  4. js-controller 3.0/3.1 jetzt im Latest!
    6.5k
js-controller
1.3k Beiträge 127 Kommentatoren 598.5k Aufrufe 89 Beobachtet
  • kmxakK kmxak
    @apollon77
    Habe aktuell probleme mit dem RFLink:
    root@raspberrypi:/opt/iobroker# iobroker rebuild RFLink  --install
    internal/validators.js:117
        throw new ERR_INVALID_ARG_TYPE(name, 'string', value);
    TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received null
        at validateString (internal/validators.js:117:11)
        at Object.join (path.js:1039:7)
        at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2231:31)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:491:13)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2583:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:1156:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        at Module.load (internal/modules/cjs/loader.js:1000:32)
        at Function.Module._load (internal/modules/cjs/loader.js:899:14) {
      code: 'ERR_INVALID_ARG_TYPE'
    rflink.0	2020-04-21 11:20:33.676	error	(25746) Cannot write "rflink.0.channels.Kaku_1.SWITCH_4": Serial not opened
    https://github.com/ioBroker/ioBroker.rflink/issues/28
    Der scheint hier Pakete nicht zu finden.
    @kmxak Seit wann hat der adaptername grossbuchstaben??
    "iobroker rebuild rflink --install"
    should be your friend
    • T ticaki
      @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
      iobroker rebuild ham --install
      Da da ein paar hundert Logeinträge rumfliegen poste ich erstmal nur das:
      2020-04-21 01:33:00.209 - info: host.tims-pi1 instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2020-04-21 01:33:00.209 - info: host.tims-pi1 Adapter system.adapter.ham.0 needs rebuild and will be restarted afterwards.
      2020-04-21 01:33:00.210 - info: host.tims-pi1 system.adapter.ham.0 will be rebuilt
      2020-04-21 01:33:00.210 - warn: host.tims-pi1 adapter "ham" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      2020-04-21 01:33:00.211 - info: host.tims-pi1 iobroker rebuild ham --install
      2020-04-21 01:33:00.745 - info: host.tims-pi1 iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.ham"
      2020-04-21 01:33:01.480 - info: host.tims-pi1 instance system.adapter.iot.0 started with pid 22888
      2020-04-21 01:33:03.485 - info: iot.0 (22888) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.iot, node: v12.16.2, js-controller: 3.0.14
      2020-04-21 01:33:04.510 - warn: iot.0 (22888) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      Terminal:
      Rebuild ham done
      Instanzen aktiviert:
      host.tims-pi1	2020-04-21 11:55:44.200	info	Rebuild for adapter system.adapter.ham.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.tims-pi1	2020-04-21 11:55:44.199	info	instance system.adapter.ham.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      ham.0	2020-04-21 11:55:42.014	info	(13030) No additional Libraries to install ...
      ham.0	2020-04-21 11:55:41.983	info	(13030) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.16.2, js-controller: 3.0.14
      host.tims-pi1	2020-04-21 11:55:40.990	info	instance system.adapter.ham.0 started with pid 13030
      host.tims-pi1	2020-04-21 11:55:40.970	info	"system.adapter.ham.0" enabled
      host.tims-pi1	2020-04-21 11:51:59.261	info	"system.adapter.ham.0" disabled
      Ich bekomme den Adapter nicht auf grün, ist aber für mich jetzt nicht wirklich relevant, nutze ihn nicht mehr.
      #66
      @ticaki ok, das "kastrierte log" hilft mir nicht wirklich :-) Schick mal voll an meine Email bitte mit Verweis hierzu!
      iobroker@fischer-ka.de
      • M muckel
        Fehler beim Smartgarden-Adapter (Startet nicht)
        host.SmartHome 2020-04-21 08:28:17.917 error startInstance system.adapter.smartgarden.0: required adapter "@jpgorganizer/utils" not found!
        Verzeichnis vorhanden. Rechte passen.
        rebuild löst das Problem auch nicht.
        Adapter neu installieren funktioniert auch nicht.
        JS-Controller 3.0.14
        node.js 12.16.2
        mit node.js 10.x funktioniert es lt. einem anderen User.
        siehe: https://forum.iobroker.net/topic/31289/neuer-adapter-smartgarden-adapter-for-gardena-smart-system/222
        #67
        @muckel Ja ist simple. die "dependencies" im io.-package sind bullshit. Da wurde früher einiges nicht sauber geprüft - jetzt wirds :-( Adapter Dev muss fixen
        • wendy2702W wendy2702
          Der js-controller hat jetzt standardmässig Sentry als Fehler-Reporting eingebaut und aktiviert. Wenn also der js-controller mit einer Fehlermeldung abstürzt (und nur dann!) werden die Fehlerdetails anonymisiert an einen von uns selbst in Deutschland betriebenen Sentry-Server gemeldet. IPs o.ä. personalisierte Daten werden nicht gespeichert. Dieses Fehler-Reporting hilft uns bei Crashes schneller und genauer zu sehen was los ist und solche Fehler noch schneller beheben zu können. Bitte legt für Crashes die Ihr seht bitte trotzdem weiterhin GitHub-Issues an und unterstützt uns indem Ihr das Fehler-Reporting aktiviert lasst. Weitere Details und wie es deaktivierbar ist findet Ihr unter https://github.com/ioBroker/plugin-sentry#what-is-sentrysentryio .
          Auch immer mehr Adapter nutzen diese Form des Fehler-Reportings.
          kann man das dauerhaft für alle Adapter zeitgleich deaktivieren? Gibt es so etwas wie einen Master Switch oder muss ich das für jeden Adapter einzeln machen.
          EDIT: Gibt es bei neu Installationen oder späteren Upgrades (JS-Controller oder einzelner Adapter) einen "prominenten" Hinweis auf das sammeln der Daten im Fehlerfall ?
          #68
          @wendy2702 Bein es gibt keinen zentralen Switch. Pro Host und Adapter getrennt
          Jeder Adapter hat am Anfang seiner README einen Absatz von Sentry drin ist.
          • B bkiss
            Leider bleibt mein hmip-Adapter (Version: 0.0.12) auf gelb
            Betriebssystem: linux
            Node.js: v10.16.0
            NPM: 6.13.7
            hmip.0	2020-04-21 15:34:54.254	error	(26624) error starting homematic: Error: undefined is not a valid state value
            hmip.0	2020-04-21 15:34:54.253	info	(26624) unkown channel type - CHANGE_OVER_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate":158747
            hmip.0	2020-04-21 15:34:54.253	info	(26624) unkown channel type - DEHUMIDIFIER_DEMAND_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate
            hmip.0	2020-04-21 15:34:54.252	info	(26624) unkown channel type - HEAT_DEMAND_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate":158747
            hmip.0	2020-04-21 15:34:54.251	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.250	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.249	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.248	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.247	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.246	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:54.245	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:53.931	info	(26624) ws connection opened
            hmip.0	2020-04-21 15:34:47.090	info	(26624) unkown channel type - CHANGE_OVER_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate":158747
            hmip.0	2020-04-21 15:34:47.089	info	(26624) unkown channel type - DEHUMIDIFIER_DEMAND_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate
            hmip.0	2020-04-21 15:34:47.088	info	(26624) unkown channel type - HEAT_DEMAND_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdate":158747
            hmip.0	2020-04-21 15:34:47.087	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.086	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.085	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.084	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.083	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.082	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.081	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:47.079	info	(26624) unkown channel type - FLOOR_TERMINAL_BLOCK_CHANNEL - {"id":"3014F711A00005D5699CF519","homeId":"ff19da28-0d1f-4c45-a47f-84b75bb3d610","label":"Fußbodenheizungsaktor - 10-fach","lastStatusUpdat
            hmip.0	2020-04-21 15:34:46.101	info	(26624) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.hmip, node: v10.16.0, js-controller: 3.0.14
            host.odroidxu4	2020-04-21 15:34:44.174	info	instance system.adapter.hmip.0 started with pid 26624```
            #69
            @bkiss Bitte Issue beim Adapter anlegen
            • L LJSven
              Bei mir sind nach dem Update mehrere Adapter rot auf dem Slave. Den tr-064 habe ich schon neu installiert - wie soll ich vorgehen?
              Ausserdem bekomme ich bei Adapterinstallation auf dem Tinkerboard immer einen pixman-1 Error.
              #70
              @LJSven Der kommt eher vom iot Adapter der neuesten version. Bzw bitte nochmal updaten auf Latest ... da haben wir mal versuche die nötigen Linux Pakete mit zu installieren
              L 1 Antwort Letzte Antwort
              • L LJSven
                @Kueppert sagte in js-controller 3.0 jetzt im Latest!:
                @LJSven ohne Fehler-Log kann da glaube ich niemand etwas zu sagen
                Es kommt ja keine Fehlermeldung - das ist das kuriose.
                #71
                @LJSven Dann lada Admin mal neu :-) Vllt hat der einfach nur ein State Update nicht bekommen
                • apollon77A apollon77
                  LJSven
                  #72
                  @apollon77 Der iot-Adapter ist auf 1.4.6 - beim Raspberry sind die Fehler auch weg (waren auch da) / beim Tinkerboard sind sie noch da.
                    muckel
                    schrieb am zuletzt editiert von muckel
                    #73
                    Ja ist simple. die "dependencies" im io.-package sind bullshit. Da wurde früher einiges nicht sauber geprüft - jetzt wirds 😞 Adapter Dev muss fixen
                    Da ich kein Entwickler bin: wo gehören die eigentlich hin?
                    • lobomauL Offline
                      lobomauL Offline
                      lobomau
                      schrieb am zuletzt editiert von lobomau
                      #74
                      Bei mir lief Update von 2.x auf 3.0.14 ohne Probleme.
                      Nur der worx-Adapter will grad nicht. Aber liegt es an dem Update?
                      worx.0	2020-04-21 16:28:00.933	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
                      worx.0	2020-04-21 16:28:00.933	error	at endReadableNT (_stream_readable.js:1187:12)
                      worx.0	2020-04-21 16:28:00.933	error	at IncomingMessage.emit (events.js:322:22)
                      worx.0	2020-04-21 16:28:00.933	error	at Object.onceWrapper (events.js:416:28)
                      worx.0	2020-04-21 16:28:00.933	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
                      worx.0	2020-04-21 16:28:00.933	error	at Request.emit (events.js:310:20)
                      worx.0	2020-04-21 16:28:00.933	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
                      worx.0	2020-04-21 16:28:00.933	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                      worx.0	2020-04-21 16:28:00.933	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:46:31)
                      worx.0	2020-04-21 16:28:00.933	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/plumbing.js:104:33)
                      worx.0	2020-04-21 16:28:00.933	error	at new StatusCodeError (/opt/iobroker/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js:32:15)
                      worx.0	2020-04-21 16:28:00.933	error	(18114) StatusCodeError: 422 - {"message":"Missing coordinates","code":"422.005"}
                      worx.0	2020-04-21 16:28:00.932	error	(18114) uncaught exception: 422 - {"message":"Missing coordinates","code":"422.005"}
                      Host: NUC8i3 mit Proxmox:
                      • Slave: Pi4
                      B apollon77A 2 Antworten Letzte Antwort
                      • lobomauL lobomau
                        bkiss
                        #75
                        @lobomau
                        Der Worx Adapter (Version 1.0.0) läuft bei mir nach dem Update ohne Probleme
                        • L LJSven
                          #76
                          @LJSven SInd aber am Ende nicht so wichtig weil nur ein kleines Feature von iot dann nicht tut.
                          • M muckel
                            #77
                            @muckel In dem Fall done ... siehe https://forum.iobroker.net/post/416368
                            • lobomauL lobomau
                              #78
                              @lobomau eher nicht. Mach mal Issue beim Adapter auf
                                LJSven
                                #79
                                Glaube ich dir - aber wenn ich eins nicht mag, sind das Fehler- & Warnmeldungen ;-) PS. Die Meldung (pixman-1) kommt jetzt aber bei jedem Adapter Update - nicht nur bei iot.
                                • L LJSven
                                  #80
                                  @LJSven Ja ich weiss. Das liegt an npm weil der immer alles prüft
                                  Kannst höchsten nochmal manuell ein
                                  sudo apt install libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                  versuchen und schauen ob es danach weg ist
                                    LJSven
                                    #81
                                    Habe es mal ausgeführt - lief durch - werde beobachten, ob es jetzt weg ist.
                                    • P Offline
                                      peer69
                                      Forum Testing
                                      #82
                                      Kann man die Meldungen zum invalid object type deaktivieren? Ich hab es den devs gemeldet, hätte jetzt aber gern wieder ein sauberes logfile.
                                      deconz.0	2020-04-21 16:44:54.251	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:44:54.251	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
                                      deconz.0	2020-04-21 16:44:53.241	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:44:53.240	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
                                      deconz.0	2020-04-21 16:44:38.212	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:44:38.212	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
                                      netatmo.0	2020-04-21 16:44:10.582	warn	(27317) This object will not be created in future versions. Please report this to the developer.
                                      netatmo.0	2020-04-21 16:44:10.579	warn	(27317) Object netatmo.0.My-Home.Events.5e9f06b99asdfasdfasddfasdfabb09.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
                                      deconz.0	2020-04-21 16:44:08.259	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:44:08.258	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
                                      netatmo.0	2020-04-21 16:43:59.394	warn	(27317) This object will not be created in future versions. Please report this to the developer.
                                      netatmo.0	2020-04-21 16:43:59.393	warn	(27317) Object netatmo.0.My-Home.Events.5e9fasdffdsafasd3fb06d.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
                                      netatmo.0	2020-04-21 16:43:19.367	warn	(27317) This object will not be created in future versions. Please report this to the developer.
                                      netatmo.0	2020-04-21 16:43:19.366	warn	(27317) Object netatmo.0.My-Home.Events.231067c231219694e4f1389.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
                                      deconz.0	2020-04-21 16:42:49.430	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:42:49.429	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
                                      deconz.0	2020-04-21 16:42:38.297	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:42:38.296	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
                                      deconz.0	2020-04-21 16:42:37.298	warn	(25582) This value will not be set in future versions. Please report this to the developer.
                                      deconz.0	2020-04-21 16:42:37.297	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
                                      harrymH apollon77A 2 Antworten Letzte Antwort
                                      • P peer69
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        #83
                                        @peer69 stell den loglevel auf error
                                        ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                        • P peer69
                                          #84
                                          @peer69 Und Issues bei den Adaptern anlegen nicht vergessen bevor Du auf "Ignore" schaltest
