  4. Test Adapter SQL History Statistics
    6.8k
sqlhistorystatistic adaptermysqlmssqlpostgresqladapter
20 Beiträge 4 Kommentatoren 2.2k Aufrufe 8 Beobachtet
  • ScroungerS Scrounger
    @Latzi
    Habs gefixt, bitte die github version 0.1.1 testen, danke!
    LatziL Online
    LatziL Online
    Latzi
    @Scrounger
    schaut gut aus, bekomme zwar noch warnings (siehe unten) läuft aber. Werde mich mal damit auseinandersetzen.
    Kannst du mir bitte mitteilen, was die 2 checkboxes
    genau bewirken?
    2020-04-18 17:10:16.311 - info: host.Pi4-Server "system.adapter.sqlstatistics.0" enabled
    2020-04-18 17:10:16.377 - info: host.Pi4-Server instance system.adapter.sqlstatistics.0 started with pid 8438
    2020-04-18 17:10:18.428 - info: sqlstatistics.0 (8438) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.sqlstatistics, node: v10.19.0
    2020-04-18 17:10:18.496 - info: sqlstatistics.0 (8438) connected with 'sql.0' instance.
    2020-04-18 17:10:18.646 - info: sqlstatistics.0 (8438) updating statistics for database provider 'mysql'...
    2020-04-18 17:10:19.469 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_DATAFILES' rowsCount is 'null'
    2020-04-18 17:10:19.508 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_TABLESTATS' rowsCount is 'null'
    2020-04-18 17:10:19.519 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_LOCKS' rowsCount is 'null'
    2020-04-18 17:10:19.533 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_TABLESPACES_SCRUBBING' rowsCount is 'null'
    2020-04-18 17:10:19.545 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMPMEM' rowsCount is 'null'
    2020-04-18 17:10:19.556 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMP_PER_INDEX' rowsCount is 'null'
    2020-04-18 17:10:19.570 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMP' rowsCount is 'null'
    2020-04-18 17:10:19.581 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_FOREIGN_COLS' rowsCount is 'null'
    2020-04-18 17:10:19.592 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMP_RESET' rowsCount is 'null'
    2020-04-18 17:10:19.644 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_TABLESPACES_ENCRYPTION' rowsCount is 'null'
    2020-04-18 17:10:19.658 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_BUFFER_PAGE_LRU' rowsCount is 'null'
    2020-04-18 17:10:19.666 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_FIELDS' rowsCount is 'null'
    2020-04-18 17:10:19.675 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMPMEM_RESET' rowsCount is 'null'
    2020-04-18 17:10:19.684 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_COLUMNS' rowsCount is 'null'
    2020-04-18 17:10:19.693 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_FT_INDEX_TABLE' rowsCount is 'null'
    2020-04-18 17:10:19.702 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_CMP_PER_INDEX_RESET' rowsCount is 'null'
    2020-04-18 17:10:19.717 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_FT_INDEX_CACHE' rowsCount is 'null'
    2020-04-18 17:10:19.732 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_FT_BEING_DELETED' rowsCount is 'null'
    2020-04-18 17:10:19.744 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_BUFFER_POOL_STATS' rowsCount is 'null'
    2020-04-18 17:10:19.757 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_TRX' rowsCount is 'null'
    2020-04-18 17:10:19.766 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_FOREIGN' rowsCount is 'null'
    2020-04-18 17:10:19.782 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_TABLES' rowsCount is 'null'
    2020-04-18 17:10:19.802 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_FT_CONFIG' rowsCount is 'null'
    2020-04-18 17:10:19.810 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_BUFFER_PAGE' rowsCount is 'null'
    2020-04-18 17:10:19.822 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_TABLESPACES' rowsCount is 'null'
    2020-04-18 17:10:19.831 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_METRICS' rowsCount is 'null'
    2020-04-18 17:10:19.839 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_INDEXES' rowsCount is 'null'
    2020-04-18 17:10:19.848 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_VIRTUAL' rowsCount is 'null'
    2020-04-18 17:10:19.855 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_SYS_SEMAPHORE_WAITS' rowsCount is 'null'
    2020-04-18 17:10:19.869 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_LOCK_WAITS' rowsCount is 'null'
    2020-04-18 17:10:19.876 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_MUTEXES' rowsCount is 'null'
    2020-04-18 17:10:19.892 - warn: sqlstatistics.0 (8438) [updateStatistic] database: 'information_schema', table: 'INNODB_FT_DELETED' rowsCount is 'null'
    Vielen Dank!!!
    ScroungerS 1 Antwort Letzte Antwort
    • LatziL Latzi
      @Scrounger
      genau bewirken?
      Vielen Dank!!!
      ScroungerS Offline
      ScroungerS Offline
      Scrounger
      @Latzi
      Aktiviert -> es werden Datenpunkt für jede Tabellen von allen Datenbanken erzeugt.
      Deaktiviert -> nur Datenpunkte für Tabellen der IoBroker Datenbank werden erzeugt.
      Löscht automatisch Datenpunkt die nicht mehr aktualisiert werden. Z.B. wenn du eine Datenbank auf die Blacklist setzt.
      Kannst beide Punkte gefahrlos ausprobieren, an deiner Datenbank geht da nix kaputt!
      Welche MySql Version hast du?
      LatziL 1 Antwort Letzte Antwort
        @Latzi
        LatziL Online
        LatziL Online
        Latzi
        schrieb am zuletzt editiert von Latzi
        @Scrounger sagte in Test Adapter SQL History Statistics:
        Datenbank ist MariaDB 10 (Server-Version: 10.3.21) auf einer Synology.
        Interessant ist, dass die Größen der Einzeltabellen in Summe nicht der Gesamtgröße entspricht, ist das erklärbar?
        Vielen Dank für die Erklärung der Auswahlfelder!!!
        Der Adapter gefällt mir richtig gut, sehr wertvoll 👏 👏
        • LatziL Latzi
          ScroungerS Offline
          ScroungerS Offline
          Scrounger
          schrieb am zuletzt editiert von Scrounger
          @Latzi sagte in Test Adapter SQL History Statistics:
          Das wird jetzt glaub hart für dich, aber weil du nicht rechnen kannst 😁 ;-)
          Du addierst die Datenbankgröße 190,92MB (Summe) mit der Größe der in dieser Datenbank enthaltenen Tabellen. Aber die sind natürlich in der Datenbankgröße schon enthalten.
          Danke, es gibt inzwischen noch mehr statistiken übers System:
          Wenn du es testen magst, von github installieren version 0.1.2
          Und hier ist erklärt was die einzelnen Systemdaten ausssagen:
          http://blog.monyog.com/top-performance-metrics-monitor-mysql-connections-buffer-pool-usage/
          LatziL GlasfaserG 2 Antworten Letzte Antwort
            LatziL Online
            LatziL Online
            Latzi
            Verdammt, du hast mich entlarvt ;-) Ist aber auch gemein die Gesamtgröße in ts_number zu packen :-)
            schon installiert, warnings kommen noch
            Danke für die Informationen, da hab ich für eine Weile Lesestoff!
              Aktuelle Test Version 0.2.0
              Veröffentlichungsdatum 18.04.2020
              Github Link https://github.com/Scrounger/iobroker.sqlstatistics
              SQL History Adapater benötigt!
              SQL History Statistics erstellt Statistiken für euren Datenbank Provider. Es werden Statistiken wie Größe in MB, Anzahl der Reihen, etc. für Datenbanken und Tabellen erstellt.
              Für die verwendete IoBroker Datenbank werden zusätzlich Statistiken über nicht mehr verwendete Datenpunkte und die verbundenen Datensätze erzeugt.
              SQLite3 Datenbank wird nicht unterstützt!
              Adapter ist Alpha und deshlab noch nicht im latest. Bitte direkt von github installieren.
              Tester für mssql & postgresql benötigt
              Da ich selber nur MySql nutze, habe ich den Adapter nur mit MySql getestet!
              Ich benötige Unterstützung beim testen mit mssql und postgresql
              liv-in-skyL Offline
              liv-in-skyL Offline
              @Scrounger
              coole idee
              • mysql
              • keine warnungen oder fehler
              • datenpunkte sind gefüllt
              • LatziL Latzi
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                Hast du bei deiner MariaDb die InnoDb funktion nicht aktiviert?
                  LatziL Online
                  LatziL Online
                  Latzi
                  Nein
                  • LatziL Latzi
                    Nein
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @Latzi
                    Nur als Hinweis , setze global max_connections höher als vorgegeben .
                    Habe mich auch letzten bei meiner Synology MariaDB/SQL ausgesperrt ..
                    set global max_connections = 200;
                    Meldung in ioBroker : mysqladmin flush-hosts
                    • GlasfaserG Glasfaser
                      @Latzi
                      LatziL Online
                      LatziL Online
                      Latzi
                      @Glasfaser
                      wo mach ich das (geht das direkt in MariaDB)?
                      • LatziL Latzi
                        @Glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @Latzi
                        in der Konsole phpMyAdmin .. ganz unten
                        oder als Festeintrag in der Config ( /etc/mysql )
                          @Latzi
                          LatziL Online
                          LatziL Online
                          Latzi
                          @Glasfaser
                          Ahhh, vielen Dank, wieder was gelernt (ist mir noch nie aufgefallen)! 👏
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Ich würde den Link oben anheften und auf den Eintrag verweisen !?
                            • LatziL Latzi
                              @Glasfaser
                              ScroungerS Offline
                              ScroungerS Offline
                              Scrounger
                              @Latzi , @Glasfaser
                              max connections gibts in der nächsten Version dann auch als info, also was die höchste Anzahl war seit dem DB läuft:
                              @Glasfaser sagte in Test Adapter SQL History Statistics:
                              Ist schon geplant wenn ich die Doku nachziehe.
                                @Latzi , @Glasfaser
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                Version 0.2.0 (2020-04-25)
                                • system statistics added
                                • adapter settings added
                                • translation added
                                • option to reset session statistics every day added
                                • sum of not used rows in iob database added
                                Der Adapter sollte davor vollständig gelöscht werden, da ich einiges an der struktur geändert habe.
                                Diese Version wird es auch demnächst im latest geben.
                                  • translation added
                                  LatziL Online
                                  LatziL Online
                                  Latzi
                                  Hi, neue Version läuft (ich bekomme auch keine warnings mehr bezüglich innodb), bei jedem Adapterstart (nicht nur beim Erststart) wird folgendes gemeldet:
                                  2020-04-25 13:14:57.322 - info: host.Pi4-Server instance system.adapter.sqlstatistics.0 started with pid 32510
                                  2020-04-25 13:14:59.123 - info: sqlstatistics.0 (32510) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.sqlstatistics, node: v10.19.0
                                  2020-04-25 13:14:59.202 - info: sqlstatistics.0 (32510) connected with 'sql.0' instance.
                                  2020-04-25 13:14:59.327 - info: sqlstatistics.0 (32510) updating avaiable datapoint infos for database provider 'mysql'...
                                  2020-04-25 13:14:59.431 - error: sqlstatistics.0 (32510) [mysql] list of available system / session infos is null. Please report this issue to the developer!
                                  2020-04-25 13:14:59.557 - error: sqlstatistics.0 (32510) [mysql] list of client is null. Please report this issue to the developer!
                                  2020-04-25 13:14:59.569 - info: sqlstatistics.0 (32510) Successful updating avaiable datapoint infos!
                                  2020-04-25 13:14:59.570 - info: sqlstatistics.0 (32510) connected with 'sql.0' instance.
                                  2020-04-25 13:14:59.625 - info: sqlstatistics.0 (32510) updating system statistics for database provider 'mysql'...
                                  2020-04-25 13:14:59.635 - error: sqlstatistics.0 (32510) [mysql] system statistics is null. Please report this issue to the developer!
                                  2020-04-25 13:14:59.635 - info: sqlstatistics.0 (32510) updating session statistics for database provider 'mysql'...
                                  2020-04-25 13:14:59.645 - error: sqlstatistics.0 (32510) [mysql] session statistics is null. Please report this issue to the developer!
                                  2020-04-25 13:14:59.647 - info: sqlstatistics.0 (32510) updating client statistics for database provider 'mysql'...
                                  2020-04-25 13:14:59.664 - error: sqlstatistics.0 (32510) [mysql] client statistics is null. Please report this issue to the developer!
                                  2020-04-25 13:14:59.668 - info: sqlstatistics.0 (32510) connected with 'sql.0' instance.
                                  2020-04-25 13:14:59.687 - info: sqlstatistics.0 (32510) updating statistics for database provider 'mysql'...
                                  Muss ich bei den Einstellungen etwas angeben? Derzeit hab ich keine weiteren Änderungen vorgenommen (auch nicht in den "neuen" Reitern Blacklist, Datenpunke,..)?
                                  EDIT: Meldungen kommen jedesmal, wenn die Abfrage läuft
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @Scrounger
                                    habe diese meldungen - muss ich was machen ?
                                    sqlstatistics.0	2020-05-02 11:42:31.528	warn	(14449) [updateDatabaseStatistic] database: 'hilde-pass', table: 'kenn' rowsCount is 'null'
                                    sqlstatistics.0	2020-05-02 11:42:31.396	info	(14449) updating statistics for database provider 'mysql'...
                                    sqlstatistics.0	2020-05-02 11:42:31.354	info	(14449) connected with 'sql.0' instance.
                                    sqlstatistics.0	2020-05-02 11:42:31.344	error	(14449) [mysql] client statistics is []. Please report this issue to the developer!
                                    sqlstatistics.0	2020-05-02 11:42:31.329	info	(14449) updating client statistics for database provider 'mysql'...
                                    sqlstatistics.0	2020-05-02 11:42:31.328	info	(14449) Successful updating session statistics!
                                    sqlstatistics.0	2020-05-02 11:42:31.249	info	(14449) updating session statistics for database provider 'mysql'...
