  3. Entwicklung
  4. Adapter mihome-vacuum anpassungen
    6.3k
vacuumadapterentwicklungtestroborockzeitplanraumreinigung
567 Beiträge 73 Kommentatoren 170.1k Aufrufe 73 Beobachtet
  • M mumurik
    @dirkhe
    mihome-vacuum.0	2020-01-19 17:46:33.160	error	[8](unknown) -> data for segment is not a number
    mihome-vacuum.0	2020-01-19 17:46:33.159	debug	Receive <<< {"error":{"code":-10000,"message":"data for segment is not a number"},"id":8}<<< 21310070000000000f9d2ccf5e2487e8c9051a4918a4ed5fa74f4af3d0fc86180d55212412c09a0daa616947a3b1b72c0a841aacf20
    mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsgRaw >>> 21310060000000000f9d2ccf5e2487e7baeddb91e685ffd1b5d10376ab481804d5b038b381e72cc623fef9f4b40f8cfc5b3792455b1aaee44afa7bd56e5b38c844505b8b566afd5408801c56ae5f9fd2b246176debcb61543c93a4761
    mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsg >>> {"id":8,"method":"app_segment_clean","params":[null,null]}
    mihome-vacuum.0	2020-01-19 17:46:31.795	debug	Timestamp: 5e2487e7
    mihome-vacuum.0	2020-01-19 17:46:31.793	info	trigger cleaning segment 16,19
    mihome-vacuum.0	2020-01-19 17:46:31.791	debug	redis pmessage messagebox.system.adapter.mihome-vacuum.0 messagebox.system.adapter.mihome-vacuum.0 {"command":"cleanSegments","message":"16,19","from":"system.adapter.mihome-vacuum.0","_id":77384923}
    mihome-vacuum.0	2020-01-19 17:46:31.788	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 16,19
    mihome-vacuum.0	2020-01-19 17:46:31.786	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomFanPower
    mihome-vacuum.0	2020-01-19 17:46:31.784	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomFanPower
    mihome-vacuum.0	2020-01-19 17:46:31.781	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomClean
    mihome-vacuum.0	2020-01-19 17:46:31.779	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomClean
    mihome-vacuum.0	2020-01-19 17:46:31.777	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.multiRoomClean
    mihome-vacuum.0	2020-01-19 17:46:31.635	debug	stateChange mihome-vacuum.0.rooms.multiRoomClean {"val":true,"ack":false,"ts":1579452391626,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579452391626}
    D Nicht stören
    D Nicht stören
    dirkhe
    #138
    @mumurik lade nochmal herunter bitte
    • D dirkhe
      mumurik
      #139
      @dirkhe
      jetzt läufts, sowohl multiRoomClean, als auch die Timer.
      Vielen Dank für die Mühe!
      • B base
        @dirkhe ja, das war der Fehler...
        ich habe Valetudo 0.8.2 installiert. Gibt es eine Möglichkeit gespeicherte Karten per send command zu laden?
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #140
        @base nein wird aber noch anderweitig integriert.
          misteriobroker
          #141
          Wie genau installiere ich denn diese aktuellste Version über Github?!
          Auf den grünen Download Button und diesen Link dort nehmen und im ioBroker über die Katze dann mit der URL installieren?
          • D Nicht stören
            D Nicht stören
            dirkhe
            #142
            Aus eigener URL hinzufügen, ich glaube das ist die Katze und dann github auswählen und einfach nach Vakuum suchen
              Sebastian Strobl
              #143
              Bei mir kommt leider eine Fehlermeldung... Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
              • D Nicht stören
                D Nicht stören
                dirkhe
                #144
                Was genau sagt das Log? Ich habe das eben noch gemacht. Passt die Berechtigung vlt nicht?
                • D dirkhe
                  misteriobroker
                  #145
                  @dirkhe said in Adapter mihome-vacuum anpassungen:
                  Ich habe das nochmal gemacht jetzt.
                  Es wird als erfolgreich beendet und bei meinen Adaptern steht der Mi Vacuum auf 1.1.5 weiterhin.
                  Wie genau muss der Reiter Rooms denn erscheinen?!
                  D DiginixD 2 Antworten Letzte Antwort
                  • M misteriobroker
                    D Nicht stören
                    D Nicht stören
                    dirkhe
                    #146
                    @misteriobroker als verfügbar oder installiert?
                    Verfügbar steht bei mir auch 1.1.5, das liegt daran, das es noch nicht bei npm ist, glaube ich.
                    Was steht denn im Log, welche Version er gestartet hst?
                    • M misteriobroker
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #147
                      @misteriobroker Als Knoten unterhalb der Adapter Objekte.
                      Aber wenn deine Version noch auf 1.1.5 steht, dann ist die 1.10.x höchstunwahrscheinlich installiert.
                      ioBroker Fixer mal ausführen falls Berechtigungen im node_modules nicht passen oder auch einfach so.
                      Im Log steht auch welche Version vom Adapter gestartet wurde.
                      ..:: So long! Tom ::..
                        misteriobroker
                        schrieb am zuletzt editiert von misteriobroker
                        #148
                        Er startet die 1.1.5 🤔
                        Verfügbar und installiert beides auf 1.1.5
                        • D Nicht stören
                          D Nicht stören
                          dirkhe
                          #149
                          Ggf mal die Einstellungen kopieren, geht unter config und dann adapter löschen und dann wie oben beschrieben neu installieren
                          • D Nicht stören
                            D Nicht stören
                            dirkhe
                            #150
                            Ich glaube, unter den allgemeinen Einstellungen muss der verwahrungsort noch auf latest gestellt werden
                              misteriobroker
                              #151
                              Mit den Einstellungen meinst du die Instanzen und deren Inhalt?
                              • D Nicht stören
                                D Nicht stören
                                dirkhe
                                #152
                                Wenn du viel eingestellt hast, macht das Sinn, zumindest den Token mal wegsichern
                                • D dirkhe
                                  @xADDRx sagte in Adapter mihome-vacuum anpassungen:
                                  @dirkhe Hab jetzt mal einiges versucht. sobald ich eine Nummer eingebe, fährt der Roboter kurz raus und wieder rein... Habt ´Ihr einen Tipp für mich?
                                  Kannst du mal das Log schicken, ggf, den Afdapter vorher auf debug stellen
                                  Das mit den Raumfarben weiß ich nicht, aber da die nicht zusammenhängend sind, wird das wahrscheinlich egal sein. Bekommst du denn für jeden Raum eine eigene Nummer?
                                  X Offline
                                  X Offline
                                  xADDRx
                                  #153
                                  @dirkhe Hallo dirkhe,
                                  wo soll denn die Nummer herkommen? Ich habe einfach ne nummer ausprobiert...
                                  Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
                                  • X xADDRx
                                    D Nicht stören
                                    D Nicht stören
                                    dirkhe
                                    #154
                                    @xADDRx du meinst den mapindex? Wenn deine Firmware das unterstützt, sendet er die von sich aus. Dazu musst du in der mihome App die Räume benennen. Wenn nicht, einfach mal testen.
                                    X 1 Antwort Letzte Antwort
                                    • D dirkhe
                                      X Offline
                                      X Offline
                                      xADDRx
                                      #155
                                      @dirkhe Ich habe den s5 mit der flolevac software. Dort kann man leider noch keine räume benennen.
                                      • X xADDRx
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        #156
                                        @xADDRx also ich würde mal versuchen, über die mihome App die Räume zu benennen. Irgendwer hier im Thread hat auch den s5 und bekommt die Räume auch nicht zurück, kann sie aber ansteuern, darum habe ich dieses manuelle raum hinzufügen gemacht, wo man ja mittlerweile auch Zonen Koordinaten hinterlegen kann
                                          misteriobroker
                                          #157
                                          Ich habe den Adapter nun gelöscht und über die Katze neu installiert.
                                          Weiterhin die 1.1.5 verfügbar
