  4. Test Adapter Shelly v3.1.x
    6.6k
shellyadapter
282 Beiträge 36 Kommentatoren 62.7k Aufrufe 36 Beobachtet
  • E Offline
    eMd
    #156
    shelly.0	2020-02-16 09:58:06.773	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureF4 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.773	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureF3 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.773	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureF2 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.772	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureF1 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.772	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureC4 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.771	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureC3 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.771	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureC2 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    shelly.0	2020-02-16 09:58:06.770	error	(9213) Error in function httpIoBrokerState for state SHSW-1#B8FB8F#1.ext.temperatureC1 and request{"url":"http://192.168.178.86/status","timeout":5000} for 192.168.178.86 (shelly1 / shelly1-B8FB8F / S
    Das kommt nach dem Update trotzdem noch, ist ein shelly ohne addon.
    {"wifi_sta":{"connected":true,"ssid":"Asmodeus","ip":"192.168.178.86","rssi":-48},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"09:59","serial":1,"has_update":true,"mac":"98F4ABB8FB8F","relays" :[{"ison":false, "has_timer":false}],"meters":[{"power":0.00,"is_valid":"true"}],"inputs":[{"input":1}],"ext_temperature":{},"update":{"status":"pending","has_update":true,"new_version":"20200206-083100/v1.5.10@e6a4205e","old_version":"20200122-090220/v1.5.9@4b657c90"},"ram_total":50944,"ram_free":39584,"fs_size":233681,"fs_free":169927,"uptime":1964275}
    Master: Intel NUC 16GB/500GB
    Slave: Raspberry Pi 3 + Homematicmodul
    Shelly, Google Home, Zigbee Aqara, Sonoff
    Meine VIS: https://youtu.be/JMYr2KYlpME
    • E Offline
      eMd
      #157
       httpIoBrokerState for state SHSW-1#500F52#1.ext.temperatureC1 and request{"url":"http://192.168.178.52/status","timeout":5000} for 192.168.178.52 (shelly1 / shelly1-500F52 / S
      shelly.0	2020-02-16 10:01:16.259	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureF4 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.258	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureF3 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.257	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureF2 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.256	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureF1 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.254	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureC4 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.253	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureC3 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.252	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureC2 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.251	error	(9213) Error in function httpIoBrokerState for state SHSW-1#500B32#1.ext.temperatureC1 and request{"url":"http://192.168.178.51/status","timeout":5000} for 192.168.178.51 (shelly1 / shelly1-500B32 / S
      shelly.0	2020-02-16 10:01:16.242	error	(9213) Error in function httpIoBrokerState for state
      Und auch der andere bleibt bestehen im LOG
      StuebiS 1 Antwort Letzte Antwort
      • E eMd
        StuebiS Offline
        StuebiS Offline
        Stuebi
        #158
        @eMd , okay die ext. Temperaturen werden anscheinend nur in /status angezeigt wenn diese da sind!
        Bitte nochmals die Version 3.2.0 per GitHub laden und testen.
        ioBroker auf Synology DS216+II im Docker Container
        • E Offline
          eMd
          #159
          Perfekt, läuft unter coap und mqtt fehlerfrei bei mir
          • E eMd
            StuebiS Offline
            StuebiS Offline
            Stuebi
            #160
            @eMd, super! Werden die Werte auch wenn der Shelly Adapter auf MQTT gestellt ist, angezeigt und ändern sich? Hier wurde gerade etwas gegenteiliges festgestellt. Ich bin mir nur nicht sicher ob auch der Shelly selber auf MQTT gestellt wurde.
            R 1 Antwort Letzte Antwort
            • StuebiS Stuebi
              racker0
              #161
              @Stuebi Hallo Stuebi, ja MQTT werte wurden umgestellt. :-) Habe vorher den MQTT/HTTP Mode verwendet. Es werden auch alle anderen Werte aktualisiert nur die ext. Sensoren nicht.
              lg racker0
              • C Offline
                ChrisXY
                #162
                Hab die neuster Version drauf. Kann man beim ConsumedPower meinen aktuellen StromZähler Stand hinzufügen ?
                StuebiS 2 Antworten Letzte Antwort
                • C ChrisXY
                  StuebiS Offline
                  StuebiS Offline
                  Stuebi
                  #163
                  Kann nochmals jemand die externen Temperatursensoren mit MQTT testen. Dafür die Version 3.2.0 über Github laden und Shelly Instanz in ioBroker neu starten. Danke!
                  • C ChrisXY
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #164
                    @ChrisXY , das ist nicht geplant. Da musst Du Dir selber etwas einfallen lassen, wie eigener Datenpunkt und dann den Wert addieren.
                    C 1 Antwort Letzte Antwort
                    • StuebiS Stuebi
                      ChrisXY
                      #165
                      @Stuebi said in Test Adapter Shelly v3.1.x:
                      Okay schade aber woher kommt den "ConsumedPower" vom EM3 ? Hab angst das der Zählerstand dann nicht mehr Aktuell ist wenn iobroker mal Neustartet /ausfällt bei reboot usw. Sonst hätte ich ein Blockly gemacht dafür.
                      • C ChrisXY
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        #166
                        @ChrisXY , du kannst deine Anforderung hier nochmals loswerden: https://github.com/schmupu/ioBroker.shelly/issues/124
                        • StuebiS Stuebi
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #167
                          @Stuebi
                          Keine Ahnung ob wichtig, im Namen fehlt ein e
                            K_o_bold
                            #168
                            Firmwareupdate aller Shellys klappt bei mir nicht mit dem Datenpunkt:
                            Muss ich dabei was beachten?
                            • K K_o_bold
                              StuebiS Offline
                              StuebiS Offline
                              Stuebi
                              #169
                              @K_o_bold , wird auch nicht mehr unterstützt.
                              E 1 Antwort Letzte Antwort
                                klassisch
                                #170
                                Da scheint sich ein Typo eingeschlichen zu haben - oder ich habe etwas nicht kapiert. Ist bei meinem Shelly Plug genauso.
                                • StuebiS Stuebi
                                  e-s
                                  #171
                                  @Stuebi
                                  wenn ich das hier richtig lese, gibt es ein paar neue Statuspunkte in der API.
                                  Mich würde der Punkt hier interessieren:
                                  * [All devices] Add attribute/parameter discoverable to /settings endpoint
                                  habe das zwar glaube ich bei meinen 23 Stück jetzt überall deaktiviert aber hier würde ich das besser sehen ob ich wirklich alle erwischt habe.
                                  Zum Hintergrund, habe noch einen Bose soundtouch 10, und davon stürzt die Android App ab, wenn shellys im Netzwerk sind und irgendwie flasch auf mDNS reagieren, habe die Hoffnung damit wieder meine App zu laufen zu bekommen. Aber entweder ich habe nicht bei allen shellys die Einstellung erwischt oder das bringt nicht den gewünschten Erfolg.
                                    dos1973
                                    schrieb am zuletzt editiert von dos1973
                                    #172
                                    ich stelle seit heute folgendes im Log für den Shelly fest.
                                    (25986) Exception: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to write outside buffer bounds
                                    ich habe noch v1.5.6 drauf angeboten wird 1.5.10
                                    kann es daran liegen?
                                    der Adapter startet dann irgendwann neu, da kein Shelly mehr via iobroker ansprechbar ist
                                    Shelly Adapter 3.3.2
                                    • D dos1973
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #173
                                      @dos1973
                                      Du meinst vermutlich Version 3.2.3 des Adapters?!
                                      Die Firmware der Shellys ist momentan schon bei 1.6.2
                                      • haselchenH haselchen
                                        @dos1973
                                        dos1973
                                        #174
                                        @haselchen
                                        sorry, habe mich vertippt bei der Version.
                                        Shelly Adapter: 3.2.2
                                        meine Shellys bekommen nur die 1.5.10 angezeigt?,
                                        muss ich die zuerst installieren um die 1.6.x zu sehen/ bekommen.
                                        • D dos1973
                                          @haselchen
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #175
                                          @dos1973
                                          No risk no fun ;)
