  4. XBox-Adapter Fehler
XBox-Adapter Fehler
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
xbox
98 Beiträge 8 Kommentatoren 17.2k Aufrufe 5 Beobachtet
  • NegaleinN Negalein
    @foxriver76 sagte in XBox-Adapter Fehler:
    Kannst nochmal ein reinstall des Adapters probieren, falls es an fehlenden Libs lag.
    noch immer viele Fehler
    $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox/tarball/master" xbox
    install https://github.com/foxriver76/ioBroker.xbox/tarball/master
    NPM version: 6.11.3
    npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
    In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^
    In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~
    In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/bufferutil.cc:16:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
    In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?     return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);                                       ^~~~~~~~~~~~~~~~
    ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback                    ^~~~~~~~~~~~~~~~~~
    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback       ^~../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void       v8::Isolate::GCEpilogueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCEpilogueCallback callback) {       ^~../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback       ^~../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’     , v8::GCType gc_type_filter = v8::kGCTypeAll) {                  ^~~~~~~~~~~~~~../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void       v8::Isolate::GCPrologueCallback callback) {                    ^~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’       v8::Isolate::GCPrologueCallback callback) {       ^~
    ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~
    ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
    ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared     , node::smalloc::FreeCallback callback             ^~~~~~~
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/bufferutil.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^
    In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);                                                    ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "mask", BufferUtil::Mask);                                                ^In file included from ../src/bufferutil.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "merge", BufferUtil::Merge);                                                  ^
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> bufferObj = args[0]->ToObject();                                                 ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Local<Object> src = array->Get(i)->ToObject();                                                   ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
    ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
    ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> mask_obj = args[1]->ToObject();                                                ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> output_obj = args[2]->ToObject();                                                  ^In file included from ../src/bufferutil.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int dataOffset = args[3]->Int32Value();                                                   ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/bufferutil.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     unsigned int length = args[4]->Int32Value();                                               ^
    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR!
     cwd /opt/iobroker/node_modules/bufferutilgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here Local<Integer> Value::ToInteger() const {                ^~~~~
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’ To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;                                           ^~~~~~~
    /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided                 Local<Int32> ToInt32(Isolate* isolate) const);                              ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../node_modules/nan/nan.h:82:0,                 from ../src/validation.cc:15:../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’ To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
    In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                      ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)   static Local<Value> New(Isolate* isolate, bool value);                       ^~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                            ^../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token   return v8::BooleanObject::New(value).As<v8::BooleanObject>();                                                              ^
    ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   return v8::RegExp::New(pattern, flags);                                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here                        Local<RegExp> New(Local<String> pattern, Flags flags));                                      ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’         v8::String::kNormalString, length);                                          ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(                                                   ^~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’       Local<String> NewExternal(Isolate* isolate,                     ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’ #define V8_DEPRECATE_SOON(message, declarator) declarator                                                ^~~~~~~~~~In file included from ../node_modules/nan/nan_new.h:189:0,                 from ../node_modules/nan/nan.h:82,                 from ../src/validation.cc:15:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);          ^~
    In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]       ? optionsObj->Get(opt)->Uint32Value()                                           ^
    In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);                                               ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’ NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {                         ^~~~~~~~~~~~~~~../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {                         ^~~~~~~~~~~~~~~
    ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {               ^~~~~~~~~~~~~~~~../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {                               ^../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();                                          ^~~~
    ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’     , node::smalloc::FreeCallback callback                                   ^~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                  ^~~~~~~~../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope         v8::Isolate::GetCurrent(), data, length, callback, hint);                                                            ^~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);        ^In file included from ../src/validation.cc:10:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’ NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,                                        ^~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’     return node::Buffer::New(v8::Isolate::GetCurrent(), size);            ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);            ^~~~
    In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);        ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(                                                   ^~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 providedIn file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->BindToCurrentContext()->Run();                                                ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return script->Run();                        ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Run());                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv));                                                            ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv));                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’ # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))                                                           ^~~
    In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]         v8::String::Value value(toStr);                                      ^In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,                 from ../src/validation.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));                                                   ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     NanAssignPersistent(t_, t->ToObject());                                         ^In file included from ../src/validation.cc:7:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here Local<Object> Value::ToObject() const {               ^~~~~
    ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);                                                              ^In file included from ../src/validation.cc:8:0:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,             ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback) inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,             ^~~~~~~~~~~~~~~
    ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]     Local<Object> buffer_obj = args[0]->ToObject();                                                  ^
    make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! System Linux 4.4.59+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validategyp ERR! node -v v10.17.0gyp ERR!
    ERROR: xbox-smartglass-core 1.0.12 has requirement urwid==2.0.1, but you'll have urwid 2.1.0 which is incompatible.
    upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
    upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
    upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
    process exited with code 0
    foxriver76F
    foxriver76F
    foxriver76
    @Negalein
    Mach mal bitte eine händische Installation.
    1. rm -r /opt/iobroker/node_modules/iobroker.xbox/
    2. npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production
    Videotutorials & mehr
    • foxriver76F foxriver76
      @Negalein
      NegaleinN
      NegaleinN
      Negalein
      @foxriver76 sagte in XBox-Adapter Fehler:
      da kommt bei Enter nur eine neue Zeile. Sonst keine Meldung.
      hier der Log (leider der Anfang abgeschnitten)
      ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated:Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
      make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
      gyp ERR! not ok
      > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
        CXX(target) Release/obj.target/validation/src/validation.o
      ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’is ambiguous
      validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
      make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
      gyp ERR! not ok
      > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox
      > npip install
      No python_modules directory; installing pip locally if needed.
      Successfully completed pip check.
      Collecting xbox-smartglass-rest>=0.9.8
        Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
      Collecting xbox-webapi>=1.1.7
        Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
      Collecting xbox-smartglass-core>=1.0.12
        Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
      Collecting xbox-smartglass-stump>=0.9.5
        Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
      Collecting Flask
        Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/49/b5/ad/7355506059779337473b8eeb49384c9c0a9d45d34c8211a96d/urwid-2.1.0-cp35-cp35m-linux_x86_64.whl
      Collecting appdirs
        Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
      Collecting requests
        Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
      Collecting cryptography==2.3.1
        Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
      Collecting gevent==1.3.7
        Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
      Collecting aenum==2.1.2; python_version <= "3.5"
        Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
      Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
      Collecting marshmallow-objects
        Using cached https://files.pythonhosted.org/packages/4d/1c/fe15bc370707e8f8db09ab0edead45ab413b75795a8be523ca6482152183/marshmallow_objects-2.0.0-py2.py3-none-any.whl
      Collecting Werkzeug>=0.15
        Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
      Collecting Jinja2>=2.10.1
        Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
      Collecting click>=5.1
        Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
      Collecting itsdangerous>=0.24
        Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
      Collecting chardet<3.1.0,>=3.0.2
        Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
      Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
        Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
      Collecting idna<2.9,>=2.5
        Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
      Collecting certifi>=2017.4.17
        Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
      Collecting cffi!=1.11.3,>=1.7
        Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
      Collecting asn1crypto>=0.21.0
        Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
      Collecting six>=1.4.1
        Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
      Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
        Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
      Collecting marshmallow>=3.0.0
        Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
      Collecting MarkupSafe>=0.23
        Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
      Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
      Installing collected packages: urwid, appdirs, chardet, urllib3, idna, certifi, requests, demjson, xbox-webapi, construct, pycparser, cffi, asn1crypto, six, cryptography, greenlet, gevent, aenum, dpkt, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, Werkzeug, MarkupSafe, Jinja2, click, itsdangerous, Flask, xbox-smartglass-rest
      Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.1.0 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
      npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
      npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
      + iobroker.xbox@0.5.12
      added 3 packages from 3 contributors in 72.319s
      Adapter bleibt gelb
      xbox.0	2020-01-17 23:55:17.849	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:17.848	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:16.846	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:16.845	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:15.842	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:15.842	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:14.839	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:14.839	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:13.836	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:13.836	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:13.803	debug	(1910) [CHECK] Auth is not established
      xbox.0	2020-01-17 23:55:13.800	debug	(1910) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-17 23:55:13.799	debug	(1910) [CONNECT] Check connection
      xbox.0	2020-01-17 23:55:13.789	error	(1910) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-17 23:55:13.784	debug	(1910) [DISCOVER] Searching for consoles
      xbox.0	2020-01-17 23:55:13.781	debug	(1910) [PING] Xbox online
      xbox.0	2020-01-17 23:55:12.833	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:12.832	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:11.830	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:11.830	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:10.827	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:10.827	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:09.824	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:09.823	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:08.821	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:08.821	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:07.818	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:07.818	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:07.811	warn	(1910) [CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2020-01-17 23:55:07.811	debug	(1910) [CONNECT] Check connection
      xbox.0	2020-01-17 23:55:07.809	error	(1910) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
      xbox.0	2020-01-17 23:55:07.806	debug	(1910) [CHECK] Auth is not established
      xbox.0	2020-01-17 23:55:07.800	debug	(1910) [DISCOVER] Searching for consoles
      xbox.0	2020-01-17 23:55:07.791	debug	(1910) [PING] Xbox online
      xbox.0	2020-01-17 23:55:06.813	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:06.813	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:05.810	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:05.809	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:04.806	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:04.805	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:03.802	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:03.801	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:02.797	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:02.797	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:01.794	warn	(1910) [LOGIN] Connection refused, will try again
      xbox.0	2020-01-17 23:55:01.794	debug	(1910) Could not parse body
      xbox.0	2020-01-17 23:55:01.784	debug	(1910) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-01-17 23:54:56.949	error	(1910) [START] Restarting adapter in 30 seconds
      xbox.0	2020-01-17 23:54:56.949	error	(1910) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobroke
      xbox.0	2020-01-17 23:54:55.208	info	(1910) [START] Starting REST server
      xbox.0	2020-01-17 23:54:55.208	debug	(1910) [START] IP address is 10.0.1.83
      xbox.0	2020-01-17 23:54:55.182	info	(1910) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
      ° Fixer ---> iob fix
      • NegaleinN Negalein
        ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
        ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
             return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
        ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
               v8::Isolate::GCEpilogueCallback callback
        ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
        ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
             , v8::GCType gc_type_filter = v8::kGCTypeAll) {
        ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
               v8::Isolate::GCEpilogueCallback callback) {
        ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
        ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
               v8::Isolate::GCPrologueCallback callback
        ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
        ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
        ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
               v8::Isolate::GCPrologueCallback callback) {
        ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
        ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
        In file included from ../src/bufferutil.cc:10:0:
        gyp ERR! not ok
        > node-gyp rebuild
        gyp ERR! not ok
        > npip install
        Collecting Flask
        Collecting appdirs
        Collecting requests
        Adapter bleibt gelb
        foxriver76F
        foxriver76F
        foxriver76
        @Negalein sagte in XBox-Adapter Fehler:
        Evtl liegt es nur daran. Mal folgendes probieren: curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py dann python get-pip.py dann pip install "urwid==2.0.1". Trotzdem strange, dass urwid in der falschen Version drauf ist wobei nicht mal pip installiert ist und somit vermutlich keine Konflikte existieren sollten. Vermutlich könnten die Jungs vom Xbox-Rest-Server auch mit >=2.0.1 kompatibel sein.
          NegaleinN
          NegaleinN
          Negalein
          root@iobroker:/opt/iobroker# curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                           Dload  Upload   Total   Spent    Left  Speed
          100 1734k  100 1734k    0     0  2644k      0 --:--:-- --:--:-- --:--:-- 2647k
          root@iobroker:/opt/iobroker# python get-pip.py
          DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
          Collecting pip
            Downloading https://files.pythonhosted.org/packages/00/b6/9cfa56b4081ad13874b0c6f96af8ce16cfbc1cb06bedf8e9164ce5551ec1/pip-19.3.1-py2.py3-none-any.whl (1.4MB)
               |████████████████████████████████| 1.4MB 1.1MB/s
          Collecting setuptools
            Downloading https://files.pythonhosted.org/packages/f9/d3/955738b20d3832dfa3cd3d9b07e29a8162edb480bf988332f5e6e48ca444/setuptools-44.0.0-py2.py3-none-any.whl (583kB)
               |████████████████████████████████| 583kB 3.1MB/s
          Collecting wheel
            Downloading https://files.pythonhosted.org/packages/00/83/b4a77d044e78ad1a45610eb88f745be2fd2c6d658f9798a15e384b7d57c9/wheel-0.33.6-py2.py3-none-any.whl
          Installing collected packages: pip, setuptools, wheel
          Successfully installed pip-19.3.1 setuptools-44.0.0 wheel-0.33.6
          root@iobroker:/opt/iobroker# pip install "urwid==2.0.1"
          Collecting urwid==2.0.1
            Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
               |████████████████████████████████| 614kB 1.2MB/s
          Building wheels for collected packages: urwid
            Building wheel for urwid (setup.py) ... done
            Created wheel for urwid: filename=urwid-2.0.1-cp27-none-any.whl size=223811 sha256=62989cc247db2deb465ac357ec891d2e89e4c03904d6c8288c414afca14b37db
            Stored in directory: /root/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0
          Successfully built urwid
          Successfully installed urwid-2.0.1
          Adapter weiterhin gelb
          xbox.0	2020-01-18 00:53:21.860	info	(8629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          xbox.0	2020-01-18 00:53:21.859	info	(8629) terminating
          xbox.0	2020-01-18 00:53:21.858	info	(8629) [END] cleaned everything up...
          xbox.0	2020-01-18 00:53:21.844	info	(8629) [END] REST server stopped
          xbox.0	2020-01-18 00:53:21.830	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
          xbox.0	2020-01-18 00:53:21.824	info	(8629) Got terminate signal TERMINATE_YOURSELF
          xbox.0	2020-01-18 00:53:21.653	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:21.653	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:20.649	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:20.648	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:20.557	debug	(8629) [CHECK] Auth is not established
          xbox.0	2020-01-18 00:53:20.555	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 00:53:20.554	debug	(8629) [CONNECT] Check connection
          xbox.0	2020-01-18 00:53:20.553	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 00:53:20.547	debug	(8629) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 00:53:20.543	debug	(8629) [PING] Xbox online
          xbox.0	2020-01-18 00:53:19.640	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:19.640	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:18.637	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:18.637	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:17.634	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:17.633	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:16.630	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:16.629	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:15.627	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:15.627	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:14.624	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:14.623	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:14.547	debug	(8629) [CHECK] Auth is not established
          xbox.0	2020-01-18 00:53:14.546	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 00:53:14.545	debug	(8629) [CONNECT] Check connection
          xbox.0	2020-01-18 00:53:14.544	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 00:53:14.541	debug	(8629) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 00:53:14.539	debug	(8629) [PING] Xbox online
          xbox.0	2020-01-18 00:53:13.621	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:13.621	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:12.618	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:12.617	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:11.615	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:11.615	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:10.612	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:10.611	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:09.608	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:09.599	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:08.596	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:08.595	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:08.549	debug	(8629) [CHECK] Auth is not established
          xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 00:53:08.547	debug	(8629) [CONNECT] Check connection
          xbox.0	2020-01-18 00:53:08.546	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 00:53:08.543	debug	(8629) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 00:53:08.540	debug	(8629) [PING] Xbox online
          xbox.0	2020-01-18 00:53:07.593	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:07.593	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:06.590	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:06.589	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:05.586	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:05.585	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:04.583	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:04.582	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:03.580	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:03.580	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:02.577	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:02.577	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:02.561	debug	(8629) [CHECK] Auth is not established
          xbox.0	2020-01-18 00:53:02.559	warn	(8629) [CONNECT] Ping response, but provided LiveID has not been discovered until now
          xbox.0	2020-01-18 00:53:02.558	debug	(8629) [CONNECT] Check connection
          xbox.0	2020-01-18 00:53:02.556	error	(8629) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
          xbox.0	2020-01-18 00:53:02.552	debug	(8629) [DISCOVER] Searching for consoles
          xbox.0	2020-01-18 00:53:02.547	debug	(8629) [PING] Xbox online
          xbox.0	2020-01-18 00:53:01.575	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:01.575	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:53:00.572	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:53:00.572	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:52:59.568	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:52:59.568	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:52:58.564	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:52:58.563	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:52:57.560	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:52:57.559	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:52:56.554	warn	(8629) [LOGIN] Connection refused, will try again
          xbox.0	2020-01-18 00:52:56.554	debug	(8629) Could not parse body
          xbox.0	2020-01-18 00:52:56.543	debug	(8629) [LOGOUT] <=== Failed to logout: undefined
          xbox.0	2020-01-18 00:52:54.718	debug	(8629) system.adapter.admin.0: logging true
          xbox.0	2020-01-18 00:52:51.805	error	(8629) [START] Restarting adapter in 30 seconds
          xbox.0	2020-01-18 00:52:51.804	error	SyntaxError: invalid syntax
          xbox.0	2020-01-18 00:52:51.804	error	^
          xbox.0	2020-01-18 00:52:51.804	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
          xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects.models import ( # noqa
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from marshmallow_objects import Model, NestedModel, fields
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump import json_model
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from xbox.stump.manager import StumpManager
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from ..consolewrap import ConsoleWrap
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from .device import *
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from .routes import routes
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.app import app
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	from xbox.rest.scripts.rest_server import main
          xbox.0	2020-01-18 00:52:51.804	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
          xbox.0	2020-01-18 00:52:51.804	error	Traceback (most recent call last):
          xbox.0	2020-01-18 00:52:51.804	error	(8629) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
          xbox.0	2020-01-18 00:52:49.985	info	(8629) [START] Starting REST server
          xbox.0	2020-01-18 00:52:49.985	debug	(8629) [START] IP address is 10.0.1.83
          xbox.0	2020-01-18 00:52:49.962	info	(8629) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
          xbox.0	2020-01-18 00:52:47.961	debug	(8629) States connected to redis: 0.0.0.0:9000
          xbox.0	2020-01-18 00:52:47.909	debug	(8629) statesDB connected
          xbox.0	2020-01-18 00:52:47.908	debug	(8629) States create PubSub Client
          xbox.0	2020-01-18 00:52:47.898	debug	(8629) Objects connected to redis: 0.0.0.0:9001
          xbox.0	2020-01-18 00:52:47.896	debug	(8629) Redis States: Use Redis connection: 0.0.0.0:9000
          xbox.0	2020-01-18 00:52:47.894	debug	(8629) objectDB connected
          xbox.0	2020-01-18 00:52:47.883	debug	(8629) Objects client initialize lua scripts
          xbox.0	2020-01-18 00:52:47.882	debug	(8629) Objects create PubSub Client
          xbox.0	2020-01-18 00:52:47.873	debug	(8629) Objects client ready ... initialize now
          xbox.0	2020-01-18 00:52:47.840	debug	(8629) Redis Objects: Use Redis connection: 0.0.0.0:9001
            Collecting pip
            Collecting wheel
            foxriver76F
            foxriver76F
            foxriver76
            @Negalein braucht gerade immer ein reinstall sorry: npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production
              NegaleinN
              NegaleinN
              Negalein
                               from ../src/bufferutil.cc:16:
              In file included from ../src/bufferutil.cc:16:0:
              ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
              ../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
              In file included from ../src/bufferutil.cc:8:0:
              ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
              ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                   NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
              ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                   NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
              ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                   NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
              ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:
              ../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   Local<Object> bufferObj = args[0]->ToObject();
              ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     Local<Object> src = array->Get(i)->ToObject();
              In file included from ../src/bufferutil.cc:7:0:
              ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:
              ../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   Local<Object> mask_obj = args[1]->ToObject();
              ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:
              ../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              ../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   Local<Object> output_obj = args[2]->ToObject();
              ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   unsigned int dataOffset = args[3]->Int32Value();
              /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                 V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
              ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   unsigned int length = args[4]->Int32Value();
              make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Fehler 1
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp ERR! node-gyp -v v5.0.3
              gyp ERR! not ok
              > node-gyp rebuild
              ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
              ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
              /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10052:16: note: declared here
               Local<Integer> Value::ToInteger() const {
              ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
              ../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’
               To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
              /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const
                 V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;
              /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 provided
              /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const
              gyp ERR! not ok
              > npip install
              Collecting Flask
              Collecting appdirs==1.4.3
              Processing /home/iobroker/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0/urwid-2.0.1-cp35-none-any.whl
              Collecting requests
              Collecting idna>=2.1
              Installing collected packages: marshmallow, marshmallow-objects, greenlet, gevent, construct, idna, asn1crypto, pycparser, cffi, six, cryptography, appdirs, demjson, urwid, certifi, chardet, urllib3, requests, xbox-webapi, dpkt, aenum, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, click, itsdangerous, Werkzeug, Flask, xbox-smartglass-rest
              Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.0.1 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
              updated 1 package in 68.765s
              Adapter gelb
              xbox.0	2020-01-18 01:22:32.977	info	(28813) [START] Starting REST server
              xbox.0	2020-01-18 01:22:32.977	debug	(28813) [START] IP address is 10.0.1.83
              xbox.0	2020-01-18 01:22:32.956	info	(28813) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
              xbox.0	2020-01-18 01:22:26.538	info	(28335) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              xbox.0	2020-01-18 01:22:26.537	info	(28335) terminating
              xbox.0	2020-01-18 01:22:26.536	info	(28335) [END] cleaned everything up...
              xbox.0	2020-01-18 01:22:26.522	info	(28335) [END] REST server stopped
              xbox.0	2020-01-18 01:22:26.508	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
              xbox.0	2020-01-18 01:22:26.500	info	(28335) Got terminate signal TERMINATE_YOURSELF
              xbox.0	2020-01-18 01:22:26.413	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:26.413	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:25.410	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:25.410	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:25.316	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2020-01-18 01:22:25.315	debug	(28335) [CONNECT] Check connection
              xbox.0	2020-01-18 01:22:25.315	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
              xbox.0	2020-01-18 01:22:25.314	debug	(28335) [CHECK] Auth is not established
              xbox.0	2020-01-18 01:22:25.309	debug	(28335) [DISCOVER] Searching for consoles
              xbox.0	2020-01-18 01:22:25.306	debug	(28335) [PING] Xbox online
              xbox.0	2020-01-18 01:22:24.407	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:24.406	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:23.399	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:23.399	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:22.396	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:22.396	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:21.393	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:21.393	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:20.390	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:20.390	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:19.387	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:19.386	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:19.311	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2020-01-18 01:22:19.310	debug	(28335) [CONNECT] Check connection
              xbox.0	2020-01-18 01:22:19.309	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
              xbox.0	2020-01-18 01:22:19.308	debug	(28335) [CHECK] Auth is not established
              xbox.0	2020-01-18 01:22:19.305	debug	(28335) [DISCOVER] Searching for consoles
              xbox.0	2020-01-18 01:22:19.303	debug	(28335) [PING] Xbox online
              xbox.0	2020-01-18 01:22:18.384	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:18.384	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:17.381	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:17.380	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:16.378	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:16.377	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:15.374	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:15.373	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:14.371	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:14.370	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:13.358	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:13.358	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:13.314	debug	(28335) [CHECK] Auth is not established
              xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2020-01-18 01:22:13.312	debug	(28335) [CONNECT] Check connection
              xbox.0	2020-01-18 01:22:13.311	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
              xbox.0	2020-01-18 01:22:13.308	debug	(28335) [DISCOVER] Searching for consoles
              xbox.0	2020-01-18 01:22:13.305	debug	(28335) [PING] Xbox online
              xbox.0	2020-01-18 01:22:12.355	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:12.355	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:11.351	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:11.351	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:10.348	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:10.347	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:09.345	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:09.345	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:08.341	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:08.341	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:07.337	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:07.337	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:07.325	debug	(28335) [CHECK] Auth is not established
              xbox.0	2020-01-18 01:22:07.323	warn	(28335) [CONNECT] Ping response, but provided LiveID has not been discovered until now
              xbox.0	2020-01-18 01:22:07.322	debug	(28335) [CONNECT] Check connection
              xbox.0	2020-01-18 01:22:07.320	error	(28335) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
              xbox.0	2020-01-18 01:22:07.315	debug	(28335) [DISCOVER] Searching for consoles
              xbox.0	2020-01-18 01:22:07.311	debug	(28335) [PING] Xbox online
              xbox.0	2020-01-18 01:22:06.335	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:06.334	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:05.332	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:05.332	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:04.328	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:04.328	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:03.324	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:03.324	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:02.321	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:02.321	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:01.318	warn	(28335) [LOGIN] Connection refused, will try again
              xbox.0	2020-01-18 01:22:01.318	debug	(28335) Could not parse body
              xbox.0	2020-01-18 01:22:01.308	debug	(28335) [LOGOUT] <=== Failed to logout: undefined
              xbox.0	2020-01-18 01:21:58.846	debug	(28335) system.adapter.admin.0: logging true
              xbox.0	2020-01-18 01:21:56.483	error	(28335) [START] Restarting adapter in 30 seconds
              xbox.0	2020-01-18 01:21:56.482	error	SyntaxError: invalid syntax
              xbox.0	2020-01-18 01:21:56.482	error	^
              xbox.0	2020-01-18 01:21:56.482	error	cls, data, context=None, many=None, partial=None, unknown=None, *args, **kwargs,
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/models.py", line 209
              xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects.models import ( # noqa
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/marshmallow_objects/__init__.py", line 3, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from marshmallow_objects import Model, NestedModel, fields
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/json_model.py", line 4, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump import json_model
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/stump/manager.py", line 13, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from xbox.stump.manager import StumpManager
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/consolewrap.py", line 6, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from ..consolewrap import ConsoleWrap
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/device.py", line 6, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from .device import *
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/routes/__init__.py", line 6, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from .routes import routes
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/app.py", line 5, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.app import app
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.5/site-packages/xbox/rest/scripts/rest_server.py", line 9, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	from xbox.rest.scripts.rest_server import main
              xbox.0	2020-01-18 01:21:56.482	error	File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
              xbox.0	2020-01-18 01:21:56.482	error	Traceback (most recent call last):
              xbox.0	2020-01-18 01:21:56.482	error	(28335) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found
              xbox.0	2020-01-18 01:21:54.708	info	(28335) [START] Starting REST server
              xbox.0	2020-01-18 01:21:54.707	debug	(28335) [START] IP address is 10.0.1.83
              xbox.0	2020-01-18 01:21:54.688	info	(28335) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
              xbox.0	2020-01-18 01:21:52.313	debug	(28335) States connected to redis: 0.0.0.0:9000
              xbox.0	2020-01-18 01:21:52.260	debug	(28335) statesDB connected
              xbox.0	2020-01-18 01:21:52.259	debug	(28335) States create PubSub Client
              xbox.0	2020-01-18 01:21:52.250	debug	(28335) Objects connected to redis: 0.0.0.0:9001
              xbox.0	2020-01-18 01:21:52.247	debug	(28335) Redis States: Use Redis connection: 0.0.0.0:9000
              xbox.0	2020-01-18 01:21:52.245	debug	(28335) objectDB connected
              xbox.0	2020-01-18 01:21:52.232	debug	(28335) Objects client initialize lua scripts
              xbox.0	2020-01-18 01:21:52.231	debug	(28335) Objects create PubSub Client
              xbox.0	2020-01-18 01:21:52.223	debug	(28335) Objects client ready ... initialize now
              xbox.0	2020-01-18 01:21:52.164	debug	(28335) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                 from ../node_modules/nan/nan.h:82,
                ../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token
                   return v8::BooleanObject::New(value).As<v8::BooleanObject>();
                ../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:
                ../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                   return v8::RegExp::New(pattern, flags);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5110:38: note: declared here
                                        Local<RegExp> New(Local<String> pattern, Flags flags));
                In file included from ../node_modules/nan/nan_new.h:189:0,
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
                ../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                   return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                ../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
                ../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’
                         v8::String::kNormalString, length);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)
                   static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
                ../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’
                   return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)
                       Local<String> NewExternal(Isolate* isolate,
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
                 #define V8_DEPRECATE_SOON(message, declarator) declarator
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
                ../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                   return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                ../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                ../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:
                ../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                       ? optionsObj->Get(opt)->Uint32Value()
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                   V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                ../node_modules/nan/nan.h: At global scope:
                ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
                 NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
                ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
                 NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
                ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
                     const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
                ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
                ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
                ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
                       _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
                     , node::smalloc::FreeCallback callback
                ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
                ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
                         v8::Isolate::GetCurrent(), data, length, callback, hint);
                ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
                ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
                     return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
                 NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
                ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
                ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                     return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
                ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
                     return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                     return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)
                   static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
                ../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
                ../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     return script->BindToCurrentContext()->Run();
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:1271:51: note: declared here
                   V8_DEPRECATED("Use maybe version", Local<Value> Run());
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
                ../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     return script->Run();
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:
                         v8::Isolate::GetCurrent(), target, func, argc, argv));
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here
                                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                     __attribute__((deprecated(message))) declarator
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
                ../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                         v8::Isolate::GetCurrent(), target, symbol, argc, argv));
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here
                ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
                         v8::Isolate::GetCurrent(), target, method, argc, argv));
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here
                ../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) const’:
                ../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
                 # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
                ../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:
                ../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                         v8::String::Value value(toStr);
                In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26:0,
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2916:51: note: declared here
                     V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                   declarator __attribute__((deprecated(message)))
                ../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                ../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value>)’:
                ../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     NanAssignPersistent(t_, t->ToObject());
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
                 Local<Object> Value::ToObject() const {
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
                 inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
                 inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
                     Local<Object> buffer_obj = args[0]->ToObject();
                gyp ERR! System Linux 4.4.59+
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! node -v v10.17.0
                gyp ERR! not ok
                > node-gyp rebuild
                In file included from ../node_modules/nan/nan.h:82:0,
                                 from ../src/validation.cc:15:
                In file included from ../src/validation.cc:7:0:
                                 Local<Int32> ToInt32(Isolate* isolate) const);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided
                ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                ../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’
                 To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const
                   V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
                ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
                ../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)
                   static Local<Value> New(Isolate* isolate, bool value);
                /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 provided
                In file included from ../src/validation.cc:15:0:
                In file included from ../src/validation.cc:10:0:
                ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                In file included from ../src/validation.cc:8:0:
                ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated:Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ isdeprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
                ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’is ambiguous
                     NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
                ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:
                ../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                validation.target.mk:105: die Regel für Ziel „Release/obj.target/validation/src/validation.o“ scheiterte
                make: *** [Release/obj.target/validation/src/validation.o] Fehler 1
                make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird verlassen
                gyp ERR! build error
                gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
                gyp ERR! not ok
                > iobroker.xbox@0.5.12 install /opt/iobroker/node_modules/iobroker.xbox
                > npip install
                No python_modules directory; installing pip locally if needed.
                Successfully completed pip check.
                Collecting xbox-smartglass-rest>=0.9.8
                  Using cached https://files.pythonhosted.org/packages/4d/4f/f035df8a2ec5742b9e772071e006ea21aae3fc3bd0963753cfc1045d6fda/xbox_smartglass_rest-0.9.8-py2.py3-none-any.whl
                Collecting xbox-smartglass-stump>=0.9.5
                  Using cached https://files.pythonhosted.org/packages/34/f0/a75667f67ce6251b96a6989b8169eb9f2e25407ce2b0888e544b8caa98fe/xbox_smartglass_stump-0.9.5-py2.py3-none-any.whl
                Collecting Flask
                  Using cached https://files.pythonhosted.org/packages/9b/93/628509b8d5dc749656a9641f4caf13540e2cdec85276964ff8f43bbb1d3b/Flask-1.1.1-py2.py3-none-any.whl
                Collecting xbox-smartglass-core>=1.0.12
                  Using cached https://files.pythonhosted.org/packages/13/c8/2ffce1ddabe5b73422c7c46e808e4b02dbbc9362d2ecd2aee2a65e6e30a5/xbox_smartglass_core-1.0.12-py2.py3-none-any.whl
                Collecting xbox-webapi>=1.1.7
                  Using cached https://files.pythonhosted.org/packages/2d/bf/aaf24cc78184393c5c2472e822c0e145b793e346a8085bee02e89a3428ba/xbox_webapi-1.1.7-py2.py3-none-any.whl
                Collecting marshmallow-objects
                  Using cached https://files.pythonhosted.org/packages/4d/1c/fe15bc370707e8f8db09ab0edead45ab413b75795a8be523ca6482152183/marshmallow_objects-2.0.0-py2.py3-none-any.whl
                Collecting Werkzeug>=0.15
                  Using cached https://files.pythonhosted.org/packages/ce/42/3aeda98f96e85fd26180534d36570e4d18108d62ae36f87694b476b83d6f/Werkzeug-0.16.0-py2.py3-none-any.whl
                Collecting gevent==1.3.7
                  Using cached https://files.pythonhosted.org/packages/87/c4/9afb40b4a8b9186787d477aa6ebcfa17ead40ecbf83d5a1ed53dadd4f6ef/gevent-1.3.7-cp35-cp35m-manylinux1_x86_64.whl
                Processing /home/iobroker/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61/construct-2.9.41-cp35-none-any.whl
                Collecting cryptography==2.3.1
                  Using cached https://files.pythonhosted.org/packages/59/32/92cade62c645756a83598edf56289e9b19aae5370642a7ce690cd06bc72f/cryptography-2.3.1-cp34-abi3-manylinux1_x86_64.whl
                  Using cached https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
                Processing /home/iobroker/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f/dpkt-1.9.1-cp35-none-any.whl
                Collecting aenum==2.1.2; python_version <= "3.5"
                  Using cached https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
                Processing /home/iobroker/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded/demjson-2.2.4-cp35-none-any.whl
                Collecting requests
                  Using cached https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl
                  Using cached https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl
                Collecting asn1crypto>=0.21.0
                  Using cached https://files.pythonhosted.org/packages/e9/51/1db4a60049fb7390959be586b6eb743098e6cea3f6b2d3ed9e17fec62ba2/asn1crypto-1.3.0-py2.py3-none-any.whl
                Collecting cffi!=1.11.3,>=1.7
                  Using cached https://files.pythonhosted.org/packages/a8/8d/986e0c4e2aa3b24db56a0affc50d1a379150e3c4da45d51d549dc2697d53/cffi-1.13.2-cp35-cp35m-manylinux1_x86_64.whl
                Collecting six>=1.4.1
                  Using cached https://files.pythonhosted.org/packages/65/eb/1f97cb97bfc2390a276969c6fae16075da282f5058082d4cb10c6c5c1dba/six-1.14.0-py2.py3-none-any.whl
                Collecting certifi>=2017.4.17
                  Using cached https://files.pythonhosted.org/packages/b9/63/df50cac98ea0d5b006c55a399c3bf1db9da7b5a24de7890bc9cfd5dd9e99/certifi-2019.11.28-py2.py3-none-any.whl
                Collecting chardet<3.1.0,>=3.0.2
                  Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
                Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
                  Using cached https://files.pythonhosted.org/packages/b4/40/a9837291310ee1ccc242ceb6ebfd9eb21539649f193a7c8c86ba15b98539/urllib3-1.25.7-py2.py3-none-any.whl
                Processing /home/iobroker/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511/pycparser-2.19-py2.py3-none-any.whl
                Adapter gelb
                foxriver76F
                foxriver76F
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                marshmallow_objects
                Jetzt mal bitte pip show marshmallow-objects Ausgabe zeigen und falls da nix kommt oder 2.0.0 kommt mal pip install "marshmallow-objects==1.0.23" dann rm -r /opt/iobroker/node_modules/iobroker.xbox und nochmal npm i iobroker.xbox --unsafe-perm --production --prefix /opt/iobroker
                Videotutorials & mehr
                • foxriver76F foxriver76
                  marshmallow_objects
                  NegaleinN
                  NegaleinN
                  Negalein
                  @foxriver76 sagte in XBox-Adapter Fehler:
                  root@iobroker:/opt/iobroker# pip show marshmallow-objects
                  WARNING: Package(s) not found: marshmallow-objects
                  root@iobroker:/opt/iobroker# pip install "marshmallow-objects==1.0.23"
                  Collecting marshmallow-objects==1.0.23
                    Downloading https://files.pythonhosted.org/packages/2d/e2/05eebaa3d7f54349547792f82710c59457d3dc19dffd5ab9c11cfed3a421/marshmallow_objects-1.0.23-py2.py3-none-any.whl
                    Downloading https://files.pythonhosted.org/packages/e3/07/c7a12d21619abeedf5fca7381f4cf3fa798a26e8d92ad66bc73f5fc58fc1/marshmallow-2.20.5-py2.py3-none-any.whl (50kB)
                       |████████████████████████████████| 51kB 475kB/s
                  Successfully installed marshmallow-2.20.5 marshmallow-objects-1.0.23
                  root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/iobroker.xbox
                  bufferutil.target.mk:105: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
                  make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird verlassen
                  gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
                  gyp ERR! not ok
                  > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
                  > node-gyp rebuild
                  make: Verzeichnis „/opt/iobroker/node_modules/utf-8-validate/build“ wird betreten
                    CXX(target) Release/obj.target/validation/src/validation.o
                  gyp ERR! not ok
                  > npip install
                  Collecting Flask
                  Collecting requests
                  Processing /home/iobroker/.cache/pip/wheels/49/b5/ad/7355506059779337473b8eeb49384c9c0a9d45d34c8211a96d/urwid-2.1.0-cp35-cp35m-linux_x86_64.whl
                  Collecting appdirs
                  Collecting Jinja2>=2.10.1
                    Using cached https://files.pythonhosted.org/packages/65/e0/eb35e762802015cab1ccee04e8a277b03f1d8e53da3ec3106882ec42558b/Jinja2-2.10.3-py2.py3-none-any.whl
                  Collecting itsdangerous>=0.24
                    Using cached https://files.pythonhosted.org/packages/76/ae/44b03b253d6fade317f32c24d100b3b35c2239807046a4c953c7b89fa49e/itsdangerous-1.1.0-py2.py3-none-any.whl
                  Collecting click>=5.1
                    Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
                  Collecting marshmallow>=3.0.0
                    Using cached https://files.pythonhosted.org/packages/6e/76/01224f14737627166b94eb3bf0e334372c014edca781e39db320ce977755/marshmallow-3.3.0-py2.py3-none-any.whl
                  Collecting idna<2.9,>=2.5
                  Collecting MarkupSafe>=0.23
                    Using cached https://files.pythonhosted.org/packages/6e/57/d40124076756c19ff2269678de7ae25a14ebbb3f6314eb5ce9477f191350/MarkupSafe-1.1.1-cp35-cp35m-manylinux1_x86_64.whl
                  Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
                    Using cached https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl
                  ERROR: xbox-smartglass-core 1.0.12 has requirement urwid==2.0.1, but you'll have urwid 2.1.0 which is incompatible.
                  Installing collected packages: marshmallow, marshmallow-objects, chardet, certifi, urllib3, idna, requests, demjson, urwid, appdirs, xbox-webapi, greenlet, gevent, construct, asn1crypto, six, pycparser, cffi, cryptography, aenum, dpkt, xbox-smartglass-core, xbox-smartglass-stump, MarkupSafe, Jinja2, itsdangerous, click, Werkzeug, Flask, xbox-smartglass-rest
                  Successfully installed Flask-1.1.1 Jinja2-2.10.3 MarkupSafe-1.1.1 Werkzeug-0.16.0 aenum-2.1.2 appdirs-1.4.3 asn1crypto-1.3.0 certifi-2019.11.28 cffi-1.13.2 chardet-3.0.4 click-7.0 construct-2.9.41 cryptography-2.3.1 demjson-2.2.4 dpkt-1.9.1 gevent-1.3.7 greenlet-0.4.15 idna-2.8 itsdangerous-1.1.0 marshmallow-3.3.0 marshmallow-objects-2.0.0 pycparser-2.19 requests-2.22.0 six-1.14.0 urllib3-1.25.7 urwid-2.1.0 xbox-smartglass-core-1.0.12 xbox-smartglass-rest-0.9.8 xbox-smartglass-stump-0.9.5 xbox-webapi-1.1.7
                  npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
                  npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
                  + iobroker.xbox@0.5.12
                  added 3 packages from 3 contributors in 69.941s
                  Adapter gelb
                  xbox.0	2020-01-18 01:44:23.875	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:23.874	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:22.872	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:22.872	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:22.852	debug	(11600) [CHECK] Auth is not established
                  xbox.0	2020-01-18 01:44:22.850	warn	(11600) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                  xbox.0	2020-01-18 01:44:22.849	debug	(11600) [CONNECT] Check connection
                  xbox.0	2020-01-18 01:44:22.847	error	(11600) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                  xbox.0	2020-01-18 01:44:22.843	debug	(11600) [DISCOVER] Searching for consoles
                  xbox.0	2020-01-18 01:44:22.838	debug	(11600) [PING] Xbox online
                  xbox.0	2020-01-18 01:44:21.870	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:21.869	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:20.866	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:20.865	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:19.862	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:19.862	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:18.859	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:18.859	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:17.855	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:17.854	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:16.851	warn	(11600) [LOGIN] Connection refused, will try again
                  xbox.0	2020-01-18 01:44:16.850	debug	(11600) Could not parse body
                  xbox.0	2020-01-18 01:44:16.840	debug	(11600) [LOGOUT] <=== Failed to logout: undefined
                  xbox.0	2020-01-18 01:44:12.016	error	(11600) [START] Restarting adapter in 30 seconds
                  xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok
                  xbox.0	2020-01-18 01:44:11.076	debug	(11600) system.adapter.admin.0: logging true
                  xbox.0	2020-01-18 01:44:10.252	info	(11600) [START] Starting REST server
                  xbox.0	2020-01-18 01:44:10.251	debug	(11600) [START] IP address is 10.0.1.83
                  xbox.0	2020-01-18 01:44:10.194	info	(11600) starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.xbox, node: v10.17.0
                  xbox.0	2020-01-18 01:44:07.537	debug	(11600) States connected to redis: 0.0.0.0:9000
                  xbox.0	2020-01-18 01:44:07.483	debug	(11600) statesDB connected
                  xbox.0	2020-01-18 01:44:07.482	debug	(11600) States create PubSub Client
                  xbox.0	2020-01-18 01:44:07.473	debug	(11600) Objects connected to redis: 0.0.0.0:9001
                  xbox.0	2020-01-18 01:44:07.471	debug	(11600) Redis States: Use Redis connection: 0.0.0.0:9000
                  xbox.0	2020-01-18 01:44:07.469	debug	(11600) objectDB connected
                  xbox.0	2020-01-18 01:44:07.457	debug	(11600) Objects client initialize lua scripts
                  xbox.0	2020-01-18 01:44:07.456	debug	(11600) Objects create PubSub Client
                  xbox.0	2020-01-18 01:44:07.448	debug	(11600) Objects client ready ... initialize now
                  xbox.0	2020-01-18 01:44:07.415	debug	(11600) Redis Objects: Use Redis connection: 0.0.0.0:9001
                  ° Fixer ---> iob fix
                  • NegaleinN Negalein
                    DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
                    ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
                    ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
                         return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
                    ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
                           v8::Isolate::GCEpilogueCallback callback
                    ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
                         , v8::GCType gc_type_filter = v8::kGCTypeAll) {
                    ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
                           v8::Isolate::GCEpilogueCallback callback) {
                    ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
                           v8::Isolate::GCPrologueCallback callback
                    ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
                    ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
                           v8::Isolate::GCPrologueCallback callback) {
                    ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                    ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
                    In file included from ../src/bufferutil.cc:10:0:
                    gyp ERR! not ok
                    > node-gyp rebuild
                    gyp ERR! not ok
                    > npip install
                    Collecting Flask
                    Collecting requests
                    Collecting appdirs
                    Adapter gelb
                    foxriver76F
                    foxriver76F
                    foxriver76
                    @Negalein brauche das install log mal von Anfang an. Habe bei mir mal noch mal geupdated von alter Version, da kommen die ganzen C Geschichten gar nicht. Dachte das war schon damals so.
                    Lass es am besten mal in ein File schreiben da es ja sonst abgeschnitten wird npm i iobroker.xbox --unsafe-perm --prefix /opt/iobroker --production &> xbox-logfile. Und mir das File dann mal hochladen o. Inhalt posten.
                      NegaleinN
                      NegaleinN
                      Negalein
                      xbox-logfile.txt
                        xbox-logfile.txt
                        foxriver76F
                        foxriver76F
                        foxriver76
                        @Negalein fangen wir mal oben an. Da fangen die ganzen C-Geschichten an.
                        bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
                        node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/bufferutil/build“ wird betreten
                        Das Package sollte mit Xbox nix zu tun haben. Taucht bei mir in der Package Lock JSON nicht auf. Schauen wir mal ob es überhaupt jemand braucht npm ls bufferutil
                          node-gyp rebuild
                          NegaleinN
                          NegaleinN
                          Negalein
                          npm ls bufferutil
                          iobroker.inst@1.1.2 /opt/iobroker
                          └─┬ iobroker.kodi@1.0.0
                            └─┬ kodi-ws@2.4.0
                              └─┬ ws@0.7.2
                                └── UNMET OPTIONAL DEPENDENCY bufferutil@1.1.x
                          Kodi könnte ich deinstallieren. Läuft nur ab und an zu Testzwecken.
                            npm ls bufferutil
                              └─┬ kodi-ws@2.4.0
                                └─┬ ws@0.7.2
                            foxriver76F
                            foxriver76F
                            foxriver76
                            @Negalein die Dep ist sowieso nur optional, da sie ja anscheinend gar nicht gebaut werden kann. Können mal probieren ob npm dann Ruhe gibt rm -r /opt/iobroker/node_modules/bufferutil dann nochmal den Befehl von oben mit Xbox install ins File.
                              NegaleinN
                              NegaleinN
                              Negalein
                              root@iobroker:/opt/iobroker# rm -r /opt/iobroker/node_modules/bufferutil
                              rm: das Entfernen von '/opt/iobroker/node_modules/bufferutil' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                foxriver76F
                                foxriver76F
                                foxriver76
                                @Negalein Anscheinend kommt das von der veralteten Abhängigkeit auf ws https://github.com/instalator/kodi-ws/blob/bde03ec364c022f61e167a83733ef70873b7df73/package.json#L29 da gibt es mittlerweile Version 7.X. 😆
                                Naja, gut allerdings sollte es die Xbox Adapter Installation nicht beeinflussen - ist halt nur äußerst unschick, da theoretisch bei jeder Installation via npm das Logging auftauchen wird und versucht wird die Dep nachzuinstallieren.
                                Dann bleibt eigentlich nur das für den Adapter Install an Logging:
                                > npip install
                                Collecting Flask
                                Collecting requests
                                Installing collected packages: appdirs, demjson, urllib3, certifi, chardet, idna, requests, urwid, xbox-webapi, asn1crypto, pycparser, cffi, six, cryptography, dpkt, aenum, construct, greenlet, gevent, xbox-smartglass-core, Werkzeug, itsdangerous, click, MarkupSafe, Jinja2, Flask, marshmallow, marshmallow-objects, xbox-smartglass-stump, xbox-smartglass-rest
                                updated 1 package in 69.394s
                                Und das schaut eigentlich echt gut aus, bis noch auf die Warning mit dem Link auf sich selbst:
                                npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector' sollte allerdings auch keine Rolle spielen. Hierfür kann man mal ls -lah /opt/iobroker/node_modules machen um nachzuschauen.
                                Xbox loggt ja:
                                xbox.0	2020-01-18 01:44:12.015	error	(11600) [START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: not found Traceback (most recent call last): File "/opt/iobrok..
                                Was kommt denn bei ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src raus? Und was bei ls -lah /opt/iobroker/node_modules/nopy/src?
                                  > npip install
                                  Collecting Flask
                                  Collecting requests
                                  Xbox loggt ja:
                                  NegaleinN
                                  NegaleinN
                                  Negalein
                                  root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src
                                  ls: Zugriff auf '/opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                  root@iobroker:/opt/iobroker# ls -lah /opt/iobroker/node_modules/nopy/src
                                  insgesamt 1,6M
                                  drwxr-xr-x 1 iobroker iobroker  110 Nov 27 13:52 .
                                  drwxr-xr-x 1 iobroker iobroker   98 Nov 27 13:52 ..
                                  -rw-r--r-- 1 iobroker iobroker 7,5K Okt 26  1985 api.js
                                  -rw-r--r-- 1 iobroker iobroker 1,6M Okt 26  1985 get-pip.py
                                  -rwxr-xr-x 1 iobroker iobroker  530 Okt 26  1985 nopenv.js
                                  -rwxr-xr-x 1 iobroker iobroker  397 Okt 26  1985 nopy.js
                                  -rwxr-xr-x 1 iobroker iobroker 2,3K Okt 26  1985 npip.js
                                  -rw-r--r-- 1 iobroker iobroker  313 Okt 26  1985 promisify.js
                                  drwxr-xr-x 1 iobroker iobroker   36 Nov 27 13:52 test
                                    insgesamt 1,6M
                                    foxriver76F
                                    foxriver76F
                                    foxriver76
                                    @Negalein Passt eigentlich auch.
                                    Was passiert bei /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                    Ist 1 zu 1 das Kommando, dass der Adapter ausführt zum den Server zu starten. Er wird sagen Datei nicht gefunden für das erste und dann greift die Alternative die eigentlich passen sollte.
                                      NegaleinN
                                      NegaleinN
                                      Negalein
                                      ist das 1 Befehl? Also alles auf 1x kopieren und ausführen?
                                      Wenn Ja, dann kommt das:
                                      root@iobroker:/opt/iobroker# /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xboxr || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                      bash: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: Datei oder Verzeichnis nicht gefunden
                                        foxriver76F
                                        foxriver76F
                                        foxriver76
                                        @Negalein Jop passt perfekt, danke. Also sind wir letztendlich wieder bei der Vermutung vom Anfang, mit dieser marhsmallow-objects Depdendency. Bin dran: https://github.com/SVilgelm/marshmallow-objects/issues/70
                                          NegaleinN
                                          NegaleinN
                                          Negalein
                                          Perfekt!
                                          Dann warte ich mal auf News von dir! 😁
                                          84.2k
