  4. zigbee: nach update von nodejs startet adapter nicht mehr
zigbee adapternodejs 12node8
71 Beiträge 5 Kommentatoren 7.3k Aufrufe 3 Beobachtet
    ls -la /usr/local/bin/npm
    tom_33
    @Thomas-Braun
    code tags kannte ich noch nicht...
    pi@ioBroker-RasPi:/opt/iobroker $ ls -la /usr/bin/npm
    lrwxrwxrwx 1 root root 38 Apr  8 22:27 /usr/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js
    pi@ioBroker-RasPi:/opt/iobroker $ npm uninstall -g npm
    npm WARN npm npm does not support Node.js v12.16.2
    npm WARN npm You should probably upgrade to a newer version of node as we
    npm WARN npm can't make any promises that npm will work with this version.
    npm WARN npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11.
    npm WARN npm You can find the latest version at https://nodejs.org/
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/co
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-deep-equal
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/invert-kv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema-traverse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ajv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lcid
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mem/node_modules/mimic-fn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nice-try
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-defer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/map-age-cleaner
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-is-promise
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-try
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-limit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-locate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/locate-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-up
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc/node_modules/minimist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-locale/node_modules/cross-spawn
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-locale/node_modules/execa
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/y18n
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
    npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
    npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
    npm ERR!   stack: "Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'",
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/iobroker/.npm/_logs/2020-04-25T21_27_29_359Z-debug.log
    pi@ioBroker-RasPi:/opt/iobroker $ npm -v
    6.4.1
    pi@ioBroker-RasPi:/opt/iobroker $ sudo npm uninstall -g npm
    removed 435 packages in 27.413s
    6.4.1
    pi@ioBroker-RasPi:/opt/iobroker $ ls -la /usr/local/bin/npm
    lrwxrwxrwx 1 root staff 38 Okt 25  2019 /usr/local/bin/npm -> ../lib/node_modules/npm/bin/npm-cli.js
    • T tom_33
      @Thomas-Braun
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      6.4.1
      6.4.1
      @tom_33
      Dann versuchen wir die Holzhammermethode:
      sudo rm -rf /usr/local/bin/npm
      Und dann nochmal mit
      which npm
      schauen ob die Version aus /usr/bin genutzt wird
        @tom_33
        which npm
        tom_33
        @Thomas-Braun
        pi@ioBroker-RasPi:/opt/iobroker $ sudo rm -rf /usr/local/bin/npm
        Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
        Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
            #1) Respektieren Sie die Privatsphäre anderer.
            #2) Denken Sie nach, bevor Sie tippen.
            #3) Mit großer Macht kommt große Verantwortung.
        [sudo] Passwort für pi:
        pi@ioBroker-RasPi:/opt/iobroker $ which npm
        ich bemüh mich eh die 3 regeln einzuhalten ;-)
        • T tom_33
          @Thomas-Braun
          @tom_33
          Okay, ist offenbar weg...
          ls -la /usr/bin/npm
            @tom_33
            ls -la /usr/bin/npm
            tom_33
            @Thomas-Braun sagte in zigbee: nach update von nodejs startet adapter nicht mehr:
            ls -la /usr/bin/npm
            ls: Zugriff auf '/usr/bin/npm' nicht möglich: Datei oder Verzeichnis nicht gefunden
            yep!
            • T tom_33
              ls -la /usr/bin/npm
              yep!
              @tom_33
              Dann noch ein
              sudo apt-get install --reinstall nodejs
                @tom_33
                Dann noch ein
                tom_33
                pi@ioBroker-RasPi:/opt/iobroker $ sudo apt-get install --reinstall nodejs
                0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                Es müssen noch 0 B von 15,9 MB an Archiven heruntergeladen werden.
                Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                (Lese Datenbank ... 56088 Dateien und Verzeichnisse sind derzeit installiert.)
                Vorbereitung zum Entpacken von .../nodejs_12.16.2-1nodesource1_armhf.deb ...
                Entpacken von nodejs (12.16.2-1nodesource1) über (12.16.2-1nodesource1) ...
                nodejs (12.16.2-1nodesource1) wird eingerichtet ...
                Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                6.14.4
                das sieht mal schon besser aus. ein fix steht evtl. noch aus und dann den iobroker starten?
                • T tom_33
                  6.14.4
                  @tom_33
                  Jetzt bist du sauber.
                  Der fixer kann nicht Schaden,
                  npm rebuild
                  in /opt/iobroker und dann würde ich den iobroker wieder anorgeln.
                  Ich würde allerdings an deiner Stelle überlegen, den Stretch auf Buster zu hieven.
                    @tom_33
                    npm rebuild
                    tom_33
                    @Thomas-Braun
                    ein ganz großes danke an dich für die geduld mit mir. da bin ich jetzt uptodate.
                    zigbee zickt leider immer noch gleich rum. z.zt. schnurrt die katze, mal sehen ob's was bringt.
                    das sagt mir leider gar nichts
                    pi@ioBroker-RasPi:~ $ nodejs -v
                    v12.16.2
                    pi@ioBroker-RasPi:~ $ node -v
                    v12.16.2
                    pi@ioBroker-RasPi:~ $ npm -v
                    6.14.4
                    host.ioBroker-RasPi	2020-04-26 00:08:12.025	info	Restart adapter system.adapter.zigbee.0 because enabled
                    host.ioBroker-RasPi	2020-04-26 00:08:12.025	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.024	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.023	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.023	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.022	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.021	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.021	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.020	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.019	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.018	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.018	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                    host.ioBroker-RasPi	2020-04-26 00:08:12.017	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    host.ioBroker-RasPi	2020-04-26 00:08:12.016	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                    host.ioBroker-RasPi	2020-04-26 00:08:12.016	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                    host.ioBroker-RasPi	2020-04-26 00:08:12.015	error	Caught by controller[0]: was compiled against a different Node.js version using
                    host.ioBroker-RasPi	2020-04-26 00:08:12.014	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                    host.ioBroker-RasPi	2020-04-26 00:08:12.013	error	Caught by controller[0]: ^
                    host.ioBroker-RasPi	2020-04-26 00:08:12.012	error	Caught by controller[0]: throw e;
                    host.ioBroker-RasPi	2020-04-26 00:08:12.010	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
                    host.ioBroker-RasPi	2020-04-26 00:08:11.364	info	instance system.adapter.zigbee.0 started with pid 1971
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                    • T tom_33
                      @Thomas-Braun
                      v12.16.2
                      v12.16.2
                      6.14.4
                      @tom_33
                      Du musst im Verzeichnis /opt/iobroker noch ein
                      npm rebuild
                      ausführen.
                      'Stretch' ist die sog. 'oldstable' Version on Debian, 'Buster' die aktuelle 'stable'. Debian wird zwar immer sehr lange gepflegt, aber man sollte da doch irgendwann auch sein System nachziehen.
                        @tom_33
                        npm rebuild
                        ausführen.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @Thomas-Braun
                        tolle Leistung ... bzw. Geduld 👍
                        • GlasfaserG Glasfaser
                          @Thomas-Braun
                          @Glasfaser said in zigbee: nach update von nodejs startet adapter nicht mehr:
                          @Thomas-Braun
                          Danke. Aber tom_33 war ja auch pflegeleicht und hat alles schön umgesetzt.
                          GlasfaserG T 2 Antworten Letzte Antwort
                            @Thomas-Braun
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Da kann ich dir Recht geben , viele ballern zwischdurch noch andere Befehle dazu .
                            • T tom_33
                              @Thomas-Braun
                              v12.16.2
                              v12.16.2
                              6.14.4
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @tom_33
                              und alles klar .... mit Zigbee !?
                                @Thomas-Braun
                                tom_33
                                @Thomas-Braun
                                da schließe ich mich an glasfaser an. und das andere seh ich als lob :-)
                                nein, zigbee macht immer noch errors. grrrr
                                • T tom_33
                                  @Thomas-Braun
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @tom_33
                                  und welche !?
                                  Jetzt sag nicht ... npm rebulid
                                    @tom_33
                                    und welche !?
                                    tom_33
                                    schrieb am zuletzt editiert von tom_33
                                    @Glasfaser
                                    ihr seid wirklich spitze! hilfe ohne ende!
                                    nein npm rebuild hat keine faxen gemacht
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.543	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.542	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.542	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.541	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.540	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.539	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: was compiled against a different Node.js version using
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.538	error	Caught by controller[0]: ^
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.537	error	Caught by controller[0]: throw e;
                                    host.ioBroker-RasPi	2020-04-26 00:34:16.536	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
                                    host.ioBroker-RasPi	2020-04-26 00:33:52.912	info	"system.adapter.zigbee.0" disabled
                                    host.ioBroker-RasPi	2020-04-26 00:33:45.862	info	Restart adapter system.adapter.zigbee.0 because enabled
                                    • T tom_33
                                      @Glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @tom_33
                                      Stoppe die Instanz , Sichere die Daten , deinstalliere Zigbee und dann über die Katze neu .
                                      Aber die neue 1.1.1
                                      Thomas BraunT T 2 Antworten Letzte Antwort
                                        @tom_33
                                        Aber die neue 1.1.1
                                        @Glasfaser
                                        Ist serialport im Modul zigbee enthalten oder was eigenes? Scheint mir da zu klemmen.
                                        npm rebuild serialport
                                        vielleicht?
                                          @tom_33
                                          Aber die neue 1.1.1
                                          tom_33
                                          @Glasfaser
                                          instanz stoppen: ok
                                          daten sichern: hm, da muss ich mit WinSCP den/die ?-ordner auf meinen windosrechner ziehen?
                                          btw: zigbee 1.1.1 läuft schon jetzt
