  4. Vorstellung meiner VIS-Oberfläche
    2.8k
    4.9k
    4.1k
51 Beiträge 14 Kommentatoren 12.2k Aufrufe 28 Beobachtet
  • S saeft_2003
    @Negalein
    Gefällt mir auch gut. Wie bekommst du den Rahmen von dem popup dialog fenster dunkel hin? Bei mir ist der immer weis. Kannst du mir evtl das widget mal exportieren?
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @saeft_2003 sagte in Vorstellung meiner VIS-Oberfläche:
    Danke dir!
    Der dunkle Rahmen kommt mWn vom eingestelltem Thema.
    Bei mir ist es dot-luv
    [{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/Akkuleer.png","class":"","contains_view":"091_Batterien_Tabelle","modal":true,"dialog_width":"720","dialog_height":"560","dialog_top":"100","dialog_left":"240","overflowX":"hidden","overflowY":"hidden","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"484px","top":"11px","width":"36px","height":"23px","z-index":"2"},"widgetSet":"jqui"}]
    ° Fixer ---> iob fix
    S 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      Danke dir!
      saeft_2003
      @Negalein
      Und genau das mit dem thema will bei mir nicht funktionieren. Welche vis version hast du?
      • S saeft_2003
        @Negalein
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        1.2.4
          1.2.4
          saeft_2003
          @Negalein
          1.2.3 das wird der Grund sein, hat auch schon ein anderer user gesagt.
          Das Problem ist das selbst wenn ich auf latest umstelle nicht die 1.2.4 angeboten bekomme. Evtl muss ich die manuell über die Konsole installieren...
            Danke dir!
            saeft_2003
            schrieb am zuletzt editiert von saeft_2003
            @Negalein sagte in Vorstellung meiner VIS-Oberfläche:
            Danke dir!
            Schei*** wars. Ich hab jetzt die 1.2.4 installiert. Dein widget verwendet und das Thema eingestellt. Dabei ändert sich die Farbe vom Button aber nicht vom dialog der sich öffnet.
            Hast du noch eine Idee?
            NegaleinN GlasfaserG 3 Antworten Letzte Antwort
            • S saeft_2003
              Danke dir!
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              Leider nicht.
              • S saeft_2003
                Danke dir!
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                hab das gerade gefunden.
                Probiers mal aus.
                • S saeft_2003
                  Danke dir!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @saeft_2003
                  Alle VIS Seiten von dir müssen auf das Thema umgestellt werden , erst dann funktioniert es mit dem PopUp Fenster !!
                  • GlasfaserG Glasfaser
                    @saeft_2003
                    saeft_2003
                    @Glasfaser
                    Ok werde ich nachher probieren. Schonmal danke 😊
                    • S saeft_2003
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @saeft_2003
                      Das Thema hatte ich erst letztens .... es liegt nur an dem Popup Widget ... wiso warum 🤔 !?
                      Link Text
                        @saeft_2003
                        saeft_2003
                        @Glasfaser sagte in Vorstellung meiner VIS-Oberfläche:
                        @saeft_2003
                        Danke 😊 das war die Lösung 👍
                        Was jetzt nur doof ist wenn ich schauen will welches Thema mir am besten gefällt muss ich jedes mal alle views umstellen?!
                        • S saeft_2003
                          @saeft_2003
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @saeft_2003
                          Hier mit "dark-hive" ... da tut sich nicht viel ....
                          ( In Spoiler gesetz ... damit der Thread klein bleibt ;) )
                          • C Offline
                            Conquest
                            @Negalein
                            Sehr schöne VIS. Würdest du einen Export bereitstellen? Kann ich mir bestimmt wieder einiges abschauen 😊
                            • C Conquest
                              @Negalein
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @Conquest sagte in Vorstellung meiner VIS-Oberfläche:
                              Willst du alles oder nur bestimmte Seiten?
                              C 1 Antwort Letzte Antwort
                                Conquest
                                Wenn der Export funktioniert würde ich alles nehmen 👍
                                Danke.
                                S NegaleinN 2 Antworten Letzte Antwort
                                • C Conquest
                                  Danke.
                                  saeft_2003
                                  Danke.
                                  Würde mich interessieren ob bei dir der export von deiner ganzen VIS geht? Weil wenn ich das in verschiedenen Browser anklicke passiert erstmal nichts und kurz danach crashen alle Adapter...
                                  https://forum.iobroker.net/topic/30404/projektexport-funktioniert-nicht-instanzen-crashen
                                  • C Conquest
                                    Danke.
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    gerade versucht.
                                    Funktioniert leider nicht. weder normal, noch anonymisiert.
                                    Adapter crashen bei mir nicht. Aber Export funktioniert nicht. Egal welcher Browser.
                                      gerade versucht.
                                      Conquest
                                      @Negalein
                                      Firefox hat bis jetzt eigentlich immer funktioniert. Dauert nur ewig bis der Download startet.
                                      Schade.
                                      • C Conquest
                                        @Negalein
                                        Schade.
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        Ich versuchs jetzt mal auf einer anderen Maschine.
                                        Wenns wieder nicht klappt, stell ich die Exporte der Views rein.
                                        • NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          @Conquest
                                          Ich hab im 1. Beitrag einiges ergänzt.
                                          Probier mal bitte aus
