  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    Verbindung an MySQL klappt bei mir nur so:
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    • sissiwupS Offline
      sissiwupS Offline
      sissiwup
      Fehler mit mysql:
      ` > sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449439045000, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
      sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449439045000, W, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'W' in 'field list'
      sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449439045000, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list' `
      MfG
      Sissi
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Hat Fehler ausgeworfen:
        ` > sql.0 2015-12-06 22:59:12 debug inMem message * hm-rega.0.37329
        sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37325
        sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37324
        sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37153
        sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.36778
        sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.load
        sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.mem
        sql.0 2015-12-06 22:59:10 info sql.0 Connected to sqlite
        sql.0 2015-12-06 22:59:10 debug sql.0 Response: {'errno':1,'code':'SQLITE_ERROR'}
        sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_bool (id INTEGER, ts INTEGER, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_string (id INTEGER, ts INTEGER, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_number (id INTEGER, ts INTEGER, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
        sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE datapoints (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT,name TEXT,type INTEGER);
        sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE sources (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT, name TEXT);
        sql.0 2015-12-06 22:59:10 info sql.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
        cubietruck 2015-12-06 22:59:01 info host.cubietruck instance system.adapter.sql.0 started with pid 7364
        cubietruck 2015-12-06 22:59:01 info host.cubietruck 'system.adapter.sql.0' enabled
        cubietruck 2015-12-06 22:59:01 info host.cubietruck object change system.adapter.sql.0 `
        Bin wieder auf Original zurück.
        Gruß,
        Eric
        • ThisoftT Offline
          ThisoftT Offline
          Thisoft
          @sissiwup: Das ist der gleiche Fehler wie bei uns - bei Dir sogar dreimal der gleiche Timestamp.
          @eric: Ja, jetzt wo DU's sagst - die hat er bei mir auch geworfen. Sind aber IMO nicht weiter schlimm. Sagt ja bloß aus dass er die bereits existierenden Tabellen in der Db nicht nochmal anlegen kann. Kommen ja auch nur beim Starten des Adapters. Ich lass die Änderung bei mir drin und teste ob der andere Fehler wieder auftaucht. Vielleicht schau ich auch morgen nochmal ob ich dahinterkomme warum jetzt dieser Fehler auftaucht. Wahrscheinlich ist aber bis dahin Bluefox sowieso schneller ;)
          22 HM-Geräte; PivCCU2 auf RasPi
          ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
          • eric2905E Offline
            eric2905E Offline
            eric2905
            Eh, bin gerade etwas verwirrt …
            Seit dem Test habe ich keine Fehler mehr im Log .... alle INSERTs usw. gehen durch .... wie gesagt, bin wieder auf die Original-Version der main.js zurückgegangen (und hab auch den Adapter neu gestartet) ....
            Gruß,
            Eric
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              ` > hm-rpc.1 2015-12-07 01:24:54 info hm-rpc.1 xmlrpc -> listDevices 0
              sql.0 2015-12-07 01:20:54 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449447653333, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
              sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(52, 1449447652908, 01:00:01 07.12.2015, 1, 3, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; c
              sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449447652664, SW, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'SW' in 'field list'
              sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449447652486, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list'
              sql.0 2015-12-07 01:20:38 info sql.0 enabled logging of hm-rpc.0.MEQ0288793.1.STATE `
              Hier scheint der String nicht korrekt gequotet zu werden ' fehlen.
              MfG
              Sissi
              • sissiwupS Offline
                sissiwupS Offline
                sissiwup
                MySQL:
                MySQL auf ioBroker
                apt-get install mysql-server mysql-client
                mysql -uroot -p
                CREATE USER 'iobroker‘@’%’ IDENTIFIED BY 'iobroker';
                GRANT ALL PRIVILEGES ON * . * TO 'iobroker'@'%';
                FLUSH PRIVILEGES;
                In /etc/mysql
                my.cnf: bind auf ip-Adresse umstellen (dann klappt es auch mit den Nachbarn) ;-)
                Achtung: iobroker ist so ein "admin". Bei Bedarf weniger Rechte einrichten.
                MfG
                Sissi
                • sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  lib/mysql.js anpassen:
                  exports.insert = function (index, state, from, db) {
                      if (db === 'ts_string') state.val = "'" + state.val + "'";
                      return "INSERT INTO iobroker." + db + " (id, ts, val, ack, _from, q) VALUES(" + index + ", " + state.ts + ", " + state.val + ", " + (state.ack ? 1 : 0) + ", " + (from || 0) + ", " + state.q + ");";
                  Neu ist die Zeile mit dem "if"
                  MfG
                  Sissi
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    Hmmm, mySQL installieren …
                    Ich denke, ich warte erst mal auf Bluefox - vielleicht hat er ja eine einfache Idee / Lösung.
                    Gruß,
                    Eric
                      starfish
                      @sissiwup:
                      filename="Bildschirmfoto 2015-12-06 um 22.56.02.png" index="0">~~ `
                      das wars, bei mir klappt die Verbindung endlich auch, wer hätte vermutet, dass gar kein Port angegeben werden darf. (vielleicht wird default zusätzlich auch ausgegeben, wenn im Feld was steht?)
                      • BluefoxB Offline
                        BluefoxB Offline
                        @sissiwup:
                        Fehler mit mysql:
                        Danke für Fehlermeldung. Habe meistens numbers getestet. Werde den Fehler fixen.
                        • sissiwupS Offline
                          sissiwupS Offline
                          sissiwup
                          Jetzt funktioniert so langsam alles.
                          Muss ich den history.0 Adapter deaktivieren, wenn ich sql.0 nutze?
                          Mit flot klappte es jetzt auch, wenn man mal die Einstellungen verstanden hat:
                          Wenn kein Datenpunkt / Messpunkt innerhalb des ausgewählten Fensters liegt, dann läßt flot die Kurve einfach weg …
                          (SOLL TEMP) Wähle ich hier 1 Tag als Intervall, dann ist die Kurve da.
                          MfG
                          Sissi
                          • sissiwupS Offline
                            sissiwupS Offline
                            sissiwup
                            Die Treppenfunktionen bei flot sind verkehrtherum implementiert.
                            Wenn ich z.B. Folgende Datnepunkte habe:
                            8:00 10Grad
                            9:00 10Grad
                            10:00 12Grad
                            11:00 12Grad,
                            Dann hätte ich einen Graphen erwartet, der um 10:00 auf 12 Grad steigt.
                            Macht er aber nicht, er steigt um 9:00 auf 12 Grad.
                            Oder mache ich etwas falsch?
                            MfG
                            Sissi
                            • BluefoxB Offline
                              BluefoxB Offline
                              Es gibt neue Version von SQL-Adapter und flot.
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Hab den neuen SQL (0.0.3) installiert, aber immer noch die Fehlermeldungen:
                                ` > sql-0 2015-12-08 08:14:46 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558876000, 2.5, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 08:09:12 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558541000, -0.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 08:07:08 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558418000, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 08:04:49 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558278000, 4.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 08:02:15 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558125000, 11.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:59:28 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557957000, 11.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:56:26 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557776000, -0.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:51:47 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557496000, 2.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:46:10 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557159000, 1.1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:39:10 error Cannot delete DELETE FROM ts_number WHERE id=18 AND ts < 1449470340;: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:35 warn Cannot get index of 'hm-rpc.0.xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:35 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0. xxxxxxxx.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:35 error Cannot delete DELETE FROM ts_number WHERE id=6 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:32 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:32 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.JEQ0553734.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:32 error Cannot delete DELETE FROM ts_number WHERE id=34 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
                                sql-0 2015-12-08 07:38:29 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.TEMPERATURE': Error: SQLITE_BUSY: database is locked `
                                Hab ich evtl. was vergessen?
                                Gruß,
                                Eric
                                PS: Habe den Screenshot jetzt durch einen Log-Auszug ersetzt.
                                • V Offline
                                  V Offline
                                  versteckt
                                  Morgähn, heißt das im Umkehrschluss, dass Couchdb und Redis raus sind?
                                  Find ich schade, ich experimentiere in der Firma damit.
                                  Gesendet von meinem iPhone mit Tapatalk
                                  Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
                                  homegear für Homematic und MAX!
                                  occ, zWave, rpi, hmm und homekit Entwickler
                                  • ThisoftT Offline
                                    ThisoftT Offline
                                    Thisoft
                                    Tja - allen Leuten recht getan… ist wohl wirklich ein Ding das niemand kann.
                                    Ich persönlich find's super dass jetzt mit MySQL und MS-SQLServer weit verbreitete Quasi-Standards und somit "richtige" SQL-Datenbanken verwendet werden!
                                    Gruß Thilo
                                    • V Offline
                                      V Offline
                                      versteckt
                                      #66
                                      So, hab auch grad alles umgestellt. Erhalte leider auch den Fehler "Error: SQLITE_BUSY: database is locked"
                                      • P Offline
                                        pix
                                        #67
                                        EDIt: Beitrag gelöscht - steht drunter nochmal, waren Fehler drin.
                                        • P Offline
                                          pix
                                          #68
                                          ich habe den History nun auch erneuert. Ich bin nach dem ersten Post vorgegangen und es hat gut funktioniert (OS X).
                                          Ich nutze den eingebauten SQlite. 261_bildschirmfoto_2015-12-08_um_14.31.38.jpg Die Adaptereinstellungen bieten einen Verbindungstest. Der meldet "ok". Leider lassen sich in flot die gewünschten Datenpunkten nicht auswählen.
                                          Und im admin-Reiter Objekte kann ich das Loggen nicht mehr ein/ausschalten, da kein Knopf mehr da ist -> Das hat sich jetzt erledigt, dauerte einige Minuten bis die grünen Knöpfe auftauchten. Allerdings muss da noch mal extra ein Haken bei "Aktiviert" gesetzt werden. 261_bildschirmfoto_2015-12-08_um_15.07.31.jpg Der "Speichern"-Knopf reagiert nur sehr träge/beim zweiten Klick.
                                          Pix
