  4. Test Adapter deConz v1.2.x Github
    6.7k
zigbeehuedeconz
250 Beiträge 30 Kommentatoren 55.2k Aufrufe 29 Beobachtet
  • T ticaki
    EDIT: Version des Adapters 1.2.4
    auf folgende Merkwürdigkeit möchte ich dich Hinweisen.
    die folgenden Zeilen Javascript:
    //brightness startet bei 1. Bei 2 gibts ebenfalls diesen Fehler.
    setState(hueGroupId+'.bri', brightness);
    setState(hueGroupId+'.on', true);
    setState(hueGroupId+'.ct', temperature);
    erzeugen diesen Fehler:
    2020-01-23 11:51:10.864 - info: deconz.0 (15386) setLightState: {"transitiontime": 0, "bri": 1, "on": true} 3 deconz.0.Lights.3.bri
    2020-01-23 11:51:10.865 - info: deconz.0 (15386) setLightState: {"transitiontime": 0, "on": true} 3 deconz.0.Lights.3.on
    2020-01-23 11:51:10.868 - info: deconz.0 (15386) setLightState: {"transitiontime": 0, "ct": 500} 3 deconz.0.Lights.3.ct
    2020-01-23 11:51:10.891 - debug: deconz.0 (15386) STATUS: 200
    2020-01-23 11:51:10.894 - debug: deconz.0 (15386) options: {"url":"http://192.168.178.96:80/api/A45B838DDE/lights/3/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"transitiontime\": 0, \"bri\": 1, \"on\": true}"}
    2020-01-23 11:51:10.895 - debug: deconz.0 (15386) setLightState BODY: [{"success":{"/lights/3/state/on":true}},{"success":{"/lights/3/state/bri":1}}]
    2020-01-23 11:51:10.897 - debug: deconz.0 (15386) STATUS: 200
    2020-01-23 11:51:10.897 - debug: deconz.0 (15386) options: {"url":"http://192.168.178.96:80/api/A45B838DDE/lights/3/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"transitiontime\": 0, \"on\": true}"}
    2020-01-23 11:51:10.898 - debug: deconz.0 (15386) setLightState BODY: [{"success":{"/lights/3/state/on":true}}]
    2020-01-23 11:51:10.905 - debug: deconz.0 (15386) Websocket message: {"e":"changed","id":"3","r":"lights","state":{"alert":null,"bri":1,"colormode":"ct","ct":495,"hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"t":"event","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:10.907 - debug: deconz.0 (15386) Websocket message: {"e":"changed","id":"3","r":"lights","state":{"alert":null,"bri":1,"colormode":"ct","ct":495,"hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"t":"event","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:10.912 - debug: deconz.0 (15386) STATUS: 200
    2020-01-23 11:51:10.913 - debug: deconz.0 (15386) options: {"url":"http://192.168.178.96:80/api/A45B838DDE/lights/3/state","method":"PUT","headers":"Content-Type\" : \"application/json","body":"{\"transitiontime\": 0, \"ct\": 500}"}
    2020-01-23 11:51:10.914 - debug: deconz.0 (15386) setLightState BODY: [{"success":{"/lights/3/state/ct":500}}]
    2020-01-23 11:51:10.933 - debug: deconz.0 (15386) Websocket message: {"e":"changed","id":"3","r":"lights","state":{"alert":null,"bri":1,"colormode":"ct","ct":500,"hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"t":"event","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:10.940 - debug: deconz.0 (15386) Websocket message: {"e":"changed","id":"3","r":"lights","state":{"alert":null,"bri":1,"colormode":"ct","ct":500,"hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"t":"event","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:10.946 - debug: deconz.0 (15386) getLightState: {"ctmax":500,"ctmin":153,"etag":"a4b6ab663ef256f0c2582cce188cf431","hascolor":true,"manufacturername":"Philips","modelid":"LST002","name":"Bett","state":{"alert":"none","bri":1,"colormode":"ct","ct":500,"effect":"none","hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:10.961 - debug: deconz.0 (15386) getLightState: {"ctmax":500,"ctmin":153,"etag":"a4b6ab663ef256f0c2582cce188cf431","hascolor":true,"manufacturername":"Philips","modelid":"LST002","name":"Bett","state":{"alert":"none","bri":1,"colormode":"ct","ct":500,"effect":"none","hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:11.004 - debug: deconz.0 (15386) getLightState: {"ctmax":500,"ctmin":153,"etag":"a4b6ab663ef256f0c2582cce188cf431","hascolor":true,"manufacturername":"Philips","modelid":"LST002","name":"Bett","state":{"alert":"none","bri":1,"colormode":"ct","ct":500,"effect":"none","hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:11.019 - debug: deconz.0 (15386) getLightState: {"ctmax":500,"ctmin":153,"etag":"a4b6ab663ef256f0c2582cce188cf431","hascolor":true,"manufacturername":"Philips","modelid":"LST002","name":"Bett","state":{"alert":"none","bri":1,"colormode":"ct","ct":500,"effect":"none","hue":7228,"on":true,"reachable":true,"sat":223,"xy":[0.5243,0.4137]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:a0:03:7c-0b"}
    2020-01-23 11:51:14.085 - info: admin.0 (812) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    folgendes funktioniert auch mit 1 und 2:
    // setState(hueGroupId+'.on', true);
    Gruß Tim
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #134
    @ticaki also zuerst muss man mal wissen, egal welchen Befehl man an eine Lampe senden will sie muss an sein. Das bedeutet on muss als erste gesetzt werden.
    Dann ist es so das bei Änderung der Helligkeit (bri) on als Parameter mitgegeben wird, somit ist on als eigener Befehl überflüssig.
    Wenn mehrere Befehle auf einmal gesendet werden soll ist es besser das mit action zu machen, damit lassen sich alle Paramter mit einem Befehl übergeben.
    "on": true, "bri": 1
    Das von dir gezeigte Problem ist eine Art Schleife die durch mehrere Befehle hintereinander verursacht wird.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    T M 2 Antworten Letzte Antwort
    • Jey CeeJ Jey Cee
      T Nicht stören
      T Nicht stören
      ticaki
      #135
      @Jey-Cee
      Danke, wusste nicht wie ich mehrere Befehle übergebe. :) Und das Script ist auch schon etwas älter.
      Spenden
      • Jey CeeJ Jey Cee
        Markus84
        #136
        @Jey-Cee said in Test Adapter deConz v1.2.x Github:
        Mir war auch nicht klar, dass man mehrere Befehle gemeinsam übergeben kann. Ich habe gerade noch versucht die Farbe über
        "on": true, "bri": 253, "xy": 0.5455,0.3861
        mit zu übergeben. Das funktioniert leider nicht. Hast du eine Idee warum nicht?
        • M Markus84
          T Nicht stören
          T Nicht stören
          ticaki
          #137
          @Markus84
          setState(myBlinkObjID+'.action', '"on": true, "bri": 1, "ct": 500, "transitiontime": 500');
          setState('deconz.0.Lights.3.action', '"on": true, "bri": '+minBri+', "ct": '+maxCt);
          Sollte selbst erklärend sein.
          Spenden
          • T ticaki
            @Markus84
            Markus84
            #138
            @ticaki
            Ich möchte gerne die Farbe mit "xy" setzen und nicht über "ct". Und das funktioniert selbst dann nicht, wenn ich es unmittelbar in den Datenpunkt eingebe...
            AsgothianA T 2 Antworten Letzte Antwort
            • M Markus84
              @ticaki
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #139
              @Markus84
              Versuch bitte mal dieses:
              "on": true, "bri": 253, "xy": [0.5455,0.3861], “colormode”: “xy”
              • M Markus84
                @ticaki
                T Nicht stören
                T Nicht stören
                ticaki
                #140
                @Markus84
                Ich bin zu müde. sry, hab die eigentliche Frage übersehen.
                Bei funktioniert die direkte Eingabe in den Datenpunkt. Die Daten werden zwar angepasst aber landen immer in der Nähe der eingegebenen Werte. Eingabe: 0.1414,0.4545 bestätigte Werte: 0.1637,0.4539
                Skript kann ich morgen testen.
                EDIT: Wenn ich den Colormode über Datenpunkt ändere, reagiert die Lampe die nächsten paar Sekunden nicht.
                Spenden
                • T ticaki
                  @Markus84
                  Markus84
                  #141
                  @ticaki
                  Super, besten Dank. Bei mir geht es mit
                  "on": true, "bri": 253, "xy": [0.1577,0.2229]
                  Der Wert bei xy muss nur in Klammern gesetzt sein. Colormode ist gar nicht nötig.
                  Besten Dank nochmal!
                  • Jey CeeJ Jey Cee
                    @schittl ja kann so verwendet werden.
                    @Holger76 sagte in Test Adapter deConz v1.2.x Github:
                    Soweit läuft alles super... nur leider reagiert manchmal kein Conbee Gerät mehr über ioBroker (über die Phoscon Sotware schon), sodass ich den Adapter neu starte, dann gehts auch wieder.
                    Liefern die Sensoren keine Werte oder werden die Lampen nicht geschalten?
                    EDIT: eine Sache hänge ich gleich noch dran: Ich habe festgestellt, wenn ich sage, "Alexa, Garderobe Licht aus", dass das Licht aus geht (ist ne 4er Hue Gruppe), der Gruppendatenpunkt [on] in ioBroker aber nicht aktualisiert wird. in der phoscon App aber ist das Gruppensymbol erloschen und wird auch wieder hell, wenn ich per Alexa das Licht wieder einschalte. Wenn ich in der Phoscon App direkt das Licht schalte, ist in iobroker auch der Datenpunkt in ioboker gesetzt. Ich weiß nun nicht, wo da der Wurm drin ist...
                    Kann ich nicht Nachvollziehen da ich kein Alexa nutze. Hast du Alexa direkt mit Phoscon verbunden oder geht das über ioBroker?
                    Holger76H Offline
                    Holger76H Offline
                    Holger76
                    #142
                    @Jey-Cee Der Fehler ist jetzt erst wieder aufgetreten. Ich bemerke dies immer anhand der Aqara Bewegungsmelder, wo kein Signal in ioBroker ankommt. Wenn ich dann mit meinen Homematic Funk-Wandsendern das Signal zum manuellen Lampen einschalten losschicke, gehen sofort die Lampen an. Also die Hue Lampen gehen ohne Probleme. Der Status der Bewegungsmelder hatte sich seit Stunden icht mehr aktualisiert, obwohl meine Frau sich ständig zb im Flur bewegte, wo einier dieser Melder installiert ist.
                    Erst nach Neustart des Adapters geht alles wieder wie gewohnt. Der Adapter ist stets die neueste Latest-Version.
                    JA, Phoscon ist auch direkt mit Alexa verbunden und läuft auch so ohne ioBroker.
                    NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
                    NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
                    • ? Offline
                      #143
                      Beim verbinden kommt Error obwohl Done da steht. Sollte also nicht als Error ausgegeben werden. Kommt beim verbinden zum Stick.
                      • Holger76H Holger76
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #144
                        @Holger76 hast du die version 1.2.4 insalliert? Das was du schilderst ist der Tatsache geschuldet das deConz neu gestartet wird, dadurch verliert der Adapter die Verbindung, das sollte zwar schon in der Version 1.2.3 des Adapters abgefangen werden aber mit der 1.2.4 ist es Definitv so. Das schließt aber nicht aus das Status Updates von Sensoren verloren gehen, da es ein mindestabstand zwischen den alive Meldungen gibt.
                        Effektiv kann das bedeuten das du deConz Version .70 verwenden musst.
                        @Brainbug sagte in Test Adapter deConz v1.2.x Github:
                        Schönheitsfehler, wird demnächst behoben. Ich glaub du bist der erste der das Meldet ;-)
                        ? Holger76H 2 Antworten Letzte Antwort
                        • Jey CeeJ Jey Cee
                          #145
                          @Jey-Cee said in [Test Adapter deConz v1.2.x Github]:
                          Sicher denn dann kann ich heute Nacht nicht schlafen 😜
                          • Jey CeeJ Jey Cee
                            Holger76H Offline
                            Holger76H Offline
                            Holger76
                            schrieb am zuletzt editiert von Holger76
                            #146
                            @Jey-Cee ich nutze in der Tat die Deconz Version 2.05.72 vom 12.12.19
                            (und Die Adapter Version 1.2.4)
                            Ein downgrade wird wohl nicht so ohne weiteres möglich sein - aber sollte das wirklich der Grund sein ?
                            Manuell habe ich Deconz auf jeden Fall nicht neu gestartet (zumindest nicht zu den Zeiten, wo es diese Probleme gab)
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #147
                              @Holger76 manuelles downgrade von deconz sollte kein Problem sein. Ich konnte einfach die 2.05.59 wieder installieren als ich die Probleme hatte.
                              A.
                                alex030
                                #148
                                @Jey-Cee Ich habe auch die neue Version installiert. Läuft soweit ganz gut. Vielen Dank! Ich habe eine Frage. In deCONZ habe ich 2 Busch-Jaeger Friends of Hue Schalter hinzugefügt. Diese funktionieren in deCONZ auch. Allerdings wird es mir über den Adapter nicht zu iobroker übertragen. Es gibt die Objekte dort einfach nicht. Im Debug Log, beim initialen Start der Instanz, wird es unter den Sensoren angezeigt. Dann aber nicht als Objekt angelegt. Was mache ich falsch? Hat jemand einen Hinweis für mich?
                                  mariohbs
                                  #149
                                  Hi Zusammen,
                                  ich habe auch das Problem, dass nach einer gewissen Zeit die Werte meiner Lampen und Schalter nicht mehr aktualisiert werden. Ich steuere die Lampen über Befehle im "action" Datenpunkt, was auch problemlos funktioniert. Normalerweise ändern sich dann auch alle angesprochenen Datenpunkte entsprechend. Nach einiger Zeit funktioniert dies aber nicht mehr, die Steuerung funktioniert aber noch Problemlos.
                                  Die Datenpunkte "Gateway_Info -> alive" und "info -> connection" bleiben aber auf true. Nach einem Neustart des Adapters geht alles sofort wieder. Adapter-Version ist 1.2.4.. Deconz läuft bei mir im Docker Container, da ich einen Rock64 verwende und es dafür wohl noch keine Installation gibt.. Keine Ahnung wo ich da die Version sehen kann....
                                  Kann ich irgendwas tun um die Rückmeldungen stabil zu bekommen?
                                  Danke und Gruß
                                  Mario
                                  Jey CeeJ Holger76H 2 Antworten Letzte Antwort
                                  • M mariohbs
                                    Hi Zusammen,
                                    Danke und Gruß
                                    Mario
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #150
                                    @mariohbs sagte in Test Adapter deConz v1.2.x Github:
                                    In der Adapter Konfiguration siehst du das.
                                      mariohbs
                                      #151
                                      Nu ja, die einfachsten Dinge übersieht man :-)
                                      Also die Version ist 2.5.69
                                      • M mariohbs
                                        Hi Zusammen,
                                        Danke und Gruß
                                        Mario
                                        Holger76H Offline
                                        Holger76H Offline
                                        Holger76
                                        #152
                                        @mariohbs
                                        dann scheint es ja doch nicht nur an meiner beta version zu liegen, denn genau das gleiche Problem habe ich auch.
                                        Ich hatte auch schon probiert, die .69er Version zu installieren und das Repo auf stable zu ändern. Nach upgrade hat er dann natürlich die 71er Stable installiert, zumindest stand das so in der Konsole... in der Phoscon App steht aber trotzdem noch .72 ?! Ich verstehs nicht Wenn noch jmd einen sicheren Weg weiß, bzw woran das liegt, nur her damit.
                                        Aber wie gesagt, da es ja scheinbar dann doch nicht mein Problem löst, ist letztendlich auch egal. Komisch nur, dass nur wenige Leute das Problem haben.
                                        • A alex030
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          schrieb am zuletzt editiert von Jey Cee
                                          #153
                                          @alex030 sagte in Test Adapter deConz v1.2.x Github:
                                          Kannst du mir das bitte mal zeigen.
                                          @Holger76 @mariohbs welche JS-controller Version nutzt ihr?
                                          Läuft ioBroker auf dem selben Host?
                                          Wenn es auch mit der .69 Auftritt könnte der Fehler auch im Adapter liegen, dazu habe ich schon eine Meldung bekommen die drauf hindeutet. Leider konnte ich das bisher nicht Nachstellen und hab noch keine weiteren Infos bekommen.
                                          Könnt ihr mal das Log level der deConz Instanz auf debug stellen und beobachten ob da Meldungen ala "Websocket message: {..." zu sehen sind während die Objekte nicht mehr Aktualisiert werden.
                                          Zum Thema falsche Versions Anzeige im Browser, leert doch mal den Cache.
                                          Holger76H M T A 4 Antworten Letzte Antwort
