  4. Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl
script engine 4.3.4 auf 4.4.2
5 Beiträge 2 Kommentatoren 336 Aufrufe 1 Beobachtet
  • F Offline
    Flopsi
    schrieb am zuletzt editiert von Flopsi
    Leider bekomme ich beim Update von Script Engine immer diese Fehlermeldung:
    $ ./iobroker upgrade javascript
    Update javascript from @4.3.4 to @4.4.2
    NPM version: 6.13.4
    npm install iobroker.javascript@4.4.2 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
     ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! errno -13
    npm
     ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node\'',npm ERR!   errno: -13,npm ERR!
       code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }npm
     ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-02-13T17_21_14_494Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.javascript@4.4.2: 243
    Kann mir wer sagen warum ?
    • F Flopsi
      NPM version: 6.13.4
      npm
      npm
      Jan1
      @Flopsi
      Rechte werden angemeckert und da kann der Fixer wie immer helfen. Probier es aus, schaden kann es nicht.
      Wie wolltest updaten, normal über Admin?
      • F Offline
        Flopsi
        ja normal über admin
        • F Flopsi
          Jan1
          @Flopsi
          Dann Fixer drüber und noch mal testen.
          • F Offline
            Flopsi
            Danke der Fix hat es gebracht jetzt ist das Update sauber durchgelaufen.
