  4. [gelöst] iobroker offline nach admin update
    6.3k
adminadapterupdatejs.controllerfrage
86 Beiträge 8 Kommentatoren 14.4k Aufrufe 5 Beobachtet
  • J JRiddim
    @haselchen sagte in iobroker nicht mehr erreichbar nach admin update:
    npm install iobroker.admin.0@3.7.2 --production
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.admin.0 - Not found
    npm ERR! 404
    npm ERR! 404  'iobroker.admin.0@3.7.2' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     /root/.npm/_logs/2020-01-29T23_00_25_012Z-debug.log
    sowohl als auch mit und ohne sudo
    haselchenH Offline
    haselchenH Offline
    haselchen
    @JRiddim
    lass mal den punkt und die 0 weg.
    npm install iobroker.admin@3.7.2 --production
    hilft das auch nicht, dann ein letzter versuch:
    cd /opt/iobroker
    sudo npm cache clean
    sudo iobroker stop
    sudo npm install iobroker.admin
    sudo iobroker start
    • haselchenH haselchen
      @JRiddim
      cd /opt/iobroker
      sudo iobroker stop
      sudo iobroker start
      JRiddim
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.admin@3.7.2
      updated 1 package in 23.061s
      19 packages are looking for funding
        run `npm fund` for details
      Langsam aber sicher.
      • J JRiddim
        haselchenH Offline
        haselchenH Offline
        haselchen
        @JRiddim
        und nun nach
        iobroker start admin.0 (oder iobroker restart)
        wie sieht es aus, kommste auf die oberfläche?
          @JRiddim
          und nun nach
          JRiddim
          system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1 : admin - enabled, port: 8089, bind: 0.0.0.0, run as: admin
          was mich nur wundert. Auf die Ports 8082, 8088, auf die ich komme ist eine ip hinterlegt nicht so wie bei den admin Instanzen?
          • J JRiddim
            haselchenH Offline
            haselchenH Offline
            haselchen
            @JRiddim
            So jetzt das Finale.
            Das hatte ich gestern auch.
            Also.... das gibst du jetzt ein
            sudo iobroker del admin.0
            sudo iobroker del admin.1
            sudo iobroker add admin.0
              @JRiddim
              JRiddim
              schrieb am zuletzt editiert von JRiddim
              sudo iobroker add admin 0
              die neue Admin.0 Instanz wird nur am Anfang als an angezeigt und dann wieder kein Lebenszeichen!
              + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              • J JRiddim
                haselchenH Offline
                haselchenH Offline
                haselchen
                @JRiddim
                was ergibt
                iobroker list instances
                  @JRiddim
                  was ergibt
                  JRiddim
                  @haselchen
                  siehe post drüber.
                  • J JRiddim
                    @haselchen
                    siehe post drüber.
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @JRiddim
                    so sieht es bei mir auch aus.
                    wenn du die seite iobroker aufrufen willst, bleibt die seite weiss oder gibt es eine fehlermeldung?
                      @JRiddim
                      JRiddim
                      @haselchen
                      es tut sich gar nichts. es wird nichts geladen.
                      J haselchenH 2 Antworten Letzte Antwort
                      • J JRiddim
                        @haselchen
                        JRiddim
                        @JRiddim
                        ich danke dir jetzt schon mal für deine Hilfe! Finde ich wirklich Klasse!
                        Du hast wahrscheinlich keine Idee mehr...
                        • J JRiddim
                          @haselchen
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @JRiddim
                          Der Browser müsste ja irgendeine Meldung bringen.
                          Mir fällt sonst leider nichts mehr ein.
                          Ich benutze Firefox.
                          Da könnte ich nur, wie eben schon geschrieben, raten, Cache leeren und F5 drücken als Hardrefresh. Raspberry Neustart.
                          Ansonsten müssen dann andere Cracks hier ran.
                          Tut mir leid.
                            @JRiddim
                            Tut mir leid.
                            JRiddim
                            @haselchen
                            Es kommt:
                            Fehler: Verbindung fehlgeschlagen
                            Firefox kann keine Verbindung zu dem Server unter 192.155.220.22:8081 aufbauen.
                            Ich hoffe es hat noch jemand eine andere Idee.
                            nochmals Danke
                            • J JRiddim
                              @haselchen
                              Es kommt:
                              nochmals Danke
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @JRiddim
                              Ist das ne spezielle IP Adresse?
                              In der Konstellation habe ich das noch nicht gesehen.
                              Sorry , ich muss das fragen, das ist die IP Adresse des Raspi wo Iobroker installiert ist?
                                @JRiddim
                                JRiddim
                                @haselchen
                                ach so nein hab jetzt nur die Zahlen auf die schnelle getippt die stimmen nicht :)
                                • J JRiddim
                                  @haselchen
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @JRiddim
                                  Aaaaach so.
                                  Okay. Ich geh pennen. Vielleicht kommt mir da noch ne Idee 😊
                                    @JRiddim
                                    Aaaaach so.
                                    JRiddim
                                    @haselchen
                                    gute Nacht :) ja das wäre super!
                                    • J JRiddim
                                      @haselchen
                                      timtig
                                      schrieb am zuletzt editiert von timtig
                                      @JRiddim
                                      hast du eigentlich evtl. noch irgendwo eine Sicherung? Würde ich versuchen einzuspielen oder den ordner einfach austauschen, und noch mal die schritte die ich dir geschrieben habe zu wiederholen. Ich habe jetzt auch gelernt die Sicherung öfters zu machen :-)
                                      und chmode hast du hoffentlich mit -R gemacht also rekursiv?
                                      • J JRiddim
                                        @haselchen
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @JRiddim
                                        Leider bin ich mit den Ideen am Ende.
                                        Vielleicht mag sich
                                        @apollon77
                                        @Homoran
                                        @arteck
                                        mal mit dem Thema auseinandersetzen.
                                        • HomoranH Offline
                                          HomoranH Offline
                                          Hab jetzt nicht den ganzen thread gelesen
                                          was gibt denn iobroker list instances aus
