  4. Eurotronic Spirit ZigBee
    5.5k
58 Beiträge 10 Kommentatoren 13.1k Aufrufe 9 Beobachtet
  • F Freaknet
    @Jey-Cee und @Asgothian
    Also, hab den Adapter gelöscht und neu installiert.
    Immer noch das selbe Problem. Adapter wird nur Gelb und jetzt sind natürlich die ganzen Datenpunkte (Sensoren) weg.
    Hier noch der Log aus dem Debug
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @Freaknet bitte das log als Textdatei (in </> code tags) posten. Das Bild zeigt zu wenig Daten.
    A.
    F 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      Freaknet
      schrieb am zuletzt editiert von Freaknet
      @Asgothian
      deconz.0	2020-01-13 19:35:54.525	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
      deconz.0	2020-01-13 19:35:54.524	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","ser
      deconz.0	2020-01-13 19:35:39.801	debug	system.adapter.admin.0: logging true
      deconz.0	2020-01-13 19:35:34.514	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","se
      deconz.0	2020-01-13 19:35:34.513	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","se
      deconz.0	2020-01-13 19:35:34.512	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","se
      deconz.0	2020-01-13 19:35:34.511	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:80/description.xml","se
      deconz.0	2020-01-13 19:35:31.356	debug	system.adapter.admin.0: logging false
      deconz.0	2020-01-13 19:35:26.406	error	already running
      deconz.0	2020-01-13 19:35:26.398	debug	statesDB connected
      deconz.0	2020-01-13 19:35:26.354	debug	objectDB connected
      nachdem ich Neustart vom System durchgeführt habe schaut der Log so aus...
      deconz.0	2020-01-13 19:57:52.511	debug	NOTIFY {"protocol":"http","version":"1.1","method":"NOTIFY","path":"*","headers":{"host":"239.255.255.250:1900","cache-control":"max-age=100","location":"http://192.168.178.57:8080/description.xml","s
      deconz.0	2020-01-13 19:57:40.407	debug	system.adapter.admin.0: logging true
      deconz.0	2020-01-13 19:57:33.421	info	Get Config: Code 404: Ressource not found
      deconz.0	2020-01-13 19:57:32.970	info	starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.16.2
      deconz.0	2020-01-13 19:57:32.654	debug	statesDB connected
      deconz.0	2020-01-13 19:57:32.520	debug	objectDB connected
      Vielleicht hilft das hier noch...
      ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2020-01-13 20:10:14 CET; 9min ago
       Main PID: 3217 (deCONZ)
         CGroup: /system.slice/deconz.service
                 └─3217 /usr/bin/deCONZ -platform minimal --http-port=8080
      Jan 13 20:10:14 debian-iobroker systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
      Jan 13 20:10:14 debian-iobroker deCONZ[3217]: libpng warning: iCCP: known incorrect sRGB profile
      Jan 13 20:10:14 debian-iobroker systemd[1]: [/lib/systemd/system/deconz.service:9] Unknown lvalue 'StartLimitIntervalSec' in section 'Ser
      Jan 13 20:10:14 debian-iobroker deCONZ[3217]: This plugin does not support propagateSizeHints()
      Jan 13 20:10:29 debian-iobroker systemd[1]: [/lib/systemd/system/deconz.service:9] Unknown lvalue 'StartLimitIntervalSec' in section 'Ser
      Jan 13 20:10:39 debian-iobroker systemd[1]: [/lib/systemd/system/deconz.service:9] Unknown lvalue 'StartLimitIntervalSec' in section 'Ser
      Jan 13 20:19:53 debian-iobroker systemd[1]: [/lib/systemd/system/deconz.service:9] Unknown lvalue 'StartLimitIntervalSec' in section 'Ser
      • F Freaknet
        @Asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @Freaknet Bitte verifizier mal was du als Port in den Einstellungen stehen hast. Die funktionierenden Logs gehen auf Port 80, die anderen auf Port 8080.
        A.
          A.
          Freaknet
          @Asgothian
          Jetzt läuft erstmal alles plötzlich wieder. Hab den Adapter nochmal deinstalliert und neu installiert. Als Port hab ich dann mal 8080 eingestellt, hat vorher immer mit keinem Port geklappt.
          • F Freaknet
            @Asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @Freaknet
            Das kann mit Voreinstellungen im Adapter zusammen gehangen haben. Aber es ist gut das jetzt alles wieder läuft.
            Die Skripte musstest du auch nicht anpassen, oder ?
              @Freaknet
              Freaknet
              @Asgothian
              Leider geklappt es trotzdem nicht :-(
              Der Adapter wird zwar grün aber die Sensoren reagieren im ioBroker nicht.
              In der App werden z.B. Bewegungen erkannt, im Adapter aber nicht...
              Oh mann, bin am Verzweifeln.
              • F Freaknet
                @Asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @Freaknet
                Bitte mach mal folgenden Test:
                • Lös einen BWM aus
                • starte den deconz Adapter neu
                • prüfe ob der Status des BWM korrekt in den Objekten steht.
                • löse einen anderen bwm aus und prüfe ob der Status im Adapter stimmt.
                Es kann sein das du ein Problem mit dem “subscriben” der Änderungen an der Rest api hast. Es gibt Kombinationen von deconz-Adapter und Rest-api bei denen die Verbindung nach einiger Zeit abreißt.
                Welche deconz Version nutzt du (deconz, nicht iobroker.deconz)
                A.
                  @Freaknet
                  • Lös einen BWM aus
                  A.
                  Freaknet
                  @Asgothian
                  Vielen Dank das Du mir so behilflich bist...
                  Vorab... hat das was zu bedeuten, dass der Deconz Adapter zwar grün wird, aber immer wieder kurz ROT aufleuchtet. Danach ist er wieder grün und so weiter.
                  BWM ausgelöst -> Adapter reagiert nicht -> App schon
                  Deconz Neustart bringt keine Aktualisierung. Bleibt letzter Wert in Objekt stehen.
                  Also Einstellungen hab ich folgende:
                  ioBroker Adapter
                  Deconz-IP + Port 8080 und API-Key
                  deconz-Gateway
                  Version 2.05.72 und Firmware 26330500
                  API-Verson 1.16.0
                  Einstellungen in der /lib/systemd/system/deconz.service
                  [Unit]
                  Description=deCONZ: ZigBee gateway -- REST API
                  Wants=deconz-init.service deconz-update.service
                  [Service]
                  User=0
                  ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80
                  Restart=on-failure
                  StartLimitIntervalSec=0
                  RestartSec=30
                  AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
                  [Install]
                  WantedBy=multi-user.target
                  Status deconz
                     Active: active (running) since Mon 2020-01-13 22:57:15 CET; 13min ago
                   Main PID: 18367 (deCONZ)
                      Tasks: 5 (limit: 4915)
                             └─18367 /usr/bin/deCONZ -platform minimal --http-port=80
                  Status deconz-gui
                  permitted by applicable law.
                  Last login: Mon Jan 13 22:53:16 2020 from 192.168.178.41
                  root@debian-iobroker:~# service deconz-gui status
                  ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
                     Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor pres
                     Active: failed (Result: exit-code) since Mon 2020-01-13 22:49:04 CET; 22min a
                   Main PID: 26981 (code=exited, status=143)
                  Falls es noch hilft hier die Log-Datei
                  host.debian-iobroker	2020-01-13 23:20:19.146	info	Restart adapter system.adapter.deconz.0 because enabled
                  host.debian-iobroker	2020-01-13 23:20:19.145	error	instance system.adapter.deconz.0 terminated with code 7 (Adapter already running)
                  host.debian-iobroker	2020-01-13 23:20:17.658	info	instance system.adapter.deconz.0 started with pid 9476
                  Bin für heute erstmal durch, muss schlafen ;-) Danke nochmal bis dahin!
                  • F Offline
                    Freaknet
                    Hey, kann es an der Version 1.2.2 vom Adapter liegen? Hab jetzt den Adapter kpl. gelöscht und die alte Version 1.1.2 in Stable installiert. Jetzt läuft wieder alles 1A.
                    Irgendwie hat die Aktualisierung zwischen Phoscon-App und der Version 1.2.2 nicht geklappt.
                    Nur wenn ich den Adapter Neu starte wird die letzte Aktualisierung geändert.
                    • H Offline
                      Hoffiheller
                      schrieb am zuletzt editiert von Hoffiheller
                      Hallo, ich habe ähnliche Probleme mit der Version 1.2.2, nur kommt bei mir noch hinzu das ich auch keine Objekte aus den IoBroker steuern kann und somit auch sämtliche skripte nicht laufen. Nachdem ich jetzt wieder auf 1.1.2 installiert habe läuft alles wieder Problemlos. Jedoch kann ich jetzt auch nicht genau sagen ob es an deconz liegt da ich ziemlich zeitgleich mit den Update mein ganzes system geupdatet habe.
                      mein System: Conbee 1 stick am Pi 4
                      Platform: linux
                      os: linux
                      Architecture: arm
                      CPUs: 4
                      Speed: 600 MHz
                      Model: ARMv7 Processor rev 3 (v7l)
                      RAM: 3.8 GB
                      System uptime: 22:16:12
                      Node.js: v10.18.1
                      NPM: 6.13.4
                      Disk size: 58.3 GiB
                      Disk free: 53.2 GiB
                      adapters count: 312
                      Uptime: 22:16:33
                      Active instances: 21
                      diese Logeinträge sind vorhanden immer wiederholend sowie ich versuche etwas zu schalten aus den IoBroker heraus.
                      deconz.0	2020-01-14 17:57:03.071	info	(7162) Set light state with ID: 4 parameter: {"on": true} Code 404: Ressource not found
                      deconz.0	2020-01-14 17:57:03.048	info	(7162) setLightState: {"on": true} 4 deconz.0.Lights.4.on
                      deconz.0	2020-01-14 17:56:51.319	info	(7162) Get Config: Code 404: Ressource not found
                      deconz.0	2020-01-14 17:56:51.209	info	(7162) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.18.1```
                      • H Hoffiheller
                        Platform: linux
                        os: linux
                        Architecture: arm
                        CPUs: 4
                        Speed: 600 MHz
                        RAM: 3.8 GB
                        Node.js: v10.18.1
                        NPM: 6.13.4
                        Disk size: 58.3 GiB
                        Disk free: 53.2 GiB
                        adapters count: 312
                        Uptime: 22:16:33
                        Freaknet
                        @Hoffiheller said in Eurotronic Spirit ZigBee:
                        Kann ich leider dazu nix sagen ob die Stats sich hätten schalten lassen, denke aber nicht, weil einfach keine Synchronisation zwischen Phoscon-App und ioBroker-Adapter bei mir stattgefunden hat. Somit sollten auch die Werte vom ioBroker (true/false) zum Gateway nicht übermittelt werden.
                        Sollte ich nochmal die Muse haben es zu versuchen würde ich ggf. mal die 1.2.0 installieren. Mir geht es Vorrangig ja um die Eurotronic Thermostate, damit ich alle Stats zum Regeln bekommen und nicht nur die aktuellen 6 Stats. Die waren in der 1.2.2 zwar da, aber hilft mir nix wenn alles weitere nicht geht.
                        Weiß jemand ob die Stats auch schon in 1.2.0 vorhanden sind?
                        Die Verbesserung der update time zu local ist für mich nebensächlich aber auch wichtig, da aktuell ja immer -1h zum letzten Update angezeigt wird. Denke hier liegt auch das Problem vergraben, ist aber wie gesagt nur eine Vermutung!
                        Bisher wurde aber bei dem Adapter echt Sau Gute Arbeit geleistet! Respekt dafür nochmal!
                        • Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          Es ist sehr bedauerlich das es mit der Aktuellen Version zu solchen Problemen kommt.
                          @Hoffiheller Adapter komplett gelöscht und nicht nur die Instanz?
                          @Freaknet sagte in Eurotronic Spirit ZigBee:
                          Diese Version kann nicht installiert werden da sie nie auf npm war, sorry.
                          Persönlicher Support
                          Spenden -> paypal.me/J3YC33
                          F H 2 Antworten Letzte Antwort
                          • Jey CeeJ Jey Cee
                            Freaknet
                            @Jey-Cee said in Eurotronic Spirit ZigBee:
                            Hab gesehen das heute die 1.2.3 in Test gegangen ist. Hat sich da grundlegend was geändert? Hatte ja die Befürchtung das es was mit der updateTime zu tun haben könnte weil da komische Werte angezeigt wurden (leider kein Screenshot gemacht) weil die Stats nicht vom Gateway zum Adapter gesendet werden.
                            Grundsätzlich: Ist es sinnvoll den kpl. deconz-Adapter zu deinstallieren und ein Reboot vom System durchzuführen oder reicht es die neue Version von gitHub zu holen und dann den Adapter "nur" zu upgraden? Vielleicht ist da ja das Problem, zumindest bei mir ;-)
                            Bin ja immer noch bereit zu testen ;-)
                            • F Freaknet
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              @Freaknet Adapter löschen, nicht nur die Instanz. Reboot ist nicht nötig.
                              Sind ein paar Bugfixes gewesen.
                              • Jey CeeJ Jey Cee
                                Freaknet
                                @Jey-Cee
                                Ok... dann hatte ich das schon richtig verstanden und gemacht ;-)
                                Dann lags an dem nicht...
                                Das deconz Gateway muss ich auch nicht neu starten nach der Adapter installation, oder? Nur halt nen neuen API-Key erzeugen lassen oder könnte ich auch den alten wieder eintragen aus der Vorgängerversion?
                                Bei anderen Adapter-Updates schaufel ich ja nur das Update drüber und der Adapter startet einfach neu...
                                Werde berichten ob 1.2.3 bei mir läuft! Wäre ne Super Tolle Sache wenn ja :-)
                                Danke bis dahin.
                                • Jey CeeJ Jey Cee
                                  Hoffiheller
                                  @Jey-Cee
                                  habe es eben nochmal versucht, Adapter komplett gelöscht und in der Version 1.2.2 Installiert, leider habe ich es in der version auch nicht geschafft einen API key zu erstellen, schlussendlich habe ich wieder ein downgrade auf Version 1.1.2 und siehe es läuft wieder.
                                  bei der Installation gab es auch ein paar Fehlermeldung mit denen ich allerdings nix anfangen kann, aber beim downgrade kamen die selben Meldungen.
                                  $ ./iobroker add deconz  --host raspberrypi
                                  NPM version: 6.13.4
                                  npm install iobroker.deconz@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                  In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
                                  In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc: At global scope:/home/iobroker/.cache/node-gyp/10.18.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.18.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
                                  In file included from /home/iobroker/.cache/node-gyp/10.18.1/include/node/node.h:63,                 from ../src/linux/BluetoothSerialPort.cc:12:/home/iobroker/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.18.1/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  /home/iobroker/.cache/node-gyp/10.18.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.18.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                  ../src/linux/DeviceINQ.cc:35:14: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden     #include <bluetooth/bluetooth.h>              ^~~~~~~~~~~~~~~~~~~~~~~compilation terminated.
                                  make: *** [BluetoothSerialPort.target.mk:107: Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
                                  gyp
                                   ERR! build error
                                  gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                  gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR!
                                  cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v10.18.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
                                  host.raspberrypi install adapter deconz
                                  ERROR: Some packets could not be installed. Please install them manually
                                  upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                  upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                  upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                  upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                  host.raspberrypi object system.adapter.deconz created/updated
                                  host.raspberrypi object enum.functions.color created/updated
                                  host.raspberrypi create instance deconz
                                  host.raspberrypi object deconz.0.Gateway_info.alive created
                                  host.raspberrypi object deconz.0.Gateway_info.network_open created
                                  host.raspberrypi object deconz.0.Gateway_info created
                                  host.raspberrypi object deconz.0.info.connection created
                                  host.raspberrypi object deconz.0.info created
                                  host.raspberrypi object deconz.0.Sensors created
                                  host.raspberrypi object deconz.0.Lights created
                                  host.raspberrypi object deconz.0.Groups created
                                  host.raspberrypi object system.adapter.deconz.0.sigKill created
                                  host.raspberrypi object system.adapter.deconz.0.eventLoopLag created
                                  host.raspberrypi object system.adapter.deconz.0.outputCount created
                                  host.raspberrypi object system.adapter.deconz.0.inputCount created
                                  host.raspberrypi object system.adapter.deconz.0.uptime created
                                  host.raspberrypi object system.adapter.deconz.0.memRss created
                                  host.raspberrypi object system.adapter.deconz.0.memHeapTotal created
                                  host.raspberrypi object system.adapter.deconz.0.memHeapUsed created
                                  host.raspberrypi object system.adapter.deconz.0.cputime created
                                  host.raspberrypi object system.adapter.deconz.0.cpu created
                                  host.raspberrypi object system.adapter.deconz.0.compactMode created
                                  host.raspberrypi object system.adapter.deconz.0.connected created
                                  host.raspberrypi object system.adapter.deconz.0.alive created
                                  host.raspberrypi object system.adapter.deconz.0 created
                                  process exited with code 0```
                                  • F Freaknet
                                    @Jey-Cee
                                    Danke bis dahin.
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    Ja kannst den alten verwenden.
                                    • H Hoffiheller
                                      @Jey-Cee
                                      NPM version: 6.13.4
                                      gyp
                                       ERR! build error
                                      Jey CeeJ Online
                                      Jey CeeJ Online
                                      Jey Cee
                                      @Hoffiheller gyp Fehler kann man normal ignorieren. Also kein Stress so lange alles tut.
                                      H 1 Antwort Letzte Antwort
                                      • Jey CeeJ Jey Cee
                                        Hoffiheller
                                        @Jey-Cee kein problem solange es eine version gibt die funktioniert bin ich zufrieden, ich dachte nur ich erwähne auch mal ein Problem
                                        👍 und vielen Dank an alle die sich die Arbeit machen so etwas auf die beine zu stellen.
                                        • Jey CeeJ Jey Cee
                                          Freaknet
                                          @Jey-Cee
                                          Jetzt noch eine Frage :-)
                                          Ab Version 1.1.3 ist ja der Port 80 als default hinterlegt.
                                          Bei mir läuft das Gateway unter http://ip/pwa/index.html.
                                          Muss ich dann im Adapter Port 80 eintragen oder kann das Feld weiter leer bleiben?
                                          Hoff das war für heute die letzte Frage ;-)
