- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- [Gelöst] Probleme mit Backup-Wiederherstellung
sieh doch mal im log nach ob sich dort irgendetwas tut.
@htrecksler kommt er doch ohne admin nicht ran
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
@Homoran über den Explorer, ist doch Windows, oder?
Gruss Hermann
2020-01-12 11:08:04.389 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker.js-controller version 2.1.0 js-controller starting 2020-01-12 11:08:04.391 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker 2020-01-12 11:08:04.391 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) hostname: LAPTOP-JRJ6BEAS(SmartHome2), node: v10.17.0 2020-01-12 11:08:04.398 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) ip addresses: fe80::35e3:cfc9:9ccf:efc 192.168.178.84 fe80::919c:c365:d90d:4596 192.168.137.1 2020-01-12 11:08:04.435 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) connected to Objects and States 2020-01-12 11:08:04.446 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) 3 instances found 2020-01-12 11:08:04.448 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) starting 3 instances 2020-01-12 11:08:04.461 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 started with pid 13704 2020-01-12 11:08:04.927 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) received SIGINT 2020-01-12 11:08:04.928 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 (force=false, process=true) 2020-01-12 11:08:04.928 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.discovery.0 (force=false, process=false) 2020-01-12 11:08:04.928 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.info.0 (force=false, process=false) 2020-01-12 11:08:04.929 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 send kill signal 2020-01-12 11:08:05.440 - [32minfo[39m: admin.0 (13704) starting. Version 3.6.12 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.admin, node: v10.17.0 2020-01-12 11:08:05.452 - [32minfo[39m: admin.0 (13704) requesting all states 2020-01-12 11:08:05.452 - [32minfo[39m: admin.0 (13704) requesting all objects 2020-01-12 11:08:05.464 - [32minfo[39m: admin.0 (13704) received all objects 2020-01-12 11:08:05.467 - [33mwarn[39m: admin.0 (13704) Repository cannot be read 2020-01-12 11:08:05.478 - [32minfo[39m: admin.0 (13704) http server listening on port 8091 2020-01-12 11:08:05.478 - [32minfo[39m: admin.0 (13704) Use link "http://localhost:8091" to configure. 2020-01-12 11:08:05.929 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 killing pid 13704 2020-01-12 11:08:05.939 - [33mwarn[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 terminated due to SIGTERM 2020-01-12 11:08:05.939 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 terminated with code null () 2020-01-12 11:08:05.940 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) All instances are stopped. 2020-01-12 11:08:06.135 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) terminated 2020-01-12 11:08:13.371 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker.js-controller version 2.1.0 js-controller starting 2020-01-12 11:08:13.374 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker 2020-01-12 11:08:13.374 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) hostname: LAPTOP-JRJ6BEAS(SmartHome2), node: v10.17.0 2020-01-12 11:08:13.381 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) ip addresses: fe80::35e3:cfc9:9ccf:efc 192.168.178.84 fe80::919c:c365:d90d:4596 192.168.137.1 2020-01-12 11:08:13.418 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) connected to Objects and States 2020-01-12 11:08:13.433 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) 3 instances found 2020-01-12 11:08:13.436 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) starting 3 instances 2020-01-12 11:08:13.452 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 started with pid 17428 2020-01-12 11:08:14.396 - [32minfo[39m: admin.0 (17428) starting. Version 3.6.12 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.admin, node: v10.17.0 2020-01-12 11:08:14.418 - [32minfo[39m: admin.0 (17428) requesting all states 2020-01-12 11:08:14.418 - [32minfo[39m: admin.0 (17428) requesting all objects 2020-01-12 11:08:14.464 - [32minfo[39m: admin.0 (17428) received all objects 2020-01-12 11:08:14.467 - [33mwarn[39m: admin.0 (17428) Repository cannot be read 2020-01-12 11:08:14.496 - [32minfo[39m: admin.0 (17428) http server listening on port 8091 2020-01-12 11:08:14.496 - [32minfo[39m: admin.0 (17428) Use link "http://localhost:8091" to configure. 2020-01-12 11:08:17.450 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.discovery.0 started with pid 18828 2020-01-12 11:08:17.989 - [32minfo[39m: discovery.0 (18828) starting. Version 1.3.0 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.discovery, node: v10.17.0 2020-01-12 11:08:21.446 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.info.0 started with pid 1572 2020-01-12 11:08:22.438 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) Update repository "default" under "http://download.iobroker.net/sources-dist.json" 2020-01-12 11:08:23.792 - [32minfo[39m: info.0 (1572) starting. Version 1.5.6 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.info, node: v10.17.0 2020-01-12 11:08:24.733 - [32minfo[39m: info.0 (1572) Popup news was read... 2020-01-12 11:10:18.327 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) received SIGINT 2020-01-12 11:10:18.329 - [32minfo[39m: admin.0 (17428) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:10:18.329 - [32minfo[39m: discovery.0 (18828) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:10:18.328 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 (force=false, process=true) 2020-01-12 11:10:18.329 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.discovery.0 (force=false, process=true) 2020-01-12 11:10:18.329 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.info.0 (force=false, process=true) 2020-01-12 11:10:18.329 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 send kill signal 2020-01-12 11:10:18.329 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.discovery.0 send kill signal 2020-01-12 11:10:18.330 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.info.0 send kill signal 2020-01-12 11:10:18.330 - [32minfo[39m: info.0 (1572) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:10:18.330 - [32minfo[39m: discovery.0 (18828) terminating 2020-01-12 11:10:18.330 - [32minfo[39m: discovery.0 (18828) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:10:18.331 - [32minfo[39m: info.0 (1572) cleaned everything up... 2020-01-12 11:10:18.331 - [32minfo[39m: info.0 (1572) terminating 2020-01-12 11:10:18.331 - [32minfo[39m: info.0 (1572) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:10:18.330 - [32minfo[39m: admin.0 (17428) terminating http server on port 8091 2020-01-12 11:10:18.331 - [32minfo[39m: admin.0 (17428) terminating 2020-01-12 11:10:18.331 - [32minfo[39m: admin.0 (17428) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:10:18.843 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:10:18.844 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:10:18.845 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:10:18.845 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) All instances are stopped. 2020-01-12 11:10:18.931 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) terminated 2020-01-12 11:11:52.028 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker.js-controller version 2.1.0 js-controller starting 2020-01-12 11:11:52.031 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker 2020-01-12 11:11:52.031 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) hostname: LAPTOP-JRJ6BEAS(SmartHome2), node: v10.17.0 2020-01-12 11:11:52.039 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) ip addresses: fe80::35e3:cfc9:9ccf:efc 192.168.178.84 fe80::919c:c365:d90d:4596 192.168.137.1 2020-01-12 11:11:52.111 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) connected to Objects and States 2020-01-12 11:11:52.127 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) 3 instances found 2020-01-12 11:11:52.130 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) starting 3 instances 2020-01-12 11:11:52.151 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 started with pid 7596 2020-01-12 11:11:53.024 - [32minfo[39m: admin.0 (7596) starting. Version 3.6.12 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.admin, node: v10.17.0 2020-01-12 11:11:53.035 - [32minfo[39m: admin.0 (7596) requesting all states 2020-01-12 11:11:53.035 - [32minfo[39m: admin.0 (7596) requesting all objects 2020-01-12 11:11:53.118 - [32minfo[39m: admin.0 (7596) received all objects 2020-01-12 11:11:53.138 - [32minfo[39m: admin.0 (7596) http server listening on port 8091 2020-01-12 11:11:53.138 - [32minfo[39m: admin.0 (7596) Use link "http://localhost:8091" to configure. 2020-01-12 11:11:56.140 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.discovery.0 started with pid 7116 2020-01-12 11:11:56.606 - [32minfo[39m: discovery.0 (7116) starting. Version 1.3.0 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.discovery, node: v10.17.0 2020-01-12 11:12:00.136 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.info.0 started with pid 3292 2020-01-12 11:12:01.441 - [32minfo[39m: info.0 (3292) starting. Version 1.5.6 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.info, node: v10.17.0 2020-01-12 11:12:02.543 - [32minfo[39m: info.0 (3292) Popup news was read... 2020-01-12 11:12:31.540 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) Update repository "default" under "http://download.iobroker.net/sources-dist.json" 2020-01-12 11:12:52.179 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker add backitup --host LAPTOP-JRJ6BEAS(SmartHome2) 2020-01-12 11:12:54.051 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker NPM version: 6.11.3 2020-01-12 11:12:54.052 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker npm install iobroker.backitup@1.3.6 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome2" (System call) 2020-01-12 11:13:08.804 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) install adapter backitup 2020-01-12 11:13:08.831 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker upload [3] backitup.admin C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup/admin/words.js words.js application/javascript 2020-01-12 11:13:08.931 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker upload [2] backitup.admin C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html 2020-01-12 11:13:08.992 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker upload [1] backitup.admin C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup/admin/index.html index.html text/html 2020-01-12 11:13:09.053 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker upload [0] backitup.admin C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png 2020-01-12 11:13:09.123 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup created/updated 2020-01-12 11:13:09.155 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) create instance backitup 2020-01-12 11:13:09.160 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.output.line created 2020-01-12 11:13:09.188 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.output created 2020-01-12 11:13:09.217 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.oneClick.iobroker created 2020-01-12 11:13:09.244 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.oneClick.ccu created 2020-01-12 11:13:09.273 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.oneClick created 2020-01-12 11:13:09.301 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history.iobrokerSuccess created 2020-01-12 11:13:09.330 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history.ccuSuccess created 2020-01-12 11:13:09.359 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history.iobrokerLastTime created 2020-01-12 11:13:09.386 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history.ccuLastTime created 2020-01-12 11:13:09.414 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history.html created 2020-01-12 11:13:09.442 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.history created 2020-01-12 11:13:09.470 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.info.latestBackup created 2020-01-12 11:13:09.498 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object backitup.0.info created 2020-01-12 11:13:09.527 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.sigKill created 2020-01-12 11:13:09.556 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.eventLoopLag created 2020-01-12 11:13:09.585 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.outputCount created 2020-01-12 11:13:09.614 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.inputCount created 2020-01-12 11:13:09.642 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.uptime created 2020-01-12 11:13:09.671 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.memRss created 2020-01-12 11:13:09.700 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.memHeapTotal created 2020-01-12 11:13:09.729 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.memHeapUsed created 2020-01-12 11:13:09.759 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.cputime created 2020-01-12 11:13:09.788 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.cpu created 2020-01-12 11:13:09.816 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.compactMode created 2020-01-12 11:13:09.845 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.connected created 2020-01-12 11:13:09.874 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0.alive created 2020-01-12 11:13:09.919 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker host.LAPTOP-JRJ6BEAS(SmartHome2) object system.adapter.backitup.0 created 2020-01-12 11:13:10.918 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) iobroker exit 0 2020-01-12 11:13:12.429 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 started with pid 1944 2020-01-12 11:13:16.497 - [32minfo[39m: backitup.0 (1944) starting. Version 1.3.6 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup, node: v10.17.0 2020-01-12 11:13:53.333 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 (force=false, process=true) 2020-01-12 11:13:53.334 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 send kill signal 2020-01-12 11:13:53.334 - [32minfo[39m: backitup.0 (1944) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:13:53.836 - [32minfo[39m: backitup.0 (1944) terminating 2020-01-12 11:13:53.836 - [32minfo[39m: backitup.0 (1944) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:13:54.335 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 killing pid 1944 2020-01-12 11:13:54.345 - [33mwarn[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated due to SIGTERM 2020-01-12 11:13:54.346 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated with code null () 2020-01-12 11:13:55.843 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 started with pid 2668 2020-01-12 11:13:58.488 - [32minfo[39m: backitup.0 (2668) starting. Version 1.3.6 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup, node: v10.17.0 2020-01-12 11:13:58.524 - [32minfo[39m: backitup.0 (2668) [iobroker] backup was activated at 02:00 every 1 day(s) 2020-01-12 11:14:15.441 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 (force=false, process=true) 2020-01-12 11:14:15.441 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 send kill signal 2020-01-12 11:14:15.448 - [32minfo[39m: backitup.0 (2668) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:14:15.950 - [32minfo[39m: backitup.0 (2668) terminating 2020-01-12 11:14:15.950 - [32minfo[39m: backitup.0 (2668) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:14:16.447 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 killing pid 2668 2020-01-12 11:14:16.461 - [33mwarn[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated due to SIGTERM 2020-01-12 11:14:16.461 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated with code null () 2020-01-12 11:14:17.953 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 started with pid 7076 2020-01-12 11:14:19.271 - [32minfo[39m: backitup.0 (7076) starting. Version 1.3.6 in C:/Program Files/iobroker/SmartHome2/node_modules/iobroker.backitup, node: v10.17.0 2020-01-12 11:14:19.290 - [32minfo[39m: backitup.0 (7076) [iobroker] backup was activated at 02:00 every 1 day(s) 2020-01-12 11:15:01.579 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) received SIGINT 2020-01-12 11:15:01.580 - [32minfo[39m: admin.0 (7596) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:15:01.581 - [32minfo[39m: discovery.0 (7116) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 (force=false, process=true) 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.discovery.0 (force=false, process=true) 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.info.0 (force=false, process=true) 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 (force=false, process=true) 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.admin.0 send kill signal 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.discovery.0 send kill signal 2020-01-12 11:15:01.580 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.info.0 send kill signal 2020-01-12 11:15:01.581 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 send kill signal 2020-01-12 11:15:01.581 - [32minfo[39m: backitup.0 (7076) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:15:01.581 - [32minfo[39m: info.0 (3292) Got terminate signal TERMINATE_YOURSELF 2020-01-12 11:15:01.581 - [32minfo[39m: discovery.0 (7116) terminating 2020-01-12 11:15:01.582 - [32minfo[39m: discovery.0 (7116) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:15:01.582 - [32minfo[39m: info.0 (3292) cleaned everything up... 2020-01-12 11:15:01.582 - [32minfo[39m: info.0 (3292) terminating 2020-01-12 11:15:01.582 - [32minfo[39m: info.0 (3292) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:15:01.581 - [32minfo[39m: admin.0 (7596) terminating http server on port 8091 2020-01-12 11:15:01.581 - [32minfo[39m: admin.0 (7596) terminating 2020-01-12 11:15:01.582 - [32minfo[39m: admin.0 (7596) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:15:02.082 - [32minfo[39m: backitup.0 (7076) terminating 2020-01-12 11:15:02.083 - [32minfo[39m: backitup.0 (7076) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-01-12 11:15:02.093 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:15:02.093 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:15:02.094 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX) 2020-01-12 11:15:02.583 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) stopInstance system.adapter.backitup.0 killing pid 7076 2020-01-12 11:15:02.592 - [33mwarn[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated due to SIGTERM 2020-01-12 11:15:02.592 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) instance system.adapter.backitup.0 terminated with code null () 2020-01-12 11:15:02.592 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) All instances are stopped. 2020-01-12 11:15:02.784 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome2) terminated 2020-01-12 11:15:22.723 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) iobroker.js-controller version 2.1.0 js-controller starting 2020-01-12 11:15:22.727 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker 2020-01-12 11:15:22.728 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) hostname: LAPTOP-JRJ6BEAS(SmartHome), node: v10.17.0 2020-01-12 11:15:22.736 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) ip addresses: fe80::35e3:cfc9:9ccf:efc 192.168.178.84 fe80::919c:c365:d90d:4596 192.168.137.1 2020-01-12 11:15:22.968 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) connected to Objects and States 2020-01-12 11:15:23.049 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) Delete host system.host.LAPTOP-JRJ6BEAS(SmartHome2) 2020-01-12 11:15:23.072 - [32minfo[39m: host.LAPTOP-JRJ6BEAS(SmartHome) 31 instances found 2020-01-12 11:15:23.076 - [33mwarn[39m: host.LAPTOP-JRJ6BEAS(SmartHome) does not start any instances on this hostseit 11.15 Uhr tut sich da nichts mehr
@DennisMenger sagte in Probleme mit Backup-Wiederherstellung:
Das sieht so aus, als ob der alte host (war der das???) gelöscht wurde, du aber den aktuellen nicht angelegt hattest.
Wenn jetzt eh nichts läuft versuche es mal mit
iobroker stop iobroker host this iobroker startkein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
iobroker stop iobroker host this iobroker start@Homoran Sauber, das hat funktioniert. Hat jetzt noch ein wenig gedauert bis alle Instanzen liefen. Jetzt scheint aber alles zu funktionieren.
"Das sieht so aus, als ob der alte host (war der das???) gelöscht wurde, du aber den aktuellen nicht angelegt hattest."
Hätte ich da noch was machen müssen? Ich dachte das macht Backitup alles? Dafür soll doch der Adapter sein oder?
@Homoran sagte in Probleme mit Backup-Wiederherstellung:
muss bei einem Restore auf einem anderen Rechner (ich nehme das bei einer anderen WIN Instanz mal so an) VOR dem ersten Start ein iobroker host this ausgeführt werden
Woher soll der neu installierte Adapter wissen, dass du nicht mehr auf dem Ursprungssystem bist
Also funktioniert der Adapter letztendlich nur, wenn man ein Backup auf dem gleichen System zurückspielen möchte. Ist ja gut zu wissen. Dann ist das für mich gelöst. Danke euch. -
Also funktioniert der Adapter letztendlich nur, wenn man ein Backup auf dem gleichen System zurückspielen möchte. Ist ja gut zu wissen. Dann ist das für mich gelöst. Danke euch.@DennisMenger sagte in Probleme mit Backup-Wiederherstellung:
nein.
Man muss nur vor dem Start auf einem anderen System ein
iobroker host thisausführenkein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
nein.
iobroker host thisausführen@Homoran ok dann weiß ich das jetzt für die Zukunft
