  4. Test Adapter ioBroker.backitup v3.1.x
    6.6k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • P PatrickFro
    Und obwohl da "none" steht:
    simatecS Offline
    simatecS Offline
    simatec
    #428
    @PatrickFro
    Was gibt der Datenpunkt "backitup.0.output.line" aus?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    P 1 Antwort Letzte Antwort
    • simatecS simatec
      @PatrickFro
      PatrickFro
      #429
      @simatec
      [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Iobroker-Backup","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"iobroker-data"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"googledrive","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"googledrive","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"3","systemLang":"de","time":"11. Maerz 2020 um 13:11 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      • P PatrickFro
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #430
        @PatrickFro OK ... history wird nicht beendet ...
        Diese Problem hatten bereits 1-2 User gehabt. Hier schein irgendwas nicht sauber kompiliert zu sein und bei irgendeinem Update ein Problem aufgetreten zu sein.
        Abhilfe kannst du wie folgt schaffen:
        • Instanz von backitup.0 löschen
        • Adapter backitup löschen
        • wenn vorhanden den Ordner backitup.0 in den Objekten löschen
        • iobroker stoppen
        • Installer Fix laufen lassen
        • iobroker starten
        • backitup installieren und konfigurieren
        P 2 Antworten Letzte Antwort
        • simatecS simatec
          • iobroker stoppen
          • iobroker starten
          PatrickFro
          #431
          @simatec Vielen Dank, teste ich morgen. Stimmt dann ggf. auch meine Tabelle in VIS? Oder wie kann ich die Tabelle passend zu den Überschriften abfragen? So viel hab ich noch nicht mit JSON gemacht...
          • simatecS simatec
            • iobroker stoppen
            • iobroker starten
            PatrickFro
            #432
            @simatec Bei dem ersten Durchlauf kam auch ein Fehler:
            Gestartet...
            [DEBUG] [iobroker] - host.raspberrypi 15396 states saved
            [DEBUG] [iobroker] - host.raspberrypi 13306 objects saved
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_11-15_32_04_backupiobroker.tar.gz
            [DEBUG] [iobroker] - done
            [ERROR] [historyDB] - [IGNORED] No source for compress!
            [DEBUG] [googledrive] - done
            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
            [DEBUG] [clean] - done
            [DEBUG] [history] - backitup.0.history.html
            [DEBUG] [history] - backitup.0.history.json
            [EXIT] 0
            Allerdings (noch ohne GoogleDrive:
            Mit GoogleDrive:
            Gestartet...
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_11-15_44_05_backupiobroker.tar.gz
            [DEBUG] [googledrive] - Copy iobroker_2020_03_11-15_44_05_backupiobroker.tar.gz...
            [ERROR] [googledrive] - File "/opt/iobroker/backups/historyDB_2020_03_11-15_44_57_backupiobroker.tar.gz" not found
            [EXIT] 0```
            code_text
            Bedeutet doch, dass nur die History-DB den aktuellen Fehler ausgelöst hat, richtig?
            • P PatrickFro
              Gestartet...
              [EXIT] 0
              Mit GoogleDrive:
              Gestartet...
              [EXIT] 0```
              code_text
              simatecS Offline
              simatecS Offline
              simatec
              #433
              @PatrickFro history und history DB ist etwas anders.
              Wenn du keinen history Adapter nutzt, schalte das history Backup ab.
              History hat den Fehler nicht verursacht, sondern irgend ein Fehler unter node
              • P Offline
                PatrickFro
                #434
                Vielen Dank. Hab heute schon 15 Backups gemacht da ich mich freue, dass es klappt ;-)
                  tazdevil20
                  schrieb am zuletzt editiert von tazdevil20
                  #435
                  ich hatte gestern ein seltsames Problem. Scheinbar gab es einen Stromausfall und danach waren sehr viele States nicht mehr gefüllt und ich musste einiges an Konfiguration nachziehen. An Backupitup habe ich in dem Moment natürlich nicht gedacht. In dem Backup habe ich jetzt im Nachgang aber auch keine states.json gefunden. Ist das richtig so, habe ich ein Problem, oder sehe ich die Datei einfach nicht im Backup?
                  Habe die Version 1.4.1 im Einsatz.
                  • G Offline
                    Gerni
                    #436
                    Ich spiele gerade mit dem Gedanken von einem Nuc zu einer Synology (1019+) zu ziehen und habe bereits entsprechende Docker Umgebung laufen inkl. ioBroker. Nun würde ich gern per Backitup auf den Docker Container ziehen. Ein Container hat kein SSH also kein WinSCP, kein Putty.
                    ioBroker NUC: Backup mit Backitup erstellt, an Dropbox übergeben
                    ioBrocker Docker: neu installiert, Backitup Adapter installiert, Dropbox verbunden. Findet auch das Backup vom NUC aber installiert es nicht. Also opt/iobroker ausgelagert und gemountet, dort in den Backups Ordner das Backup per Filestation hochgeladen.
                    Backitup findet das Archiv, installiert auch iwas bzw. rödelt vor sich hin. Ergebnis ist dann wieder eine leere Installation. Bleibt dann hier hängen bzw. geht nicht darüber hinaus. Manchmal öffnet sich auch ein neuer BrowserTab mit :8091. Dieser Seite hat dann keinen Inhalt.
                    Woran kann es liegen?
                    Oder kennt sich sonst jemand auch mit Docker aus? Vielleicht ist da die Lösung zu suchen
                    Schon mal Danke.
                    Jede Menge verschiedenes Zeug
                    • G Gerni
                      Schon mal Danke.
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #437
                      @Gerni
                      Da sollten die Docker Experten etwas zu sagen.
                      Grundsätzlich halte ich es aber für die sicherste Restore Methode, das Backup lokal abzulegen, und dann daraus den restore auszuführen.
                      • E Offline
                        extbingh
                        schrieb am zuletzt editiert von Jey Cee
                        #438
                        Guten Tag,
                        der automatische Backup funktioniert bei mir über das integrierte NAS der FRITZ!Box, das Ganze ist nur 1,9mb groß, dauert dementsprechend auch nicht lange. Version 1.4.1
                        Jedoch bekomme ich keine Benachrichtigung per Telegram oder E-Mail. (Telegram funktioniert z.B über CPU Temperatur Warnung) Der Adapter ist auch die ganze Zeit am "laden" obwohl gar nichts mehr geschrieben wird. Also da steht oben "Backitup-Ausführung" und die ganze Zeit (über 10 Minuten etc.) lädt da der Ladebalken, es passiert aber nichts und das Backup ist schon längst fertig (braucht keine 30 Sekunden) Also es beendet sich nicht von alleine obwohl "Schließen wenn fertig" markiert ist, somit kommt wohl anscheinend auch keine Benachrichtigung.
                        Log:
                        [DEBUG] [mount] start with
                        {"mountType":"CIFS","type":"storage","source":"local","mount":"XXX","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XXX","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"fritz.nas/USBStick/ioBrokerBackup","dirMinimal":"sharename/backupDir","user":"ioBrokerBackup","pass":"****"}
                        [DEBUG] [mount] - done
                        [DEBUG] [iobroker] start with {"type":"creator","time":"06:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":
                        Langer Text mit Daten (da steht die macAD usw. deswegen keine copy)
                        [DEBUG] [iobroker] - host.raspberrypi-iob 2125 states saved
                        [DEBUG] [iobroker] - host.raspberrypi-iob 2529 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_03_19-16_10_07_backupiobroker.tar.gz
                        [DEBUG] [mysql] - done
                        [DEBUG] [mysql] - MySql File deleted!
                        [DEBUG] [historyDB] - done
                        /edit:
                        "Zigbee Datenbank sichern" deaktivieren, dann gehts... ^^ Redis ebenso (gibt ne Fehlermeldung, aber Benachrichtigung geht und Fenster schließt sich) History, MYSQL (Datenbank vorhanden) und IoBroker/NAS an.
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #439
                          Ab sofort ist die Version 1.4.3 im Github und ab spätestens heute Nacht auch in der latest und stable Repo.
                          Changelog
                          1.4.3 (21.03.2020)
                          • (simatec) Fix for autochecker
                          • (simatec) Fix start after restore
                          • (simatec) update dependencies
                          • simatecS simatec
                            Changelog
                            1.4.3 (21.03.2020)
                            skokarl
                            schrieb am zuletzt editiert von skokarl
                            #440
                            @simatec
                            Guten Morgen, ich hab vorhin IOBroker neu installiert und ein Restore gestartet.
                            Sieht so schlecht nicht bei mir aus, aber perfekt auch noch nicht.
                            Ich weiß nicht ob es an mir oder am Adapter liegt. Daher bitte die Frage ohne Wertung.
                            IOT wird nicht grün
                            iot.0	2020-03-22 04:16:02.829	error	(4016) Cannot read keys: "error:0909006C:PEM routines:get_name:no start line" / Error: error:0909006C:PEM routines:get_name:no start line
                            Shelly meckert
                            shelly.0	2020-03-22 04:19:33.328	error	(3630) Wrong http username or http password! Please enter the user credential from restricted login for 192.168.178.67 (shelly1 / sh ......
                            Kann sein dass das alles normal ist, frage ja nur mal. 😬
                            Ich dachte Zugangsdaten etc. werden immer mit gesichert.
                            • S skokarl
                              @simatec
                              IOT wird nicht grün
                              Shelly meckert
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #441
                              @skokarl
                              Das ist zu Adapter spezifisch. Bitte frage da bei den jeweiligen Entwicklern nach
                              • O Offline
                                O Offline
                                Oli
                                #442
                                wo finde ich in einer gespeicherten Backup Datei die Javascripte?
                                Oliver
                                • O Oli
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #443
                                  @Oli in der backup.json
                                  O 1 Antwort Letzte Antwort
                                  • simatecS simatec
                                    O Offline
                                    O Offline
                                    Oli
                                    #444
                                    @simatec
                                    Vielen Dank, habe es gefunden
                                    Oliver
                                      Dreamdancer
                                      #445
                                      Hallo allerseits,
                                      ich habe gerade einmal alle Updates gefahren, auch das des Adapters Backitup nun in der Version 1.4.5.
                                      Alles gut verlaufen, gibt kein Minimal bzw. Total Backup mehr ... nur noch (in meinem Fall) ioBroker und mysql.
                                      Wenn ich aber nun das Tarball öffne, liegen dort lediglich die VIS Projekte unter "files".
                                      Userdata, admin und web Adapter haben Ordner, sind aber leer, kein anderer Adapter hat auch nur bloss einen Ordner dort.
                                      Insbesondere bitter wäre das bei den Scripten, würden diese verloren gehen.
                                      Mache ich was falsch, muss man die Adapter einstellen, oder ist das ein Fehler?
                                      • D Dreamdancer
                                        Hallo allerseits,
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #446
                                        @Dreamdancer sagte in Test Adapter Backitup v1.4.x:
                                        Nein alles OK ....
                                        Du brauchst nur ... den Anfang vom Thread lesen , dort ist es dann mehrfach in den einzelnen Anfragen ...erklärt .
                                        TIP :
                                        Du kannst auch die Suche innerhalb des Thread´s aktivieren , wenn du mal was bestimmtes suchst !
                                        • simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #447
                                          Ab sofort steht das Release 1.5.0 zur Verfügung und sollte im Laufe des Tages im Latest auftauchen.
                                          Changelog
                                          1.5.0 (21.04.2020)
                                          • (simatec) revised error handling
                                          • (simatec) revised mount process
                                          • (simatec) revised umount process
                                          • (simatec) added log for last backup file
                                          • (simatec) updated dependencies
                                          • (simatec) added sentry.io support
