2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
    steff.h.
    schrieb am zuletzt editiert von steff.h.
    #1599
    das kommt wohl eher von den vorherigen Versuchen....
    ich habe jetzt den Ordner im DSM nochmal komplett gelöscht
    das Image neu laden lassen und den Container neu erstellt....leider das Gleiche
    Fehler: Verbindung fehlgeschlagen
    Steff_Server2 ist der Hostname der DS, richtig. Das ist meine Backup und Test DS :-)
    Hier das log des ersten Starts:
    ---------------     2020-02-13 14:16:40      ---------------
    -----       Welcome to your ioBroker-container!        -----
    -----          Startupscript is now running.           -----
    -----                Please be patient!                -----
    -----              Debugging information               -----
    -----                      System                      -----
    -----               arch:      x86_64                  -----
    -----                     Versions                     -----
    -----               image:     v4.1.0                  -----
    -----               node:      v10.19.0                -----
    -----               npm:       6.13.4                  -----
    -----                       ENV                        -----
    -----               ADMINPORT: 8081                    -----
    -----               AVAHI:     false                   -----
    -----               PACKAGES:  vi                      -----
    -----               REDIS:     false                   -----
    -----               SETGID:    1000                    -----
    -----               SETUID:    1000                    -----
    -----               USBDEVICES: none                    -----
    -----               ZWAVE:     false                   -----
    -----         Step 1 of 5: Preparing container         -----
    Installing additional packages is set by ENV.
    The following packages will be installed: vi...
    Done.
    There are no changes in UID/ GID needed.
    -----   Step 2 of 5: Detecting ioBroker installation   -----
    There is no data detected in /opt/iobroker. Restoring initial ioBroker installation...
    Done.
    -----   Step 3 of 5: Checking ioBroker installation    -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    Done.
    Looks like this is a new and empty installation of ioBroker.
    Hostname needs to be updated to  Steff_Server2...
    Socket.io Server detected. Please update to js-controller 2.0 or higher!
    The host for instance "system.adapter.admin.0" was changed from "91ffef819ab9" to "Steff_Server2".
    The host for instance "system.adapter.discovery.0" was changed from "91ffef819ab9" to "Steff_Server2".
    The host for instance "system.adapter.info.0" was changed from "91ffef819ab9" to "Steff_Server2".
    Done.
    -----      Step 4 of 5: Applying special settings      -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information take a look at readme.md on Github!
    -----          Step 5 of 5: ioBroker startup           -----
    Starting ioBroker...
    host.Steff_Server2 check instance "system.adapter.admin.0" for host "Steff_Server2"
    host.Steff_Server2 check instance "system.adapter.discovery.0" for host "Steff_Server2"
    host.Steff_Server2 check instance "system.adapter.info.0" for host "Steff_Server2"
    andreA 1 Antwort Letzte Antwort
    • S steff.h.
      -----                      System                      -----
      -----                       ENV                        -----
      Done.
      Done.
      Done.
      Done.
      Done.
      andreA Offline
      andreA Offline
      andre
      #1600
      @steff-h Sieht für mich immer noch so aus als ob ioBroker laufen würde. Keine Fehlermeldungen. Wie rufst du den Admin auf?
      Zeig mir mal die Config deines Containers. Dazu den Container im Portainer öffnen und auf "Inspect" klicken, dann oben rechts auf "Text" klicken und den Text kopieren.
      Kannst mir die Daten auch gerne per Mail oder Chat zukommen lassen.
      MfG,
      André
        steff.h.
        #1601
        über die NAS-IP:8081, so bin ich zumindest bei V2 immer auf die Oberfläche gekommen
        die Config kommt per PN :-)
        danke dir
        PS: Chat geht leider nicht, hast du geblockt
        Hab es dir jetzt über das Kontaktformular deiner HP geschickt
        • J Offline
          Jörg D.
          #1602
          Guten Morgen, habe bei mir gerade das gleiche Fehlerbild! Wollte von MACVLAN wieder zu Host zurück. Läuft aber nicht. Das Log sieht auch so aus.
          Viele Grüße
          Jörg
          • andreA Offline
            andreA Offline
            andre
            #1603
            @steff-h @Jörg-D Ich krieg es nicht auf die Reihe. Alles sieht gut aus. Einzig das Anmeckern der js-controller Version habe ich nicht im Log... Habe es gerade nochmal nachgestellt. Bei mir läuft es...
            Könnt ihr mal in der Kommandozeile im Container folgendes machen?
            iobroker status
            iobroker info
            iobroker version
            MfG,
            André
            • J Offline
              Jörg D.
              #1604
              Neue Installation:
              ***root@buanet-iobroker1:/opt/iobroker# iobroker status
              iobroker is not running on this host.
              No iobroker host is running.
              Objects type: file
              States type: file
              root@buanet-iobroker1:/opt/iobroker# iobroker info
              Platform : linux
              os : linux
              Architecture : x64
              CPUs : 2
              Speed : 2001 MHz
              Model : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
              RAM : 9.5 GB
              System uptime : 48d. 03:38:58
              Node.js : v10.19.0
              Disk size : 3.5 TiB
              Disk free : 955.2 GiB
              NPM : v6.13.4
              r
              root@buanet-iobroker1:/opt/iobroker# iobroker version
              2.2.8***
              • J Jörg D.
                Neue Installation:
                Objects type: file
                States type: file
                Platform : linux
                os : linux
                Architecture : x64
                CPUs : 2
                Speed : 2001 MHz
                RAM : 9.5 GB
                Node.js : v10.19.0
                Disk size : 3.5 TiB
                NPM : v6.13.4
                r
                2.2.8***
                andreA Offline
                andreA Offline
                andre
                #1605
                @Jörg-D sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                Diese Meldung ist seltsam. Und wahrscheinlich die Ursache, bzw. das was die Meldung hervor ruft... Das Problem: ich habe keine Ahnung wie das sein kann :( Der js-controller im Image ist nämlich schon größer 2.0... Zumindest bei meinem Test.
                Habt ihr mal das Image neu geladen? Oder mal die beta-Version getestet?
                MfG,
                André
                  dtp
                  #1606
                  Also bei mir läuft der ioBroker im host-Modus soweit sehr gut. Dies nur zur Info.
                  • J Offline
                    Jörg D.
                    #1607
                    Gerade mit der 4.1.3beta probiert, das Gleiche:
                    Danke für Deine Mühe!
                    • apollon77A Offline
                      #1608
                      Läuft irgendetwas anderes auf Port 9000 oder 9001? Das ist auch der Standardprogramm vom Portainer as i know ... dann kollidiert das mit den iobroker dbs die auf diesen ports im Standard geöffnet werden. Kann man ändern in der iobroker.json in iobroker-data Verzeichnis oder mit iobroker setup custom.
                      • J Offline
                        Jörg D.
                        #1609
                        Yes, genau das war das Problem! Portainer deaktiviert und schon ging es.
                        Vielen Dank und einen schönen Abend!
                        • apollon77A apollon77
                          andreA Offline
                          andreA Offline
                          andre
                          #1610
                          @apollon77 In der Tat, so ist es... @Jörg-D @steff-h euer Portainer hängt vermutlich auf Port 9000! Zumindest konnte ich es so 1:1 nachstellen.... :)
                          Portainer einfach mit "-p 8889:9000" auf Port 8889 hängen und dann läufts...
                          MfG,
                          André
                            steff.h.
                            #1611
                            Ja, also um auf die Oberfläche von Portainer zu kommen muss ich ip:9000 eingeben
                            Ich dachte aber ioBroker ist auf ip:8081?
                            Das heißt ich gehe jetzt in Docker und auf Terminal und gebe dort -p 8889:9000 ein und dann ist Portainer auf ip:8889 erreichbar und iobroker dann auf ip:8081 oder ist dieser dann auf ip:9000?
                            Das versteh ich gerade irgendwie nicht....(sry für die Unwissenheit)
                              steff.h.
                              #1612
                              Ok, hab es verstanden :-)
                              Hab jetzt auch einfach Portainer deaktiviert und schon ging es :-)
                              Danke!!!
                              • S steff.h.
                                #1613
                                @steff-h iobroker Admin - das web Interface - ist auf Port 8081 im default. Iobroker nutze aber auch ports 9000 und 9001 für die Datenbanken.
                                  steff.h.
                                  #1614
                                  ah ok, dass wusste ich nicht :-)
                                  danke euch!!!
                                  Aber wo änder ich den Port von Portainer genau? Im Docker kann ich im Terminal nichts eingeben, da blinkt nur der weiße Balken...
                                  auf der Portainer Oberfläche hab ich es auch versucht....
                                  Use custom command aktiviert
                                  command: -p 8889:9000
                                  und dann auf connect
                                  ebenfalls ohne Erfolg
                                  weil den js-Controller habe ich auch bis jetzt immer über den Docker-Terminal ungedatet....
                                  aber auch wenn der Portainer deaktiviert ist und ich auf die Oberfläche von ioBroker komme, kann ich über den Docker-Terminal ebenfalls nichts eingeben für den ioBroker Container
                                  • S steff.h.
                                    danke euch!!!
                                    andreA Offline
                                    andreA Offline
                                    andre
                                    #1615
                                    @steff-h Den Port von Portainer kannst du nur beim Erstellen vom Portainer Container ändern.
                                    MfG,
                                    André
                                      steff.h.
                                      #1616
                                      ah ok, dass erklärt einiges :-)
                                      jetzt hat das auch geklappt und ich kann beide Container gleichzeitig laufen lassen....
                                      Vielen Dank für die Gedult mit mir und die Hilfe!!!!
                                        dtp
                                        #1617
                                        Bei mir läuft's seit geraumer Zeit sehr gut ohne Portainer. Ich mache aber auch nicht so viel mit Docker-Containern (aktuell nur ioBroker und Motioneye). Daher war für mich der Portainer eher hinderlich als nützlich.
                                        • D dtp
                                          andreA Offline
                                          andreA Offline
                                          andre
                                          schrieb am zuletzt editiert von andre
                                          #1618
                                          An der Stelle nochmal der Hinweis: Portainer ist nur eine Oberfläche zur Administration des Docker Daemon und hat keinen Einfluss darauf wie der ioBroker-Container läuft. Portainer setzt, genauso wie die Oberfläche der DS auch, die grafische Konfiguration in Docker Befehle um und bietet ein entsprechendes Monitoring.
                                          Wenn es darum geht den Container einmal auf zu setzen dann tut es auch die Oberfläche der DS (mit Einschränkungen, siehe MACVLAN) oder ein einzeiliger Befehl in der Kommandozeile. Der Mehrwert bei Portainer liegt bei anderen Features die die Oberfläche der DS nicht zur Verfügung stellt. Einige Beispiele:
                                          • Update des Container über einen Klick per "Recreate"
                                          • Anlegen eines MACVLAN
                                          • Nutzung von Stacks aka "docker-compose" (Tutorial dazu folgt demnächst)
                                          • durchreichen von USB-Devices
                                          • setzen von capabilities
                                            usw...
                                          Der Vollständigkeit halber sei darauf hingewiesen, dass es auch noch andere GUIs für Docker gibt. Ich empfehle Portainer weil ich mehrere Alternativen getestet habe und Portainer als Sieger vom Platz gegangen ist, auch wenn Portainer aktuell längst nicht ohne Bugs ist... :)
                                          MfG,
                                          André
