  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.5k Aufrufe 59 Beobachtet
  • maximal1981M Offline
    maximal1981
    #370
    irgendwie verliert der Adapter öfters die Verbindung zur Cloud. Ich habe leider keine Ahnung wo ich mit der Fehler suche beginnen soll. Kann mir jemand helfen, um die Ursache zu finden?
    tado.0	2020-02-15 00:25:36.516	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
    tado.0	2020-02-15 00:25:12.132	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
    tado.0	2020-02-15 00:23:21.306	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
    tado.0	2020-02-15 00:22:51.968	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
    tado.0	2020-02-15 00:22:28.348	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
    tado.0	2020-02-15 00:22:00.678	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
    tado.0	2020-02-15 00:21:34.694	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
    tado.0	2020-02-15 00:21:08.306	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
    tado.0	2020-02-15 00:20:42.941	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
    tado.0	2020-02-15 00:20:15.455	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
    tado.0	2020-02-15 00:18:28.913	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
    tado.0	2020-02-15 00:18:03.353	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
    tado.0	2020-02-15 00:17:38.525	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
    tado.0	2020-02-15 00:17:12.247	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
    tado.0	2020-02-15 00:16:48.088	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
    tado.0	2020-02-15 00:16:22.085	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
    tado.0	2020-02-15 00:15:55.992	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
    tado.0	2020-02-15 00:15:29.743	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
    tado.0	2020-02-15 00:13:43.238	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
    tado.0	2020-02-15 00:13:17.206	info	(783) state tado.0.122768.Rooms.8.setting.power deleted
    tado.0	2020-02-15 00:12:52.895	info	(783) state tado.0.122768.Rooms.7.setting.power deleted
    tado.0	2020-02-15 00:12:25.584	info	(783) state tado.0.122768.Rooms.10.setting.power deleted
    tado.0	2020-02-15 00:12:03.103	info	(783) Initialisation finished, connected to Tado Cloud service refreshing every : 30 seconds
    tado.0	2020-02-15 00:11:58.006	info	(783) state tado.0.122768.Rooms.6.setting.power deleted
    tado.0	2020-02-15 00:11:31.787	info	(783) state tado.0.122768.Rooms.4.setting.power deleted
    tado.0	2020-02-15 00:11:04.630	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
    tado.0	2020-02-15 00:10:39.095	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
    tado.0	2020-02-15 00:07:35.058	info	(783) Connected to Tado cloud, initialyzing ...
    tado.0	2020-02-15 00:07:23.961	info	(783) state tado.0.122768.Rooms.3.setting.power deleted
    tado.0	2020-02-15 00:06:54.482	error	(783) Disconnected from Tado cloud service ..., retry in 30 seconds !
    tado.0	2020-02-15 00:06:38.791	info	(783) state tado.0.122768.Rooms.2.setting.power deleted
    tado.0	2020-02-15 00:06:04.448	error	(783) Issue in Get all rooms Error: getaddrinfo EAI_AGAIN my.tado.com my.tado.com:443
    tado.0	2020-02-15 00:03:48.115	info	(783) state tado.0.122768.Rooms.11.setting.power deleted
    • Thomas JansenT Offline
      Thomas Jansen
      #371
      Also auch auf die Gefahr hin, das Ihr mich köpft, ist es jetzt möglich (Aus, Auto, Manuell Betrieb) irgendwo in den Datenpunkten mit 1,2,3 einzustellen?
      LG
      Schöne Nacht Euch ;)
      Thomas JansenT 1 Antwort Letzte Antwort
      • Thomas JansenT Thomas Jansen
        LG
        Thomas Jansen
        #372
        @Thomas-Jansen sagte in Test Adaper Tado v0.1.x:
        LG
        Habe das Problem, das der HAM Adapter nach Update node, nodejs das tado plugin nicht mehr ohne fehler zulässt... :(
          LG
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #373
          das hat nix mit diesem adapter zu tun bitte nicht Themen vermischen !
          @maximal1981 sagte in Test Adaper Tado v0.1.x:
          Das kann viele. gründe. haben, schlechte. internet Verbindung/tado überlastet usw.
          du könntest das polling mal erhöhen das er wenig oft die. cloud abfragt.
          • DutchmanD Dutchman
            Thomas Jansen
            #374
            @Dutchman sorry, habe gestern abend echt was verwechselt. Also ich habe bisher den HAM Adapter mit dem homebridge tado plugin benutzt. Das funktioniert aber nicht mehr da nach dem Update npm etc dieses Plugin wohl nicht mehr unterstützt wird. Er spuck auf jedenfall jede menge Fehler aus. Egal, anderes Problem..... Ich hatte jedoch in meiner VIS alles auf HAM ausgelegt. Jetzt möchte ich aber komplett auf diesen Adapter wechseln. Deshalb noch mal etwas klarer die Frage ;) ob in den Datenpunkten des Adapters (läuft übrigens bei mir sehr gut) AUS,AUTO,Manuell eingestellt werden können mit 1,2,3 oder so?
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              schrieb am zuletzt editiert von Dutchman
              #375
              Alles gut, hatte Frage Dan falsch verstanden ;)
              BIn gerade unterwegs müsste ich selber erst schauen 🙈
                Thomas Jansen
                #376
                @Dutchman 👍 😊 wäre echt cool.... 4 Monate IOBROKER meine NERVEN hihihihih bis später... LG
                  senger1985
                  #377
                  @Thomas-Jansen
                  "Aus" kannst du die Thermostate, über den Datenpunkt "Power", "Auto" ist ja, wenn man "clearZoneOverlay" ausführt und "Manuell" stellt er ja automatisch ein, sobald man die Temperatur ändert.
                  Oder verstehe ich dich gerade falsch?
                  • J Offline
                    Jogi19
                    #378
                    Ich bekomme keine Werte mehr im Bereich openWindow.
                    Im LOG kommt folgende Fehlermeldung:
                    881) Send this info to developer !!! { Unhandable information found in DoReadDevices : "openWindowDetected" with value : true
                    Hier noch ein Bild:
                    Der Bereich openWindow ist bei mir auch nicht bei allen Zimmern vorhanden.
                    Ich habe den Eindruck als ob das erst seit den letzten Änderungen von Tado in der IOS APP 5.9.4 (9255) so ist
                    • J Jogi19
                      Hier noch ein Bild:
                      senger1985
                      #379
                      @Jogi19 ich kann den Fehler bei mir nicht reproduzieren.
                      Welche Adapter-Version hast du drauf?
                      • S senger1985
                        Jogi19
                        #380
                        @senger1985 Ich habe die Version 0.1.6
                        Wie gesagt, wenn ich das Fenster öffne bekomme ich in der App von Tado angezeigt, dass das Fenster offen ist, aber im ioBroker bleibt alles leer. Müssten nicht bei openWindow dann irgendwelche Werte stehen.
                        S DutchmanD 2 Antworten Letzte Antwort
                        • J Jogi19
                          senger1985
                          schrieb am zuletzt editiert von senger1985
                          #381
                          @Jogi19 jup, die dürften, unter "openWindow", eigentlich nicht leer bleiben.
                          Würdest du so nett sein und hier:
                          https://github.com/iobroker-community-adapters/ioBroker.tado/issues
                          ein Issue erstellen, damit Dutchman Bescheid weiß.
                          • J Jogi19
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #382
                            @Jogi19 sagte in Test Adaper Tado v0.1.x:
                            hmm ... installiere mal bitte von git ich habe extra loggin eingebaut.
                            wen der Fehler auftritt sollte ein state "test_data" erstellt. werden mit einen JSON. string da drin.
                            Den brauche ich mal :)
                            • C Offline
                              Coffeelover
                              #383
                              Hallo @Dutchman
                              ich habe in der Tado-App gerade die Meldung bekommen, dass ich ab jetzt händisch die Modi Home/Away wechseln kann. Kannst du mal sehen, ob dieser "Schalter" auch über die API verfügbar geworden ist?
                              Vielen Dank
                                Jogi19
                                #384
                                @Dutchman Ich habe mal probiert den Adapter über Github neu zu installieren. Habe über ioBroker "über eigene Url installieren" ausgewählt kann aber keine Veränderung erkennen.
                                Nach wie vor bekomme ich im Log diese Meldung:
                                2931) Send this info to developer !!! { Unhandable information found in DoZoneState : "openWindowDetected" with value : true
                                aber ich kann kein state "test_data" finden.
                                Habe ich bei der Installation was falsch gemacht?
                                • J Jogi19
                                  DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #385
                                  1. Send this info to developer !!! { Unhandable information found in DoZoneState : "openWindowDetected" with value : true
                                  das ist was ich brauchte danke :)
                                  fix kommt morgen
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #386
                                    @Jogi19 bitte. 0.1.7 probieren
                                    • S senger1985
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #387
                                      @senger1985 sagte in Test Adaper Tado v0.1.x:
                                      hast du 0.1.7 probiert ?!
                                        K_o_bold
                                        #388
                                        Habt ihr auch Probleme mit dem Tado Server?
                                        • C Offline
                                          cactus-online
                                          #389
                                          Ja, sowohl App als auch Web.
