<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl]]></title><description><![CDATA[<p dir="auto">Leider bekomme ich beim Update von Script Engine immer diese Fehlermeldung:</p>
<pre><code>$ ./iobroker upgrade javascript
Update javascript from @4.3.4 to @4.4.2
NPM version: 6.13.4
npm install iobroker.javascript@4.4.2 --loglevel error --prefix "/opt/iobroker" (System call)
npm
 ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! errno -13
npm
 ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node\'',npm ERR!   errno: -13,npm ERR!
   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }npm
 ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-02-13T17_21_14_494Z-debug.log
ERROR: host.raspberrypi Cannot install iobroker.javascript@4.4.2: 243
</code></pre>
<p dir="auto">Kann mir wer sagen warum ?</p>
]]></description><link>https://forum.iobroker.net/topic/30140/update-von-script-engine-4-3-4-auf-4-4-2-schlägt-fehl</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 18:09:46 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/30140.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Feb 2020 17:30:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl on Thu, 13 Feb 2020 18:42:43 GMT]]></title><description><![CDATA[<p dir="auto">Danke der Fix hat es gebracht jetzt ist das Update sauber durchgelaufen.</p>
]]></description><link>https://forum.iobroker.net/post/377122</link><guid isPermaLink="true">https://forum.iobroker.net/post/377122</guid><dc:creator><![CDATA[Flopsi]]></dc:creator><pubDate>Thu, 13 Feb 2020 18:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl on Thu, 13 Feb 2020 18:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flopsi" aria-label="Profile: Flopsi">@<bdi>Flopsi</bdi></a><br />
Dann Fixer drüber und noch mal testen.</p>
]]></description><link>https://forum.iobroker.net/post/377108</link><guid isPermaLink="true">https://forum.iobroker.net/post/377108</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Thu, 13 Feb 2020 18:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl on Thu, 13 Feb 2020 18:06:44 GMT]]></title><description><![CDATA[<p dir="auto">ja normal über admin</p>
]]></description><link>https://forum.iobroker.net/post/377092</link><guid isPermaLink="true">https://forum.iobroker.net/post/377092</guid><dc:creator><![CDATA[Flopsi]]></dc:creator><pubDate>Thu, 13 Feb 2020 18:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to Update von Script Engine 4.3.4 auf 4.4.2 schlägt fehl on Thu, 13 Feb 2020 18:01:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flopsi" aria-label="Profile: Flopsi">@<bdi>Flopsi</bdi></a><br />
Rechte werden angemeckert und da kann der Fixer wie immer helfen. Probier es aus, schaden kann es nicht.</p>
<p dir="auto">Wie wolltest updaten, normal über Admin?</p>
]]></description><link>https://forum.iobroker.net/post/377089</link><guid isPermaLink="true">https://forum.iobroker.net/post/377089</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Thu, 13 Feb 2020 18:01:27 GMT</pubDate></item></channel></rss>
