  4. Test Adapter zoneminder v0.3.x
zonemindermotioncamera
206 Beiträge 23 Kommentatoren 45.4k Aufrufe 26 Beobachtet
  • MeistertrM Offline
    MeistertrM Offline
    Meistertr
    #162
    so die 0.3.3 ist online damit sollten Loginfehler von Adapterseite der Vergangenheit angehören.
    coyoteC 1 Antwort Letzte Antwort
    • MeistertrM Meistertr
      coyoteC Offline
      coyoteC Offline
      coyote
      schrieb am zuletzt editiert von coyote
      #163
      @Meistertr bekomme nach einer Weile leider immer noch den Websocket Error, hier das Log nach start:
      zoneminder.0	2019-11-12 06:37:53.345	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:53.344	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:53.342	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:53.341	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:53.332	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:53.330	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:53.329	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:53.320	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:53.301	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:53.284	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:53.272	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:53.271	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:53.220	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:53.220	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:53.219	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:48.218	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:48.192	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:48.191	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:48.190	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:48.177	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:48.171	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:48.170	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:48.169	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:48.167	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:48.166	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:48.165	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:48.157	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:48.156	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:48.142	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:48.142	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:48.141	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:43.140	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:43.139	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:43.137	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:43.078	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:43.076	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:43.073	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:43.051	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:43.025	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:43.024	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:43.022	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:43.017	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:42.981	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:42.981	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:42.980	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:37.973	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:37.972	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:37.955	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:37.951	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:37.950	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:37.944	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:37.943	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:37.942	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:37.913	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:37.913	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:37.912	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:37.904	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:37.903	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:37.877	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:37.877	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:37.876	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:32.861	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:32.860	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:32.854	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:32.853	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:32.849	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:32.836	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:32.835	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:32.834	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:32.832	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:32.831	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:32.830	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:32.822	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:32.821	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:32.802	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:32.802	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:32.801	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:27.799	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:27.797	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:27.775	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:27.773	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:27.772	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:27.769	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:27.763	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:27.762	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:27.760	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:27.759	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:27.758	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:27.754	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:27.753	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:27.716	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:27.716	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:27.715	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:22.714	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:37:22.711	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:22.710	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:22.703	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:22.702	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:22.700	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:22.699	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:22.692	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:22.689	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:22.684	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:22.660	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:22.659	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:22.659	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:17.656	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:17.655	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:17.652	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:17.650	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:17.617	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:17.614	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:17.608	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:17.607	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:17.599	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:17.586	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:17.585	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:37:17.568	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:17.559	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:17.530	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_4
      zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_2
      zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:13.555	debug	(1449) FOUND in listzoneminder.0.cam_1
      zoneminder.0	2019-11-12 06:37:13.554	debug	(1449) CAM_ids: ["zoneminder.0.cam_1","zoneminder.0.cam_2","zoneminder.0.cam_3","zoneminder.0.cam_4"]
      zoneminder.0	2019-11-12 06:37:13.543	debug	(1449) found states:_[["zoneminder.0.cam_4.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_4.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_4.zmEvent","Name","text","INIT"],["zo
      zoneminder.0	2019-11-12 06:37:13.468	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) Monitor_3 o.Monitor_Status = [object Object]
      zoneminder.0	2019-11-12 06:37:13.465	debug	(1449) Monitor_3 o.Monitor = [object Object]
      zoneminder.0	2019-11-12 06:37:13.464	debug	(1449) monitor found in Objects
      zoneminder.0	2019-11-12 06:37:13.440	debug	(1449) found states:_[["zoneminder.0.cam_3.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_3.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_3.zmEvent","Name","text","INIT"],["zo
      zoneminder.0	2019-11-12 06:37:13.431	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:37:13.429	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:37:13.428	debug	(1449) Monitor_2 o.Monitor_Status = [object Object]
      zoneminder.0	2019-11-12 06:37:13.428	debug	(1449) Monitor_2 o.Monitor = [object Object]
      zoneminder.0	2019-11-12 06:37:13.427	debug	(1449) monitor found in Objects
      zoneminder.0	2019-11-12 06:37:13.426	debug	(1449) found states:_[["zoneminder.0.cam_2.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_2.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_2.zmEvent","Name","text","INIT"],["zo
      zoneminder.0	2019-11-12 06:37:13.413	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:37:13.412	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:13.411	debug	(1449) Monitor_1 o.Monitor_Status = [object Object]
      zoneminder.0	2019-11-12 06:37:13.410	debug	(1449) Monitor_1 o.Monitor = [object Object]
      zoneminder.0	2019-11-12 06:37:13.409	debug	(1449) monitor found in Objects
      zoneminder.0	2019-11-12 06:37:13.399	debug	(1449) found states:_[["zoneminder.0.cam_1.zmEvent","MonitorId","default_num","0"],["zoneminder.0.cam_1.zmEvent","EventId","default_num","000"],["zoneminder.0.cam_1.zmEvent","Name","text","INIT"],["zo
      zoneminder.0	2019-11-12 06:37:13.383	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:37:13.362	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:37:13.361	debug	(1449) Monitor_0 o.Monitor_Status = [object Object]
      zoneminder.0	2019-11-12 06:37:13.361	debug	(1449) Monitor_0 o.Monitor = [object Object]
      zoneminder.0	2019-11-12 06:37:13.348	debug	(1449) monitor found in Objects
      zoneminder.0	2019-11-12 06:37:12.921	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:12.891	debug	(1449) found states:_[["zoneminder.0.history.LastzmEvent","MonitorId","default_num","0"],["zoneminder.0.history.LastzmEvent","EventId","default_num","000"],["zoneminder.0.history.LastzmEvent","Name","
      zoneminder.0	2019-11-12 06:37:12.889	debug	(1449) [{"Monitor":{"Id":"1","Name":"Garage","ServerId":null,"StorageId":"1","Type":"Ffmpeg","Function":"Modect","Enabled":"1","LinkedMonitors":null,"Triggers":"","Device":"/dev/video0","Channel":"0",
      zoneminder.0	2019-11-12 06:37:12.882	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:37:12.642	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:12.641	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:12.631	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:37:12.630	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:12.629	debug	(1449) Connected to Api
      zoneminder.0	2019-11-12 06:37:12.612	debug	(1449) AUTH: get authkey auth=11cda9fcd2470143abefbebc7d6ce7d2
      zoneminder.0	2019-11-12 06:37:12.612	debug	(1449) AUTH: json Message {"credentials":"auth=11cda9fcd2470143abefbebc7d6ce7d2","append_password":0,"version":"1.32.3","apiversion":"1.0"}
      zoneminder.0	2019-11-12 06:37:12.611	debug	(1449) REQUEST: Get data"{\n \"credentials\": \"auth=11cda9fcd2470143abefbebc7d6ce7d2\",\n \"append_password\": 0,\n \"version\": \"1.32.3\",\n \"apiversion\": \"1.0\"\n}"
      zoneminder.0	2019-11-12 06:37:12.454	debug	(1449) REQUEST: Options {"method":"POST","uri":"http://192.168.66.184/zm/api/host/login.json","body":"user=admin&pass=admin","headers":{"content-type":"application/x-www-form-urlencoded","content-leng
      zoneminder.0	2019-11-12 06:37:12.437	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:37:12.436	debug	(1449) data: {"user":"admin","password":"admin","host":"http://192.168.66.184/zm","zmEvent":true}
      zoneminder.0	2019-11-12 06:37:12.360	info	(1449) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.zoneminder, node: v10.17.0
      zoneminder.0	2019-11-12 06:37:06.528	info	(1223) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      zoneminder.0	2019-11-12 06:37:06.526	info	(1223) terminating
      und hier dann nach einer Weile wieder den Error mit drin, das hat sich die Nacht so weit hochgeschaukelt, dass das komplette Log fast nur noch aus dem Error bestand:
      zoneminder.0	2019-11-12 06:39:39.941	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:39:39.940	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:39:39.939	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:39:39.938	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","9.09"],["
      zoneminder.0	2019-11-12 06:39:39.936	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:39:39.932	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:39.931	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:39.930	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:39:39.930	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:39.929	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:39.923	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:39:39.922	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:39:39.869	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:39:39.868	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:39:39.868	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:39:34.867	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:39:34.866	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:39:34.865	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","9.09"],["
      zoneminder.0	2019-11-12 06:39:34.864	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:39:34.863	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:34.861	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:39:34.860	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:34.859	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:34.858	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:39:34.857	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:39:34.808	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:39:34.808	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:39:34.805	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:39:29.796	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:39:29.751	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:39:29.750	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:39:29.748	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:39:29.747	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:29.739	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:29.736	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:39:29.736	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:29.735	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:29.733	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:39:29.731	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:39:29.711	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:39:29.711	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:39:29.710	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:39:24.707	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:39:24.706	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","NotRunning"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],[
      zoneminder.0	2019-11-12 06:39:24.703	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:39:24.699	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:39:24.698	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:39:24.697	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:39:24.696	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:24.695	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:24.693	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:39:24.692	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:24.691	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:24.690	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:39:24.688	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:39:24.658	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:39:24.658	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:39:24.657	debug	(1449) SetStates
      zoneminder.0	2019-11-12 06:39:22.229	error	(1449) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      zoneminder.0	2019-11-12 06:39:19.657	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:39:19.651	debug	(1449) found states:_[["zoneminder.0.cam_4.info","MonitorId","default_num","4"],["zoneminder.0.cam_4.info","Status","text","Running"],["zoneminder.0.cam_4.info","CaptureFPS","default_num","0.00"],["zo
      zoneminder.0	2019-11-12 06:39:19.650	debug	(1449) found states:_[["zoneminder.0.cam_4.monitor","Name","text","Monitor-4"],["zoneminder.0.cam_4.monitor","Function",null,"1"],["zoneminder.0.cam_4.monitor","Enabled",null,true],["zoneminder.0.cam_
      zoneminder.0	2019-11-12 06:39:19.648	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:39:19.647	debug	(1449) found states:_[["zoneminder.0.cam_3.info","MonitorId","default_num","3"],["zoneminder.0.cam_3.info","Status","text","Connected"],["zoneminder.0.cam_3.info","CaptureFPS","default_num","10.00"],[
      zoneminder.0	2019-11-12 06:39:19.646	debug	(1449) found states:_[["zoneminder.0.cam_3.monitor","Name","text","Haustuer"],["zoneminder.0.cam_3.monitor","Function",null,"2"],["zoneminder.0.cam_3.monitor","Enabled",null,true],["zoneminder.0.cam_3
      zoneminder.0	2019-11-12 06:39:19.603	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:19.602	debug	(1449) found states:_[["zoneminder.0.cam_2.info","MonitorId","default_num","2"],["zoneminder.0.cam_2.info","Status","text","Connected"],["zoneminder.0.cam_2.info","CaptureFPS","default_num","16.67"],[
      zoneminder.0	2019-11-12 06:39:19.599	debug	(1449) found states:_[["zoneminder.0.cam_2.monitor","Name","text","Garten"],["zoneminder.0.cam_2.monitor","Function",null,"1"],["zoneminder.0.cam_2.monitor","Enabled",null,true],["zoneminder.0.cam_2.m
      zoneminder.0	2019-11-12 06:39:19.597	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:19.596	debug	(1449) found states:_[["zoneminder.0.cam_1.info","MonitorId","default_num","1"],["zoneminder.0.cam_1.info","Status","text","Connected"],["zoneminder.0.cam_1.info","CaptureFPS","default_num","14.29"],[
      zoneminder.0	2019-11-12 06:39:19.595	debug	(1449) found states:_[["zoneminder.0.cam_1.monitor","Name","text","Garage"],["zoneminder.0.cam_1.monitor","Function",null,"2"],["zoneminder.0.cam_1.monitor","Enabled",null,true],["zoneminder.0.cam_1.m
      zoneminder.0	2019-11-12 06:39:19.594	debug	(1449) REQUEST: Get data"{\n \"monitors\": [\n {\n \"Monitor\": {\n \"Id\": \"1\",\n \"Name\": \"Garage\",\n \"ServerId\": null,\n
      zoneminder.0	2019-11-12 06:39:19.579	debug	(1449) REQUEST: Options {"method":"GET","uri":"http://192.168.66.184/zm/api/monitors.json?&auth=11cda9fcd2470143abefbebc7d6ce7d2","headers":{"user-agent":"@nodeminder-api"},"resolveWithFullResponse":t
      zoneminder.0	2019-11-12 06:39:19.578	debug	(1449) GET_
      zoneminder.0	2019-11-12 06:39:19.577	debug	(1449) SetStates
      So sah es heute Nacht aus und das ist nur ein Bruchteil davon:
      2019-11-12 00:00:51.826  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.828  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.829  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.830  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.831  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.833  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.834  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.843  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
      2019-11-12 00:00:51.844  - error: zoneminder.0 (16978) WEBSOCKET: Error: client: 192.168.66.184 Message: Error: connect ETIMEDOUT 192.168.66.184:9000
        mikiline
        schrieb am zuletzt editiert von mikiline
        #164
        Kann ich momentan nicht bestätigen. Hab den Adapter heute morgen nach der Meldung von Meistert installiert und seitdem keine Fehlermeldung bekommen.
        Einzig das der lastZMevent wieder auf INIT steht, obwohl alarm vorhanden war. ich habe jedoch den adapter nicht neu gestartet
        MeistertrM 1 Antwort Letzte Antwort
        • M mikiline
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #165
          @mikiline ja das mit dem init is mir gerade aufgefallen und wird gefixed
            mikiline
            #166
            Websocketmeldungen erscheinen wieder. Und es bringt mir meinen Zoneminder Server durcheinander. Webcam bleibt dann "rot". Scheint etwas mit den Alarmen zu tun zu haben.
            Nach Restart Adapter und ZM geht es wieder
              mikiline
              #167
              wäre es dir möglich bitte noch dies einzubinden
              curl -XGET  http://server/zm/api/states.json # returns list of run states
              curl -XPOST  http://server/zm/api/states/change/restart.json #restarts ZM
              curl -XPOST  http://server/zm/api/states/change/stop.json #Stops ZM
              curl -XPOST  http://server/zm/api/states/change/start.json #Starts ZM
              • M mikiline
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                #168
                @mikiline wenn mal ein Websocket error auftritt ist das nicht so tragisch. da der adapter sich dann ein paar Sekunden später neu verbindet. schwierig wird es wenn in einer Sekunde 10 oder mehr websocket errors aufreten. Das init problem sollte nun behoben sein.
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  #169
                  @Meistertr genau so ist es ja bei mir mit den websocket Errors. Das schaukelt sich immer weiter auf. Aber woran liegt das eigentlich? Bei 2-3 Versionen vorher war das ja noch nicht
                    @djsirius von adapter her passt alles, schau mal unter
                    http://zoneminder/zm/api/monitors.json ob hier monitore aufgelistet sind
                    XsevX Offline
                    XsevX Offline
                    Xsev
                    schrieb am zuletzt editiert von Xsev
                    #170
                    @Meistertr
                    Vielleicht kannst du mir helfen. Ich verwende die Adapter Verison 0.3.3. und ZM 1.32.3.
                    Ich hab seit längerem immer wieder Performance Probleme wenn der Adapter läuft.
                    Anbei ein Screenshot wie das ganze aussieht. Ab dem Moment wenn ich den Adapter Starte steigt stündlich (auf die Minute genau) die CPU Last. Dies geht soweit das mein Broker dann jede Stunde für ca 2 Minuten völlig aus dem Ruder läuft, Vis etc. dann kurzzeitig hängt.
                    Kannst du damit vielleicht was anfangen?
                      mikiline
                      #171
                      @Meistertr
                      Hi, Machst Du noch etwas am Adapter? Falls ja, könntest Du bitte die Tokenaktualisierung auch in dem EventURL aktualisieren?
                      Problem ist, das wenn der Adapter neu startet, der Token bei der MonitorURL aktualisiert wird, jedoch bei der EventURL nicht.
                      Danke und Grüsse
                        djsirius
                        #172
                        @Meistertr
                        Ich würde mich auch freuen, wenn es mit dem Adapter weiter gehen würde! 👍
                        djsirius
                          MeistertrM Offline
                          Meistertr
                          #173
                          Zur Zeit stockt es etwas da ich von zoneminder momentan nicht so begeistert bin und die api sich in den letzten. Versionen stark geeandert hat und eine große Änderung noch bevorsteht.. Aber weiter machen will ich auf jeden Fall noch
                            mikiline
                            #174
                            @Meistertr sagte in Test Adapter zoneminder v0.3.x:
                            Darf ich fragen mit was du nicht mehr so begeistert bist? Hast Du Probleme mit Zoneminder?
                            • coyoteC Offline
                              coyoteC Offline
                              coyote
                              #175
                              Das würde mich auch interessieren. Ich habe letzte Woche zoneminder nochmal komplett neu aufgesetzt und endlich auch die Objekterkennung am laufen, jedoch muss ich momentan sagen, dass die Erkennung irgendwie recht langsam ist.
                              Ich habe nebenbei noch tinycam Monitor auf einen Android Tablet laufen und schicke über simple API einen request sobald eine Erkennung da ist. Das ist locker mindestens 5 Sekunden schneller als zoneminder.
                              Zoneminder bekomme ich einfach momentan nicht gescheit eingestellt.
                              Mit der einen Cam geht die Personenerkennung, mit der anderen erkennt er keine Person, aber Auto funktioniert leider weiß ich nicht wirklich wieso
                                MeistertrM Offline
                                Meistertr
                                #176
                                ich habe zoneminder in einem Container auf proxmox am laufen, glaube da ist auch das Problem , da meine Grafikkarte aus meinem sehr potenten nuc nicht durchgereicht wird. Die Folge ist teilweise sehr hohe CPU last. ich habe ums haus relolink Kameras mit 5mpx die bekomme ich nicht über den rstp steam eingebunden sondern nur über ffmpeg und das auch nur mit einer sehr geringen VGA Auflösung da sonst das Problem mit der hohen CPU last auftritt (nuc i5 mit 3 kernen für zoneminder bekomme ich bis zu 100% Auslastung).
                                Desweiteren nervt der Event Manager der teilweise zu langsam reagiert. Teilweise habe ich bis zu 5 Sekunden Verzögerung gemessen. das ist mir viel zu langsam. Außerdem lößt er teilweise gar nicht aus.
                                Dazu kommt bei hoher Auflösung eine Latenzzeit von 15 Sekunden was nahezu untragbar für mich ist (wahrscheinlich auch der fehlenden Grafikkarte geschuldet)
                                Dann noch das api Problem, in den letzten 3 Versionen sind 3 Verschiedene Apis mit der Ankündigung ein er neuen verbesserten api... da ich im adapter nicht 4 verschiedene Fälle abfangen will warte hier noch etwas ab
                                Johannes BauerstatterJ coyoteC M 3 Antworten Letzte Antwort
                                  Johannes BauerstatterJ Offline
                                  #177
                                  @Meistertr Hallo ich hab auf meinem NUC Motioneye für die Snapshot URL´s und Kerberos für die Bewegungserkennung und Bildaufzeichnung. Meiner Meinung nach viel einfacher zu bedienen als Zoneminder. Leider braucht man in Kerberos für jede Kamera einen eigenen Container.
                                    coyoteC Offline
                                    coyoteC Offline
                                    coyote
                                    #178
                                    @Meistertr OK, dann deckt sich das ja ziemlich mit meiner Erfahrung. Auch im Container auf einem i3 Nuc.
                                    Objekterkennung ist bei mir auch viel zu langsam, wie ich schon geschrieben habe, locker 5 Sekunden zu spät.
                                    @Johannes-Bauerstatter kann kerberos.io Objekterkennung?
                                    Johannes BauerstatterJ 1 Antwort Letzte Antwort
                                    • coyoteC coyote
                                      schrieb am zuletzt editiert von Johannes Bauerstatter
                                      #179
                                      @coyote Bewegungserkennung funktioniert bestens; Objekte geht glaub ich nicht...
                                      • coyoteC coyote
                                        mikiline
                                        #180
                                        @coyote
                                        Also die 5 Sekunden stehen auch in der config für den Eventmanager (als Abfragezeit)
                                        Bei mir läuft Zoneminder eigentlich sehr stabil. Auch die Motionerkennung usw...
                                          mikiline
                                          #181
                                          @Meistertr
                                          Reolink RLC-422 habe ich auch. Bestens eingebunden mit "Remote". in der Kamera selbst am Besten bei Encode auf "Base" stellen
                                          Auch die hohe CPU Last habe ich nicht. Mit einer Kamera habe ich dir mal ein Bild angehängt
                                          Und hier mal meine Konfiguration der Kamera
