<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Was sind das für Fehlermeldungen?]]></title><description><![CDATA[<pre><code>
host.raspberrypi	2020-01-16 09:51:08.065	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.raspberrypi	2020-01-16 09:51:08.065	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at require (internal/module.js:11:18)
host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Module.require (module.js:597:17)
host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
host.raspberrypi	2020-01-16 09:51:08.064	error	Caught by controller[0]: at Module.load (module.js:566:32)
host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Module._compile (module.js:653:30)
host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
host.raspberrypi	2020-01-16 09:51:08.063	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v57-linux-arm/bindings.node
host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
host.raspberrypi	2020-01-16 09:51:08.062	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
host.raspberrypi	2020-01-16 09:51:08.061	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
host.raspberrypi	2020-01-16 09:51:08.061	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/8.17.0/linux/arm/bindings.node
host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
host.raspberrypi	2020-01-16 09:51:08.060	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
host.raspberrypi	2020-01-16 09:51:08.059	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: ^
host.raspberrypi	2020-01-16 09:51:08.058	error	Caught by controller[0]: throw err;
host.raspberrypi	2020-01-16 09:51:08.057	error
</code></pre>
<p dir="auto">Gruss</p>
]]></description><link>https://forum.iobroker.net/topic/29012/was-sind-das-für-fehlermeldungen</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 03:32:28 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/29012.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jan 2020 08:53:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Was sind das für Fehlermeldungen? on Thu, 30 Jan 2020 21:13:28 GMT]]></title><description><![CDATA[<p dir="auto">Also ich habe seit dem Zigbee Adapter Update auf 1.02 die gleichen Fehlermeldungen.<br />
Wäre also auch auf eine Antwort gespannt.</p>
<p dir="auto">Grüße</p>
]]></description><link>https://forum.iobroker.net/post/368148</link><guid isPermaLink="true">https://forum.iobroker.net/post/368148</guid><dc:creator><![CDATA[edonisXP]]></dc:creator><pubDate>Thu, 30 Jan 2020 21:13:28 GMT</pubDate></item></channel></rss>
