Adapter: Weatherunderground 24h Prognose
Update erledigt wie empfohlen, leider jetzt Fehler:
2016-01-17 23:14:00.916 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.weatherunderground.0 started with pid 1427
2016-01-17 23:14:01.794 - info: weatherunderground.0 starting. Version 0.0.4 in /Users/pix/Documents/iobroker/node_modules/iobroker.weatherunderground
2016-01-17 23:14:01.818 - error: uncaught exception: Cannot read property 'length' of undefined
2016-01-17 23:14:01.820 - error: TypeError: Cannot read property 'length' of undefined
at getWuConditionsData (/Users/pix/Documents/iobroker/node_modules/iobroker.weatherunderground/weatherunderground.js:133:31)
at Object.utils.adapter.ready (/Users/pix/Documents/iobroker/node_modules/iobroker.weatherunderground/weatherunderground.js:49:9)
at initAdapter (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2746:58)
at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:328:29)
at Socket.onack (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
at Socket.onpacket (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
at Manager. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
at Manager.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
at Manager.ondecoded (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
at Decoder. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
2016-01-17 23:14:02.121 - info: weatherunderground.0 adapter weatherunderground is unloading
2016-01-17 23:14:02.130 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.weatherunderground.0 terminated with code 6 (uncaught exception)</anonymous></anonymous></anonymous>Ausserdem hat mein Config Fenster kein weiteres Feld. Hab den Cache gelöscht. Gruß Pix -
uiuiui… das scheint kein guter Tip gewesen zu sein. Offenbar wird die Config nicht automatisch neu geladen, wenn nur mit npm die neuste Version installiert wird.
Also um Sauber nochmals von Vorne zu beginnen:
- api-key und location aus dem aktuellen config Dialog rauskopieren (brauchen wir gleich wieder)
iobroker del weatherunderground
npm uninstall iobroker.weatherunderground (ich glaube das ist nicht unbedingt nötig)
npm install iobroker.weatherunderground
iobroker add weatherunderground
nun sollte die neuster Version installiert sein. Im Config Dialog sollte nun auch die Zeile für die Mess Station vorhanden sein.
config wieder einfüllen
viel Erfolg!
Daniel
korrigiert nach Hinweis von Pix - Danke!
super Arbeit. Der Adapter läuft einwandfrei. Jetzt kann ich einen weiteren Teil von der CCU auf iobroker umziehen.
Gibt es eine Möglichkeit, die Daten (weather (engl.)) auch in Deutsch anzurufen?
Gruß Andreas
Gesendet von meinem Nexus 5 mit Tapatalk
npm uninstall weatherunderground (ich glaube das ist nicht unbedingt nötig)
npm install weatherunderground
viel Erfolg!
Daniel `
mit der Anleitung gab es an einer Stelle ein Problem.
Es sollte npm install iobroker.weatherunderground heißen, dann gehts.
Vielen Dank für den Adapter und die schnelle Hilfe :D
Pix
jetzt sind doch wieder Probleme aufgetaucht. Der homekit Adapter stürzt beim Einlesen der wunderground Daten an einer Stelle ab:
2016-01-20 17:59:40.008 - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
2016-01-20 17:59:40.010 - info: homekit.0 requesting all states
2016-01-20 17:59:40.011 - info: homekit.0 requesting all objects
2016-01-20 17:59:41.726 - info: homekit.0 received all states
2016-01-20 17:59:43.110 - info: homekit.0 received all objects
2016-01-20 17:59:43.111 - info: homekit.0 hap-nodejs starting...
2016-01-20 17:59:43.121 - info: homekit.0 Accessory: Switch Object: State
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Thermostat Object: CurrentTemperature
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Thermostat Object: TargetTemperature
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Thermostat Object: State
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Temperature Object: CurrentTemperature
2016-01-20 17:59:43.122 - info: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity
2016-01-20 17:59:43.123 - info: homekit.0 Accessory: Light Object: State
2016-01-20 17:59:43.125 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.1.CUX9002001.1.TEMPERATURE
2016-01-20 17:59:43.126 - info: homekit.0 < hap CUxD Wetter Sensoren Balkon.TEMPERATURE get CurrentTemperature for hm-rpc.1.CUX9002001.undefined
2016-01-20 17:59:43.127 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.FEQ0064905.1.TEMPERATURE
2016-01-20 17:59:43.127 - info: homekit.0 < hap Thermostat WC Sensoren.TEMPERATURE get CurrentTemperature for hm-rpc.0.FEQ0064905.1.TEMPERATURE
2016-01-20 17:59:43.130 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.HEQ0130265.1.TEMPERATURE
2016-01-20 17:59:43.130 - info: homekit.0 < hap Thermostat Schlafzimmer Sensoren.TEMPERATURE get CurrentTemperature for hm-rpc.0.HEQ0130265.1.TEMPERATURE
2016-01-20 17:59:43.132 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.HEQ0237599.1.TEMPERATURE
2016-01-20 17:59:43.132 - info: homekit.0 < hap Temperatur Feuchte Sensoren Balkon.TEMPERATURE get CurrentTemperature for hm-rpc.0.HEQ0237599.undefined
2016-01-20 17:59:43.132 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.HEQ0367075.1.TEMPERATURE
2016-01-20 17:59:43.133 - info: homekit.0 < hap Thermostat Bad Sensor.TEMPERATURE get CurrentTemperature for hm-rpc.0.HEQ0367075.1.TEMPERATURE
2016-01-20 17:59:43.133 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.KEQ0516482.4.ACTUAL_TEMPERATURE
2016-01-20 17:59:43.133 - info: homekit.0 < hap Heizkörper Bad Klima RT.ACTUAL_TEMPERATURE get CurrentTemperature for hm-rpc.0.KEQ0516482.4.ACTUAL_TEMPERATURE
2016-01-20 17:59:43.134 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.1.TEMPERATURE
2016-01-20 17:59:43.134 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:1.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined
2016-01-20 17:59:43.135 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.2.TEMPERATURE
2016-01-20 17:59:43.137 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:2.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined
2016-01-20 17:59:43.139 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.3.TEMPERATURE
2016-01-20 17:59:43.139 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:3.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined
2016-01-20 17:59:43.140 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.4.TEMPERATURE
2016-01-20 17:59:43.140 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:4.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined
2016-01-20 17:59:43.140 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.5.TEMPERATURE
2016-01-20 17:59:43.141 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:5.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined
2016-01-20 17:59:43.141 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day2.temperature_max
2016-01-20 17:59:43.141 - info: homekit.0 < hap Forecast of temperature for the day after tomorrow get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.142 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day2.temperature_min
2016-01-20 17:59:43.142 - info: homekit.0 < hap Forecast of temperature for the day after tomorrow get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.143 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day1.temperature_max
2016-01-20 17:59:43.143 - info: homekit.0 < hap Forecast of temperature for tomorrow get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.144 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day1.temperature_min
2016-01-20 17:59:43.144 - info: homekit.0 < hap Forecast of temperature for tomorrow get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.145 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_max
2016-01-20 17:59:43.145 - info: homekit.0 < hap Forecast of temperature for today get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.145 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_min
2016-01-20 17:59:43.146 - info: homekit.0 < hap Forecast of temperature for today get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.147 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_actual
2016-01-20 17:59:43.147 - info: homekit.0 < hap Actual temperature get CurrentTemperature for yr.0.forecast.undefined
2016-01-20 17:59:43.148 - info: homekit.0 > iobroker subscribe Thermostat weatherunderground.0.current.temp_c
2016-01-20 17:59:43.149 - error: uncaught exception: Cannot read property '_id' of undefined
2016-01-20 17:59:43.150 - error: TypeError: Cannot read property '_id' of undefined
at Object.createAccessory_Thermostat [as Thermostat] (/Users/pix/Documents/iobroker/node_modules/iobroker.homekit/main.js:426:21)
at main (/Users/pix/Documents/iobroker/node_modules/iobroker.homekit/main.js:168:69)
at /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/main.js:20:13
at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.homekit/main.js:76:60)
2016-01-20 17:59:43.481 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
2016-01-20 17:59:43.481 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled
2016-01-20 17:59:49.658 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0</anonymous></anonymous></anonymous>Ich habe daraufhin homekit deaktiviert. Dann die weatherunderground-Instanz gelöscht und homekit neu gestartet. Homekit lief wieder! Denke das Log ist aufschlussreich. Gruß Pix -
Nachdem HomeKit wieder läuft, muss ich mir das ansehen?
Gesendet von meinem iPhone mit Tapatalk
9600_bildschirmfoto_vom_2018-12-26_11-02-52.png -
Homekit läuft, weil ich Wunderground abgeschaltet habe :)
Ich interpretiere das Log so, dass da ein Datenpunkt von Weatherunderground.0 nicht korrekt ist. Homekit ist da wohl empfindlich und bockt.
2016-01-20 17:44:06.896 - info: homekit.0 > iobroker subscribe Thermostat hm-rpc.0.MEQ0203474.5.TEMPERATURE 2016-01-20 17:44:06.896 - info: homekit.0 < hap Temperaturdifferenz-Sensor Schlafzimmer:5.TEMPERATURE get CurrentTemperature for hm-rpc.0.MEQ0203474.undefined 2016-01-20 17:44:06.896 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day2.temperature_max 2016-01-20 17:44:06.897 - info: homekit.0 < hap Forecast of temperature for the day after tomorrow get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.897 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day2.temperature_min 2016-01-20 17:44:06.897 - info: homekit.0 < hap Forecast of temperature for the day after tomorrow get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.898 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day1.temperature_max 2016-01-20 17:44:06.898 - info: homekit.0 < hap Forecast of temperature for tomorrow get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.899 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day1.temperature_min 2016-01-20 17:44:06.900 - info: homekit.0 < hap Forecast of temperature for tomorrow get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.900 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_max 2016-01-20 17:44:06.900 - info: homekit.0 < hap Forecast of temperature for today get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.901 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_min 2016-01-20 17:44:06.901 - info: homekit.0 < hap Forecast of temperature for today get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.903 - info: homekit.0 > iobroker subscribe Thermostat yr.0.forecast.day0.temperature_actual 2016-01-20 17:44:06.903 - info: homekit.0 < hap Actual temperature get CurrentTemperature for yr.0.forecast.undefined 2016-01-20 17:44:06.903 - info: homekit.0 > iobroker subscribe Thermostat weatherunderground.0.current.temp_c 2016-01-20 17:44:06.905 - error: uncaught exception: Cannot read property '_id' of undefined 2016-01-20 17:44:06.906 - error: TypeError: Cannot read property '_id' of undefinedGanz oben wird noch versucht, ein HM-Gerät einzulesen. Dann kommen ein paar yr-Adapter-Punkte, die auch undefined sind, geht auch durch. Aber beim iobroker subscribe Thermostat weatherunderground.0.current.temp_c bricht homekit zusammen.
Kannst du mal gucken?
Pix
6961_iot.log -
Hallo, habe grade den Adapter installiert, ich gehe davon aus, das du auch das Script "damals" gebaut hast.
Das war bis jetzt im Einsatz.
Was ist mir aufgefallen:
1.) In der Admin Maske wird
> < style="padding-left: 12px"> Apikeyangezeigt, sieht nach einem HTML Fehler aus2.) Beim starten liefert er folgende Fehler im Logfile:
2016-01-20 19:15:01.615 - info: weatherunderground.0 starting. Version 0.0.4 in /Users/christian/DEVELOPMENT/node_modules/iobroker.weatherunderground 2016-01-20 19:15:02.459 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '0' of undefined 2016-01-20 19:15:02.460 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.460 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '1' of undefined 2016-01-20 19:15:02.461 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.461 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '2' of undefined 2016-01-20 19:15:02.461 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.461 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '3' of undefined 2016-01-20 19:15:02.461 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.461 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '4' of undefined 2016-01-20 19:15:02.461 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.461 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '5' of undefined 2016-01-20 19:15:02.461 - error: weatherunderground.0 Reported WU-Error Type: querynotfound 2016-01-20 19:15:02.461 - error: weatherunderground.0 Could not parse Forecast-Data: TypeError: Cannot read property '6' of undefined 2016-01-20 19:15:02.462 - error: weatherunderground.0 Reported WU-Error Type: querynotfound ...Werde mir dann mal das Thema bez. homekit ansehen.
@pix: Welche Werte wolltest du dir anzeigen lassen?
LG Christian
Fehler gefunden (leider).
Ich habe folgende Logik bei mir drinnen:
if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "sensor.humidity") humidity.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "value.temperature") thermostat.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "indicator.battery") battery.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "indicator.battery") battery.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "value.battery") battery.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "alarm") alarm.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "level.temperature") setpoint.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "switch") switches.push(obj._id); if (obj.common !== undefined && obj.common.role !== undefined && obj.common.role == "sensor.temperature") temperature.push(obj._id);Das ist dann natürlich mit dem Adapter ein Problem, weil die Werte als value.xxx definiert sind und somit in HomeKit in die falsche Regel reinfallen.
@Dschaedl: Hast du dich auf Referenzwerte bezogen beim festlegen, oder einfach aufgrund von "best practice"?
Mir geht es darum ob ich das anpassen muss, oder ob ich das an dich übergebe.
LG Christian
Das war bis jetzt im Einsatz. `
Script? welches script :shock: :shock: (Ich habe nie ein script publiziert)> 1.) In der Admin Maske wird> < style="padding-left: 12px"> Apikeyangezeigt, sieht nach einem HTML Fehler aus
schon gefixt 8-) (nächste Version)
schalte mal das Log auf Debug. Dann solltest du ganz am Anfang die URL sehen, die aufgerufen wird. Ich vermute da stimmt etwas nicht. copy/paste sie dann einfach mal in einen Browser um zu sehen was passiert…Daniel
Mir geht es darum ob ich das anpassen muss, oder ob ich das an dich übergebe. `
Ich habe versucht mich an https://github.com/ioBroker/ioBroker/bl … commonrole zu halten.
Und habe dann kreativ mit neuen Typen erweitert…
@bluefox: Wie ist hier das korrekte Vorgehen?
btw: Ich habe dich als collaborator hinzugefügt.
viele Grüsse
Daniel
@bluefox: Wie ist hier das korrekte Vorgehen? `
Man muss versuchen auf jeden Fall zu nehmen, dass was schon da ist. Und nur wenn es nichts mehr gibt, dann neue hinzufügen und auch in SCHEMA.md Beschreiben.Warum? Weil in vis werden (irgendwann) spezielle Widgets geschaffen, die automatisch die IDs anhand von role identifizieren werden. Auch in Mobile werden dann die Datenpunkte gemäß Rollen angezeigt.
btw: Ich habe dich als collaborator hinzugefügt. `
Danke! -
