  3. Entwicklung
  4. Zigbee Adapter mit neuem Converter
zigbee adaptershpeherdherdsman
498 Beiträge 58 Kommentatoren 172.3k Aufrufe 78 Beobachtet
  • C Offline
    ChrisXY
    schrieb am zuletzt editiert von ChrisXY
    #311
    Also ich würd gern nun gerne dne 3. IKEA USB Verstärker anlernen nicht möglich .. es ist dauerhaft ein Fragezeichen Gerät... im Log steht aber es wurde Erkannt ..
    Pairing time left: 42
    Pairing time left: 43
    Pairing time left: 44
    Pairing time left: 45
    Error: Failed to execute LQI for '0x7cb03eaa0a059dbc'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Pairing time left: 46
    Pairing time left: 47
    Pairing time left: 48
    Pairing time left: 49
    New device joined '0x14b457fffef8c765' model TRADFRI Signal Repeater
    Interview successful: {"friendly_name":"0x14b457fffef8c765","model":"E1746","vendor":"IKEA","description":"TRADFRI signal repeater","supported":true}
    Error: Device 14b457fffef8c765 "TRADFRI Signal Repeater" not described in statesMapping.. undefined
    Pairing time left: 50
    Pairing time left: 51
    Pairing time left: 52
    Pairing time left: 53
    Pairing time left: 54
    Pairing time left: 55
    Pairing time left: 56
    Pairing time left: 57
    Pairing time left: 58
    Pairing time left: 59
    Pairing time left: 60
    Pairing time left: 61
    Pairing time left: 62
    Pairing time left: 63
    Pairing time left: 64
    Pairing time left: 65
    Error: Failed to execute LQI for '0x00158d0000f870bf'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Pairing time left: 66
    Pairing time left: 67
    Pairing time left: 68
    Pairing time left: 69
    Error: Failed to execute LQI for '0x14b457fffef8c765'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Pairing time left: 70
    Pairing time left: 71
    Pairing time left: 72
    Pairing time left: 73
    Pairing time left: 74
    Pairing time left: 75
    Pairing time left: 76
    Error: Failed to execute LQI for '0x7cb03eaa0a05a80f'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Pairing time left: 77
    Pairing time left: 78
    Pairing time left: 79
    Pairing time left: 80
    Pairing time left: 81
    Pairing time left: 82
    Pairing time left: 83
    Pairing time left: 84
    Pairing time left: 85
    Pairing time left: 86
    Pairing time left: 87
    Error: Failed to execute LQI for '0x00158d0002539b10'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Pairing time left: 88
    Pairing time left: 89
    Pairing time left: 90
    Error: Failed to execute LQI for '0x7cb03eaa0a01c6c5'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)". undefined
    Device '0x14b457fffef8c765' announced itself
    Pairing time left: 91
    Pairing time left: 92
    Pairing time left: 93
    Pairing time left: 94
    Interview started: 0x14b457fffef8c765
    P
    Was mit auffällt der neu gekaufte heute hat : Firmware Version: 2.2.005
    Die alten bei mir die wunderbar erkannt wurden haben: Firmware Version: 2.0.019
    EDIT: Laut der Map scheint er aber als repeate rzu arbeiten .. Hab aber auch noch das ? da stehen und disen Pinken Active Kreis
    • J Jan1
      Ich kann Geräte nicht mehr löschen. Wenn ich auf den Abfalleimer klicke, dann wird es nur unbekannt und aus dem Netz entfernt, aber bleibt in der Liste enthalten:
      Adapter Neustart und Stick neu stecken hat auch kein Erfolg gebracht.
      XsevX Offline
      XsevX Offline
      Xsev
      #312
      @Jan1 sagte in Zigbee Adapter mit neuem Converter:
      Das Problem hab ich leider auch immer wieder, bislang half Adapter neu drüber installieren aber aktuell hab ich auch einen Osram Plug den ich nicht mehr raus bekomme.
      • AsgothianA Asgothian
        @matdos1gmx-de sagte in Zigbee Adapter mit neuem Converter:
        @Asgothian
        Ok ja wie gesagt Hauptsache es funktioniert.
        Bekomme aber immer noch im EG das Schloss nicht so weit das es funktioniert im OG Stick und auf dem Test Pi geht es ohne Probleme woran liegt das?
        Gibt es evtl ein Problem mit dem USB 3.0 am PI4?
        Ich habe mir jetzt durch das viele Rumprobieren mit Adapter Zigbee 1 EG alles komlett zerschossen incl. OG (nicht mal Backup geht mehr immer nur ? in beiden Adaptern), da ich die Sticks unter den USB Ports getauscht habe ect. habe jetzt alle erdenkliche Probiert keine Chance das Ding ins EG zu bekommen .
        Wenn ich jetzt eh schon alles Platt habe gibt es irgendeine Möglichkeit die Zigbee Adapter komlpett zu entfernen das ich die komplett neu ohne irgendwelche Fehler neu installieren kann?
        Zigbee Adapter und alle Dateien und Ordner habe ich bereits unter Objekte und Adpter gelöscht hat aber auch nichts gebracht.
        • USB3 ist ein Problem beim Pi4. Besser den Stick mit USB Verlängerung an einen der beiden usb2 Ports anschliessen
        • Um komplett alles los zu werden musst du noch unter /opt/iobroker/data das Verzeichnis zigbee_x löschen, wobei das x die ID der Instanz ist (zigbee_0 für den Adapter dessen Objekte bei zigbee.0 stehen
        A.
        Matdos
        #313
        @Asgothian @arteck
        Da ich von SD boote und dann nach dem Boot vom Pi auf die angeschlossene Festplatte zugegriffen wird die auch an USB 2.0 hängt (auf den linken USB Ports) habe ich hier nur noch einen Port frei. (wenn ich die Platte auf die USB 3.0 Ports anschliesse fährt der Pi nicht mehr hoch).
        Habe jetzt denn zweiten Zibee Stick bzw. das zweite Netzwerk gelöscht und jetzt laufen alle 31 Geräte auf dem Zigbee 0 Adapter der links oben im USB Port steckt. (konnte alle Geräte sauber drauf anlernen und das läuft auch bis jetzt mal soweit)
        Ich möchte hier noch einmal ein Dank aussprechen, für eure Arbeit die Ihr hier alle Investiert und das Ihr so gut es geht alle Unterstützt, und versucht die Probleme zu lösen die aufkommen!!!
        Vielen Dank!!
        • J Jan1
          Matdos
          schrieb am zuletzt editiert von Matdos
          #314
          @Jan1 @Xsev @Asgothian @arteck
          Bei mir hat es sehr oft (nicht immer) geholfen das Gerät noch einmal anzulernen das das Gerät in der Kachel wieder angezeigt wird.
          Dann erst das Gerät zurücksetzen und dann die Kachel löschen, oder erst nochmal die Kachel löschen dann den Adapter stoppen und dann das Gerät reseten, danach den Adapter wieder starten dann sollte die undefined Kachel weg sein.
          Die Xiaomi Tür Fensterkontake musste ich heute auch wieder anlernen und hier war es genau so als ich sie löschen wollte weil in den Objekten nur der Ordner und keine Datenpunkte angezeigt bekommen habe, war es unmöglich das Gerät bzw nach dem löschen die Undefined Kachel zu löschen, ich habe dann den Adapter gestoppt das Gerät zurückgesetzt, den Adpter gesartet und das Gerät neu angelernt danach hat sich der Sensor sauber verbunden.
          Ich konnte die Kacheln erst sauber löschen nachdem die Geräte wieder sauber angelernt waren (bzw wenn ich auf das i geklickt habe und da die FW vom Gerät angezeigt wurde).
          Würd mich Interessieren ob das bei euch auch so ist bzw. funktioniert.
          • M Matdos
            Jan1
            #315
            @matdos1gmx-de
            Seit wann funktioniert das "i" wieder in der Version des Adapters?
            Welche Version läuft bei Dir?
            • J Jan1
              @matdos1gmx-de
              Matdos
              #316
              @Jan1
              Habe die Version 1.0.0-b
              Wenn ich da drauf klicke wird unter Objekte der Datenpunkt link quality erneuert und das ist teilweise nötig, so zumindest mein Empfinden damit das Gerät einmal angesprochen wird.
              Jedes Gerät das ich angelernt habe habe ich erst durch den Klick auf das i Überprüft ob die FW angezeigt wird und erst dann habe ich die anderen Datenpunkte erzeugt also sprich beim Tür Fensterkontakt true und False wenn man den Magnet drüber zieht und das hat gut funktioniert.
              Wichtig ist nur das man sich Zeit lässt und ein Gerät nach und nach anlernt. Ich habe den Fehler gemacht in der MInute wo man zeit hat 2 Fensterkontakte anzulernen ohne den ersten richtig zu Konfigurieren, dann wurden bei beiden zwar die Ordner erstellt aber die Datenpunkte wurden in den Ordnern nicht erstellt und es war auch nicht möglich die nachträglich rein zu bekommen.
              also: anlernen-Name ändern-Speichern-danch auf das i klicken und FW kontrollieren-dann den Magnet drüber ziehen (oder was auch immer) damit die restlichen Datenpunkte gefüllt werden.
              • M Matdos
                @Jan1
                Jan1
                #317
                @matdos1gmx-de
                was sagt den @arteck dazu, Info geht doch noch nicht oder habe ich schon wieder was verpasst? bei mir gehts mit der b Version nicht.
                v522533V M AsgothianA 3 Antworten Letzte Antwort
                • J Jan1
                  @matdos1gmx-de
                  v522533V Offline
                  v522533V Offline
                  v522533
                  #318
                  @Jan1
                  bei mir geht info auch nicht
                  Gruß Chris
                  • J Jan1
                    @matdos1gmx-de
                    Matdos
                    #319
                    @Jan1
                    Keine Ahnung das i funktioniert beim mir am Danalock Schloss - Ikea Signal Repeater - Osram Steckdosen - Eurotronic Thermostate
                    Bei den Xiaomi Geräten aktuell wird mir nichts angezeigt (beim Bewegungsmelder und einem Fensterkontakt kommt ein error aber das liegt da dran das die schlechten Pegel haben) aber der Datenpunkt mit link quality wird erneuert.
                    Ich bin mir aber ziemlich sicher das frisch nach dem anlernen der Xiaomi Geräte mir eine FW angezeigt wurde aber da waren die auch noch direkt mit dem Coordinator verbunden jetzt sind die Tür Fenster Kontakte alle mit den Routern verbunden vieleicht liegt es da dran?
                    • J Jan1
                      @matdos1gmx-de
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #320
                      @matdos1gmx-de
                      Was genau kommt als Meldung ?
                      Bei mir ging es bis zum Update auf die 1.0.0-b auch nicht.
                      A.
                        @matdos1gmx-de
                        A.
                        Jan1
                        #321
                        @Asgothian
                        In der Kachel:
                        und das Log dazu:
                        zigbee.0	2020-01-04 11:59:36.492	error	(29819) Failed to publish: "Error: Data request failed with error: 'MAC transaction expired' (240)\n at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/a
                        Das ganze bei nem Tradfri Taster.
                        • v522533V Offline
                          v522533V Offline
                          v522533
                          #322
                          bei mir siehts so aus bei allen geräten:
                          Gruß Chris
                          • J Jan1
                            @Asgothian
                            In der Kachel:
                            und das Log dazu:
                            Matdos
                            #323
                            @Jan1
                            Ja geanu die Meldung kommt bei mr bei 2 -3 Xiaomi geräte dem Bewegungsmelder mit 13 link quality und zwei Fensterkontakt mit 2 und 21 link quality bei den andern habe ich nur ne leere Kachel es wird aber trotzdem ein Error ins log geschrieben wenn ich die versuche abzufragen.
                            Das ist jetzt ein Error wo die Kachel leer bleibt ohne Fehlermeldung
                            • J Offline
                              Jan1
                              #324
                              Ganz am Anfang des Threads steht dazu, dass es in dieser Version des Adapters noch nicht funktioniert und ich habe noch keine Meldung gelesen, dass es mittlerweile voll funktionieren sollte.
                              • v522533V v522533
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #325
                                @v522533 sagte in Zigbee Adapter mit neuem Converter:
                                Diese Meldung sollte weg sein wenn du auf die 1.0.0-b updatest.
                                und das Log dazu:
                                Das ist ein Zeichen dafür das es funktioniert. Du musst immer bedenken das batteriebetriebene Geräte (z.Bsp. der Taster) generell erst einmal im Stromsparmodus sind. Sie sind nur zu ganz bestimmten Zeitpunkten bereit auf Nachrichten zu antworten. Solange wie du nicht genau die triffst geht da nichts.
                                Bei den Xiaomi kann man diesen Modus für etwa 30 Sekunden triggern, wenn man den Knopf kurz drückt mit dem man sie in den Pairing modus bekommt.
                                Ich kann die Sensoren abfragen in dem ich als erstes den Knopf kurz drücke und dann auf das I klicke.
                                A.
                                v522533V J 2 Antworten Letzte Antwort
                                  und das Log dazu:
                                  A.
                                  v522533V Offline
                                  v522533V Offline
                                  v522533
                                  #326
                                  @Asgothian
                                  habe schon lange den 1.0.0 b drauf
                                  Gruß Chris
                                    und das Log dazu:
                                    A.
                                    Jan1
                                    #327
                                    @Asgothian
                                    OK, alles klar.
                                    Ich meine mit dem "alten" Adapter hatte ich da ein paar mal auf Info geklickt und es wohl immer passend erwischt, da dort immer ne "normale" Meldung kam. Ich nutze das zu selten um da was genaues drüber sagen zu können. Wusste eben nur, dass es mit der ersten Version eben offiziell nicht funktioniert hat.
                                    Mit Deiner Methode funktioniert es:
                                    • v522533V v522533
                                      @Asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #328
                                      @v522533 Seltsam.. bei mir ging es nach dem Update.
                                      A.
                                        @Asgothian
                                        A.
                                        Matdos
                                        #329
                                        @Asgothian sagte in Zigbee Adapter mit neuem Converter:
                                        @Asgothian
                                        A.
                                        Ich habe noch ein kleines Problem habe jetzt ja nur noch den Zigbee 0 Adapter, wenn ich aber ein Backup mit Backitup mache werden Zigbee0 Zigbee1 und Zigbee2 Adapter gesichert (die zwei habe ich gelöscht zigbee2 war nur für ein Test erstellt)
                                        Muss ich die Adapter über die Shell in dem Pfad wo du mir geschrieben hast löschen?
                                        • XsevX Offline
                                          XsevX Offline
                                          Xsev
                                          #330
                                          Ich bekomme jetzt auch fast von allen Geräten Infos, komisch hatte die B version vorher schon drauf hab sie vorgestern nur neu installiert weil ich wieder Geräte nicht löschen konnte. Gab es eine neue B Version?
