  4. Fehler nmp install
Fehler nmp install
nmp
3 Beiträge 2 Kommentatoren 483 Aufrufe 1 Beobachtet
    sveni_lee
    irgendwie stehe ich auf Kriegsfuß mit nmp...
    svenilee@Gotham-City:/opt/iobroker$ sudo npm install commander --save
    > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
    > node-gyp rebuild
    gyp ERR! configure error
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/bufferutil/build'
    gyp ERR! System Linux 4.4.0-170-generic
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
    gyp ERR! node -v v10.18.0
    gyp ERR! node-gyp -v v5.0.5
    gyp ERR! not ok
    > serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp info it worked if it ends with ok
    node-pre-gyp verb cli [ '/usr/bin/node',
    node-pre-gyp verb cli   '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp',
    node-pre-gyp verb cli   'install',
    node-pre-gyp verb cli   '--fallback-to-build' ]
    node-pre-gyp info using node-pre-gyp@0.6.32
    node-pre-gyp info using node@10.18.0 | linux | x64
    node-pre-gyp verb command install []
    node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" (not found)
    node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v64-linux-x64.tar.gz
    node-pre-gyp ERR! Tried to download(undefined): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v64-linux-x64.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@10.18.0 (node-v64 ABI) (falling back to source compile with node-gyp)
    node-pre-gyp http EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build'
    node-pre-gyp verb command build [ 'rebuild' ]
    node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v64-linux-x64.tar.gz
    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v64-linux-x64.tar.gz
    node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v64-linux-x64.tar.gz
    node-pre-gyp http Connection closed while downloading tarball file
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build'
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.4.0-170-generic
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
    node-pre-gyp ERR! node -v v10.18.0
    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok
    > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
    > node-gyp rebuild
    gyp ERR! not ok
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/utf-8-validate/build'
    gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
    gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/strip-ansi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/jsprim/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/sshpk/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/is-fullwidth-code-point/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/brace-expansion/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/package.json'
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
    + commander@4.0.1
    updated 1 package in 18.608s
    5 packages are looking for funding
      run `npm fund` for details
    kann man die installation irgendwie reparieren...
    • S sveni_lee
      > node-gyp rebuild
      gyp ERR! not ok
      gyp ERR! not ok
      > node-gyp rebuild
      gyp ERR! not ok
      gyp ERR! not ok
      + commander@4.0.1
      @sveni_lee sagte in Fehler nmp install:
      Was willst du reparieren?
      Bei EACCES riecht es nach Arbeit für den Fixer.
      ber das kennst du?
      https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
        sveni_lee
        leider hat das keine Besserung gebracht.
        Mein Problem ist diese Fehlermeldung:
        svenilee@Gotham-City:/opt/iobroker$ wscat -n -c wss://192.168.1.34:8002/api/v2/channels/samsung.remote.control?name=aW9Ccm9rZXI=
        internal/modules/cjs/loader.js:638
            throw err;
        Error: Cannot find module 'commander'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
            at Module.require (internal/modules/cjs/loader.js:692:17)
            at require (internal/modules/cjs/helpers.js:25:18)
            at Object.<anonymous> (/usr/lib/nodejs/ws/bin/wscat:13:15)
            at Module._compile (internal/modules/cjs/loader.js:778:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            at Module.load (internal/modules/cjs/loader.js:653:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
