  4. JavaScript
  5. Script fürTabelle der Batterie Zustände
javascriptmonitoringtemplate
1.4k Beiträge 67 Kommentatoren 889.9k Aufrufe 86 Beobachtet
  • liv-in-skyL liv-in-sky
    @Homoran bin gespannt :-)
    #111
    @liv-in-sky 😢
    2020-01-11 18:54:40.716 - warn: javascript.0 (4615) Object "Battery percentage.undefined.undefined" does not exist
    2020-01-11 18:54:40.717 - error: javascript.0 (4615) script.js.Batterien: script.js.Batterien:179
    2020-01-11 18:54:40.718 - error: javascript.0 (4615) val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
    2020-01-11 18:54:40.718 - error: javascript.0 (4615) ^
    2020-01-11 18:54:40.719 - error: javascript.0 (4615) TypeError: Cannot read property 'common' of null
    2020-01-11 18:54:40.719 - error: javascript.0 (4615) at script.js.Batterien:179:56
    2020-01-11 18:54:40.719 - error: javascript.0 (4615) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    2020-01-11 18:54:40.719 - error: javascript.0 (4615) at writeHTML (script.js.Batterien:170:36)
    2020-01-11 18:54:40.720 - error: javascript.0 (4615) at script.js.Batterien:365:1
    2020-01-11 18:54:40.720 - error: javascript.0 (4615) at Script.runInContext (vm.js:133:20)
    code:
    $('tradfri.0.*.batteryPercentage').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
            var ida = id.split('.');
              counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
             val0=getObject(id).common.name ; //ida[2]+"."+ida[3];
               var ida = val0.split('.');
               //val0=ida[0];
               log(val0+"   "+id);
              val1help=getState(id).val;
              val1help=parseFloat((getState(id).val));
              if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()} else{val1=(" <font color=\"green\"> ")+val1help.toString()}
              if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()}
              if (getState(id).val==null) {val2="never used"}; //log(id)};
              if (val1help<=battAlarm) {val2="✘"} else{val2="✔"}
              if (val1help>battAlarm && val1help<=battAlarmWarning) val2="⚠️"
      @liv-in-sky 😢
      code:
                 //val0=ida[0];
                 log(val0+"   "+id);
      liv-in-skyL
      liv-in-skyL
      #112
      @Homoran die zeile 7 und 8 gehört weg
        @liv-in-sky 😢
        code:
                   //val0=ida[0];
                   log(val0+"   "+id);
        liv-in-skyL
        liv-in-skyL
        #113
        @Homoran
        der wichtige split ist in zeile 2 - den überschreibst du mit zeile 7 und 8
          #114
          @liv-in-sky
          (4615) script.js.Batterien: TRADFRI remote control 2 tradfri.0.RC-65537.batteryPercentage
          und
          (4615) script.js.Batterien: Stehlampe Arcade tradfri.0.RC-65536.batteryPercentage
            @liv-in-sky
            und
            liv-in-skyL
            liv-in-skyL
            #115
            @Homoran paßt so oder ?
              #116
              @liv-in-sky
              Jepp!!
              DANKE!
              jetzt will ich das noch etwas intensiver ansehen um es zu verstehen, dann kommt es auch in den zweiten tradfri Block
                @liv-in-sky
                Jepp!!
                DANKE!
                liv-in-skyL
                liv-in-skyL
                #117
                @Homoran ich glaube den den zweiten block kannst du streichen, wenn du im ersten block die tradfri.0.*. mit einem * ersetzt
                tradfri.*.*.batteryPercentage **oder** tradfri.*.batteryPercentage
                dann sollten alle tradfri instanzen gefunden werden
                  @Homoran
                  #118
                  @liv-in-sky sagte in Script mit Tabelle der Batterie Zustände:
                  und genau bin ich vorhin hängen geblieben - war so kurz davor 😢
                  Passt - Danke!
                    #119
                    Das hätte ich gleich getestet 😂
                      Passt - Danke!
                      liv-in-skyL
                      liv-in-skyL
                      #120
                      @Homoran poste bitte dein fertiges script nochmal - dann mache ich einen link im ersten post
                      vorallem auch wegen des hm-rpc
                      • D darkiop
                        Interessante Projekt habt ihr da!
                        Kann jemand ne aktuelle Version posten? Dann kann ich ggf. auch durch Tests etwas dazu beitragen.
                        liv-in-skyL
                        liv-in-skyL
                        #121
                        @darkiop hast du auch noch irgendwelche instanzen bzw adapter, die wir noch nicht haben?
                        bis jetzt haben wir
                        • xiaomi
                        • dect thermostate fritzbox
                        • hue
                        • hue-extended
                        • homeatic
                        • ikea tradfri
                          bis jetzt haben wir
                          • xiaomi
                          • hue
                          • hue-extended
                          • homeatic
                          • ikea tradfri
                          #122
                          @liv-in-sky
                          Du hast IKEA Tradfri vergessen
                          hier mit .*.*.batteryPercentage
                          ich räume es noch etwas auf - dann poste ich es
                          feddich!
                          Hier die aktuelle Version
                          //HIER WIRD PFAD UND FILENAME DEFINIERT
                          const path = "/htmlakku.html";                   //FIlenamen definieren
                          const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                          let   braucheEinFile=true;                          // bei true wird ein file geschrieben
                          let   braucheEinVISWidget=false;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                          let dpVIS="vis.0.Batterien"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                          var battAlarm=30;
                          var battAlarmWarning=50;
                          let mySchedule="  0 * * * * ";                       //jede stunde
                          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                          var htmlFeld1='Device';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                          var htmlFeld2='Voltage';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                          var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                          //hier werden die styles für die tabelle definiert
                          //ÜBERSCHRIFT ÜBER TABELLE
                          let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                          let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                          const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                          const htmlFarbUber="white";                         // Farbe der Überschrift
                          const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                          const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                          //MEHRERE TABELLEN NEBENEINANDER
                          let   mehrfachTabelle=4;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                          const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                          const htmlFarbTableColorUber="black";               // Überschrift in der tabelle - der einzelnen Spalten
                          //GANZE TABELLE
                          let abstandZelle="1";
                          let weite="auto";                                     //Weite der Tabelle
                          let zentriert=true;                                   //ganze tabelle zentriert
                          const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                          const htmlSchriftart="Helvetica";
                          const htmlSchriftgroesse="12px";
                          //FELDER UND RAHMEN
                          let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                          const htmlFarbFelderschrift="#000000";                  // SchriftFarbe der Felder
                          const htmlFarbFelderschrift2="#000000";                 // SchriftFarbe der Felder für jede 2te Tabelle
                          const htmlFarbTableColorGradient1="grey";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                          const htmlFarbTableColorGradient2="white";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                          const htmlFarbTableBorderColor="blue";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                          let htmlRahmenLinien="rows";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                          const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                          // HIER NICHTS  ÄNDERN
                          let borderHelpBottum;
                          let borderHelpRight;
                          let htmlcenterHelp;
                          let htmlcenterHelp2;
                          if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                          if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                          if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                          if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                          zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                          zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                          const htmlZentriert='<center>'
                          const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                            "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                            " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                           // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                            " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                            " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                            "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                            " </style></head><body> <div>";
                          //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                               "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                          const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                          const htmlTabUeber3="</tr>";
                          table td:first-child {}  //1
                          table td:nth-child(2) {} //2
                          table td:nth-child(3) {} //3
                          table td:last-child {}   //4
                          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                            	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                          var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                            "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                          var htmlTabUeber="";
                          var htmlOut="";
                          var mix;
                          var counter;
                          //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                          var val1; var val0; var val2;
                          function writeHTML(){
                          htmlOut="";
                          counter=-1;
                          htmlTabUeber="";
                          switch (mehrfachTabelle) {
                            case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                            case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                            case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                            case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                          if (!UeberschriftSpalten) {htmlTabUeber=""}
                          //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                          //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                          var myColl=[];
                          var val1help;
                               // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
                               counter=0;
                               val0="<font color=\"blue\"><b>HUE Devices</b>"; val1=""; val2="";
                               tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                               tabelleAusbessern();
                               counter=-1
                          $('hue-extended.0.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                    val0=ida[0];
                                   //if (val1help) {val1=(" <font color=\"red\"> ")+"bat low"} else{val1=(" <font color=\"green\"> ")+"bat ok"}
                                  // if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()}
                                  // if (getState(id).val==null) {val2="never used"}; //log(id)};
                                 //  if (val1help) {val2="❌"} else{val2="✅"}
                                  // if (val1help>battAlarm && val1help<=battAlarmWarning) val2="⚠️"
                            }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                               counter=0;
                               val0="<font color=\"blue\"><b>IKEA Tradfri</b>"; val1=""; val2="";
                               counter=-1
                          $('tradfri.*.*.batteryPercentage').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                   // log(val0+"   "+id);
                                 //  if (val1help) {val1=(" <font color=\"red\"> ")+"bat low"} else{val1=(" <font color=\"green\"> ")+"bat ok"}
                                     counter=0;
                                     val0="<font color=\"blue\"><b>HOMEMATIC</b>"; val1=""; val2="";
                                     counter=-1
                          $('hm-rpc.0.*.0.LOWBAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                 //var ida = id.split('.');
                                    val0=ida[0].replace(/:.+/g,"");
                                    //log(val0+"   "+id);
                                   if (val1help) {val1=(" <font color=\"red\"> ")+"low bat"} else{val1=(" <font color=\"green\"> ")+"full bat"}
                                   if (val1help) {val2="✘"} else{val2="✔"}
                                     counter=0;
                                     val0="<font color=\"blue\"><b>HOMEMATIC IP</b>"; val1=""; val2="";
                                     counter=-1
                          $('hm-rpc.1.*.0.LOW_BAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                   val1=getState(id.replace("LOW_BAT","OPERATING_VOLTAGE")).val;
                                   if (val1!="NORMAL") {val1=(" <font color=\"red\"> ")+val1} else{val1=(" <font color=\"green\"> ")+val1}
                                     counter=0;
                                     val0="<font color=\"blue\"><b>HANDYs</b>"; val1=""; val2="";
                                     counter=-1
                                  $('controll-own.0.HANDY.*batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                   val0=ida[3];
                                   log(val0+"   "+id);
                                   if (val1help<=battAlarm) {val2="❌"} else{val2="✅"}
                                      $('controll-own.0.HANDY.*Batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                   val0=ida[3];
                                   log(val0+"   "+id);
                          //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                               tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                          } // function ende
                          //MAIN:
                          schedule(mySchedule,  function () {
                          writeHTML();
                          if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                          writeHTML();
                          if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}                                 //     <tdalign
                          function tabelleBind(){
                                  case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;
                                  case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                  case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;
                                  case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                            else {if(counter%2==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}}
        } break; } //switch ende
                          function tabelleAusbessern() {
                                  case 1:    break;
                                  case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                             if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                             break;
                                  case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                             if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                             break;
                                  case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                             if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                             break; }
                          function tabelleFinish() {
                                  case 1:    break;
                                             break;
                                             break;
                                             break; }
                                  var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                 if (!htmlSignature) htmlUnter="";
                                   //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                    var htmlOutVIS="";
                                  //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                     if (htmlUberschrift)
                                         { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                       } else {
                                        zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                           // log("bin raus aus tabelleBind");
                                    if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                    //console.log dpVIS;
                          var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                          var htmlEnd="</table>"+htmlUnter+"</div></body>";
                          //mit oder ohne überschrift - zentriert oder links
                          htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                          //log(htmlOut);
                            @liv-in-sky
                            feddich!
                            var battAlarm=30;
                            //GANZE TABELLE
                            //FELDER UND RAHMEN
                            let htmlcenterHelp;
                            var htmlOut="";
                            var mix;
                            var counter;
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                            var myColl=[];
                            var val1help;
                                 counter=0;
                                 counter=-1
                                      val0=ida[0];
                                 counter=0;
                                 counter=-1
                                       counter=0;
                                       counter=-1
                                      //log(val0+"   "+id);
                                       counter=0;
                                       counter=-1
                                       counter=0;
                                       counter=-1
                                     val0=ida[3];
                                     log(val0+"   "+id);
                                     val0=ida[3];
                                     log(val0+"   "+id);
                            } // function ende
                            //MAIN:
                            writeHTML();
                            writeHTML();
        } break;
                                    case 1:    break;
                                               break;
                                               break;
                                               break; }
                                    case 1:    break;
                                               break;
                                               break;
                                               break; }
                                      var htmlOutVIS="";
                                         } else {
                            //log(htmlOut);
                            liv-in-skyL
                            liv-in-skyL
                            #123
                            @Homoran die homematic ip sache ist aber noch nicht fertig
                            da müssen noch farben rein und werte, die man definieren kann
                              @liv-in-sky
                              feddich!
                              var battAlarm=30;
                              //GANZE TABELLE
                              //FELDER UND RAHMEN
                              let htmlcenterHelp;
                              var htmlOut="";
                              var mix;
                              var counter;
                              htmlOut="";
                              counter=-1;
                              htmlTabUeber="";
                              var myColl=[];
                              var val1help;
                                   counter=0;
                                   counter=-1
                                        val0=ida[0];
                                   counter=0;
                                   counter=-1
                                         counter=0;
                                         counter=-1
                                        //log(val0+"   "+id);
                                         counter=0;
                                         counter=-1
                                         counter=0;
                                         counter=-1
                                       val0=ida[3];
                                       log(val0+"   "+id);
                                       val0=ida[3];
                                       log(val0+"   "+id);
                              } // function ende
                              //MAIN:
                              writeHTML();
                              writeHTML();
        } break;
                                      case 1:    break;
                                                 break;
                                                 break;
                                                 break; }
                                      case 1:    break;
                                                 break;
                                                 break;
                                                 break; }
                                        var htmlOutVIS="";
                                           } else {
                              //log(htmlOut);
                              liv-in-skyL
                              liv-in-skyL
                              #124
                              @Homoran ich würde dann gerne das script von dir nehmen und ein allgemeines daraus machen - wobei man dann oben im setting die adapter auswählen kann, die man hat
                                #125
                                dan müssen noch farben rein und werte, die man definieren kann
                                Ich müsste jetzt mal Akkus (wegen der Niedrigeren Spannung) reintun und sehen wann die Geräte nicht mehr erreichbar sind.
                                Leider ist das mit den Geräten an die ich schnell rankomme nicht WAF-freundlich ;-)
                                Muss dann mal morgen draußen einen Sensor abbauen.
                                  #126
                                  Danke!
                                  und einen all-in-one Datenpunkt der auf true geht wenn EIN Gerät eine leere Batterie hat?
                                    liv-in-skyL
                                    liv-in-skyL
                                    #127
                                    @Homoran - aber das script kann ich trotzdem vorbereiten - ich nehme dazu dein script - wenn du also etwas ändern willst bei dir, dann sage mir bescheid - damit die versionen nicht durcheinander kommen
                                    der all-in-one datenpunkt kommt dann auf die todo list
                                      #128
                                      @liv-in-sky
                                      Super!
                                      Meine Idee war, ähnlich wie bei dem Lüftungsscript, dass man ganz oben die verschiedenen Eingaben macht.
                                      Dazu einen Block, den man kopieren kann/muss , je nachdem wieviele Instanzen man nutzt mit den Variablen für:
                                      • Instanz
                                      • Bezeichnung (Teil-ID) des Datenpunktes mit dem Batteriewert
                                      • ggf. die Schaltschwellen für die Farben
                                      Ich habe keine Ahnung ob das umsetzbar ist
                                        Danke!
                                        liv-in-skyL
                                        liv-in-skyL
                                        #129
                                        @Homoran wenn du lust hast, probiere das mit der 2ten rpc instanz (zusammenfassen) aus - tradfri.*.batteriePercentage und wenn es funktioniert, poste das script nochmal
                                          #130
                                          @liv-in-sky
                                          @Homoran sagte in Script mit Tabelle der Batterie Zustände:
                                          already done ;-)
                                          33.2k
                                          84.3k
