  4. Update auf Zigbee Adpater 1.0.2 nichtsgeht mehr!
zigbee adapter cc2531
7 Beiträge 2 Kommentatoren 389 Aufrufe 2 Beobachtet
  • MyzerATM Offline
    MyzerATM Offline
    MyzerAT
    habe nachdem ich nach einen rückspielen einen Backups nur noch fehler, habe dann auf Zigbee Adapter Version 1.0.2 geupdatet und es änder sich nichts
    zigbee.0	2020-02-16 01:57:53.208	error	Failed to configure 0x000d6ffffe9f8c0d TRADFRI signal repeater, attempt 1 (Error: Bind 0x000d6ffffe9f8c0d/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:57:43.204	info	Configuring 0x000d6ffffe9f8c0d TRADFRI signal repeater
    zigbee.0	2020-02-16 01:57:43.204	error	Failed to configure 0x000d6ffffebb1e78 TRADFRI signal repeater, attempt 1 (Error: Bind 0x000d6ffffebb1e78/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:57:33.200	info	Configuring 0x000d6ffffebb1e78 TRADFRI signal repeater
    zigbee.0	2020-02-16 01:57:33.199	error	at <anonymous>)
    zigbee.0	2020-02-16 01:57:33.199	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
    zigbee.0	2020-02-16 01:57:33.199	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-02-16 01:57:33.199	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:235:23)
    zigbee.0	2020-02-16 01:57:33.199	error	Failed to configure 0xd0cf5efffeea2f74 TRADFRI signal repeater, attempt 1 (Error: Bind 0xd0cf5efffeea2f74/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:57:23.198	info	Configuring 0xd0cf5efffeea2f74 TRADFRI signal repeater
    zigbee.0	2020-02-16 01:57:23.196	error	at <anonymous>)
    zigbee.0	2020-02-16 01:57:23.196	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
    zigbee.0	2020-02-16 01:57:23.196	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-02-16 01:57:23.196	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:235:23)
    zigbee.0	2020-02-16 01:57:23.196	error	Failed to configure 0x000d6ffffe9f907c TRADFRI signal repeater, attempt 1 (Error: Bind 0x000d6ffffe9f907c/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:57:13.194	info	Configuring 0x000d6ffffe9f907c TRADFRI signal repeater
    zigbee.0	2020-02-16 01:57:13.193	error	at <anonymous>)
    zigbee.0	2020-02-16 01:57:13.193	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
    zigbee.0	2020-02-16 01:57:13.193	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-02-16 01:57:13.193	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:235:23)
    zigbee.0	2020-02-16 01:57:13.193	error	Failed to configure 0x000d6ffffe9c27d9 TRADFRI signal repeater, attempt 1 (Error: Bind 0x000d6ffffe9c27d9/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:57:03.187	info	Configuring 0x000d6ffffe9c27d9 TRADFRI signal repeater
    zigbee.0	2020-02-16 01:57:03.186	error	at <anonymous>)
    zigbee.0	2020-02-16 01:57:03.186	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
    zigbee.0	2020-02-16 01:57:03.186	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-02-16 01:57:03.186	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:235:23)
    zigbee.0	2020-02-16 01:57:03.186	error	Failed to configure 0x000d6ffffe9cc0e8 TRADFRI signal repeater, attempt 1 (Error: Bind 0x000d6ffffe9cc0e8/1 genBasic from '0x00124b0014b93a3b/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
    zigbee.0	2020-02-16 01:56:53.188	info	Zigbee started
    zigbee.0	2020-02-16 01:56:53.187	info	0x000b57fffe8d03d2 (addr 29540): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
    zigbee.0	2020-02-16 01:56:53.187	info	0x000b57fffe48a839 (addr 24046): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
    zigbee.0	2020-02-16 01:56:53.187	info	0x000b57fffe972bd2 (addr 41788): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
    zigbee.0	2020-02-16 01:56:53.187	info	0x00158d000192d13d (addr 9702): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    zigbee.0	2020-02-16 01:56:53.187	info	0x00158d0002eee870 (addr 53802): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
    zigbee.0	2020-02-16 01:56:53.187	info	0x0017880104101f75 (addr 63604): 8718696449691 - Philips Hue White Single bulb B22 (Router)
    zigbee.0	2020-02-16 01:56:53.187	info	0x00158d000192d1ae (addr 46127): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d000192d245 (addr 16755): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d0001922cdf (addr 52708): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d0001922dcd (addr 23284): SPZB0001 - Eurotronic Spirit Zigbee wireless heater thermostat (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d0002c8cbab (addr 55164): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d0003140898 (addr 24690): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d0002c76455 (addr 35687): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x00158d00030aaa7c (addr 9922): WXKG03LM - Xiaomi Aqara single key wireless wall switch (EndDevice)
    zigbee.0	2020-02-16 01:56:53.186	info	0x000d6ffffe9f8c0d (addr 54272): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.185	info	0x000d6ffffebb1e78 (addr 20291): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.185	info	0xd0cf5efffeea2f74 (addr 38965): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.185	info	0x000d6ffffe9f907c (addr 37646): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.185	info	0x000d6ffffe9c27d9 (addr 55051): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.185	info	0x00158d000183f3a5 (addr 35259): WXKG02LM - Xiaomi Aqara double key wireless wall switch (EndDevice)
    zigbee.0	2020-02-16 01:56:53.185	info	0x000d6ffffe9cc0e8 (addr 29752): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.0	2020-02-16 01:56:53.184	info	0x00158d000201a358 (addr 23213): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
    zigbee.0	2020-02-16 01:56:53.180	info	Configuring 0x000d6ffffe9cc0e8 TRADFRI signal repeater
    zigbee.0	2020-02-16 01:56:53.178	info	Currently 22 devices are joined:
    zigbee.0	2020-02-16 01:56:53.163	info	--> transmitPower : norm
    zigbee.0	2020-02-16 01:56:53.157	info	Disable LED
    zigbee.0	2020-02-16 01:56:53.151	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}
    zigbee.0	2020-02-16 01:56:51.720	info	Starting Zigbee...
    könnt ihr mir bitte einen schubs geben, damit ich auf die spur des fehlers komme
    lg Rudi
    Node 22.23.0
    Nodejs 22.23.0
    npm 10.9.8
    js-controller 7.2.2
    • MyzerATM MyzerAT
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @MyzerAT
      er bekommt die Ikea repeater nicht konfiguriert. Kannst du die Kurz aus- und Wieder einstöpseln ?
      A.
      • MyzerATM Offline
        MyzerATM Offline
        MyzerAT
        muss ich dazu das paring aktiveren ?
        lg Rudi
        Node 22.23.0
        Nodejs 22.23.0
        npm 10.9.8
        js-controller 7.2.2
        • MyzerATM MyzerAT
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @MyzerAT nein
          es geht nur darum sie dazu zu bringen eine Nachricht zu senden.
          A.
          • MyzerATM Offline
            MyzerATM Offline
            MyzerAT
            schrieb am zuletzt editiert von MyzerAT
            ok , wird aber eine weile dauern, da ich die in der Wohnung verstreut habe und nicht sher gut zu Fuss bin, hänge leider am Sauerstoff :-(
            lg Rudi
            Node 22.23.0
            Nodejs 22.23.0
            npm 10.9.8
            js-controller 7.2.2
            • MyzerATM Offline
              MyzerATM Offline
              MyzerAT
              @Asgothian
              1000 danke , das wars, kannst du mir auch sagen warum das jetzt aufgetreten ist ?
              thx
              lg Rudi
              Node 22.23.0
              Nodejs 22.23.0
              npm 10.9.8
              js-controller 7.2.2
              • MyzerATM MyzerAT
                @Asgothian
                thx
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @MyzerAT Warum es aufgetreten ist kann ich nicht sagen. Aber ich kann sagen was da abgelaufen ist.
                • Die Fehlermeldung besagt das der Adapter die Geräte nicht konfiguriert bekommen hat, also wollten oder konnten die Geräte nicht mit dem Adapter kommunizieren.
                • wenn die Ikea Router neu eingestöpselt werden senden Sie an das Zigbee Netz eine Nachricht "ich bin wieder da, gibts was neues"
                • wenn der Herdsman diese Nachricht bekommt, versucht er sofort die Router zu konfigurieren. Da sie gerade nach Neuigkeiten gefragt haben sind sie auch zur Kommunikation bereit.
                A.
