  4. Test Adapter ZWave2 (v0.8.x)
    6.4k
zwavez-wavetest
157 Beiträge 9 Kommentatoren 24.0k Aufrufe 10 Beobachtet
  • AlCalzoneA AlCalzone
    @taba_luga Kannst du mir dann mal einen Log (OZW_Log.txt) des alten Adapters zukommen lassen, damit ich etwaige Unterschiede in der Kommunikation suchen kann?
    taba_luga
    schrieb am zuletzt editiert von taba_luga
    #133
    @AlCalzone hier das logfile. OZW_Log.txt
    Bei den Thermostaten, die anscheinend direkt mit Node 1 kommunizieren, scheint es keine Auffälligkeiten zu geben. So zumindest die ersten Ergebnisse. (Node 20, 22, 28).
    • T taba_luga
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #134
      @taba_luga Hab da was im OZW_Log gefunden (beachte die vorletzte Zeile):
      2020-01-10 19:07:02.095 Info, Node030, Sending (Send) message (Callback ID=0x7d, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=30): 0x01, 0x0a, 0x00, 0x13, 0x1e, 0x03, 0x40, 0x01, 0x00, 0x25, 0x7d, 0xe2
      2020-01-10 19:07:02.095 Info, Node030, Encrypted Flag is 0
      2020-01-10 19:07:02.134 Detail, Node030,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
      2020-01-10 19:07:02.134 Detail, Node030,   ZW_SEND_DATA delivered to Z-Wave stack
      2020-01-10 19:07:05.701 Detail, Node030,   Received: 0x01, 0x07, 0x00, 0x13, 0x7d, 0x01, 0x01, 0x68, 0xfe
      2020-01-10 19:07:05.701 Detail, Node030,   ZW_SEND_DATA Request with callback ID 0x7d received (expected 0x7d)
      2020-01-10 19:07:05.703 Info, Node030, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
      2020-01-10 19:07:05.703 Warning, Node030, WARNING: Device is not a sleeping node.
      2020-01-10 19:07:05.703 Error, Node030, ERROR: node presumed dead
      2020-01-10 19:07:05.703 Detail, Node030,   Expected callbackId was received
      2020-01-10 19:07:05.703 Detail, Node030,   Expected reply was received
      2020-01-10 19:07:05.703 Detail, Node030,   Message transaction complete
      2020-01-10 19:07:05.703 Detail, Node030, Removing current message
      2020-01-10 19:07:05.703 Detail, Node030, Notification: Notification - Node Dead
      2020-01-10 19:07:05.703 Error, Node030, ERROR: Dropping command because node is presumed dead
      Danach sendet auch der keine Nachrichten mehr an die #30. Der originale Adapter kommuniziert das nur nicht so aufdringlich ;)
      Hast du mal einen Netzwerk-Heal probiert?
        taba_luga
        #135
        @AlCalzone wie lange läuft denn der Netzwerk-Heal? Bei mir habe ich unverändert seit ca. 3h die Loading Spinner neben dem Status drehen.
        • T taba_luga
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #136
          @taba_luga In der Regel ein paar Minuten. Schlafende Geräte musst du aber manuell aufwecken.
            taba_luga
            #137
            @AlCalzone, die Geräteübersicht der Zwave2.0 Instanz schaut leider immer noch nicht fertig aus:
            Der Status hat sich allerdings bei dem ein oder anderen Gerät geändert.
            Um 15:36:48.097 CNTRLR starting network heal... gestartet....
            zwave-2386.log
            • T taba_luga
              zwave-2386.log
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #138
              @taba_luga Da scheint was schief gelaufen zu sein. Brech es mal ab, warte ein wenig, bis sich alles beruhigt hat und probiere es dann nochmal.
              @Rolf_KA In ein paar Minuten gib es eine neue Beta-Version (v0.9.0-beta.0) für dich zum Testen. Supervision CC ist mit drin, ebenfalls verwendet die Multilevel Switch CC nun (sofern möglich) diese um ihre Befehle zu überwachen. Meine Hoffnung ist, dass damit zum richtigen Zeitpunkt der Status der Roller Shutter abgefragt wird - aber mangels Hardware alles ungetestet...
              Ob es klappt oder nicht, über einen Log würde ich mich freuen ;)
              R 1 Antwort Letzte Antwort
              • Schuko80S Offline
                Schuko80S Offline
                Schuko80
                #139
                Ich habe auch Probleme mit den Thermostaten (Danfoss LC-13) hatte dir im anderen Thread wo ich Probleme mit dem alten Adapter hatte noch dazu geschrieben.
                Die Danfoss Thermostate haben direkte Verbindung zum USB Stick, übernehmen, wenn sie sich schlafen gelegt haben, aber nur sehr spät den gesendeten Wert.
                Wenn ich an die Thermostate manuell ran gehe, dann haben diese die Eigenschaften, bei nicht hergestellter Verbindung ca. 10 Sekunden zu brauchen, bis sie benutzbar sind und dann blinkt das Funksymbol. Quasi die gleiche Situation, als wenn sie nicht mit dem Stick in Verbindung stehen.
                Vom Gefühl her ist es, als wenn beim alten Adapter eine dauerhafte Verbindung besteht, die bei deinem fehlt
                Nuc6cayh + Proxmox / Zigbee (Deconz / Conbee I ) / ZWave / Homematic (CCU2)
                  Rolf_KA
                  #140
                  @AlCalzone sagte in Test Adapter ZWave2 (v0.8.x):
                  Du bist einfach ein Genie und hast bis jetzt mehr vollbracht als OZW derzeit bieten kann !!! 🤗 !!!
                  Meine Fibarao RullerShutter 3 (alle mit Firmware 5.1) melden jetzt nach der End- Fahrt, den korrekten Wert unter currentValue !!!
                  Topp!!!
                  Mein Dank hierzu kommt noch @AlCalzone
                  Vielen Dank für deinen Einsatz
                  VG, Rolf_KA
                  • Schuko80S Schuko80
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #141
                    @Schuko80
                    Ich kann dir nicht ganz folgen. Soweit ich das richtig sehe, sind die LC-13 größtenteils identisch mit den Devolo HomeControl Thermostaten.
                    Diese sind batteriebetrieben und wachen daher nur sporadisch auf, um Änderungen abzuholen. Eine "permanente" Verbindung kann daher im Gegensatz zu netzbetriebenen Geräten nicht bestehen.
                    Diese Frequenz kannst du in der "Wake Up" Klasse unter "wakeupInterval" einstellen. Je kleiner der Wert, desto geringer die Latenz zwischen Updates, aber desto größer ist auch der Batterieverbrauch.
                    Nahezu Live-Updates bekommst du nur bei Geräten, die "FLiRS" unterstützen. Dieses Modell kann das aber nicht.
                    • malorossM Offline
                      malorossM Offline
                      maloross
                      #142
                      noch eine Anfängerfrage: da eine neue Version im ioB nicht angezeigt wird, wie gehe ich korrekt vor, um das Upgrade anzustoßen?
                      Auch Frauen können sich für Technik begeistern! ;)
                      Equipment:
                      diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
                      • malorossM maloross
                        Rolf_KA
                        #143
                        @maloross sagte in Test Adapter ZWave2 (v0.8.x):
                        Ich installiere derzeit immer so:
                        Ich meine sein Adapter ist noch nicht offiziell freigegeben...
                        malorossM 1 Antwort Letzte Antwort
                        • R Rolf_KA
                          malorossM Offline
                          malorossM Offline
                          maloross
                          #144
                          @Rolf_KA Ìnstallationsroutine ist klar, aber ohne vorherige Deinstallation einfach drüber installieren? oder einen sauberen Neuanfang?
                          Equipment:
                            Rolf_KA
                            #145
                            Ich habe bisher immer einfach drüber installiert, sein Adapter ist derzeit auch Beta.0 funktioniert aber bei mir bestens :-)
                            • R Rolf_KA
                              malorossM Offline
                              malorossM Offline
                              maloross
                              #146
                              @Rolf_KA ok, wenn das auch funktioniert, werde ich die neue Version installieren und schauen, ob und was sich geändert hat.
                              Equipment:
                              • malorossM Offline
                                malorossM Offline
                                maloross
                                #147
                                Eben erst aufgefallen: Fibaro FGS-222 Double Switch: unter Binary Switch werden nur folgende DP angezeigt:
                                Es kann keine Schaltung ausgelöst werden. Heilung bzw, Cache leeren brachte keine Änderung.
                                Equipment:
                                  Rolf_KA
                                  #148
                                  Bei mir funktioniert der Nachfolger DoubleSwitch2 perfekt.
                                  • R Rolf_KA
                                    malorossM Offline
                                    malorossM Offline
                                    maloross
                                    #149
                                    @Rolf_KA sagte in Test Adapter ZWave2 (v0.8.x):
                                    und wo soll ich da ansetzen?
                                    Equipment:
                                    • AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #150
                                      @maloross @Rolf_KA Bei Installation per Github können Änderungen am Adapter selbst fehlen, wenn ich diese nicht kompiliert habe.
                                      Sauber wäre per Konsole (ggf. Adapter vorher stoppen):
                                      cd /opt/iobroker
                                      npm i iobroker.zwave2
                                      iobroker upload zwave2
                                      Schätze, da gab es einen Timeout beim Interview o.ä. Das sauber abzufangen ist eines der nächsten Dinge, die ich angehen werde. Aktuell kannst du leider nur nochmal den Cache leeren und hoffen, dass es klappt.
                                      Übrigens v0.9.0 ist draußen!
                                      R 3 Antworten Letzte Antwort
                                        cd /opt/iobroker
                                        Rolf_KA
                                        #151
                                        Wieder etwas dazu gelernt :-)
                                        PERFEKT 👍 👍 👍
                                          cd /opt/iobroker
                                          Rolf_KA
                                          #152
                                          Perfekt 👍 läuft 👍
