  2. English
  3. ioBroker general
  4. get zigbee data automatically
    2.1k
    1.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
simple api adapterzigbee cc2531 cc2530rpi raspi 4xiaomi zigbee
11 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • erfan shaiganiE Offline
    erfan shaigani
    hi everyone , I have a zigbee xiaomi tempreture sensor , I can manually get data by IOBROKER SIMPLE API by "get": "http://ipaddress:8087/get/stateID/?prettyPrint",
    in a json formatted file , but as I said it is manually !!
    I want to receive data automatically whenever the tempreture changes
    i have a rpi4 , and sqlite database on it
    thanks in advance
    • erfan shaiganiE erfan shaigani
      thanks in advance
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @erfan-shaigani more details please. What zigbee gateway do you use?
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      erfan shaiganiE 1 Antwort Letzte Antwort
      • Jey CeeJ Jey Cee
        erfan shaigani
        @Jey-Cee i use a raspberry pi as my gateway
        • mickymM Offline
          mickymM Offline
          mickym
          I don't see the problem.
          When the value changes, you will get a trigger in your favorite logic machine and do what you want. ;) - So you can create json strings, files or do start any other action.
          I use Node-Red as logic machine - but you can use Javascript / Blockly as well.
            @erfan-shaigani sagte:
            Which Zigbee modem ?
            • mickymM mickym
              erfan shaigani
              @mickym
              thnaks a lot , can you explain more ? I am not familliar enough with logic machine.
              or if u are ok , i can give u my email or whatsapp id
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @erfan-shaigani
                A logic machine - is for example your JavaScript Adapter and you can use Blockly.
                I am not so familiar with Blockly. I prefer the Node-RED adapter.
                You have an iobroker node - where you can select den data - point where the your zigbee Adapter stores the temperature of your sensor.
                I have also the xiaomi sensor as well - and if you look to the screen shot. If the value changes - a message will be automatically created and you can do with this value - what you want. I just display it on the node-RED dashboard, but you can format a json-string as well and send it whereever you want.
                • mickymM mickym
                  @erfan-shaigani
                  erfan shaigani
                  @mickym thanks a lot !!! "You have an iobroker node" you said ,
                  how can I find this node ? I mean how did you connect iobroker to this node in youe node red ?
                  in your picture I can see Node "93a14......"
                  where does it come form
                  again thanks a lot for your help
                  • mickymM Offline
                    mickymM Offline
                    mickym
                    Have you installed the node-red Adapter in iobroker?
                    • mickymM mickym
                      erfan shaigani
                      @mickym hello again , yes I installed it ,
                      now what should I do ?
                      my final goal is to send the data to an external server whenever the data changes
                      or at least I want to be notified about the changes in the data to send a query and save the data on my rpi
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @erfan-shaigani
                        I can not write a Node-Red tutorial here - but there are a lot of videos.
                        I can recommend this site - to get familiar with Node-RED this page: http://www.steves-internet-guide.com/node-red-overview/
                        and his starter video: https://www.youtube.com/watch?v=y05vQUIMIxs&feature=youtu.be
                        instead of the mqtt-in node - you can use the "iobroker in" node.
                        So if you have open your node red - drag an "iobroker in" node into the flow area. Configure this node by opening this node - and select your datapoint of your temperature sensor - as you can see in my screen-shot.
                        Then wire for the first time a debug node to the "iobroker in" node and have the debug window open in node-red.
                        Everytime your temperature will change generates a new message, which you can see in the debug window.
                        With this message - containing the temperature you can do what you want. Create your json string, you can use to put it in an other data object, write to a file, a database, put in an http-request and even use the simple api.
                        83.1k
