  4. Anzeige Status Docker Container
dockervisjavascript
44 Beiträge 5 Kommentatoren 7.5k Aufrufe 8 Beobachtet
  • GlasfaserG Glasfaser
    @RK62
    Gefällt mir die Idee , das fehlte mir noch bei meinen anderen Infos zu der Synology 👍
    Es mußte ein Ordner "tmp" in 0_userdata.0 erstellt werden mit den Rechten 0777 , sonst kommt "No such file or directory" bzw. es wurde nichts unter 0_userdata.0 geschrieben .
    Kann du es noch in Json umwandelt !?
    Hier mein Vis:
    @Negalein etwas für dich ;)
    EDIT : Widget eingefügt
    [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.Synology.Dockerzustand.DockerInfo.HTML1}","class":"mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe"},"style":{"left":"590px","top":"28px","width":"478px","height":"279px","z-index":"100","background":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","color":"#d7cec1","font-family":"Jura-DemiBold","font-size":"medium"},"widgetSet":"basic"}]
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @Glasfaser sagte in Anzeige Status Docker Container:
    etwas für dich
    Wie hast du die Farbe (aktiv/inaktiv) eingestellt?
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      etwas für dich
      GlasfaserG Offline
      GlasfaserG Offline
      @Negalein
      mit dem CSS von Ihm !
        @Negalein
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        hab ich komplett vergessen! :)
        Funktioniert perfekt
          GlasfaserG Offline
          GlasfaserG Offline
          @Negalein
          Kürzen kannst du hiermit , wenn du Image am Ende nicht haben möchtest .
          Die zwei Daten reichen mir .
            @Negalein
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            guter Tipp.
            Muss mir für die System-View irgend ein anderes Konzept überlegen.
            Der Platz wird schon sehr eng. ;)
              guter Tipp.
              GlasfaserG Offline
              GlasfaserG Offline
              @Negalein
              Die Schriftgröße vom Widget mußt du noch ändern ... oder täuscht das .
              Deshalb meine Frage an @RK62 ob er es in JSON Format noch zusätzlich ändern kann , da hat man mehr möglichkeiten .
              NegaleinN RK62R 2 Antworten Letzte Antwort
                @Negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Ja, das mach ich ganz am Schluß.
                Mir gefällt die Aufteilung noch nicht.
                Und jedesmal wenn ich die Schriftgröße zB auf small geändert habe, beim Widget dann noch die Größe angepasst habe, sah es so aus.
                Obwohl bei 250x107 rechts noch viel Platz ist, verschiebt sich alles, sobald ich nur um 1px runtergehe.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Negalein
                  Ja das liegt am html .
                  Du kannst hiermit noch spielen .
                  Bereich von 0.9 - 0.1 oder 1 - 3
                  Bei mir passt es damit :
                    @Negalein
                    RK62R Offline
                    RK62R Offline
                    RK62
                    @Glasfaser Mit JSON konnte ich mich noch nicht so richtig anfreunden bei der Visualsierung.
                    Bitte mal testen, vielleicht kannst Du dann die Formatierung für JSON hier ergänzen.
                    1. Script für SYNOLOGY-Aufgabenplaner (JSON)
                    docker container ls --all --format='{{json .}},' >/volume1/docker/prod/iobroker/iobroker-data/files/0_userdata.0/tmp/dockerinfo.json
                    2. Javascript im iobroker erstellen (JSON)
                    Formatierung ist nicht schön gelöst, aber ich kann's nicht besser ;-)
                        Docker Status auslesen
                    // Konstanten / Vorbelegung
                    const js  = 'javascript.0.Synology';
                    const fn  = 'iobroker-data/files/0_userdata.0/tmp';
                    const fs  = require('fs');
                    // Docker-Info's
                    createState(js+'.DockerInfo.JSON',    { name: 'JSON-Ausgabe', role: 'value',  type: 'string'});
                        Function: Docker-Liste lesen & verarbeiten
                    function GetDockerInfoJSON() {
                        fs.readFile (fn+'/dockerinfo.json', 'utf8',  function(error, data) {
                            if(error) var ausgabe = 'Fehler beim Lesen!';
                            else ausgabe = '['+data.substr(0,data.lastIndexOf(","))+']';
                            setState(js+'.DockerInfo.JSON',ausgabe);
                    GetDockerInfoJSON();
                    schedule('* * * * *', GetDockerInfoJSON);                    // Jede Minute abrufen
                    Gruß, Ralf
                    GlasfaserG 3 Antworten Letzte Antwort
                    • RK62R RK62
                      // Docker-Info's
                      Gruß, Ralf
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @RK62
                      Leider funktioniert es nicht mehr !
                      Habe nichts weiter gemacht ,da ich jetzt ein "Fehler beim Lesen!" bekomme .
                      Die Text Datei wird auch schön geschrieben, habe auch den Speicherort im Aufgabeplaner / Script geändert auch dort das gleiche .
                      Finde einfach den Fehler nicht .
                      • RK62R RK62
                        // Docker-Info's
                        Gruß, Ralf
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @RK62
                        Fehler gefungen ,obwohl es gestern ging 🤔
                        Mußte den Pfad von dir :
                        auf ... ändern bzw. erweitern um /opt/iobroker/
                        /opt/iobroker/iobroker-data/files/0_userdata.0/tmp
                        • RK62R RK62
                          // Docker-Info's
                          Gruß, Ralf
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @RK62
                          Kannst du es auch zum Status aulesen für die Synology VMM anbieten !?
                          RK62R 1 Antwort Letzte Antwort
                            @RK62
                            RK62R Offline
                            RK62R Offline
                            RK62
                            @Glasfaser Nee, habe ich nicht im Einsatz. Das Gerüst sollte aber nutzbar sein wenn es möglich ist die Informationen via Befehlszeile / bash auszulesen.
                            • RK62R RK62
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @RK62
                              Dann wäre die Frage wo ,
                              habe schon alle Haupt-Unterverzeichnisse durch und auch mit cat .... die Dateien anzeigen lassen , aber noch nichts gefunden .
                              • RK62R Offline
                                RK62R Offline
                                RK62
                                Die Datei wird es so noch nicht geben.
                                Bei DOCKER ermittle ich den Status auch über das "docker" Kommando von der Befehlszeile aus.
                                  darkiop
                                  Hallo zusammen, ich bin die Tage hierrüber gestolpert (habs aber noch nicht eingebunden): https://www.youtube.com/watch?v=jhyPFQ6Fkpk
                                  Vielleicht auf für euch Interessant.
                                  Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                    darkiop
                                    Ihr könnt auch direkt über den docker Befehl ein JSON ausgeben lassen:
                                    docker container ls --all --format "{{json .Names}};{{json .Image}};{{json .Status}}"
                                    • D darkiop
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @darkiop
                                      Danke für den weiteren Tip.
                                      Synology VMM wäre interessant , hast du da eine Idee !?
                                      Das Youtube stammt von dieser Entwicklung in diesem Thread Link Text.
                                      Habe ich schon Jahre laufen .....funktioniert sehr gut , da der Adapter Synology meine Zugang immer wieder sperrt Link Text oder Link Text , habe ich den Adapter aus und nutze dieses Skript .
                                        @darkiop
                                        darkiop
                                        @Glasfaser Eigentlich könnte man ein generisches Skript mit den wichtigsten Werten zusammenstricken und diese per Simple API an den ioBroker schicken - ausführen dann auf dem jeweiligen Host per crontab.
                                        • D darkiop
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @darkiop
                                          Das ist doch schon so .. und mit Simple API ... was meinst du denn .
