  4. JS 3.0 Controler deConz-Adapter Fehler/Neustarts
deconzjs 3.0js controller update
9 Beiträge 7 Kommentatoren 1.3k Aufrufe 7 Beobachtet
  • c_hoch_bC Offline
    c_hoch_bC Offline
    c_hoch_b
    schrieb am zuletzt editiert von c_hoch_b
    Hey,
    nach dem Update auf den JS 3.0 habe ich div. Fehler bis hin zu Adapter-Neustarts.
    Log:
    2020-04-21 17:25:27.150 - info: deconz.0 (10377) cleaned everything up...
    2020-04-21 17:25:27.155 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.14.ct: The state is missing the required property val!
    2020-04-21 17:25:27.155 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.156 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.14.on: The state is missing the required property val!
    2020-04-21 17:25:27.156 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.156 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.14.level: The state is missing the required property val!
    2020-04-21 17:25:27.157 - error: deconz.0 (10377) uncaught exception: Cannot read property '0' of undefined
    2020-04-21 17:25:27.157 - error: deconz.0 (10377) TypeError: Cannot read property '0' of undefined
    at Request.request [as _callback] (/usr/local/iobroker/node_modules/iobroker.deconz/main.js:1696:25)
    at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-04-21 17:25:27.158 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.15.ct: The state is missing the required property val!
    2020-04-21 17:25:27.158 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.159 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.15.on: The state is missing the required property val!
    2020-04-21 17:25:27.159 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.160 - info: deconz.0 (10377) terminating
    2020-04-21 17:25:27.160 - info: deconz.0 (10377) Terminated (NO_ERROR): Without reason
    2020-04-21 17:25:27.161 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.15.level: The state is missing the required property val!
    2020-04-21 17:25:27.161 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.161 - error: deconz.0 (10377) uncaught exception: Cannot read property '0' of undefined
    2020-04-21 17:25:27.162 - error: deconz.0 (10377) TypeError: Cannot read property '0' of undefined
    2020-04-21 17:25:27.164 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.17.ct: The state is missing the required property val!
    2020-04-21 17:25:27.165 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.165 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
    2020-04-21 17:25:27.184 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.17.level: The state is missing the required property val!
    2020-04-21 17:25:27.184 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.184 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.16.on: The state is missing the required property val!
    2020-04-21 17:25:27.184 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
    2020-04-21 17:25:27.185 - warn: deconz.0 (10377) This value will not be set in future versions. Please report this to the developer.
    2020-04-21 17:25:27.185 - warn: deconz.0 (10377) State value to set is invalid for deconz.0.Lights.19.on: The state is missing the required property val!
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[1]: TypeError: Cannot read property '0' of undefined
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[1]: at Request.request [as _callback] (/usr/local/iobroker/node_modules/iobroker.deconz/main.js:1696:25)
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[3]: TypeError: Cannot read property '0' of undefined
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[3]: at Request.request [as _callback] (/usr/local/iobroker/node_modules/iobroker.deconz/main.js:1696:25)
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[4]: TypeError: Cannot read property '0' of undefined
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[4]: at Request.request [as _callback] (/usr/local/iobroker/node_modules/iobroker.deconz/main.js:1696:25)
    2020-04-21 17:25:27.807 - error: host.iMac-von-C2.local Caught by controller[4]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-04-21 17:25:27.807 - info: host.iMac-von-C2.local instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-04-21 17:25:27.807 - info: host.iMac-von-C2.local Restart adapter system.adapter.deconz.0 because enabled
    Raspi 4, MacOS, CCU 2, Conbee2, HomeKit/ Yahka, Homebridge, Hue,-Bulb/Switches/Sensors, Harmony, Kodi, Tado, Osram, Xiaomi, HomeMatic, Marantz, VU+, Alexa (Echo‘s)
      Michaelnorge
      Here the same:
      2020-04-21 18:50:03.031 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.5.on: The state is missing the required property val!
      2020-04-21 18:50:03.031 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:35.641 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.13.on: The state is missing the required property val!
      2020-04-21 18:50:35.642 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:39.970 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
      2020-04-21 18:50:39.971 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:39.987 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
      2020-04-21 18:50:39.988 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:51.781 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
      2020-04-21 18:50:51.782 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:51.831 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
      2020-04-21 18:50:51.831 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:50:58.783 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.19.on: The state is missing the required property val!
      2020-04-21 18:50:58.784 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:22.760 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.1.on: The state is missing the required property val!
      2020-04-21 18:51:22.761 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:36.161 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.13.on: The state is missing the required property val!
      2020-04-21 18:51:36.161 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:39.970 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.42.level: The state is missing the required property val!
      2020-04-21 18:51:39.970 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:40.014 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.10.on: The state is missing the required property val!
      2020-04-21 18:51:40.014 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:40.430 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
      2020-04-21 18:51:40.430 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:40.469 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
      2020-04-21 18:51:40.470 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:49.975 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.10.on: The state is missing the required property val!
      2020-04-21 18:51:49.976 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:49.989 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.9.on: The state is missing the required property val!
      2020-04-21 18:51:49.989 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:49.990 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.11.on: The state is missing the required property val!
      2020-04-21 18:51:49.991 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:51:50.037 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.42.on: The state is missing the required property val!
      2020-04-21 18:51:50.038 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:52:23.100 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
      2020-04-21 18:52:23.101 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:52:23.150 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
      2020-04-21 18:52:23.150 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:52:50.963 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.16.on: The state is missing the required property val!
      2020-04-21 18:52:50.963 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:53:12.654 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.13.on: The state is missing the required property val!
      2020-04-21 18:53:12.655 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:53:47.322 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.42.level: The state is missing the required property val!
      2020-04-21 18:53:47.322 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:53:47.327 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.10.on: The state is missing the required property val!
      2020-04-21 18:53:47.328 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:53:47.352 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.42.on: The state is missing the required property val!
      2020-04-21 18:53:47.353 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:54:13.095 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.13.on: The state is missing the required property val!
      2020-04-21 18:54:13.095 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:54:13.320 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.17.on: The state is missing the required property val!
      2020-04-21 18:54:13.320 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      2020-04-21 18:54:13.328 - warn: deconz.0 (1820) State value to set is invalid for deconz.0.Lights.18.on: The state is missing the required property val!
      2020-04-21 18:54:13.328 - warn: deconz.0 (1820) This value will not be set in future versions. Please report this to the developer.
      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
      • G Offline
        guergen
        Hatte ich auch..... Beta ist Beta.....
        • c_hoch_bC c_hoch_b
          Hey,
          Log:
          GlasfaserG Offline
          GlasfaserG Offline
          @c_hoch_b sagte in JS 3.0 Controler deConz-Adapter Fehler/Neustarts:
          @Jey-Cee
          @c_hoch_b
          @Michaelnorge
          das sieht ja Grausig aus ... es gibt hier die Funktion </> Code Tags , den Log reinzustellen !
          hier geht zur Hilfe
          c_hoch_bC Jey CeeJ 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            @Jey-Cee
            @c_hoch_b
            @Michaelnorge
            hier geht zur Hilfe
            c_hoch_bC Offline
            c_hoch_bC Offline
            c_hoch_b
            @Glasfaser
            Danke! Habs direkt geändert. ;-)
              @Jey-Cee
              @c_hoch_b
              @Michaelnorge
              hier geht zur Hilfe
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              @Glasfaser sagte in JS 3.0 Controler deConz-Adapter Fehler/Neustarts:
              Dazu gibt es schon einen Issue auf Github.
              Die Meldung mit dem Absturz hab ich auf dem Schirm und wird gefixt.
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
              • M1cS0wM Offline
                M1cS0wM Offline
                M1cS0w
                Joa, bei mir tauchen nun nur noch warnings auf. Dachte ich Installiere node auf Version 12, und passend js controller auf 3. Da ja die Ankündugung war, dass das nun quasi der Standard ist. Alles gut durchgelaufen. fixer, danach npm rebuild, soweit ohne Fehler.
                Doch deconz zeigt die warns an in Version 1.3.3
                deconz.0	2020-04-21 23:44:09.492	warn	(18240) This value will not be set in future versions. Please report this to the developer.
                deconz.0	2020-04-21 23:44:09.492	warn	(18240) State value to set is invalid for deconz.0.Lights.4.bri: The state is missing the required property val!
                deconz.0	2020-04-21 23:44:09.449	warn	(18240) This value will not be set in future versions. Please report this to the developer.
                deconz.0	2020-04-21 23:44:09.449	warn	(18240) State value to set is invalid for deconz.0.Lights.3.bri: The state is missing the required property val!
                deconz.0	2020-04-21 23:44:05.873	warn	(18240) {"address":"/lights/4","description":"parameter, /lights/4/ct, is not modifiable. Device is set to off.","type":201}
                deconz.0	2020-04-21 23:44:05.870	warn	(18240) {"address":"/lights/3","description":"parameter, /lights/3/ct, is not modifiable. Device is set to off.","type":201}
                deconz.0	2020-04-21 23:44:05.870	warn	(18240) This value will not be set in future versions. Please report this to the developer.
                deconz.0	2020-04-21 23:44:05.869	warn	(18240) State value to set is invalid for deconz.0.Lights.4.bri: The state is missing the required property val!
                deconz.0	2020-04-21 23:44:05.867	warn	(18240) This value will not be set in future versions. Please report this to the developer.
                deconz.0	2020-04-21 23:44:05.867	warn	(18240) State value to set is invalid for deconz.0.Lights.3.bri: The state is missing the required property val!
                Funktioniert aber soweit alles.
                • M1cS0wM M1cS0w
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @M1cS0w
                  Die Antwort darauf ... ist über deinen Beitrag von Jey Cee
                  • JB_SullivanJ Offline
                    JB_Sullivan
                    Nur so als Info, bei mir kommt auch die Meldung - aber nur dieser eine Eintrag alle 7 Minuten mehr nicht.
                    deconz.0	2020-04-22 07:52:55.086	warn	(7304) This value will not be set in future versions. Please report this to the developer.
                    deconz.0	2020-04-22 07:52:55.086	warn	(7304) State value to set is invalid for deconz.0.Lights.5.on: The state is missing the required property val!
