  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
  • eric2905E Offline
    eric2905E Offline
    eric2905
    Hat Fehler ausgeworfen:
    ` > sql.0 2015-12-06 22:59:12 debug inMem message * hm-rega.0.37329
    sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37325
    sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37324
    sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.37153
    sql.0 2015-12-06 22:59:11 debug inMem message * hm-rega.0.36778
    sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.load
    sql.0 2015-12-06 22:59:11 info sql.0 enabled logging of system.host.cubietruck.mem
    sql.0 2015-12-06 22:59:10 info sql.0 Connected to sqlite
    sql.0 2015-12-06 22:59:10 debug sql.0 Response: {'errno':1,'code':'SQLITE_ERROR'}
    sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_bool (id INTEGER, ts INTEGER, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
    sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_string (id INTEGER, ts INTEGER, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
    sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE ts_number (id INTEGER, ts INTEGER, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
    sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE datapoints (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT,name TEXT,type INTEGER);
    sql.0 2015-12-06 22:59:10 debug sql.0 CREATE TABLE sources (id INTEGER NOT NULL PRIMARY KEY AUTOINCREMENT, name TEXT);
    sql.0 2015-12-06 22:59:10 info sql.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
    cubietruck 2015-12-06 22:59:01 info host.cubietruck instance system.adapter.sql.0 started with pid 7364
    cubietruck 2015-12-06 22:59:01 info host.cubietruck 'system.adapter.sql.0' enabled
    cubietruck 2015-12-06 22:59:01 info host.cubietruck object change system.adapter.sql.0 `
    Bin wieder auf Original zurück.
    Gruß,
    Eric
    • ThisoftT Offline
      ThisoftT Offline
      Thisoft
      @sissiwup: Das ist der gleiche Fehler wie bei uns - bei Dir sogar dreimal der gleiche Timestamp.
      @eric: Ja, jetzt wo DU's sagst - die hat er bei mir auch geworfen. Sind aber IMO nicht weiter schlimm. Sagt ja bloß aus dass er die bereits existierenden Tabellen in der Db nicht nochmal anlegen kann. Kommen ja auch nur beim Starten des Adapters. Ich lass die Änderung bei mir drin und teste ob der andere Fehler wieder auftaucht. Vielleicht schau ich auch morgen nochmal ob ich dahinterkomme warum jetzt dieser Fehler auftaucht. Wahrscheinlich ist aber bis dahin Bluefox sowieso schneller ;)
      22 HM-Geräte; PivCCU2 auf RasPi
      ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Eh, bin gerade etwas verwirrt …
        Seit dem Test habe ich keine Fehler mehr im Log .... alle INSERTs usw. gehen durch .... wie gesagt, bin wieder auf die Original-Version der main.js zurückgegangen (und hab auch den Adapter neu gestartet) ....
        Gruß,
        Eric
        • sissiwupS Offline
          sissiwupS Offline
          sissiwup
          ` > hm-rpc.1 2015-12-07 01:24:54 info hm-rpc.1 xmlrpc -> listDevices 0
          sql.0 2015-12-07 01:20:54 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449447653333, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
          sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(52, 1449447652908, 01:00:01 07.12.2015, 1, 3, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; c
          sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449447652664, SW, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'SW' in 'field list'
          sql.0 2015-12-07 01:20:53 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449447652486, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list'
          sql.0 2015-12-07 01:20:38 info sql.0 enabled logging of hm-rpc.0.MEQ0288793.1.STATE `
          Hier scheint der String nicht korrekt gequotet zu werden ' fehlen.
          MfG
          Sissi
          1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
          • sissiwupS Offline
            sissiwupS Offline
            sissiwup
            MySQL:
            MySQL auf ioBroker
            apt-get install mysql-server mysql-client
            mysql -uroot -p
            CREATE USER 'iobroker‘@’%’ IDENTIFIED BY 'iobroker';
            GRANT ALL PRIVILEGES ON * . * TO 'iobroker'@'%';
            FLUSH PRIVILEGES;
            In /etc/mysql
            my.cnf: bind auf ip-Adresse umstellen (dann klappt es auch mit den Nachbarn) ;-)
            Achtung: iobroker ist so ein "admin". Bei Bedarf weniger Rechte einrichten.
            MfG
            Sissi
            • sissiwupS Offline
              sissiwupS Offline
              sissiwup
              lib/mysql.js anpassen:
              exports.insert = function (index, state, from, db) {
                  if (db === 'ts_string') state.val = "'" + state.val + "'";
                  return "INSERT INTO iobroker." + db + " (id, ts, val, ack, _from, q) VALUES(" + index + ", " + state.ts + ", " + state.val + ", " + (state.ack ? 1 : 0) + ", " + (from || 0) + ", " + state.q + ");";
              Neu ist die Zeile mit dem "if"
              MfG
              Sissi
              • eric2905E Offline
                eric2905E Offline
                eric2905
                Hmmm, mySQL installieren …
                Ich denke, ich warte erst mal auf Bluefox - vielleicht hat er ja eine einfache Idee / Lösung.
                Gruß,
                Eric
                  starfish
                  @sissiwup:
                  Verbindung an MySQL klappt bei mir nur so:
                  filename="Bildschirmfoto 2015-12-06 um 22.56.02.png" index="0">~~ `
                  das wars, bei mir klappt die Verbindung endlich auch, wer hätte vermutet, dass gar kein Port angegeben werden darf. (vielleicht wird default zusätzlich auch ausgegeben, wenn im Feld was steht?)
                  • BluefoxB Offline
                    BluefoxB Offline
                    @sissiwup:
                    Fehler mit mysql:
                    ` > sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(53, 1449439045000, VD-12, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'VD' in 'field list'
                    sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(50, 1449439045000, W, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'W' in 'field list'
                    sql.0 2015-12-06 22:57:27 error sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(48, 1449439045000, Windstille, 1, 3, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Windstille' in 'field list'
                    Danke für Fehlermeldung. Habe meistens numbers getestet. Werde den Fehler fixen.
                    • sissiwupS Offline
                      sissiwupS Offline
                      sissiwup
                      Jetzt funktioniert so langsam alles.
                      Muss ich den history.0 Adapter deaktivieren, wenn ich sql.0 nutze?
                      Mit flot klappte es jetzt auch, wenn man mal die Einstellungen verstanden hat:
                      Wenn kein Datenpunkt / Messpunkt innerhalb des ausgewählten Fensters liegt, dann läßt flot die Kurve einfach weg …
                      (SOLL TEMP) Wähle ich hier 1 Tag als Intervall, dann ist die Kurve da.
                      MfG
                      Sissi
                      • sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        Die Treppenfunktionen bei flot sind verkehrtherum implementiert.
                        Wenn ich z.B. Folgende Datnepunkte habe:
                        8:00 10Grad
                        9:00 10Grad
                        10:00 12Grad
                        11:00 12Grad,
                        Dann hätte ich einen Graphen erwartet, der um 10:00 auf 12 Grad steigt.
                        Macht er aber nicht, er steigt um 9:00 auf 12 Grad.
                        Oder mache ich etwas falsch?
                        MfG
                        Sissi
                        • BluefoxB Offline
                          BluefoxB Offline
                          Es gibt neue Version von SQL-Adapter und flot.
                          • eric2905E Offline
                            eric2905E Offline
                            eric2905
                            Hab den neuen SQL (0.0.3) installiert, aber immer noch die Fehlermeldungen:
                            ` > sql-0 2015-12-08 08:14:46 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558876000, 2.5, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 08:09:12 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558541000, -0.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 08:07:08 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558418000, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 08:04:49 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558278000, 4.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 08:02:15 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558125000, 11.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:59:28 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557957000, 11.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:56:26 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557776000, -0.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:51:47 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557496000, 2.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:46:10 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557159000, 1.1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:39:10 error Cannot delete DELETE FROM ts_number WHERE id=18 AND ts < 1449470340;: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:35 warn Cannot get index of 'hm-rpc.0.xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:35 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0. xxxxxxxx.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:35 error Cannot delete DELETE FROM ts_number WHERE id=6 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:32 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:32 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.JEQ0553734.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:32 error Cannot delete DELETE FROM ts_number WHERE id=34 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
                            sql-0 2015-12-08 07:38:29 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.TEMPERATURE': Error: SQLITE_BUSY: database is locked `
                            Hab ich evtl. was vergessen?
                            Gruß,
                            Eric
                            PS: Habe den Screenshot jetzt durch einen Log-Auszug ersetzt.
                            • V Offline
                              V Offline
                              versteckt
                              Morgähn, heißt das im Umkehrschluss, dass Couchdb und Redis raus sind?
                              Find ich schade, ich experimentiere in der Firma damit.
                              Gesendet von meinem iPhone mit Tapatalk
                              Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
                              homegear für Homematic und MAX!
                              occ, zWave, rpi, hmm und homekit Entwickler
                              • ThisoftT Offline
                                ThisoftT Offline
                                Thisoft
                                Tja - allen Leuten recht getan… ist wohl wirklich ein Ding das niemand kann.
                                Ich persönlich find's super dass jetzt mit MySQL und MS-SQLServer weit verbreitete Quasi-Standards und somit "richtige" SQL-Datenbanken verwendet werden!
                                Gruß Thilo
                                • V Offline
                                  V Offline
                                  versteckt
                                  #66
                                  So, hab auch grad alles umgestellt. Erhalte leider auch den Fehler "Error: SQLITE_BUSY: database is locked"
                                  • P Offline
                                    pix
                                    #67
                                    EDIt: Beitrag gelöscht - steht drunter nochmal, waren Fehler drin.
                                    • P Offline
                                      pix
                                      #68
                                      ich habe den History nun auch erneuert. Ich bin nach dem ersten Post vorgegangen und es hat gut funktioniert (OS X).
                                      Ich nutze den eingebauten SQlite. 261_bildschirmfoto_2015-12-08_um_14.31.38.jpg Die Adaptereinstellungen bieten einen Verbindungstest. Der meldet "ok". Leider lassen sich in flot die gewünschten Datenpunkten nicht auswählen.
                                      Und im admin-Reiter Objekte kann ich das Loggen nicht mehr ein/ausschalten, da kein Knopf mehr da ist -> Das hat sich jetzt erledigt, dauerte einige Minuten bis die grünen Knöpfe auftauchten. Allerdings muss da noch mal extra ein Haken bei "Aktiviert" gesetzt werden. 261_bildschirmfoto_2015-12-08_um_15.07.31.jpg Der "Speichern"-Knopf reagiert nur sehr träge/beim zweiten Klick.
                                      Pix
                                      • sissiwupS Offline
                                        sissiwupS Offline
                                        sissiwup
                                        #69
                                        @eric2905:
                                        Gruß,
                                        Eric
                                        PS: Habe den Screenshot jetzt durch einen Log-Auszug ersetzt. `
                                        Man sieht oben, das die Timestamps noch auf 000 enden, das darf nicht sein.
                                        Hier kannst du kurzzeitig den fix aus den Post einsetzen, wo die Zeile durch Date.now ersetzt wird.
                                        Das hat bei mir geholfen.
                                        MfG
                                        Sissi
                                        • sissiwupS Offline
                                          sissiwupS Offline
                                          sissiwup
                                          #70
                                          @versteckt:
                                          So, hab auch grad alles umgestellt. Erhalte leider auch den Fehler "Error: SQLITE_BUSY: database is locked" `
                                          Probier mal:
                                          Ja, es liegt offensichtlich an den fehlenden Millisekunden. Aber nicht nur auf dem Pi - ich arbeite mit Windows.
                                          Ich habe mich aber jetzt noch mal in den Code reingekniet und empfehle Dir folgendes zu testen - wenn Du Dir's zutraust.
                                          Und zwar musst Du in der Datei "..\iobroker\node_modules\iobroker.sql\main.js" die Zeile 552:
                                          Code:
                                          state.ts = parseInt(state.ts, 10) * 1000 + (parseInt(state.ms, 10) || 0);
                                          durch die folgende ersetzen:
                                          Code:
                                          state.ts = parseInt(Date.now());
                                          Dann die Datei speichern und den SQL-Adapter neustarten. Dann dürfte es keine doppelten Timestamps mehr geben (und ich hoffe dass ich damit nichts anderes durcheinanderbringe - aber wir sind ja hier noch in der Beta ;) )
                                          Gruß Thilo
                                          MfG
                                          Sissi
