Onkyo
Hi Guys
I can not speak russian. So I don´t know about your discuss here. I have added some code to the onkyo adapter to control with VIS. Eventually you have the same thematic!?
After installing the "new test version" through npm you can use buttons to power on|off zone1 and zone2, muting and other things.
If you will thest this and report to me (I will do a pull request and need feedback from you) you can do the following:
1. Delete onkyo instance
2. Delete onkyo adapter
3. Delete all onkyo objects
4. Connect wiht SSH in the folder /opt/iobroker
5. npm install https://github.com/Eisbaeeer/ioBroker.o … ll/master/
The adapter appears in admin.
6. Install instance
7. configure (check box!)
8. Start adapter
Your feedback is welcome!
Hi Guys
6. Install instance
8. Start adapter
Your feedback is welcome! `
A strange development, why do we need a new driver for the VIS widget?! ````
[{"tpl":"tplMetroTileToggle","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true",
"bg_class_false":"bg-gray","bg_class_true":"bg-teal","icon_class_false":"icon-arrow-up-2","icon_class_true":"icon-arrow-up-2",
"icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"",
"brand_bg_class_true":"","visibility-oid":"","oid":"","label_false":"Закрыто","label_true":"Закрыто","icon_false":"","icon_true":"",
"oidTrue":"onkyo.0.command","oidFalse":"onkyo.0.command","select_on_true":false,"oidTrueValue":"ZMT00",
"oidFalseValue":"ZMT01","badge_top":"0","badge_left":"0","gestures-offsetX":0,"gestures-offsetY":0,
"gestures-swiping-value":"","gestures-rotating-value":"","gestures-pinching-value":"","gestures-swipeRight-value":"",
"gestures-swipeLeft-value":"","gestures-swipeUp-value":"","gestures-swipeDown-value":"","gestures-rotateLeft-value":"",
"gestures-rotateRight-value":"","gestures-pinchIn-value":"","gestures-pinchOut-value":""},
"style":{"left":"246px","top":"30px","width":"88px","height":"91px","z-index":"9999","opacity":"1"},"widgetSet":"metro"}] -
A strange development, why do we need a new driver for the VIS widget? `
Hi Instalator
We asked some times in forum, how to use the onkyo with VIS. Nobody tell us, how to use the onkyo adapter.
Can you explain us how to use the adapter in VIS. Perhaps you realized a much better surface.
There are some more users who want to use the adapter with VIS. It would be great if you tell us how we can put on/off the zones and the other tools.
Perhaps you can provide some screenshots?
I used this strange way for 2nd driver because I don´t know how we should use it and I don´t want to change anything of your code. If the adapter works with VIS, let me say, hey, I learned verry much by programming in this adapter. There is no reaoson to use the code, if the adapter works with VIS. ;-)
Greetings Eisbaeeer
Hi Instalator
Greetings Eisbaeeer `
All objects in IoB work with VIS.
I looked at your driver and understand your idea. Make better pullreqest the https://github.com/ioBroker/ioBroker.onkyo drivers and will test together. I think that BlueFox would not mind.
BlueFox! объкты для второй, третьей зоны не создаются по причине отсутствия имени команды в файле команд?
Получается для основной зоны имена прописаны:
"PWR":{ "name":"system-power","description":"System Power Command","values":{ "00":{ "name":"standby","description":"sets System Standby","models":"set1"}, "01":{ "name":"on","description":"sets System On","models":"set1"}, "QSTN":{ "name":"query","description":"gets the System Power Status","models":"set1"}}},А для остальных зон нет:
"zone2":{ "ZPW":{ "standby":{ "value":"00","models":"set139"}, "on":{ "value":"01","models":"set139"}, "query":{ "value":"QSTN","models":"set139"}},Если переименовать так? они создадутся? или почему тогда создаются не все объекты для команд?
"ZPW":{ "name":"zone2-power","description":"System Power Command","values":{ "00":{ "name":"standby","description":"sets System Standby","models":"set139"}, "01":{ "name":"on","description":"sets System On","models":"set139"}, "QSTN":{ "name":"query","description":"gets the System Power Status","models":"set139"}}}, -
Нашел косячек в файле команд.
Там для PWZ имя стоит power как и для основной зоны.
исправил на
"zone2":{ "Zone2.power":"ZPW",И Zone2.power появился в списке объектов.
Так что не русско говорящий товарищь зря пилил свой код)
Добавлено! Создал пулреквест, получается мы создаем объекты только для зоны main и имена в разных зонах пересекаются.
` > All objects in IoB work with VIS.
I looked at your driver and understand your idea. . `
OK, can you shortly explain, wich button do you use to power on/off and the corrosponding objekt?
I don't get running it with only one button.
Eisbaeeer
Gesendet von meinem SM-G920F mit Tapatalk
Eisbaeeer
Eisbaeeer `
You wrote a little wrong code.I have made changes that allow you to automatically create objects, but check when BlueFox will return from vacation.
https://github.com/GermanBluefox/node-e … 9fac6dca4d
https://github.com/ioBroker/ioBroker.on ... 1532dd5799
https://github.com/ioBroker/ioBroker.on ... ca6105cb19
Change at these files, delete all the objects in Onkio driver and restart the IOB.
Eisbaeeer `
I changed the driver. Objects are created automatically. Replace folder with the drivers, and delete all the objects in Onkio driver and restart the IOB.
filename="iobroker.onkyo.rar" index="0">~~ `
What result? -
filename="iobroker.onkyo.rar" index="0">~~What result?Hi,
I tested with the main power button. Result is, that the button doesn´t change the colour, because the status in iobroker is NOT "true" or "false" or "1" or "0". And this can not be working. Only this 4 states are allowed in iobroker. The object get´s the state (value) "standby".
I have attached a screenshot of my test. The buttons left of the marked are my working buttons who changes the logo by selecting a picture for the value "false" and an other for the value "true".
I tested the "Mute" button, too. This is working how it should !!!
So it seems, that only the feedback of power button is wrong. Can you change that from "standby" to "false" and if the receiver is on to "true"?
At the moment we get:
Receiver off = "standby"
Receiver on = "1"
Correct feedbacks will be:
Receiver off = "false"
Receiver on = "true"
Eisbaeeer
Hi
I changed my vis to test further. In zone 1 there is no "radio preset" available. The radio preset in zone2 doesn´t working. If I try to set the preset to "2" for preset memory 2, the receiver doesn´t recognize that. It doesn´t matter, what you type in, no reaction.
The other "net-usb" things are not tested at the moment.
Greetings Eisbaeeer
Hi
Hallo!Zuletzt hatte ich den Hörer nachließ. Ich nahm es für eine kostenlose Ersatzkarte hdmi zur Reparatur. Ich kann den Fahrer nur 2 Wochen überprüfen.
Hi Installator
The translation does not make sense. I think it´s better to write in english.
I changed the "eiscp-commands.json" to get the status working in onkyo adapter. I changed the both "standby" to "false" states in zone1 and zone2.
You can compare the file with yours:
Now I get the correct feedback and my power buttons are working. Can you change this in your code?
My opinion is, that the adapter has too much overhead for the target function. It is not clear, why we need so much alias for the commands?
Who needs this and for wich function?
My main feature is to control the onkyo through VIS.
Can someone explain how do you use the adapter and the other functions?
My first adapter was created without an extra "node_module" for eiscp. I realized all in RAW mode wihtout too much overhead.
The other issue is, that I get now zone3, zone4 …., but I don´t have this zones!
For me the adapter now doing that what he should. So all is fine and I am happy. I can use it as it is.
Eisbaeeer
139_eiscp-commands.json.txt -
Hi Installator
Eisbaeeer `
Hello! I can not yet test the driver. I gave my ressiver in the replacement motherboard repair hdmi -
filename="iobroker.onkyo.rar" index="2">~~What result?Hi,
Receiver on = "1"
filename="Screenshot.png" index="2">~~
Eisbaeeer `
I changed the code to standby to False.
What do you do before prevented as in the picture?
Eisbaeeer
[{"tpl":"tplHqButton","data":{"visibility-cond":"==","visibility-val":1,"oid":"onkyo.0.system-power","min":"standby","max":"true","iconName":"/vis/img/dashui/avSony.png","btIconWidth":"47","offsetAuto":false,"leftOffset":"4","topOffset":"7","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","usejQueryStyle":false,"changeEffect":"waves","testActive":false,"waveColor":"#FFFFFF","oid-working":"","filterkey":"media","pushButton":false,"gestures-offsetX":0,"gestures-offsetY":0},"style":{"left":"26px","top":"171px","z-index":"3","border-radius":"50px","width":"50px","height":"50px"},"widgetSet":"hqwidgets"}]
