  4. Fire TV Adapter
Fire TV Adapter
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
181 Beiträge 41 Kommentatoren 68.6k Aufrufe 29 Beobachtet
  • L Lordcyber
    Hallo, an dem Adapter bin ich jetzt auch dran.
    Habe es nach den anleitungen heir installiert.
    es kommt allerdings:
    host.IoBroker	2019-09-09 22:54:17.799	info	Restart adapter system.adapter.firetv.0 because enabled
    host.IoBroker	2019-09-09 22:54:17.799	error	instance system.adapter.firetv.0 terminated with code 1 ()
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:79:20)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23)
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: TypeError: fns.adapter is not a function
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: ^
    Caught	2019-09-09 22:54:17.799	error	by controller[0]: fns.adapter = fns.adapter(options);
    Caught	2019-09-09 22:54:17.798	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148
    host.IoBroker	2019-09-09 22:54:17.500	info	instance system.adapter.firetv.0 started with pid 25136
    Was stimmt da nicht?
    sigi234S Online
    sigi234S Online
    @Lordcyber
    Suche mal nach soef
    • L Offline
      Lordcyber
      @sigi234 said in Fire TV Adapter:
      @Lordcyber
      Suche mal nach soef
      Habe jetzt das soef installiert. der Fehler ist aber immer noch da.
      Mike
      Thinkcentre M92 mit Proxmox / Iobroker als VM unter Debian
      • L Lordcyber
        @Lordcyber
        Suche mal nach soef
        sigi234S Online
        sigi234S Online
        @Lordcyber sagte in Fire TV Adapter:
        @Lordcyber
        Suche mal nach soef
        hast du an deinem stick die Meldung .. adb erhalten und freigeschaltet ?
        L 1 Antwort Letzte Antwort
        • sigi234S sigi234
          @Lordcyber
          Suche mal nach soef
          Lordcyber
          schrieb am zuletzt editiert von Lordcyber
          @Lordcyber
          Suche mal nach soef
          Nein, es kam auch keine Meldung. Im Menü hab ich debugging auf an gestellt.
          Neugestartet wurde der Stick auch.
          Node.js
          v10.16.3
          NPM
          6.11.3
          kann da was falsch sein?
          Mike
          • P Offline
            Pascal51882
            habe nach den Anleitungen hier auf dieser Seite den Adapter, ADB und Fastboot installiert.
            ADB liegt bei mir unter: /usr/lib/android-sdk/platform-tools/adb
            So habe ich ihn auch im Adapter eingegeben.
            ADB ist auf meinem Fire TV aktiv. Habe bereits Apps darüber installiert.
            Der Adapter bleibt rot. Habe ich etwas übersehen?
            Laut Log wird ein Modul nicht gefunden. Was muss ich noch machen bzw. mache ich falsch?
            host.DebianVM	2019-11-10 17:07:51.368	info	Restart adapter system.adapter.firetv.0 because enabled
            host.DebianVM	2019-11-10 17:07:51.368	error	instance system.adapter.firetv.0 terminated with code 1 ()
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at bootstrap_node.js:625:3
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at startup (bootstrap_node.js:204:16)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module.runMain (module.js:694:10)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._load (module.js:498:3)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at tryModuleLoad (module.js:506:12)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module.load (module.js:566:32)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module._compile (module.js:653:30)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.firetv/firetv.js:6:14)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at require (internal/module.js:11:18)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Module.require (module.js:597:17)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._load (module.js:475:25)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
            Caught	2019-11-10 17:07:51.368	error	by controller[0]: Error: Cannot find module './node_modules/adbkit/lib/adb/client'
            Caught	2019-11-10 17:07:51.367	error	by controller[0]: ^
            Caught	2019-11-10 17:07:51.367	error	by controller[0]: throw err;
            Caught	2019-11-10 17:07:51.367	error	by controller[0]: module.js:550
            host.DebianVM	2019-11-10 17:07:51.203	info	instance system.adapter.firetv.0 started with pid 11631
            host.DebianVM	2019-11-10 17:07:51.199	info	object change system.adapter.firetv.0
            host.DebianVM	2019-11-10 17:07:50.305	info	Restart adapter system.adapter.firetv.0 because enabled
            I 1 Antwort Letzte Antwort
            • P Pascal51882
              I Offline
              I Offline
              ichwersonst
              Hallo Leute,
              ich bin neu hier und ich hab genau das gleiche Problem und Meldungen wie Pascal51882 vor mir geschrieben hat.
              Ich habe schon den Thread komplett gelesen und auch in anderen Foren nach Hinweisen gesucht. Leider komme ich nicht weiter.
              Ich würde mich freuen, wenn da jemand der mehr mit den Meldungen anfangen kann, ein paar Tipps geben könnte was da falsch läuft.
              Grüße :-)
              • C Offline
                ChrisXY
                Ich auch .. scheint wohl an JS 2.0 zu liegen :(
                  michi150870
                  Hallo, ich habe nach dieser Anleitung gemacht und geht schon seit Monaten. Auch mit JS 2.0 .
                  https://www.schimmer-media.de/forum/index.php?thread/513-firetv-adaptor/&postID=30719&highlight=Firetv#post30719
                  • C Offline
                    ChrisXY
                    Ja die lösung ist "npm install soef" danach lief es dann auch.
                    • X xbow42
                      Umzug auf einen äteren Intel-Nuc hab ich den fire.tv-Adaper jetzt auch am laufen.
                      Vorher am BananaPi hab ich ihn garnicht zum laufen gebracht weil ich ADB-Debugging am Gerät garnicht aktiviert habe. :?
                      Nach einigem probieren und hier im Forum lesen hat es mit dieser Vorgehensweise geklappt.
                      an der ssh-root-console
                      apt-get install adb
                      nano /opt/iobroker/node_modules/iobroker.firetv/firetv.js
                      Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client.js'),
                      Strg+O; Strg+X
                      dann im iobroker die firetv.0-instanz (ggf. löschen) und installieren.
                      Pfard zu ADB.exe "/usr/lib/android-sdk/platform-tools/adb"
                      bei Devices meine beiden Geräte neu eingerichtet
                      Bsp: true FireTV-WZ 10.0.1.20
                      Am FireTV-gerät
                      unter: Einstellungen->Mein Fire TV->Entwickleroptionen->ADB-Debugging [An]
                      im iobroker
                      • Instanz firetv.0 stoppen
                      • Log löschen
                      • Instanz firetv.0 starten
                      • Log sollte dann in etwa so aussehen.
                      firetv.0 2018-11-11 12:52:29.532 info 10.0.1.20: ADB version: 36, Android Version: , API Level:
                      firetv.0 2018-11-11 12:52:29.531 error ID: 10.0.1.20 Error=Failure: 'device unauthorized. This adb server's $ADB_VENDOR_KEYS is not set Try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device.'
                      firetv.0 2018-11-11 12:52:29.510 error ID: 10.0.1.20 Error=Failure: 'device unauthorized. This adb server's $ADB_VENDOR_KEYS is not set Try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device.'
                      firetv.0 2018-11-11 12:52:29.493 error ID: 10.0.1.20 Error=Failure: 'device unauthorized. This adb server's $ADB_VENDOR_KEYS is not set Try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device.'
                      firetv.0 2018-11-11 12:52:29.491 error ID: 10.0.1.20 Error=Failure: 'device unauthorized. This adb server's $ADB_VENDOR_KEYS is not set Try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device.'
                      firetv.0 2018-11-11 12:52:29.168 info starting. Version 0.0.33 in /opt/iobroker/node_modules/iobroker.firetv, node: v8.12.0
                      Am Fire-TV-Gerät "USB-Debugging" zu lassen/bestätigen.
                      Ich habe das Fire-TV-Gerät gleich noch mal neu gestartet, vielleicht nicht nötig schadet aber auch nicht.
                      Wenn man jetzt die firetv.0-Instanz stopt/startet sollten keine Fehlermeldungen im Log auftauchen.
                      Jetzt werde ich erst mal sehen was man mit dem Adapter überhaupt anfangen kann.
                      cu xbow
                      metaxaM Offline
                      metaxaM Offline
                      metaxa
                      schrieb am zuletzt editiert von metaxa
                      @xbow42 sagte in Fire TV Adapter:
                      cu xbow
                      Hi, ich habe den Adapter nun endlich auf grün :-)
                      Hast du oder irgendwer Steuer- oder mehr Infomöglichkeiten entdeckt?
                      Mehr gibts bei mir nicht:
                      Andersrum gefragt: Läuft! freu und nun?
                      LG, mxa
                      • kmxakK kmxak
                        Moin,
                        hat jemand von euch den Fire TV Adapter erfolgreich am laufen?
                        ADB geht auf meinem Server aber der Adapter bekommt absolut keine Verbindung
                        firetv.0	2017-07-11 19:42:43.431	error	can not connect to 192.168.2.51 Error=connect ECONNREFUSED 127.0.0.1:5037
                        firetv.0	2017-07-11 19:42:43.429	error	can not connect to 192.168.2.54 Error=connect ECONNREFUSED 127.0.0.1:5037
                        firetv.0	2017-07-11 19:42:42.503	info	starting. Version 0.0.28 in /opt/iobroker/node_modules/iobroker.firetv, node: v4.8.2
                        firetv.0	2017-07-11 19:42:39.104	info	terminating
                        root@FHEM:/home/alex# adb kill-server
                        root@FHEM:/home/alex# adb start-server
                        * daemon not running. starting it now on port 5037 *
                        * daemon started successfully *
                        root@FHEM:/home/alex# adb connect 192.168.2.51:5555
                        connected to 192.168.2.51:5555
                        root@FHEM:/home/alex# adb devices
                        List of devices attached
                        192.168.2.51:5555       device
                        root@FHEM:/home/alex# adb disconnect 192.168.2.51:5555
                        Einer eine Idee?
                        Stephan SchleichS Offline
                        Stephan Schleich
                        schrieb am zuletzt editiert von Stephan Schleich
                        Gibt's mittlerweile eine Lösung?
                        Hab n aktuelles System bekomm aber folgende Fehlermeldung.
                        ADB etc geht bereits, nur der Adapter meckert.
                        • Stephan SchleichS Stephan Schleich
                          crunchipC Offline
                          crunchipC Offline
                          @Stephan-Schleich sagte in Fire TV Adapter:
                          scheinbar gehts noch nicht, auch am Stick aktiviert?
                          Stephan SchleichS 1 Antwort Letzte Antwort
                            Stephan Schleich
                            Die Anleitungen hier stimmen schon, ihr müsste nur am Schluss noch unter "/opt/iobroker/node_modules/iobroker.firetv" "npm install soef" ausführen und schon läufts
                            • F Offline
                              Flopsi
                              Bei mir hat es so geklappt nach dieser Anleitung:
                              am Ende muss ich aber noch den Tip von befolgen danach wurde es grün :)
                              @Stephan Schleich
                              Stephan Schleich Starter 14. Feb. 2020, 07:35
                              Die Anleitungen hier stimmen schon, ihr müsste nur am Schluss noch unter >"/opt/iobroker/node_modules/iobroker.firetv" "npm install soef" ausführen und schon läufts
                              cd /opt/iobroker/node_modules/iobroker.firetv
                              dann
                              npm install soef
                              das war es bei mir.
                              Es wurde GRÜN.
                              • M manne_r
                                wer auch daran verzweifelt eine App zu starten - ich habs gerade hinbekommen (zumindest die Tagesschau)
                                it seems that you need to know the exact name off the class to start.. i just got the tagesschau to work with that entry in the StartApp
                                de.cellular.tagesschau/de.ndr.tagesschau.firetv.activities.HomeActivity
                                i got that from connecting via adb to the stick
                                adb connect xx.xx.xx.xx:5555
                                to get the package name:
                                adb shell pm list packages -f tages
                                to get some idea about what the class may be named:
                                adb shell pm dump /data/app/de.cellular.tagesschau-1/base.apk | grep tages
                                if you just enter de.cellular.tagesschau
                                the adapter tries to open "MainActivity" which doesn't seem to exist…
                                I Offline
                                I Offline
                                ichwersonst
                                @manne_r ich bin gerade am verzweifeln beim starten einer app über den firetv adapter.
                                ich finde einfach nicht heraus, welcher befehl in welchem syntax in die start app zeile im objekte verzeichnis muss.
                                Ich hab die package names herausgefunden und ich vermute das ich die class duch ein "/" getrennt angeben muss. leider funktioniert es nicht.
                                als result bekomme ich das hier wieder : Error: Activity class {com.spotify.tv.android/MainActicity} does not exist.
                                Vielleicht kannst du mir ja helfen ... würde mich freuen :-)
                                harrymH 1 Antwort Letzte Antwort
                                • I ichwersonst
                                  harrymH Offline
                                  harrymH Offline
                                  harrym
                                  @ichwersonst einfach den Namen verwenden? Starten kannst du mMn eh nur eine App nach der anderen.
                                  ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
                                  • harrymH harrym
                                    I Offline
                                    I Offline
                                    ichwersonst
                                    @harrym das funktioniert leider nur mit netflix.
                                    Alle anderen Apps bringen dieses Result wenn ich nur den Namen (z.B. YoutTube) verwende: Error: Activity class {YouTube/MainActicity} does not exist.
                                      Sali84
                                      Weiss einer wie ich die ADB.exe bei einer Docker installation, "installiert" bekomme? oder muss ich einfach die Exe Datei im Pfad im Container angeben?
                                      Kann man nur die einzelne Exe irgendwo downloaden?
                                      Grüsse
                                      • S Sali84
                                        Grüsse
                                        @Sali84
                                        Debian?
                                        Dann
                                        apt install adb
                                        Im Adapter muss ich dann immer noch den kompletten Pfad angeben, im $PATH wird adb warum auch immer nicht gefunden:
                                        ls -la /usr/bin/adb
                                        lrwxrwxrwx 1 root root 37 Mär 18  2019 /usr/bin/adb -> ../lib/android-sdk/platform-tools/adb
                                          Sali84
                                          Ja, einfach eine iobroker Installation im Docker auf einem Synology NAS. Also meinst Du so einfach geht das dann? :)
