  4. Was sind das für Fehlermeldungen?
host
2 Beiträge 2 Kommentatoren 188 Aufrufe 1 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    host.raspberrypi	2020-01-16 09:51:08.065	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-01-16 09:51:08.065	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Module.require (module.js:597:17)
    host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Module._compile (module.js:653:30)
    host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
    host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v57-linux-arm/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.061	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.061	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/8.17.0/linux/arm/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: ^
    host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-01-16 09:51:08.057	error
    Gruss
    • E Offline
      edonisXP
      Also ich habe seit dem Zigbee Adapter Update auf 1.02 die gleichen Fehlermeldungen.
      Wäre also auch auf eine Antwort gespannt.
