  4. Vorstellung meiner VIS-Oberfläche
    2.8k
    4.9k
    4.1k
51 Beiträge 14 Kommentatoren 12.2k Aufrufe 28 Beobachtet
  • O Oli
    @Negalein
    Sehr schöne Vis, wie hast du das mit den Koordinaten der Tankstellen gemacht?
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @Oli sagte in Vorstellung meiner VIS-Oberfläche:
    Die Koordinaten kommen aus dem Script für E-Control (Österreich)
    ° Fixer ---> iob fix
    O 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      O Offline
      O Offline
      Oli
      @Negalein
      danken, werde ich mir mal ansehen, welches Widget verwendest du für Volumeanzeige?
      Oliver
      • O Oli
        @Negalein
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        hqwidgets - circleknob
        [{"tpl":"tplHqCircle","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"alexa2.0.Echo-Devices.G090QU067444121X.Player.volume","displayPrevious":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_center":true,"descriptionLeft":"active media progress","hideNumber":false,"angleOffset":"","thickness":"0.05","color":"#ffffff","bgcolor":"#8a8a8a","linecap":false,"anticlockwise":false,"g_value":true,"min":"0","max":"100","digits":"0","step":"1","is_comma":false,"unit":"%","caption":"Volume"},"style":{"left":"361px","top":"133px","width":"150px","height":"150px","z-index":"40","box-shadow":"0px 0px 25px #8a8a8a","border-radius":"180px","color":"#ffffff","opacity":""},"widgetSet":"hqwidgets"}]
          O Offline
          O Offline
          Oli
          @Negalein
          super danke
          Oliver
          • NashraN Offline
            NashraN Offline
            Nashra
            Most Active Forum Testing
            Sieht cool aus 👍
            Gruß Ralf
              Hallo
              Nun möchte ich euch auch mal meine Visualisierung vorstellen.
              Vieles wurde mit der Hilfe des Forums umgesetzt. Unter anderem sind Designs & Scripte von @Kuddel, @sigi234, @Mic, @liv-in-sky, @Oli, @Glasfaser, @klaus88, @Scrounger in Verwendung.
              Sollte ich wen vergessen haben, so seit mir nicht böse! ;)
              Das VIS läuft derzeit nur am PC in 1920x1080.
              Für ein Wandtablett muss die weibliche Hoheit noch überzeugt werden. 😁
              vis (27).png vis (28).png vis (29).png vis (30).png vis (31).png vis (32).png vis (33).png vis (34).png vis (35).png vis (36).png vis (37).png vis (38).png vis (39).png vis (28).png vis (41).png vis (42).png vis (43).png vis (44).png vis (45).png vis (90).png vis (48).png vis (49).png vis (50).png vis (51).png vis (52).png vis (53).png vis (54).png vis (55).png vis (56).png vis (57).png vis (58).png vis (25).png vis (26).png
              2020-03-02-scripts.zip
              VIS als Projekt
              instances - ioBroker (1).png instances - ioBroker (2).png instances - ioBroker (3).png instances - ioBroker (4).png instances - ioBroker (5).png instances - ioBroker (6).png instances - ioBroker (7).png instances - ioBroker (8).png instances - ioBroker (9).png instances - ioBroker (10).png instances - ioBroker (11).png instances - ioBroker (12).png instances - ioBroker (13).png instances - ioBroker (14).png instances - ioBroker (15).png
              saeft_2003
              @Negalein
              Gefällt mir auch gut. Wie bekommst du den Rahmen von dem popup dialog fenster dunkel hin? Bei mir ist der immer weis. Kannst du mir evtl das widget mal exportieren?
              • S saeft_2003
                @Negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @saeft_2003 sagte in Vorstellung meiner VIS-Oberfläche:
                Danke dir!
                Der dunkle Rahmen kommt mWn vom eingestelltem Thema.
                Bei mir ist es dot-luv
                [{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/Akkuleer.png","class":"","contains_view":"091_Batterien_Tabelle","modal":true,"dialog_width":"720","dialog_height":"560","dialog_top":"100","dialog_left":"240","overflowX":"hidden","overflowY":"hidden","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"484px","top":"11px","width":"36px","height":"23px","z-index":"2"},"widgetSet":"jqui"}]
                S 2 Antworten Letzte Antwort
                  Danke dir!
                  saeft_2003
                  @Negalein
                  Und genau das mit dem thema will bei mir nicht funktionieren. Welche vis version hast du?
                  • S saeft_2003
                    @Negalein
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    1.2.4
                      1.2.4
                      saeft_2003
                      @Negalein
                      1.2.3 das wird der Grund sein, hat auch schon ein anderer user gesagt.
                      Das Problem ist das selbst wenn ich auf latest umstelle nicht die 1.2.4 angeboten bekomme. Evtl muss ich die manuell über die Konsole installieren...
                        Danke dir!
                        saeft_2003
                        schrieb am zuletzt editiert von saeft_2003
                        @Negalein sagte in Vorstellung meiner VIS-Oberfläche:
                        Danke dir!
                        Schei*** wars. Ich hab jetzt die 1.2.4 installiert. Dein widget verwendet und das Thema eingestellt. Dabei ändert sich die Farbe vom Button aber nicht vom dialog der sich öffnet.
                        Hast du noch eine Idee?
                        NegaleinN GlasfaserG 3 Antworten Letzte Antwort
                        • S saeft_2003
                          Danke dir!
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Leider nicht.
                          • S saeft_2003
                            Danke dir!
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            hab das gerade gefunden.
                            Probiers mal aus.
                            • S saeft_2003
                              Danke dir!
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @saeft_2003
                              Alle VIS Seiten von dir müssen auf das Thema umgestellt werden , erst dann funktioniert es mit dem PopUp Fenster !!
                              • GlasfaserG Glasfaser
                                @saeft_2003
                                saeft_2003
                                @Glasfaser
                                Ok werde ich nachher probieren. Schonmal danke 😊
                                • S saeft_2003
                                  @Glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @saeft_2003
                                  Das Thema hatte ich erst letztens .... es liegt nur an dem Popup Widget ... wiso warum 🤔 !?
                                  Link Text
                                    @saeft_2003
                                    saeft_2003
                                    @Glasfaser sagte in Vorstellung meiner VIS-Oberfläche:
                                    @saeft_2003
                                    Danke 😊 das war die Lösung 👍
                                    Was jetzt nur doof ist wenn ich schauen will welches Thema mir am besten gefällt muss ich jedes mal alle views umstellen?!
                                    • S saeft_2003
                                      @saeft_2003
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @saeft_2003
                                      Hier mit "dark-hive" ... da tut sich nicht viel ....
                                      ( In Spoiler gesetz ... damit der Thread klein bleibt ;) )
                                      • C Offline
                                        Conquest
                                        @Negalein
                                        Sehr schöne VIS. Würdest du einen Export bereitstellen? Kann ich mir bestimmt wieder einiges abschauen 😊
                                        • C Conquest
                                          @Negalein
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          @Conquest sagte in Vorstellung meiner VIS-Oberfläche:
                                          Willst du alles oder nur bestimmte Seiten?
                                          C 1 Antwort Letzte Antwort
