  4. Python Fehler bei Adapter update
    5.4k
pythonadapterupdate
7 Beiträge 4 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • R Offline
    Ritter
    bei jedem update von Adaptern unter Windows 10 habe ich Python Fehlermeldungen unter Windows 10. Die Adapter funktionieren aber und sind dann aktualisiert. Wie kann man das reparieren?
    $ ./iobroker upgrade onvif
    Update onvif from @0.2.0 to @0.3.0
    NPM version: 6.14.4
    npm install iobroker.onvif@0.3.0 --loglevel error (System call)
    gyp
    ERR! find Python gyp ERR! find Python Python is not set from command line or npm configurationgyp ERR! find Python Python is not set from environment variable PYTHONgyp ERR! find Python checking if "python" can be usedgyp ERR! find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python
    checking if "python3" can be usedgyp ERR! find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR! find Python gyp ERR! find Python **********************************************************gyp ERR! find Python
    You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp ERR! find Python - Set the environment variable PYTHONgyp ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"gyp ERR! find Python For more information consult the documentation at:gyp ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR! find Python
    gyp ERR! configure error gyp ERR! stack Error: Could not find any Python installation to usegyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:310:5)gyp ERR! stack
        at ChildProcess.errorhandler (child_process.js:322:5)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:273:12)gyp ERR! stack     at onErrorNT (internal/child_process.js:469:16)gyp ERR! stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)gyp ERR! System Windows_NT 10.0.18362gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\iobroker\node_modules\unix-dgramgyp ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [4] onvif.admin C:/iobroker/node_modules/iobroker.onvif/admin/words.js words.js application/javascript
    upload [3] onvif.admin C:/iobroker/node_modules/iobroker.onvif/admin/template.png template.png image/png
    upload [2] onvif.admin C:/iobroker/node_modules/iobroker.onvif/admin/onvif_logo.png onvif_logo.png image/png
    upload [1] onvif.admin C:/iobroker/node_modules/iobroker.onvif/admin/onvif.png onvif.png image/png
    upload [0] onvif.admin C:/iobroker/node_modules/iobroker.onvif/admin/index_m.html index_m.html text/html
    Adapter "onvif" updated
    process exited with code 0
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
    • R Ritter
      NPM version: 6.14.4
      gyp
      @Ritter
      Ist python überhaupt in deinem Windows installiert?
      • R Offline
        Ritter
        Unter Programme steht:
        Python 2.7.15 (64-bit)
        • R Ritter
          NPM version: 6.14.4
          gyp
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @Ritter sagte in Python Fehler bei Adapter update:
          Sorry wenn ich etwas meckere. Liest sich irgendwer eigentlich mal die Fehlermeldungen durch?
          Eigentlich steht da ganz genau beschrieben, was es versucht um die Phyton Installation zu finden.
          Suche in der phyton hilfe, wie du in Windows die umgebungsvariable PATH mit dem richtigen Pfad bestückst oder ändere den installationspfad
          Meine Adapter und Widgets
          Links im Profil
          • R Offline
            Ritter
            gelesen hab ich die Fehlermeldungen schon zumindest das wenige was ich davon verstehe.Bbei PATH stand schon das richtige. Habe jetzt Python 2.7.15 und 3.7.7 installiert, dann waren es weniger Fehlermeldungen. Diese sind jetzt noch übrig:
            gyp
            ERR! build error gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
            • surfer09S Offline
              surfer09S Offline
              surfer09
              Ich habe diese Fehler auch bei meinem IO-Broker unter Windows 10 64bit. Fällt mir jetzt extrem nach dem JS-Controller Update (bin jetzt auf Version 3.0.18) auf. Vorher hatte ich die Meldung nicht, wenn ich die Adapter upgedatet habe.
              • R Offline
                Ritter
                Ich glaube bei ist es auch seit JS-Controller 3.0.0, kann es aber nicht 100 prozentig sagen.
