  4. Modbus Wrong CRC for Frame
modbus adapter
14 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    mathschut
    Hi, mit Modbus Stick meine ich einen RS485 USB Stick. Hier die Einstellungen:
    modbus.1	2020-04-06 11:55:38.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:37.573	error	(10245) Wrong CRC for frame: 1,3,76,9,63,9,75,9,82,16,14,16,30,16,20,0,91,0,100,0,100,19,135,0,0,8,24,0,0,8,215,0,0,9,1,0,0,25,244,255,255,253,214,255,255,253,42,255,255,253,187,249,253,133,189,1,0,9,
    modbus.1	2020-04-06 11:55:37.074	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:36.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:36.073	error	(10245) Wrong CRC for frame: 1,3,1,109,0,4
    modbus.1	2020-04-06 11:55:35.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:35.073	error	(10245) Wrong CRC for frame: 1,3,76,9,63,9,74,9,82,16,13,16,29,16,20,0,91,0,97,0,99,19,135,0,0,8,24,0,0,8,158,0,0,8,244,0,0,25,169,255,255,253,218,255,255,253,91,255,255,253,133,41,8,116,0,0,9,8,0,0,9
    modbus.1	2020-04-06 11:55:34.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:34.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:33.573	error	(10245) Wrong CRC for frame: 1,3,1,109,0,4
    modbus.1	2020-04-06 11:55:33.072	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:32.573	error	(10245) Wrong CRC for frame: 1,3,76,9,65,9,75,9,84,16,15,16,32,16,23,0,91,0,97,0,99,19,135,0,0,8,28,0,0,8,154,0,0,8,242,0,0,25,167,255,255,253,218,255,255,253,75,255,255,253,155,255,255,255,75,253,44,
    modbus.1	2020-04-06 11:55:32.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:31.572	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:31.073	error	(10245) Wrong CRC for frame: 1,3,1,109,0,4
    modbus.1	2020-04-06 11:55:30.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:30.073	error	(10245) Wrong CRC for frame: 1,3,76,9,67,9,79,9,84,16,21,16,35,16,25,0,91,0,99,0,99,19,135,0,0,8,33,0,0,8,185,0,0,8,255,0,0,25,219,255,255,253,218,255,255,253,16,255,255,253,152,255,255,89,253,199,0,0
    modbus.1	2020-04-06 11:55:29.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:29.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:28.573	error	(10245) Wrong CRC for frame: 1,3,1,109,0,4
    modbus.1	2020-04-06 11:55:28.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:27.573	error	(10245) Wrong CRC for frame: 1,3,76,9,66,9,79,9,82,16,20,16,34,16,22,0,91,0,100,0,99,19,135,0,0,8,28,0,0,8,220,0,0,8,253,0,0,25,246,255,255,253,221,255,255,253,3,255,255,253,219,253,141,105,1,0,9,94,0
    modbus.1	2020-04-06 11:55:27.073	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:26.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:26.072	error	(10245) Wrong CRC for frame: 1,3,1,109,0,4
    modbus.1	2020-04-06 11:55:25.629	info	(10245) List of port: [{"comName":"/dev/ttyAMA0"},{"manufacturer":"1a86","pnpId":"usb-1a86_USB2.0-Serial-if00-port0","vendorId":"1a86","productId":"7523","comName":"/dev/ttyUSB0"},{"manufacturer":"Tex
    modbus.1	2020-04-06 11:55:25.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    modbus.1	2020-04-06 11:55:25.073	error	(10245) Wrong CRC for frame: 1,3,76,9,67,9,79,9,82,16,21,16,34,16,23,0,91,0,100,0,99,19,135,0,0,8,28,0,0,8,218,0,0,8,251,0,0,25,244,255,255,253,221,255,255,253,3,255,255,191,216,65,104,1,0,9,94,0,0,9,
    modbus.1	2020-04-06 11:55:24.573	error	(10245) Wrong CRC for frame: 1,3,0,243,0
    EDIT: Bitte log in Code Tags posten
    • wendy2702W Online
      wendy2702W Online
      Aha, und welcher?
      Ist der USB Port auch wirklich dein Stick oder besser dein Adapter?
      Wie ist die Verdrahtung? Leitungslänge, Widerstände, etc ?
      Stimmen die Adapter einstellungen mit dem WR überein ? Geschwindigkeit, Parity, Stop Bit, etc ?
      Sicher das du bei Eingangsregister richtig bist und wenn ja, stimmt "unsigned 16bit.... " ?
      Hast du die Instanz mal auf Debug gestellt?
        mathschut
        Hi, dass die Anzeige vom Stick, sollte der richtige sein. Kabel zum WR ist ungefähr 3m lang und Widerstände habe ich nicht dazwischen. Baudrade sollte laut Wechelrichter stimmen. Die anderen Werte weiß ich leider nicht. Bekomme ich die Werte irgendwie raus? Wie stelle ich die Instanz auf Debug? Achso die Abfrage ist bei Holding Register nicht bei Eingangsregister
        [255146.967165] usb 1-1.4: new full-speed USB device number 9 using dwc_otg
        [255147.100286] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
        [255147.100304] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
        [255147.100313] usb 1-1.4: Product: USB2.0-Serial
        [255147.101419] ch341 1-1.4:1.0: ch341-uart converter detected
        [255147.104784] usb 1-1.4: ch341-uart converter now attached to ttyUSB0
        root@raspi-owfs:/home/pi#
        EDIT: LOG IN CODE TAGS--- BITTE!!!!
          mathschut
          modbus.1	2020-04-06 12:09:01.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:09:00.573	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:09:00.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:59.573	error	(12354) Wrong CRC for frame: 1,3,76,9,62,9,78,9,88,16,15,16,38,16,24,0,53,0,34,0,97,19,137,0,0,4,126,0,0,1,89,0,0,8,207,0,0,14,167,255,255,254,81,255,255,253,45,255,255,253,174,255,255,249,127,63,89,1
          modbus.1	2020-04-06 12:08:59.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:58.573	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:58.073	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:08:57.574	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:57.074	error	(12354) Wrong CRC for frame: 1,3,76,9,60,9,75,9,90,16,11,16,37,16,24,0,53,0,33,0,98,19,137,0,0,4,120,0,0,1,100,0,0,8,218,0,0,14,175,255,255,254,79,255,255,253,80,255,255,253,168,255,255,249,191,106,25
          modbus.1	2020-04-06 12:08:56.573	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:56.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:55.573	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:08:55.074	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:54.574	error	(12354) Wrong CRC for frame: 1,3,76,9,60,9,74,9,89,16,10,16,35,16,23,0,53,0,33,0,97,19,137,0,0,4,133,0,0,1,107,0,0,8,209,0,0,14,193,255,255,254,92,255,255,253,95,255,255,253,251,251,253,197,105,15,0,3
          modbus.1	2020-04-06 12:08:54.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:53.574	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:53.073	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:08:52.574	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:52.074	error	(12354) Wrong CRC for frame: 1,3,76,9,59,9,75,9,89,16,10,16,36,16,22,0,52,0,33,0,98,19,138,0,0,4,102,0,0,1,87,0,0,8,204,0,0,14,138,255,255,254,79,255,255,253,78,255,255,253,163,255,255,249,255,210,135
          modbus.1	2020-04-06 12:08:51.573	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:51.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:50.573	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:08:50.074	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:49.574	error	(12354) Wrong CRC for frame: 1,3,76,9,60,9,77,9,87,16,13,16,36,16,21,0,52,0,34,0,98,19,138,0,0,4,104,0,0,1,109,0,0,8,213,0,0,14,169,255,255,254,79,255,255,253,56,255,255,253,255,255,255,225,138,7,0,3,
          modbus.1	2020-04-06 12:08:49.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:48.574	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:48.074	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          modbus.1	2020-04-06 12:08:47.573	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:47.074	error	(12354) Wrong CRC for frame: 1,3,76,9,59,9,74,9,88,16,9,16,34,16,21,0,52,0,33,0,98,19,138,0,0,4,111,0,0,1,100,0,0,8,218,0,0,14,173,255,255,254,79,255,255,253,91,255,255,253,163,255,255,255,74,255,253,
          modbus.1	2020-04-06 12:08:46.573	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:46.073	error	(12354) Wrong CRC for frame: 1,3,0,243,0
          modbus.1	2020-04-06 12:08:45.573	error	(12354) Wrong CRC for frame: 1,3,1,109,0,4
          • wendy2702W Online
            wendy2702W Online
            Hm,
            CRC Fehler kann ein diskrepanz mit den Adapter Einstellungen sein.
            Das sollte die Doku vom WR eigentlich mehr infos liefern... oder google :-)
            Bei drei metern kann es schon zu problemen ohne Widerstände kommen.
            Bei den Adaptern, weiss noch immer nicht welcher das ist, hatte ich auch mal Probleme bis ich diesen hier verwendet habe:
            https://www.amazon.de/DIGITUS-Seriell-Konverter-Einbaubuchse-schwarz/dp/B007VZY4CW
            Ist "Soli" eigentlich ein Abkürzung oder der Hersteller name ?
              mathschut
              Hi, dass ist der Wechselrichter: https://www.ginlong.com/rhi_inverter1/22071.html
              • wendy2702W Online
                wendy2702W Online
                Aha...
                und woher hast du die Information das der Modbus spricht?
                Konnte ich in der Anleitung nicht finden oder wo steht das?
                  mathschut
                  Der Einspeisungszähler ist per Modbus mit dem WR verbunden und im anderem Forum sprechen den Leute auch per Modbus an.
                  • wendy2702W Online
                    wendy2702W Online
                    Ist er per MODBUS verbunden oder per RS.485 ?
                    Das sind zwei verschiedene paar Schuhe.
                      mathschut
                      per RS.485
                      • wendy2702W Online
                        wendy2702W Online
                        Denke du redest vom Photovoltaikforum.
                        Da konnte ich zumindest schonmal das lesen:
                        Modbus SunSpec
                        Irgendwo im thread im PV Forum (bist ja gerade selber dort aktiv) steht auch da es eine "bastel geschichte ist" da man parallel auf dem Modbus lauscht zum Zähler.
                          mathschut
                          ja genau.
