt, da die Instanzen Ping und Lupusec partout nicht funktionieren wollten. Der Fehler ist bei dem Neuaufbau von IoBroker mit einem neu angelegten LCX-Container (Ubuntu 20.0.4) aufgetreten.
