  4. Motioneye Telegram
Motioneye Telegram
motioneye telegram
73 Beiträge 5 Kommentatoren 10.5k Aufrufe 8 Beobachtet
    thecastle
      <variables>
        <variable type="undefined" id="timeout">timeout</variable>
        <variable type="undefined" id="timeout2">timeout2</variable>
      </variables>
      <block type="procedures_defnoreturn" id="t_)mr`e%3].H@^udza,~" x="838" y="-362">
        <field name="NAME">Foto senden</field>
        <statement name="STACK">
          <block type="timeouts_settimeout" id="*%r=Y5~X`NnVxrh5XHlk">
            <field name="DELAY">1000</field>
            <field name="UNIT">ms</field>
            <statement name="STATEMENT">
              <block type="exec" id="275h7oKZ+y395LT+iu#-">
                <mutation with_statement="false"></mutation>
                <field name="WITH_STATEMENT">FALSE</field>
                <field name="LOG"></field>
                <value name="COMMAND">
                  <shadow type="text" id="ltM-0,OSxYcM(e^Y{`Sd">
                    <field name="TEXT">wget --output-document /var/lib/motioneye/Camera1 'http://192.168.178.34:8765/picture/1/current/?'</field>
                  </shadow>
                </value>
                <next>
                  <block type="timeouts_settimeout" id=";^]@[*~xh;=yM/dG~iQ%">
                    <field name="NAME">timeout2</field>
                      <block type="telegram" id="#7%V,l]!]C@U3;RF%x{P">
                        <value name="MESSAGE">
                          <shadow type="text" id=",tsALc;|bOL4A$#yWM]{">
                            <field name="TEXT">/var/lib/motioneye/Camera1/alarm.jpg</field>
                          </shadow>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
      <block type="on" id="hV,U:1/V6qpawuVB.m8q" x="163" y="-312">
        <field name="OID">cloud.0.services.ifttt</field>
          <block type="controls_if" id="It:BOaOu][{+og:8@v!w">
            <value name="IF0">
              <block type="logic_compare" id="%8rAH*~R8IQ2{]_V~AoD">
                <field name="OP">EQ</field>
                <value name="A">
                  <block type="get_value" id="E*GzIO?FI{$Q|7rcDec$">
                  </block>
                </value>
                <value name="B">
                  <block type="text" id="zL73Xsp,2Y3xah6462]-">
                    <field name="TEXT">Bewegung_erkannt</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="telegram" id="ERxs|dSCxN8I0:o7Dx?S">
                  <shadow type="text" id="Z7Fqumr:htFev+?tMeKR">
                    <field name="TEXT">Bewegung erkannt</field>
                  </shadow>
                </value>
                <next>
                  <block type="procedures_callnoreturn" id="ut|%,2}Ih[*?OAk4gM[E">
                    <mutation name="Foto senden"></mutation>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    • T thecastle
        <variables>
        </variables>
                    </shadow>
                  </value>
                  <next>
                            </shadow>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
        </block>
              <value name="IF0">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                    </shadow>
                  </value>
                  <next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
        </block>
      </xml>
      crunchipC Offline
      crunchipC Offline
      @thecastle
      @ilovegym sagte in Motioneye Telegram:
      @thecastle du hast im Editor als Warnung stehen, dass du in den settings "exec" einschalten sollst.. 🙂
        thecastle
        Okay das habe ich gemacht. Hat noch jemad eine Idee
        • T thecastle
          crunchipC Offline
          crunchipC Offline
          @thecastle hast du den timeout mal erhöht, z.b.2000ms
            thecastle
            ja, aber das muss an mir liegen weil ich das Bild doch immer unter alarm speichere und das alle bzw... das erste immer wieder verende
              thecastle
              Habe mal die Anleitung oben versucht, da habe ich soweit alles bis auf... ich verstehe nich ganz was ich da alles eintragen soll?
              // Variablen
              var cam_img = 'http://192.168.178.34:8765/picture/1/current/';   // Pfad zum Kamerabild (Im Beispiel eine Foscam)
              var trigger_auto = 'hm-rpc.0.JEQXXXXXXX.1.MOTION';  // Datenpunkt zur autmatischen Auslösung (Status des Bewegungsmelders, Fenster-/ Türkontakt oder der Türklingel)
              var trigger_manu = 'javascript.0.notify.telegram.cam.trigger_manu'; // Datenpunkt zur manuellen Auslösung (wird bei Bedarf automatisch angelegt)
              var trigger_more_img = 'javascript.0.notify.telegram.cam.trigger_more_img'; // Datenpunkt zur Abfrage weiterer Bilder (wird bei Bedarf automatisch angelegt)
              var disable = 'javascript.0.notify.telegram.cam.disable';   // Aktivierung/Deaktivierung des Versands per telegram (wird bei Bedarf automatisch angelegt)
              var interval = '3000';  // Verzögerung der weiteren Aufnahmen in Millisekunden
              var img_path = '/opt/iobroker/temp/cam/';   // Pfad zum lokalen Speicherort der aufgenommenen Bilder. Bilder werden bei jeder Auslösung überschrieben. Pfad muss schon vorhanden sein!
              // Ab hier braucht in der Regel nichts mehr geändert zu werden. Also Finger weg wenn du nicht weißt was du tust. :)
              // Datenpunkte anlegen (Kann unter Umständen auskommentiert werden, wenn die Datenpunkte manuell angelegt wurden.)
              createState( trigger_auto, false, {name: 'http://192.168.178.34:8765/picture/1/current/'});
              createState( trigger_manu, false, {name: 'http://192.168.178.34:8765/picture/1/current/'});
              createState( trigger_more_img, false, {name: 'http://192.168.178.34:8765/picture/1/current/'});
              createState( disable, false, {name: 'Aktivierung/Deaktivierung des Versands per telegram'});
              ``` I
              • T thecastle
                // Variablen
                ``` I
                crunchipC Offline
                crunchipC Offline
                @thecastle was ist unklar?
                  thecastle
                  Im prenzieb alles was ich da selber eintragen muss (ich weiß es steht auskommentiert dahinter ) aber weiß nicht was verlangt wird
                  • T thecastle
                    crunchipC Offline
                    crunchipC Offline
                    @thecastle
                    • var cam_img = deinen Pfad der cam
                    • var trigger_auto = ist der Datenpunkt, den du angelegt hast und per webhook in Motioneye triggerst
                    • var img_path = dein pfad den du dir angelegt hast, wo das Bild gespeichert wird
                      den rest kannst du so lassen
                    danach musst du noch deine Text2Command Befehle eintragen, ist ja auf der Seite gut beschrieben
                      thecastle
                      Lönnte das so aussehen?
                      // Variablen
                      var cam_img = 'http://192.168.178.34:8765/';   // Pfad zum Kamerabild (Im Beispiel eine Foscam)
                      var trigger_auto = 'https://maker.ifttt.com/Trigger/KameraBewegung/with/key/nquVxRxR5JetQdqt3tGhagx3ZwyV407mxDRQhJDx3Hq';  // Datenpunkt zur autmatischen Auslösung (Status des Bewegungsmelders, Fenster-/ Türkontakt oder der Türklingel)
                      var img_path = '/var/lib/motioneye/Camera1/';   // Pfad zum lokalen Speicherort der aufgenommenen Bilder. Bilder werden bei jeder Auslösung überschrieben. Pfad muss schon vorhanden sein!
                      • T thecastle
                        // Variablen
                        crunchipC Offline
                        crunchipC Offline
                        @thecastle nicht ganz
                        das stimmt nicht, da sollte dein erstellter Datenpunkt rein und dieser wird von motioneye getriggert
                        hier als Beispiel in meinem Fall
                        var trigger_auto = 'kamera.0.detection-pi';  // Datenpunkt zur autmatischen Auslösung
                          thecastle
                          Achsoo das ist bei mir in Motioneye so wie ich es trinne habe ;( ich schau mal ob ich das nur so ender kann
                            thecastle
                            Gieb es ein fertiges bsp.?
                            • T thecastle
                              crunchipC Offline
                              crunchipC Offline
                              @thecastle in wie fern, das Beispiel siehst du doch auf der Seite und ist alles erklärt.
                              das was du machen musst,
                              • ein Datenpunkt anlegen,
                              • web Hook Url in Motioneye hinterlegen( dieser schaltet dann deinen Datenpunkt true/false) ist sozusagen dein Auslöser( vergleichbar mit Schalter/Bewegungsmelder)
                                alles andere, hab ich oben schon geschrieben
                                thecastle
                                Mit was hat der Datenpunk den zutun? Angenommen ich würde einen neuen web Hook mit ifttt machen muss ich dan dort den Datenpunkt anlegen?, das Ding ist ja das mein web hook funktioniert ich bekomme ja mit meiner "Methode" auch ein Bild, auch wenn es jetzt des selbe ist( immer die sebe Datei deshalb funktioniert der webhook. Ich verstehe nur nicht ganz das mit dem Datenpunk. Ich bin total verwirrt ;(
                                • T thecastle
                                  Hallo, möchte mit Motioneye eine Motiondetection realisieren wo mir per Telegram eine Nachricht schickt.
                                  Gegeben ist:
                                  RPI2, Ioproker, Motioneye und Telegram mit Botvather *alles installiert und funktioniert
                                  Für jede anfängerfreundliche Hilfe wäre ich sehr dankbar
                                  crunchipC Offline
                                  crunchipC Offline
                                  @thecastle sagte in Motioneye Telegram:
                                  Das war doch deine Anfangsfrage! Ich verstehe nicht was du mit ifttt willst.
                                  Deine Kamera ist in Motioneye eingebunden. Wenn die Kamera eine Bewegung erkennt, schaltet dein angelegter Datenpunkt , mittels webhook auf true.
                                  Also vereinfacht im script...
                                  Bewegung erkannt, Datenpunkt wird true, hole Bild, sende Bilde an telegram.
                                  Wenn du noch text2command mit eingerichtet hast, kannst du manuell ein Bild abrufen, Überwachung an/aus schalten
                                    thecastle
                                    Also ich bin gerade bei deiner Anleitung von oben nicht mehr bei den skript von mir und bei deinem stimmt ja mein Webhook nicht weil der anders ausschaut wie bei dir, wegen dem "kamera.0.detection-pi" Datenpunkt. jetzt weiß ich nichtv ob ich bei dem kamera.0.detection-pi ein skript anlegen soll oder ( stehe auf dem Schlauch)
                                    Es wäre mega super wenn wenn du mir schritt für schritt sagen könntest wie ich das löse könnnte.
                                      thecastle
                                      schrieb am zuletzt editiert von thecastle
                                      Oje :( Jetzt habe ich solange daran rumgespiel das ich jetzt noch nicht mal mehr eine Nachrricht bei bewegung bekomme
                                      Angenommen ich würde noch mal alles neu machen, wo hast du dein webhook angelegt?
                                      • T thecastle
                                        crunchipC Offline
                                        crunchipC Offline
                                        @thecastle also nochmal von vorne, was möchtest du verwenden, das Blockly oder das javascript?
                                        mein Datenpunkt war nur ein Beispiel, denn kannst du benennen wie du willst. je nach Struktur, ob du
                                        0_userdata.0 oder einen selbst angelegten Ordner erstellst, ist dir überlassen.
                                        Als Beispiel
                                        Mein Ordner lautet
                                        • Kamera.0
                                          darin 2 Datenpunkte
                                        • detection-haustuer
                                        • trigger-haustuer
                                        mein webhook in motioneye
                                        http://IoBrokerIP:8087/set/kamera.0.detection-haustuer?value=true
                                        Speicherort für das Foto
                                        /opt/iobroker/ipcam/alarm
                                        als Blockly
                                          thecastle
                                          Achsoo also ist webhook nix outsourced bei ifttt oder einem anderen Anbieter?
                                          ich versuche das mal so nach zustellen.
