  4. Google Home/Assistant ioBroker einrichten/nutzen
    1.0k
googlegoogle asisstantgoogle homegoogle home minihow-toanleitung
1.2k Beiträge 127 Kommentatoren 526.1k Aufrufe 139 Beobachtet
  • T tombox
    @Maximilian-Klie könntest du ein export von den objekten (Beschreibung Beitrag 1) machen dann kann ich mir das anschauen. Wenn ich Zeit habe.
    #817
    @tombox
    Hier bitte:
      "deconz.0.Sensors.2": {
        "type": "device",
        "common": {
          "name": "Bad oben Temp",
          "role": "sensor",
          "smartName": false
        "native": {
          "ep": 1,
          "etag": "1cc6a3fe67a5e3502457af81c184ceae",
          "id": "2",
          "manufacturername": "LUMI",
          "modelid": "lumi.weather",
          "swversion": "20161129",
          "type": "ZHATemperature",
          "uniqueid": "00:15:8d:00:03:f0:55:74-01-0402"
        "from": "system.adapter.deconz.0",
        "user": "system.user.admin",
        "ts": 1574276560696,
        "_id": "deconz.0.Sensors.2",
        "acl": {
          "object": 1636
      "deconz.0.Sensors.2.battery": {
        "type": "state",
        "common": {
          "name": "Multisensor battery",
          "type": "number",
          "role": "indicator.battery",
          "read": true,
          "write": false
        "native": {},
        "ts": 1574276560720,
        "_id": "deconz.0.Sensors.2.battery",
        "acl": {
          "object": 1636,
          "state": 1636
      "deconz.0.Sensors.2.lastupdated": {
        "type": "state",
        "common": {
          "name": "lastupdated",
          "type": "string",
          "role": "state",
          "read": true,
          "write": false
        "native": {},
        "ts": 1574276615079,
        "_id": "deconz.0.Sensors.2.lastupdated",
        "acl": {
          "object": 1636,
          "state": 1636
      "deconz.0.Sensors.2.offset": {
        "type": "state",
        "common": {
          "name": "Multisensor offset",
          "type": "number",
          "role": "state",
          "read": true,
          "write": true,
          "smartName": false
        "native": {},
        "from": "system.adapter.iot.0",
        "ts": 1577399877048,
        "_id": "deconz.0.Sensors.2.offset",
        "acl": {
          "object": 1636,
          "state": 1636
      "deconz.0.Sensors.2.on": {
        "type": "state",
        "common": {
          "name": "Multisensor on",
          "type": "boolean",
          "role": "state",
          "read": true,
          "write": true,
          "smartName": false
        "native": {},
        "ts": 1574276560746,
        "_id": "deconz.0.Sensors.2.on",
        "acl": {
          "object": 1636,
          "state": 1636
      "deconz.0.Sensors.2.reachable": {
        "type": "state",
        "common": {
          "name": "Multisensor reachable",
          "type": "boolean",
          "role": "state",
          "read": true,
          "write": false
        "native": {},
        "_id": "deconz.0.Sensors.2.reachable",
        "acl": {
          "object": 1636,
          "state": 1636
      "deconz.0.Sensors.2.temperature": {
        "type": "state",
        "common": {
          "name": "Sensor Bad oben",
          "type": "number",
          "role": "value.temperature",
          "unit": "°C",
          "read": true,
          "write": true,
          "smartName": false,
          "enums": [
              "_id": "enum.functions.infos",
              "common": {
                "name": "Infos",
                "icon": "",
                "color": false
              "_id": "enum.rooms.bad_oben",
              "common": {
                "name": "Bad oben",
                "icon": "",
                "color": false
        "native": {},
        "ts": 1577541459184,
        "_id": "deconz.0.Sensors.2.temperature",
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
    Ich will nicht ausschließen, dass ich irgendwo Mist gemacht hab. Das ist jetzt auch nur ein Sensor exemplarisch. Danke schon mal!
      @tombox
      Hier bitte:
          "type": "device",
          "common": {
            "role": "sensor",
            "smartName": false
          "native": {
            "ep": 1,
            "id": "2",
          "acl": {
            "object": 1636
          "type": "state",
          "common": {
            "type": "number",
            "read": true,
            "write": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state",
          "common": {
            "type": "string",
            "role": "state",
            "read": true,
            "write": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state",
          "common": {
            "type": "number",
            "role": "state",
            "read": true,
            "write": true,
            "smartName": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state",
          "common": {
            "type": "boolean",
            "role": "state",
            "read": true,
            "write": true,
            "smartName": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state",
          "common": {
            "type": "boolean",
            "role": "state",
            "read": true,
            "write": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state",
          "common": {
            "type": "number",
            "unit": "°C",
            "read": true,
            "write": true,
            "smartName": false,
            "enums": [
                "common": {
                  "name": "Infos",
                  "icon": "",
                  "color": false
                "common": {
                  "name": "Bad oben",
                  "icon": "",
                  "color": false
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
      tombox
      #818
      @Maximilian-Klie die json datei wäre einfacher für mich
      • T tombox
        #819
        @tombox Verzeihung. Hier isse: deconz.0.Sensors.2.json
        • T tombox
          @echoDave Ja ich war auch überrascht wie schlecht die Unterstützung ist und das anscheinend keine signifikanten Verbesserungen kommen. Aber du kannst gerne dein Wunsch auf Englisch in einem Ticket bei Google äußern. Vielleicht hat es ja ein Einfluss
          https://issuetracker.google.com/issues/new?component=655104&template=1284148
          echoDaveE Offline
          echoDaveE Offline
          echoDave
          #820
          @tombox said in Google Home/Assistant ioBroker einrichten/nutzen:
          Mache ich danke.
          Aber der Zustand, dass der Adapter Abstürzt wenn ich in der GHome App ein Thermostat aufrufe wäre noch zu klären. Ich habe mal den iot Adapter etwas debugt und folgendes rausgefunden:
          der Fehler Steckt in folgender Datei:
          /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js
          Und zwar in der Zeile 2073:
          getStates(ids, callback, states) {
              states = states || {};
              if (!ids || !ids.length) {
                  callback(states);
              } else {
                  const id = ids.shift();
                  this.adapter.getForeignState(id, (err, state) => {     <-- Hier steck der Fehler!
                      states[id] = state && state.val;
                      setImmediate(() => this.getStates(ids, callback, states));
          ids ist ein Array der zwei Elemente hat, das erste ist bestückt das zweite ist leer. Warum auch immer liefert hier das ids.length in der If trotzdem eine 1 für das leere Element. Dadurch geht der If zum zweiten mal in den Else-Zweig. Beim shift kommt's dann zur "Tragödie", die Konstante id wird undefined, wodurch der getForeignState abbricht weil er .startwith(ALIAS_STARTS_WITH) nicht auf ein undefiniertes Objekt machen kann. Dadurch schmiert der Adapter dann ab und Google Home App bekommt keine Antwort.
          Ich habe die Funktion wie folgt abgeändert:
                 if (!id || !id.length) {
                     callback(states);
                 } else {
                     //const id = ids.shift();
          Also den Shift vor die If gezogen und in der If Frage ich die Konstante ab.
          Jetzt läuft es durch und man kann Thermostate über die App auch bedienen.
          Hat noch jemand anders den Fehler gehabt?
          Und reicht es hier als Lösung oder soll ich das noch wo anders posten?
          Viele Grüße, David
          • R Offline
            Ritter
            schrieb am zuletzt editiert von Ritter
            #821
            ich hab jetzt auch mal diese Zeilen abgeändert und es funktionieren jetzt auch die Thermostate. Vorher ist der Adapter sofort abgestürzt, sobald irgendetwas mit Temperatur zu tun hatte.
            Allerdings kann ich sie nur über die Google Home App bedienen und nicht auf Zuruf, hier kommt das das Gerät aktuell nicht erreichbar ist.
            • echoDaveE echoDave
              Mache ich danke.
                      callback(states);
                  } else {
                         callback(states);
                     } else {
              Viele Grüße, David
              tombox
              #822
              @echoDave Hi danke für das Feedback, In meiner Version ist der Fehler schon länger behoben aber ich hatte noch keine Zeit es in die offizielle Version zu kopieren. Werde ich zeitnah machen.
              Bzw teste doch mal meine Version ob da der Fehler auch weg ist.
              echoDaveE 1 Antwort Letzte Antwort
                tombox
                #823
                @Maximilian-Klie Der schnellste Weg dein Problem zu fixen ist Sensor.2 manuell zu löschen und durch deconz neuerzeugen lassen und dann wie beschrieben dem Device Sensors.2 ein Raum und Funktion zu weisen und nicht dem State temperature
                echoDaveE ? 2 Antworten Letzte Antwort
                • T tombox
                  echoDaveE Offline
                  echoDaveE Offline
                  echoDave
                  #824
                  @tombox welche ist deine hast du mal nen Link zum github?
                    tombox
                    #825
                    @echoDave https://github.com/TA2k/ioBroker.iot Anleitung zur Installation in Beitrag 1
                    • hollywootH hollywoot
                      Moin!
                      Nachdem ich die Heizkörperthermostate nun endlich zugange habe (Auto Mode hat nicht funktioniert, obwohl Raum und Funktion zugeordnet. Objekt wird gefunden und im iot angezeigt mit komplett korrekten Einstellungen. Iot schmiert bei Abfrage dieser Geräte allerdings mit nem riesen Error-Block ab und restartet. Füge ich das identische Objekt manuell hinzu, funktioniert es sofort!), möchte ich nun auch gerne meine Rollläden und Tür-/Fensterkontakte in der GHome App und per Sprache sehen und steuern können.
                      Da ich beides nicht eingebunden bekomme, bzw nur so, dass die Geräte nicht steuerbar sind (Icon in der GHome App mit einem "Einstellungen-Ritzel". Beim auswählen bekommt man nur die Informationen, dass das Gerät zu iobroker gehört, mehr nicht), möchte ich hier einmal um Hilfe bitten und stelle zudem gerne die Json-Files zur Verfügung. Es muss ja noch andere Leute geben, die zB den HM Rollladenaktor nutzen.
                      jalousie.json
                      tuerkontakt.json
                      tombox
                      #826
                      @hollywoot Also die Jalousie wird erkannt wenn man dem Channel hm-rpc.0.OEXXXXXXXX.1 einen Raum und Funktion zuweist. Das Problem ist das der Türsensor bei mir im gleichen Channel liegt. Damit ist es schwer zwei Geräte automatisch zu erkennen. Ist es möglich den Sensor von der Jalousie zu trennen?
                      hollywootH 1 Antwort Letzte Antwort
                      • T tombox
                        echoDaveE Offline
                        echoDaveE Offline
                        echoDave
                        schrieb am zuletzt editiert von echoDave
                        #827
                        ok Danke aber welcher Brunch ist deiner? den Master 1.1.9 habe ich bereits von da.
                        Sorry übersehen, dass es dein repo ist nicht das vom iobroker. ich teste mal.
                        Wieso kann man die Thermostate nicht per Sprache steuern?
                        • T tombox
                          echoDaveE Offline
                          echoDaveE Offline
                          echoDave
                          #828
                          @tombox
                          Hmm also deine Version hat schon mal Probleme die Thermostate überhaupt einzufügen:
                          iot.0	2019-12-31 16:33:19.970	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1457539.1.SET_TEMPERATURE. Not added to GoogleHome
                          iot.0	2019-12-31 16:33:19.970	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1773490.1.SET_TEMPERATURE. Not added to GoogleHome
                          iot.0	2019-12-31 16:33:19.969	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1773431.1.SET_TEMPERATURE. Not added to GoogleHome
                          iot.0	2019-12-31 16:33:19.969	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1452909.1.SET_TEMPERATURE. Not added to GoogleHome
                          iot.0	2019-12-31 16:33:19.969	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1450924.1.SET_TEMPERATURE. Not added to GoogleHome
                          iot.0	2019-12-31 16:33:19.968	warn	(10126) Missing name, type or treat for: hm-rpc.0.MEQ1773015.1.SET_TEMPERATURE. Not added to GoogleHome
                          mit Blinds gibts auch Probleme, irgendwie fügt die Adapter Version einen Doppelten Eintrag hinzu ohne Namen.
                          Der Führt zu Fehlern:
                          Bildschirmfoto 2019-12-31 um 16.48.40.png Bildschirmfoto 2019-12-31 um 16.48.10.png
                          Meine Ikea Glühbirne (Zigbee) wurde auch nicht wirklich gut erkannt, konnte die nicht steuern.
                            @tombox
                            tombox
                            #829
                            @echoDave Wenn du MEQ1457539.1 und PEQ2266365.1 und die Lampe kurz als Export bereitstellen könntest, kann ich mir das bei mir anschauen.
                            • T tombox
                              echoDaveE Offline
                              echoDaveE Offline
                              echoDave
                              #830
                              @tombox gerne aber erst im neuen Jahr, habe die master vom iobroker wieder installiert damit das System über die Tage läuft :) stelle es im Neuen Jahr wieder auf deine Version.
                              Guten Rutsch euch allen!
                              • R Offline
                                Ritter
                                #831
                                Ich habe jetzt auch wieder die Version von tombox installiert. Thermostate kann ich damit hinzufügen und beim Synchronisieren der Geräte wird der Adapter jetzt nicht mehr rot.
                                Wenn ich Geräte manuell hinzufüge und dann Type und Funktion auswähle z.B. Thermostat dann steht nach dem speichern plötzlich Light drin oder switch. Nach ca. 3-5 mal korrigieren und neu speichern bleibt es dann.
                                Eine Zeile bei den google devices kann ich nicht mehr löschen, hier steht nur Blinds und Wohnzimmer das sich immer mal wieder verändert.
                                  tombox
                                  #832
                                  @echoDave Der Export ist unabhängig davon welche Version gerade installiert ist. Bei den Thermostaten überprüfe nochmal das der Raum und Funktion auf dem Channel zugewiesen ist und nicht SET_TEMPERATURE
                                  • T tombox
                                    echoDaveE Offline
                                    echoDaveE Offline
                                    echoDave
                                    #833
                                    @tombox ok, kann schon mal sagen, dass bei mir die functions/räume auf den states liegen und nicht auf Channels.
                                    • T tombox
                                      #834
                                      Heya! Danke, werde ich testen. Das Ergebnis teile ich hier mit.
                                      • R Offline
                                        Ritter
                                        #835
                                        hab die neue Version von heute installiert, hier sind die fehlerhaften Einträge jetzt verschwunden, Thermostate lassen sich einbinden und per Sprache abfragen, auch beim Speichern bleibt es unter Google Devices nicht mehr grau. Läuft jetzt super, Danke.
                                        • echoDaveE Offline
                                          echoDaveE Offline
                                          echoDave
                                          #836
                                          Bei mir bringt die Version von heute ganz andere Probleme:
                                          iot.0	2020-01-01 14:55:18.147	error	(19946)
                                          iot.0	2020-01-01 14:55:18.147	error	(19946) [object Object]
                                          iot.0	2020-01-01 14:55:18.147	error	(19946) 3799978283214788838
                                          iot.0	2020-01-01 14:55:18.146	error	(19946) TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at devices.forEach.dev (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2476:28) at A
                                          iot.0	2020-01-01 14:55:18.144	error	(19946) TypeError: Cannot convert undefined or null to object
                                          <-- jetzt folgt der Aufruf ind er App ->
                                          iot.0	2020-01-01 14:54:52.565	error	(19946) [GHOME] devices are unknown to google home
                                          iot.0	2020-01-01 14:54:49.191	warn	(19946) Missing name, type or treat for: hm-rpc.0.MEQ1450924.1.ACTUAL_TEMPERATURE. Not added to GoogleHome
                                          iot.0	2020-01-01 14:54:49.190	warn	(19946) Missing name, type or treat for: hm-rpc.0.MEQ1450924.1.SET_TEMPERATURE. Not added to GoogleHome
                                          iot.0	2020-01-01 14:54:29.507	info	(19946) hm-rpc.0.MEQ1450924.1 is auto added with type thermostat.
                                          Hier der JSON des Objects:
                                          hm-rpc.0.MEQ1450924.json
