  4. Test Adapter MercedesMe v0.0.x
mercedes
1.0k Beiträge 122 Kommentatoren 363.0k Aufrufe 107 Beobachtet
  • lighu36L Offline
    lighu36L Offline
    lighu36
    #223
    mercedesme.1	2019-12-16 16:10:14.788	warn	(17172) No vehicles found
    mercedesme.1	2019-12-16 16:09:57.309	info	(17172) starting. Version 0.0.18 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.mercedesme, node: v10.16.3
    mercedesme.1	2019-12-16 16:09:57.234	info	(17172) States connected to socket.io: 127.0.0.1
    mercedesme.1	2019-12-16 16:02:08.732	warn	(10908) No vehicles found
    mercedesme.1	2019-12-16 16:01:51.886	info	(10908) starting. Version 0.0.18 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.mercedesme, node: v10.16.3
    mercedesme.1	2019-12-16 16:01:51.746	info	(10908) States connected to socket.io: 127.0.0.1
    mercedesme.1	2019-12-16 16:01:23.864	error	(17748) Login Failed. Please try to login manually.
    • lighu36L lighu36
      tombox
      #224
      @lighu36 Can you put the instance in debug and send me the log file after restart instance
      lighu36L 1 Antwort Letzte Antwort
      • T tombox
        lighu36L Offline
        lighu36L Offline
        lighu36
        schrieb am zuletzt editiert von lighu36
        #225
        是我的车有问题吗? 我的汽车购买已经超过3年了,
        您是要这个日志吗
        • lighu36L lighu36
          您是要这个日志吗
          tombox
          #226
          @lighu36
          Which smartphone app your are using for your car?
          I added in the current github version options to change the country code or accept-language.
          In which country the car is registered?
          • T tombox
            @lighu36
            lighu36L Offline
            lighu36L Offline
            lighu36
            #227
            中国
            • lighu36L lighu36
              中国
              tombox
              #228
              @lighu36 sagte in Test Adapter MercedesMe v0.0.x:
              中国
              You can try to use in the mercedesme instance options in the bottom after reinstalling via github link (first post in this thread):
              accept language zh_CN
              and
              country code CN
              • T tombox
                中国
                and
                country code CN
                lighu36L Offline
                lighu36L Offline
                lighu36
                #229
                @tombox 好的
                • H Offline
                  hajuerue
                  #230
                  auf wieviel habt ihr die Aktualisierung stehen in Sekunden?
                  Hatte es auf 300, dann kommen aber die Meldungen wenn man Pech hat erst nach 5 Minuten ;-)
                  Was ist das zu empfehlende kleinste, so das man nicht vom Server gesperrt wird? (habs mal auf 30 gestellt)
                  Gibt es schon Neuigkeiten ob das mit der Vorklimatisierung nun auch gehen sollte.
                  Wie am 3ten geschrieben, stellt er bei mir die Zeit nun zwar nichtmehr auf 23:59, dafür aber auf die Zeit in der Vergangenheit, und somit denkt dass System dass man erst am nächsten Tag die Klima braucht ;-)
                  Gruss
                  HaJueRue
                  • H hajuerue
                    Gruss
                    HaJueRue
                    tombox
                    #231
                    @hajuerue ich habemal ein delay in die github version gebaut. Installiern via github. Instanz neustarten und remote option VorklimaDelay setzen.
                    30sek sollte kein Problem sein, da der Adapter nur Änderungen bekommt wenn wirklich welche bei mercedes vorliegen. Die app verhält sich ähnlich
                      mouk
                      #232
                      Hallo.
                      Ich habe das Modul eben das erste Mal versucht zu installieren. Bekomme aber folgende Fehler.
                      Kann mir jemand weiterhelfen?
                      JS-Controller ist 2.2.7
                      MercedesME Module aus dem Github is 0.0.19
                      Vielen Dank
                      Mouk
                      • M mouk
                        Hallo.
                        Vielen Dank
                        Mouk
                        tombox
                        #233
                        @mouk scheint so als hättest du eine alte node Version
                        Update mal auf 10
                        https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                        Bzw npm rebuild ausführen wie in der Anleitung
                          mouk
                          #234
                          Danke für den Hinweis.
                          Hatte zwar schon 10 drauf, habe aber eben die Installation nochmal durchgeführt.
                          Leider immer noch der gleiche Fehler.
                          Node.js v10.18.0
                          NPM 6.13.4
                          JS 2.2.7
                          Noch eine Idee vielleicht?
                          Mouk
                          • M mouk
                            Node.js v10.18.0
                            NPM 6.13.4
                            JS 2.2.7
                            Mouk
                            tombox
                            #235
                            @mouk npm rebuild im opt/IoBroker Ordner ausgeführt? Bzw Mercedes Adapter nochmal neuinstallieren
                              mouk
                              #236
                              Ich habe es gelöst.
                              Musste Canvas 2.6.0 im Mercedes me Ordner installieren.
                              Keine Ahnung warum.
                              d.h.
                              den Befehl:
                              sudo npm install canvas@2.6.0 --unsafe-perm=true
                              im Ordner /opt/iobroker/node_modules/iobroker.mercedesme
                              ausführen.
                              Jetzt teste ich erstmal etwas herum.
                              Danke trotzdem
                              • J Offline
                                JürgenB
                                #237
                                hatte bisher die Version 0.0.16 installiert gehabt und dort war das Model im Bereich Details richtig vorhanden.
                                Nach dem Update auf Version 0.0.20 wird hier zwar der vordere Teil richtig dargestellt aber der hintere Teil fehlt bzw. wird mit Estate angezeigt.
                                Woran könnte das liegen?
                                Jürgen
                                • J JürgenB
                                  Jürgen
                                  tombox
                                  #238
                                  @JürgenB Es kann sein das Mercedes jetzt die veränderten Informationen liefert wenn du zurück auf die 16 gehst und da die anderen information angezeigt werden War vielleicht durch die Umstellung von Webseiten daten auf daten aus der Mercedes Me App das da unterschiedliche informationen. zurückgegeben werden
                                  • T tombox
                                    JürgenB
                                    #239
                                    @tombox
                                    Danke für die Antwort.
                                    Dann werd ich wohl vorerst bei der Version 16 bleiben.
                                    • H Offline
                                      hajuerue
                                      #240
                                      hab gestern auch die 0.0.20 installiert.
                                      Hatte gehofft das ich damit dann die Vorklimatisierung nutzen kann.
                                      Leider ist das aber noch genauso wie bei den vorhergehenden Versionen.
                                      Die Zeit wird auf die aktuelle gesetzt, und somit geht Mercedes davon aus, dass man den nächsten Tag meint.
                                      Gibts da evtl ne Einstellung die ich irgendwo übersehen habe.
                                      Bei meinem BED, muss die Zeit >15 Minuten in der Zukunft liegen, sonst geht er vom nächsten Tag aus.
                                      Gruss
                                      HaJueRueiobroker_mercedesme_remote_080120.png MercedesMe_Zeit-zu-knapp_080120.png
                                      • H hajuerue
                                        Gruss
                                        tombox
                                        #241
                                        @hajuerue dann bei vorklima delay auf 15 setzten
                                        H 1 Antwort Letzte Antwort
                                        • T tombox
                                          hajuerue
                                          #242
                                          @tombox
                                          und wo? in der Instance find ich das irgendwie nicht.
