  4. [Vorlage] Vis für Adapter HeatingControl
    apollon77A
vistemplate
444 Beiträge 52 Kommentatoren 164.4k Aufrufe 66 Beobachtet
  • O Oli
    @Pittini
    super Danke für die schnelle Bearbeitung, leider bekomme ich immer noch Warnmeldungen
    javascript.0	2020-03-23 11:09:13.895	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-03-23 11:09:13.895	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-03-23 11:09:13.895	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-03-23 11:09:13.895	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
    javascript.0	2020-03-23 11:09:13.894	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
    javascript.0	2020-03-23 11:09:13.894	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
    javascript.0	2020-03-23 11:09:13.894	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
    javascript.0	2020-03-23 11:09:13.893	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:324:5)
    javascript.0	2020-03-23 11:09:13.893	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
    javascript.0	2020-03-23 11:09:13.892	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.RoomValues.CurrentTimePeriod" which expects a number. Please fix your code to use a number or change the state type to o
    javascript.0	2020-03-23 11:09:13.892	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-03-23 11:09:13.892	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-03-23 11:09:13.891	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-03-23 11:09:13.891	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
    javascript.0	2020-03-23 11:09:13.891	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
    javascript.0	2020-03-23 11:09:13.891	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
    javascript.0	2020-03-23 11:09:13.890	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
    javascript.0	2020-03-23 11:09:13.890	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:324:61)
    javascript.0	2020-03-23 11:09:13.889	warn	(774) getState "heatingcontrol.0.Rooms.Wohnzimmer.ActiveTimeSlot" not found (3) states[id]=null
    P
    P
    Pittini
    #145
    @Oli sagte in [Vorlage] Vis für Adapter HeatingControl:
    Mach mir mal bitte nen Screen vom aufgeklappten heatingcontrol.0.Rooms.Wohnzimmer
    O 1 Antwort Letzte Antwort
    • P Pittini
      O
      O
      Oli
      #146
      @Pittini
      hier der gewünschte Screen
      Oliver
      P 1 Antwort Letzte Antwort
      • O Oli
        @Pittini
        P
        P
        Pittini
        #147
        Danke. Dacht ichs mir doch, für den Bug kann ich nix, da musste Dich an Rene wenden bzw. ein Issue aufmachen. Wenn der Adapter das Feld nicht füllt kanns mein Skript logischerweise nicht auslesen.
        • P Pittini
          O
          O
          Oli
          #148
          @Pittini
          alles klar, danke
          Oliver
          • Stephan SchleichS
            Stephan SchleichS
            Stephan Schleich
            schrieb am zuletzt editiert von Stephan Schleich
            #149
            @Pittini: Ich bekomm mit dem Script folgende Warnmeldungen beim start
            • Stephan SchleichS Stephan Schleich
              P
              P
              Pittini
              schrieb am zuletzt editiert von Pittini
              #150
              @Stephan-Schleich sagte in [Vorlage] Vis für Adapter HeatingControl:
              Adapterversion? Skriptversion? Welchen View (das Projekt oder den SimpleView)?
              Sieht aus als wenn händisch ne Temperatur mit °C eingegeben wurde obwohl nur ne Zahl erlaubt ist oder ne Zahl mit Komma statt Punkt? Solltest Du sowas gemacht haben, ist das der Fehler, ansonsten, bitte Screen mit aufgeklappten Datenpunkten von:
              heatingcontrol.0.Profiles.0.Wohnzimmer.Sun.Periods.0
              und
              heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.Periods
              und
              javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods
              Stephan SchleichS 1 Antwort Letzte Antwort
              • P Pittini
                und
                und
                Stephan SchleichS
                Stephan SchleichS
                Stephan Schleich
                #151
                @Pittini: Adapter: 0.3.18, Script: von heute, SimpleView
                Die Werte stehen als Zahl drinnen
                Javascript:
                HeatingControl:
                  Javascript:
                  HeatingControl:
                  P
                  P
                  Pittini
                  #152
                  Adapter: 0.3.18
                  Bitte 0.3.19 einspielen, da wurden etlicher solcher Probleme gelöst, dann nochmal Feedback bitte.
                    @Bastelritius hast Du Material Designadapter oder Material Design Widgets Adapter installiert? Die verursachen mit diesem View ärger.
                    BastelritiusB
                    BastelritiusB
                    Bastelritius
                    #153
                    ich hoffe ich beantworte jetzt alle Fragen und übersehe nichts.
                    @Beliar_666: Ich hatte den Adapter mal testweise installiert, aber wieder gelöscht. Jedoch erscheinen noch die Widgets im VIS-Editor:
                    Zumal ich auch meine Vis Seite mit dem aktuellen MD-Desing von uhlah laufen habe. Dort funtioniert das Auf und zuklappen auch. Auch der input mit Datetime klappt.
                    @Pittini
                    • Update habe ich gemacht, habe jetzt die Version 0.3.19
                    • Widget "jqui - ctrl - Input Datetime" sollte ich haben
                    1. Liste Deiner installierten Adapter, vorallem mit Vis zusammenhängende.
                    2. die Objektliste von "javascript.0.vis.HeatingControl" mit aufgeklappten Channels
                    3. die Objektliste von "heatingcontrol.0" mit aufgeklappten Channel "Info"
                    4. Haupt- und Profil- Einstellungen aus dem HeatingControl Adapter.
                    Ich hoffe ich habe nichts vergessen.
                    • BastelritiusB Bastelritius
                      @Pittini
                      P
                      P
                      Pittini
                      #154
                      @Bastelritius sagte in [Vorlage] Vis für Adapter HeatingControl:
                      Schaut eigentlich soweit ok aus. Leider hast das wichtigste vergessen, nämlich die Auskunft obs jetzt funktioniert oder nicht und wenn nein, was nicht geht, bzw. ob das update keinerlei Effekt hatte. Am besten nochmal n Log. Tritt der Fehler bei Start auf oder wenn Du was änderst im Vis?
                      BastelritiusB 1 Antwort Letzte Antwort
                      • P Pittini
                        BastelritiusB
                        BastelritiusB
                        Bastelritius
                        #155
                        @Pittini , Hallo.
                        Also beim Start vom Script erscheinen folgende Warnmeldungen:
                        24.3.2020, 13:31:22.096	[info ]: javascript.0 (1038) Stop script script.js.common.HeatingControlMapper
                        24.3.2020, 13:31:22.208	[info ]: javascript.0 (1038) Start javascript script.js.common.HeatingControlMapper
                        24.3.2020, 13:31:22.221	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: registered 0 subscriptions and 0 schedules
                        24.3.2020, 13:31:22.271	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: CreateStates fertig!
                        24.3.2020, 13:31:22.274	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: <div class="mdui-listitem mdui-center-v" style="height:48px;"> <img height=40px src="/vis.0/HeatingControl/images/fts_window_1w.svg"&nbsp</img> <div class="mdui-label">Büro<div class="mdui-subtitle">seit 24.03.2020 08:14:38</div></div></div><div class="mdui-listitem mdui-center-v" style="height:48px;"> <img height=40px src="/vis.0/HeatingControl/images/fts_window_1w.svg"&nbsp</img> <div class="mdui-label">Gaeste_WC<div class="mdui-subtitle">seit 11.03.2020 20:45:01</div></div></div>
                        24.3.2020, 13:31:22.276	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: reaching CreateCurrentTimePeriodTrigger - Oldroom= none ChoosenRoom= Büro
                        24.3.2020, 13:31:22.278	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 0 Büro
                        24.3.2020, 13:31:22.279	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 1 Gaeste_WC
                        24.3.2020, 13:31:22.282	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: Reaching SetVis
                        24.3.2020, 13:31:22.284	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:79)
                        24.3.2020, 13:31:22.284	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.286	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:17)
                        24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.299	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:79)
                        24.3.2020, 13:31:22.300	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.300	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:17)
                        24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.309	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:79)
                        24.3.2020, 13:31:22.310	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.310	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.315	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:17)
                        24.3.2020, 13:31:22.316	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.316	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.321	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:79)
                        24.3.2020, 13:31:22.322	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.322	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        24.3.2020, 13:31:22.327	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:17)
                        24.3.2020, 13:31:22.328	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                        24.3.2020, 13:31:22.328	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                        Bei Änderungen am Profil im Vis erscheint folgendes:
                        heatingcontrol.0	2020-03-24 13:33:29.651	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                        heatingcontrol.0	2020-03-24 13:33:24.713	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                        heatingcontrol.0	2020-03-24 13:33:13.058	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.057	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.047	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.046	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.045	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.035	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.034	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        heatingcontrol.0	2020-03-24 13:33:13.033	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                        javascript.0	2020-03-24 13:33:28.079	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=0_userdata.0.rolladensteuerung.rolladen_runter_helligkeit, timerId=undefined) => {"val":"110","ack":false,"ts":1584725455483,"q":0,"from":"syste
                        javascript.0	2020-03-24 13:33:28.078	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=hm-rpc.0.NEQ0118858.1.BRIGHTNESS, timerId=undefined) => {"val":219,"ack":true,"ts":1585053208075,"q":0,"from":"system.adapter.hm-rpc.0","user":"
                        javascript.0	2020-03-24 13:33:28.078	info	(1038) script.js.Rollos.Rolladen_automatik: setForeignState(id=0_userdata.0.rolladensteuerung.rolladen_steuerung, state={"val":0,"ack":true})
                        javascript.0	2020-03-24 13:33:28.077	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=0_userdata.0.rolladensteuerung.rolladen_runter_helligkeit, timerId=undefined) => {"val":"110","ack":false,"ts":1584725455483,"q":0,"from":"syste
                        javascript.0	2020-03-24 13:33:28.076	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=hm-rpc.0.NEQ0118858.1.BRIGHTNESS, timerId=undefined) => {"val":219,"ack":true,"ts":1585053208075,"q":0,"from":"system.adapter.hm-rpc.0","user":"
                        javascript.0	2020-03-24 13:33:22.172	info	(1038) script.js.common.HeatingControlMapper: MinimumTemp=Null, skipping entry and showing 0
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.168	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                        javascript.0	2020-03-24 13:33:22.168	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.167	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.166	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.166	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.166	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                        javascript.0	2020-03-24 13:33:22.165	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Fri.1.time" not found (3)
                        javascript.0	2020-03-24 13:33:22.165	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.164	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                        javascript.0	2020-03-24 13:33:22.163	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:22.163	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:22.162	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.162	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.162	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.160	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.160	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.159	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.159	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.159	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                        javascript.0	2020-03-24 13:33:22.157	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Thu.1.time" not found (3)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.153	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.153	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                        javascript.0	2020-03-24 13:33:22.153	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.152	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.151	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.151	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.151	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                        javascript.0	2020-03-24 13:33:22.150	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Fri.0.time" not found (3)
                        javascript.0	2020-03-24 13:33:22.150	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.148	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                        javascript.0	2020-03-24 13:33:22.148	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:22.148	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:22.146	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                        javascript.0	2020-03-24 13:33:22.146	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                        javascript.0	2020-03-24 13:33:22.145	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Thu.0.time" not found (3)
                        javascript.0	2020-03-24 13:33:22.143	info	(1038) script.js.common.HeatingControlMapper: Reaching SetVis
                        javascript.0	2020-03-24 13:33:20.672	info	(1038) script.js.common.HeatingControlMapper: Trigger für Raum Büro gelöscht, und für Raum Gaeste_WC gesetzt.
                        javascript.0	2020-03-24 13:33:20.672	info	(1038) script.js.common.HeatingControlMapper: reaching CreateCurrentTimePeriodTrigger - Oldroom= Büro ChoosenRoom= Gaeste_WC
                        javascript.0	2020-03-24 13:33:20.670	info	(1038) script.js.common.HeatingControlMapper: MinimumTemp=Null, skipping entry and showing 0
                        javascript.0	2020-03-24 13:33:20.665	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.665	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.665	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.665	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.665	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.664	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.664	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.664	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                        javascript.0	2020-03-24 13:33:20.664	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:20.663	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:20.663	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.663	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.662	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.661	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                        javascript.0	2020-03-24 13:33:20.660	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Fri.1.time" not found (3)
                        javascript.0	2020-03-24 13:33:20.660	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.660	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.659	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.657	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.657	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                        javascript.0	2020-03-24 13:33:20.657	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:20.656	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:20.656	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.655	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.655	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.654	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.654	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                        javascript.0	2020-03-24 13:33:20.653	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Thu.1.time" not found (3)
                        javascript.0	2020-03-24 13:33:20.651	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.651	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.651	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.651	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.650	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                        javascript.0	2020-03-24 13:33:20.650	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:20.649	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:20.649	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.649	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.649	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.648	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                        javascript.0	2020-03-24 13:33:20.647	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Fri.0.time" not found (3)
                        javascript.0	2020-03-24 13:33:20.646	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.646	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.646	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.646	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.646	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.645	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.645	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.645	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                        javascript.0	2020-03-24 13:33:20.645	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                        javascript.0	2020-03-24 13:33:20.644	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                        javascript.0	2020-03-24 13:33:20.644	warn	(1038) at processImmediate (timers.js:658:5)
                        javascript.0	2020-03-24 13:33:20.644	warn	(1038) at tryOnImmediate (timers.js:676:5)
                        javascript.0	2020-03-24 13:33:20.644	warn	(1038) at runCallback (timers.js:705:18)
                        javascript.0	2020-03-24 13:33:20.644	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                        javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                        javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                        javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                        javascript.0	2020-03-24 13:33:20.643	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                        javascript.0	2020-03-24 13:33:20.642	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Thu.0.time" not found (3)
                        javascript.0	2020-03-24 13:33:20.640	info	(1038) script.js.common.HeatingControlMapper: Reaching SetVis
                        javascript.0	2020-03-24 13:33:17.208	info	(1038) script.js.common.HeatingControlMapper: SetTimeTempValue: heatingcontrol.0.Profiles.0.Büro.Thu.Periods.0.time set to 07:27
                        javascript.0	2020-03-24 13:33:17.208	info	(1038) script.js.common.HeatingControlMapper: Reaching SetTimeTempValue
                        javascript.0	2020-03-24 13:33:17.207	info	(1038) script.js.common.HeatingControlMapper: string
                        Das Auf- und zuklappen der Cards geht auch nicht.
                          @Pittini , Hallo.
                          P
                          P
                          Pittini
                          #156
                          Die Änderung auf 0.3.19 vom HeatingControl hat ja schon was geholfen, Fehler sind weniger geworden. Was übrig ist, kommt mir bekannt vor und sollte eigentlich gefixt sein, welche Version vom meinem Skript verwendest Du? Wenns nicht die 1.0.5 ist, bitte updaten und erneutes Feedback bzw. Logs.
                          Der Fehler mit den nicht klappbaren cards, da scheinst Du nicht alleine zu sein, siehe hier und ich kann da wenig machen, das hängt mit dem MD zusammen. Vieleicht kann @Uhula da was zu sagen oder es eingrenzen, bei den meisten funktionierts ja, also müssen Du und @chhe irgendwas gemeinsam haben, evtl. is das ja auch ne Hilfestellung für @Uhula. Sollte er das hier nicht mitkriegen, schildere das Problem einfach im oben verlinkten Thread.
                          • C
                            C
                            chhe
                            #157
                            Hi @Bastelritius
                            ich habe für den Fehler mit den nicht klappbaren Cards einen neuen Thread anglegt. Das Thema scheint etwas komplexer zu sein, dort können wir die Informationen gut bündeln.
                            Vielleicht schilderst du dort deine Situation nochmal... Und wir hoffen dass @Uhula sich dort meldet.
                            • P Pittini
                              BastelritiusB
                              BastelritiusB
                              Bastelritius
                              #158
                              @Pittini, so ich hatte die version 1.0.4. Mit der 1.0.5 kommen keine Warnmeldungen mehr. Super, danke für die Hilfe.
                              Jetzt bekomme ich nur noch folgende Meldung vonm heatingcontrol in meinem Log:
                              heatingcontrol.0	2020-03-24 14:53:51.003	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                              @CHHE Ich hänge mich an deinen Thread.
                                P
                                P
                                Pittini
                                #159
                                Ist bekannt, dazu gibts bereits ein Issue bei Git, siehe hier und ne Meldung im Thread, siehe da.
                                • Stephan SchleichS
                                  Stephan SchleichS
                                  Stephan Schleich
                                  #160
                                  Kann es ein das der Javascript Punkt HolidayPresent für die Temperatur fehlt?
                                    P
                                    P
                                    Pittini
                                    #161
                                    Nein kann nicht sein.
                                    Mein Skript spiegelt das was da ist. Und da es diesen Punkt im HC Adapter nicht gibt, wird er vom Skript auch nicht erstellt.
                                    Weiterhin gab es zu dem Thema bereits in Issue von mir hier wonach es in der readme erklärt wurde.
                                    Zum dritten hilft lesen, in der readme steht:
                                    Inked2020-03-29 11_20_48-rg-engineering_ioBroker.heatingcontrol_ heating control incl. simple actor handl_LI.jpg
                                    • R
                                      R
                                      rotamint
                                      #162
                                      Guten Abend zusammen,
                                      ich komme nicht wirklich weiter und Bitte um Hilfe. Das Script liefert mir folgende Fehlermeldung:
                                      Wer kann mir bitte weiter helfen?
                                      In der VIS sieht es folgendermassen aus:
                                      Ich bin der Meinung korrekt nach Anleitung vorgegangen zu sein. Den so oft genannten "Material Design Adapter" konnte ich bei mir nicht installiert finden:
                                      Danke für Eure Unterstützung!
                                      Gruß Stefan.
                                      • R rotamint
                                        Gruß Stefan.
                                        P
                                        P
                                        Pittini
                                        #163
                                        @rotamint sagte in [Vorlage] Vis für Adapter HeatingControl:
                                        An Deinem ersten Screenshot sehe ich das da was falsch gelaufen ist beim kopieren des Skriptes. Deswegen machst das jetzt anders (werd auch die Anleitung entsprechend ändern). Du klickst im Browserfenster auf die Skriptdatei (Endung .js). Dann wird das Skript angezeigt, drüber rechts gibts nen Button "Raw", da klickste drauf. Jetzt haste das Skript blanko im Browser. Mit Strg A alles markieren, dann mit Strg C in die Zwischenablagen kopieren und dann im iobroker Skriptfenster mit Strg V einfügen. Dann sollte das auch klappen.
                                        R 1 Antwort Letzte Antwort
                                        • P Pittini
                                          R
                                          R
                                          rotamint
                                          #164
                                          @Pittini Vielen Dank für Deine schnelle Hilfe. Jetzt bin ich ein ganzes Stück weiter! Ich Danke Dir sehr!
                                          Der Fehler im zweiten Bild, und dass sich beim Klick auf das Zahnrad folgendes Bild öffnet:
                                          Soll das in diesem link zum Post beschrieben werden, oder hast Du auch hierfür für mich eine schnelle und unkomplizierte Lösung?
                                          Vielen Dank. Gruß Stefan.
                                          84.0k
